1. 作品用途:点阵
2. 软件版本:allegro16.6
3. 层数:4层
5. PCB尺寸:异形
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C0603 | CAP NP_C0603_0.1UF | 0.1uF | IC | 2 | C1; C3 |
C0603 | CAP NP_C0603_100NF | 100nF | IC | 12 | C2; C4; C5; C6; C7; C8; C9; C13; C20; C21; C26; C29 |
C0603 | CAP NP_C0603_20PF | 20pF | IC | 2 | C10; C12 |
C0603 | CAP_0_C0603_0.1UF | 0.1uF | IC | 6 | C11; C14; C15; C16; C17; C18 |
C0603 | CAP NP_C0603_10NF | 10nF | IC | 2 | C19; C25 |
C0603 | CAP NP_C0603_47PF | 47pF | IC | 1 | C23 |
C0603 | CAP NP_C0603_1NF | 1nF | IC | 1 | C24 |
C0805 | CAP NP_C0805_10UF_10V | 10uF_10V | IC | 2 | C27; C28 |
C1206 | CAP NP_C1206_47UF_10V | 47uF_10V | IC | 1 | C22 |
CON_SMT_50_3_90DEG | CON3_CON_SMT_50_3_90DEG_CON3 | CON3 | IC | 3 | J1; J4; J6 |
CON_SMT_50_6_90DEG | CON6_CON_SMT_50_6_90DEG_CON6 | CON6 | IC | 3 | J5; J7; J8 |
CON_SMT_80_4_90DEG | CON4_CON_SMT_80_4_90DEG_2MMX4 | 2MMx4 | IC | 1 | SWD1 |
CON_SMT_100_2_90DEG | CON2_CON_SMT_100_2_90DEG_CON2 | CON2 | IC | 1 | J9 |
ECAP_SMD_6MM3_SQ_M | CAP_ECAP_SMD_6MM3_SQ_M_220UF_35 | 220uF_35V | IC | 2 | E1; E2 |
ECAP_SMD_6MM3_SQ_M | CAP_ECAP_SMD_6MM3_SQ_M_220UF_16 | 220uF_16V | IC | 1 | E3 |
EPS_12F | ESP12F_EPS_12F_ESP-12F | ESP-12F | IC | 1 | U13 |
FB0805 | FB_FB0805_100R_100MHZ | 100R_100MHz | IC | 2 | FB1; FB2 |
HC_49_TH | CRYSTAL/SM_HC_49_TH_8MHZ | 8MHz | IC | 1 | Y1 |
INDR_PIO54 | FB_INDR_PIO54_22UH | 22uH | IC | 1 | L1 |
JUMP_SMD_M | JUMPER_JUMP_SMD_M_JUMPER | JUMPER | IC | 2 | J2; J3 |
LED1615_RGY | LED_RGY_2_LED1615_RGY_LED_RGY | LED_RGY | IC | 2 | D6; D7 |
LED1615_RW | LED_RW_LED1615_RW_LED_RW | LED_RW | IC | 1 | D1 |
LED_8X8 | LED8*8_LED_8X8_LED8*8 | LED8*8 | IC | 3 | U1; U2; U4 |
LED_0603_C1 | LED_LED_0603_C1_LED | LED | IC | 5 | D2; D3; D4; D5; D11 |
LQFP48 | STM32F103C8_LQFP48_STM32F103C8T | STM32F103C8T6 | IC | 1 | U12 |
R0603 | RESISTOR_R0603_75 | 75 | IC | 1 | R1 |
R0603 | RESISTOR_R0603_120 | 120 | IC | 1 | R2 |
R0603 | RESISTOR_R0603_100 | 100 | IC | 17 | R3; R4; R5; R8; R20; R23; R24; R25; R48; R49; R52; R53; R54; R57; R58; R59; R60 |
R0603 | RESISTOR_R0603_140 | 140 | IC | 3 | R6; R7; R11 |
R0603 | RESISTOR_R0603_80 | 80 | IC | 2 | R9; R12 |
R0603 | RESISTOR_R0603_130 | 130 | IC | 2 | R10; R13 |
R0603 | RESISTOR_R0603_10K | 10K | IC | 11 | R14; R15; R16; R17; R18; R19; R21; R22; R51; R62; R66 |
R0603 | R_0_R0603_100 | 100 | IC | 6 | R26; R28; R32; R34; R37; R38 |
R0603 | R_0_R0603_10K | 10K | IC | 1 | R27 |
R0603 | R_0_R0603_4.7K | 4.7K | IC | 5 | R29; R30; R31; R35; R44 |
R0603 | RESISTOR_R0603_22R | 22R | IC | 4 | R33; R36; R46; R47 |
R0603 | RESISTOR_R0603_0R | 0R | IC | 1 | R39 |
R0603 | R_R0603_10K | 10K | IC | 6 | R40; R41; R42; R43; R55; R56 |
R0603 | RESISTOR_R0603_4.7K | 4.7K | IC | 1 | R45 |
R0603 | RESISTOR_R0603_2K2 | 2K2 | IC | 1 | R50 |
R0603 | RESISTOR_R0603_220K | 220K | IC | 1 | R61 |
R0603 | RESISTOR_R0603_47K | 47K | IC | 1 | R63 |
R0603 | RESISTOR_R0603_29K4 | 29K4 | IC | 1 | R64 |
R0603 | RESISTOR_R0603_1K9 | 1K9 | IC | 1 | R65 |
RES_ARRAY | RESAR_IS_0_RES_ARRAY_10 | 10 | IC | 2 | RN1; RN2 |
RES_ARRAY | RESAR_IS_0_RES_ARRAY_180 | 180 | IC | 6 | RN3; RN4; RN5; RN6; RN7; RN8 |
SMA | DIODE_S_SMA_SS34 | SS34 | IC | 1 | D9 |
SMA | DIODE_S_SMA_SS110 | SS110 | IC | 1 | D10 |
SO08_M | TPS54331D_SO08_M_TPS54331 | TPS54331 | IC | 1 | U14 |
SOD123 | DIODE_S_SOD123_NC | NC | IC | 1 | D8 |
SOP8_39 | BS814A-2_SOP8_39_BS814A-2 | BS814A-2 | IC | 2 | U3; U5 |
SOP16_39 | 74HC595PW_0_SOP16_39_74HC595PW | 74HC595PW | IC | 6 | U6; U7; U8; U9; U10; U11 |
SOT23_M | SI2302_0_SOT23_M_SI2302 | SI2302 | IC | 8 | Q1; Q2; Q3; Q4; Q5; Q6; Q7; Q8 |
SOT23_M | NPN_SOT23_M_MMBT4401 | MMBT4401 | IC | 1 | Q9 |
SOT223 | LM317_223_SOT223_AMS1117-33 | AMS1117-33 | IC | 1 | U15 |
TOUCH_KEY_6_22 | TOUCH KEY_8_TOUCH_KEY_6_22_TOUC | touch_key | IC | 7 | SW1; SW2; SW3; SW4; SW5; SW6; SW7 |
