Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C0402_RF_EDIT | CAP_C0402_RF_EDIT_DISCRETE_1.2 | 1.2 pF | DISCRETE | 1 | C20 |
C0402_RF_EDIT | INDUCTOR_C0402_RF_EDIT_2.7NH | 2.7nH | IC | 1 | L1 |
CAPC1005X55N_0402 | 100K_0402 | 100K | DISCRETE | 1 | R21 |
CAPC1005X55N_0402_E | 0P1UFD_0402 | 0.1 uF | DISCRETE | 18 | C1; C4; C6; C7; C9; C11; C14; C16; C25; C28; C29; C32; C35; C36; C37; C38; C41; C42 |
CAPC1005X55N_0402_E | CAP NP_CAPC1005X55N_0402_E_12.5 | 12.5 pF | IC | 2 | C22; C23 |
CAPC1005X55N_0402_E | 0P01UFD_0402 | 0.01 uF | IC | 1 | C39 |
CAPC1608X90N_0603_E | 1P0UFD_0603_25V | 1.0 uF | DISCRETE | 18 | C2; C3; C5; C8; C10; C12; C13; C15; C17; C18; C24; C26; C27; C30; C31; C33; C34; C40 |
CAPC1608X90N_0603_E | 100UFD_0603_25V | 100 pF | DISCRETE | 1 | C21 |
CR-LED0603 | 0603_LED | ESD 5VDC | IC | 3 | D1; D2; D3 |
CR-LED0805 | LED_AMBER0805 | Status LED Blue | IC | 1 | LED1 |
CR-LED0805 | LED_GREEN0805 | Status LED Green | IC | 1 | LED2 |
CR-LED0805 | LED_RED0805 | Power LED Red | IC | 1 | LED3 |
ECX-2236-SMD_CRYSTAL-EDIT | ZTA_14_ECX-2236-SMD_CRYSTAL-EDI | 24MHz | IC | 1 | Y2 |
EVQ9P-SWITCH_1 | SW_EVQP7J01 | SW RA PUSH | IC | 2 | SW1; SW2 |
FTSH-105-XX-X-DV-K | HDR5X2X50KS | 50MIL KEYED SMD | IO | 1 | J2 |
FUSE_MF-MSMF050-2 | FUSE | PTC Resettable Fuse | IC | 1 | F1 |
L-0402-RF | CAP_L-0402-RF_DISCRETE_1.2 PF_ | 1.2 pF | DISCRETE | 1 | C19 |
QFN40P700X700X60-57T570X570N | PSOC_BLE_2_QFN40P700X700X60-57T | PSoC_BLE | IC | 1 | U1 |
QFN68_8X8MM | CY8C5667LTI-LP008_QFN68 | CY8C5868LTI-LP039 QFN68 | IC | 1 | U3 |
R-CR0603 | 1P7_0603 | Zero Ohm | DISCRETE | 1 | R1 |
R-CR0603 | 22_0603 | 22E | IC | 2 | R17; R18 |
RESC1608X55N_0603_E | 0OHM_0805_2 | Zero Ohm | DISCRETE | 1 | R2 |
RESC1608X55N_0603_E | 0OHM_0805 | Zero Ohm | DISCRETE | 2 | R3; R4 |
RESC1608X55N_0603_E | 1_0OHM_0805 | Zero Ohm | DISCRETE | 1 | R5 |
RESC1608X55N_0603_E | 4P7_0603 | 4.7K | DISCRETE | 2 | R6; R16 |
RESC1608X55N_0603_E | 330OHM_0805 | 330 ohm | DISCRETE | 1 | R7 |
RESC1608X55N_0603_E | 2P2K_0603 | 2.2K | DISCRETE | 2 | R9; R10 |
RESC1608X55N_0603_E | 0_0603 | ZERO | DISCRETE | 5 | R12; R13; R14; R15; R26 |
RESC1608X55N_0603_E | RESISTOR_RESC1608X55N_0603_E_15 | 15K | IC | 2 | R19; R20 |
RESC1608X55N_0603_E | RESISTOR_RESC1608X55N_0603_E_30 | 30K | IC | 2 | R23; R24 |
RESC2012X70N_0805 | 0OHM_0805_4 | Zero Ohm | DISCRETE | 1 | R8 |
RESC2012X70N_0805 | 0OHM_0805_1 | Zero Ohm | DISCRETE | 1 | R11 |
RESC2012X70N_0805 | 330OHM_0805_1 | 330 ohm | DISCRETE | 1 | R22 |
RESC2012X70N_0805 | 330OHM_0805_3 | 330 ohm | DISCRETE | 1 | R25 |
SOD323 | SD05-7 | 5V 350W | DISCRETE | 1 | TVS1 |
SOT563 | NTZD3152P | NTZD3152P | DISCRETE | 1 | U2 |
TP-43-TH | TP-43R_2 | VBUS | DISCRETE | 1 | TP6 |
TP-43-TH | TP-43R_1 | GND | DISCRETE | 1 | TP10 |
TP-43R_S | TP-43R_R | RED | DISCRETE | 13 | TP1; TP2; TP3; TP4; TP5; TP7; TP8; TP9; TP11; TP12; TP13; TP14; TP15 |
USB_A_90_PLUG_DIP | USB_A_90_PLUG_SMT | USB A PLUG | IC | 1 | J1 |
WIGGLE_ANT | WIGGLE ANTENNA_2_WIGGLE_ANT_ANT | ANTENNA | IC | 1 | ANT1 |
Y-XTAL-CFS308 | 32P768KHZ_CFS308 | 32.768KHz | IC | 1 | Y1 |
附件:
