查看: 339|回复: 2
[allegro16.2][2层] CY8CKIT-037 PSoC 4 Motor Control Evaluation Kit(LM5005MHX...
发表于 2020-1-16 17:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.2][2层] CY8CKIT-037 PSoC 4 Motor Control Evaluation Kit(LM5005MHX/NOPB+CY7C65213+LM393DR)原理图和pcb文件
+ ?% F! K9 h- L/ @
) {0 v% e& H3 c5 w" D' m文件描述:2 c/ V" T4 |, a) `. f" \3 r1 r, R
: r+ \9 v  O* V7 R7 o& J; I; f+ J
1. 作品用途:CY8CKIT-037 PSoC 4 Motor Control Evaluation Kit
3 z8 X& K) d+ ^2 H% [1 W/ ]2. 软件版本:allegro16.2
' G; R* }' G; b, a1 j2 S3 g8 l, q: x9 l3. 层数:2层/ a( G4 G5 U3 Z5 m8 a! x
4. 用到的主要芯片:LM5005MHX/NOPB+CY7C65213+LM393DR5 U3 }4 l, O/ T$ J, _# e( J8 i
5. pcb尺寸: 4000*6000 MIL
+ W3 M  w) f8 _& T1 [2 Z( l# v* l/ z/ F! Z% ^+ x: w
作品截图如下:
1 s* Z  p% o. s2 \% q4 Z7 `- m" M% T. m
顶层截图:- r6 j  b& E- z" s8 {, u' w* P
+ V- U+ b, T8 @) Q9 Y0 m3 `& A# \底层截图:
* U% @7 d; }3 R9 i 7 m3 Q9 h+ h. v6 n1 _1 A# `
6 C6 X7 W$ |1 m/ e" T/ a! a全层截图:
' s" m1 w* b2 O1 W& K ' F5 v- f, i; p. `
2 K0 Y, S) ^! ~! W1 O% a3 g
叠层阻抗信息如下:; E0 Y7 z$ J8 x6 g* V% Z; a
6 O- @+ y2 U# |0 H2 r! s
! A( Y+ ?- h7 n) s' a. y
BOM:8 p1 j7 g. K, A
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C0402CAP NP_C0402_0.1UF/16V0.1uF/16VIC3C44; C46; C48
C0402CAP NP_C0402_1UF/16V1uF/16VIC1C45
C0603CAP NP_C0603_8200PF/50V8200pF/50VIC1C3
C0603CAP NP_C0603_1UF/50V1uF/50VIC2C4; C43
C0603CAP NP_C0603_1800PF/50V1800pF/50VIC1C5
C0603CAP NP_C0603_22NF/50V22nF/50VIC1C6
C0603CAP NP_C0603_2700PF/50V2700pF/50VIC1C7
C0603CAP NP_C0603_1000PF/50V1000pF/50VIC2C8; C47
C0603CAP NP_C0603_0.1UF/50V0.1uF/50VIC2C10; C26
C0603CAP NP_C0603_0.1UF/100V0.1uF/100VIC1C12
C0603CAP NP_C0603_100PF/50V100pF/50VIC7C20; C21; C22; C23; C24; C25; C29
C0603CAP NP_C0603_330PF/50V330pF/50VIC6C35; C36; C37; C38; C39; C40
C1206CAP NP_C1206_1UF/100V1uF/100VIC2C1; C2
C1206CAP NP_C1206_10UF/50V10uF/50VIC4C16; C17; C18; C19
CLF6045_EINDUCTOR_CLF6045_E_150UH/0.6A/C150uH/0.6A/CLF6045T-151MIC1L2
CR-LED06030603_LEDESD 5VDCIC3D10; D11; D12
DPAK-D_EDIODE_2_DPAK-D_E_STPS15L60CB/60STPS15L60CB/60V/7.5AIC1D2
EVQP_ESW PUSHBUTTON_EVQP_E_RESETRESETIC1SW1
EVQP_ESW PUSHBUTTON_EVQP_E_RUN/STOPRun/StopIC1SW2
FUSE_EFUSE_FUSE_E_NO LOAD 125V/2.5A/0NO LOAD 125V/2.5A/045202.5MRLIC1F2
HDR1X3HEADER 3_HDR1X3_3 PIN HEADER3 Pin HeaderIC12J13; J14; J15; J16; J17; J18; J19; J20; J21; J22; J23; J24
HDR1X5_2_5MMHEADER 5_HDR1X5_2_5MM_5 PIN HEA5 Pin HeaderIC1J12
HDR1X8HEADER 8_HDR1X8_8 PIN HEADER8 Pin HeaderIC2J1; J4
HDR1X10HEADER 10_HDR1X10_10 PIN HEADER10 Pin HeaderIC1J3
HDR2-3_81_ACON2_1_HDR2-3_81_A_20020327-D0220020327-D021B01LFIC1J9
HDR2-3_81_BCON2_1_HDR2-3_81_B_12-48V/3A PO12-48V/3A POWER CONNIC1J8
HDR2-3_81_CCON2_3_HDR2-3_81_C_20020327-D0220020327-D021B01LFIC1J10
HDR2X9HEADER 9X2_HDR2X9_18 (9X2) PIN18 (9x2) Pin HeaderIC1J2
INDC2012X105NINDUCTOR_INDC2012X105N_FERRITEFERRITE BEADIC1L3
INDC2012X105NINDUCTOR_INDC2012X105N_220 OHM/220 Ohm/2AIC1L4
IPAKIRFPC50/TO_1_IPAK_IRFU3607PBFIRFU3607PBFIC8Q1; Q2; Q3; Q4; Q5; Q6; Q7; Q8
KLDPJ102A12-24V/3A, 2.1mm, PWR CONNIO1J7
LITTELFUSE_60R250FUSE_LITTELFUSE_60R250_60R250XM60R250XMR/60V/2.50AIC1F1
POT_10K_296U_VERPOT12_2_POT_10K_296U_VER_296UE1296UE103B1CIC1R38
QFN50P500X500X100-33BNCYUSBS232_8_QFN50P500X500X100-3CY7C65213IC1U8
R0603LED_R0603_RED LEDRed LedIC1LED1
R0603LED_R0603_GREENGREENIC1LED2
R0603R_R0603_10K/1%10K/1%IC3R1; R44; R50
R0603R_R0603_2K/1%2K/1%IC9R2; R42; R43; R48; R49; R64; R73; R74; R75
R0603R_R0603_143K/1%143K/1%IC1R3
R0603R_R0603_18.2K/1%18.2K/1%IC1R4
R0603R_R0603_16.9K/1%16.9K/1%IC1R5
R0603R_R0603_9.1K/1%9.1K/1%IC1R6
R0603R_R0603_1K/1%1K/1%IC5R7; R45; R51; R63; R65
R0603R_R0603_5.49K /1%5.49K /1%IC1R9
R0603R_R0603_590/1%590/1%IC1R10
R0603R_R0603_2.4K/5%2.4K/5%IC1R11
R0603R_R0603_330 OHM/5%330 ohm/5%IC1R12
R0603R_R0603_22 OHM22 ohmIC8R20; R21; R22; R23; R24; R25; R26; R27
R0603R_R0603_330 OHM330 ohmIC2R37; R39
R0603R_R0603_20K/1%20K/1%IC4R40; R41; R46; R47
R0603R_R0603_1K/5%1K/5%IC5R52; R56; R60; R61; R62
R0603R_R0603_22 OHM/1%22 ohm/1%IC2R53; R57
R0603R_R0603_8.2K/1%8.2K/1%IC3R70; R71; R72
R0603R_R0603_3.9K/5%3.9K/5%IC3R76; R77; R78
R0603R_R0603_10K/5%10K/5%IC1R82
R0603R_R0603_1.8K/1%1.8K/1%IC2R83; R84
R0603R_R0603_4.7K/5%4.7k/5%IC1R91
R0603R_R0603_220OHM/1%220ohm/1%IC3R92; R93; R94
R1206INDUCTOR_R1206_600OHM@100MHZ/1.600ohm@100MHz/1.5A/BLM31PG601SN1LIC1L1
R1206_ER_R1206_E_30M OHM/0.5W/1%30m ohm/0.5W/1%IC3R34; R35; R36
R1210VARISTOR_R1210_V60MLA1210/67V/2V60MLA1210/67V/250AIC1VR1
R-CR0603RESISTOR_R-CR0603_0 OHM/5%0 ohm/5%IC2R103; R104
R-CR0603RESISTOR_R-CR0603_0 OHM/5% NO0 ohm/5% No LoadIC1R105
RB4_4-11C_RB4_4-11_330UF/63V/UVZ1J331MP330uF/63V/UVZ1J331MPDIC1C11
SMD6X6C_SMD6X6_22UF/35V/EEE-FK1V220R22uF/35V/EEE-FK1V220RIC1C9
SO8_MIR2101_0_SO8_M_IR2101IR2101IC4U3; U4; U5; U6
SOD-80LDIODE21_0_SOD-80L_SK310A-TPSK310A-TPIC1D1
SOD-80L_EDIODE_SOD-80L_E_US1A-TPUS1A-TPIC4D3; D4; D5; D6
SOIC127P600X175-8N_AAD8072_0_SOIC127P600X175-8N_A_LLM393DRIC1U2
SOT-23-5OPAMP/AD8601ARTZ_2_SOT-23-5_OPAOpAmp/AD8601ARTZIC1U7
TE_CONNECTIVITY_1734510-1USB_MINI_B_DIPUSB MINI BIO1J11
TPTPGNDDISCRETE2TP1; TP2
TPTP19GND NO LOADDISCRETE1TP19
TP1TP21VDDDISCRETE1TP15
TP1TP20_1P0_1/Cmp0-_Ia_REFDISCRETE1TP17
TP1TP1P0_7/Ic_REFDISCRETE1TP18
TP2TP2Ia NO LOADDISCRETE1TP3
TP3TP3Ic NO LOADDISCRETE1TP4
TP4TP4AH No LoadDISCRETE1TP5
TP5TP5AL No LoadDISCRETE1TP6
TP6TP6BH No LoadDISCRETE1TP7
TP7TP7BL No LoadDISCRETE1TP8
TP8TP8CH No LoadDISCRETE1TP9
TP9TP9CL No LoadDISCRETE1TP10
TP10TP10DH No LoadDISCRETE1TP11
TP11TP11DL No LoadDISCRETE1TP12
TP12TP13+12VDISCRETE1TP13
TP12TP20P2_6/VIN_SENSE NO LOADDISCRETE1TP20
TP13TP13_1VinDISCRETE1TP14
TP16TP16P0_2 NO LOADDISCRETE1TP16
TSSOP20LM5005MH_TSSOP20_LM5005MHX/NOPBLM5005MHX/NOPBIC1U1
附件:
/ ]  E9 e+ n9 n- O. ~原理图和PCB文件如下:; \& \" f- M5 Y) U/ V) X
游客,如果您要查看本帖隐藏内容请回复
: m8 A7 S; A: e
发表于 2020-11-9 11:08 | 只看该作者
    2022-4-14 15:15
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2020-11-9 14:57 | 只看该作者
    _R0603_143K/1%
    GMT+8, 2025-7-10 02:14 , Processed in 0.140625 second(s), 27 queries , Gzip On.
