* `7 H6 b2 G6 C' w& I( c# r y X9 ~[allegro16.2][2层] CY8CKIT-001C, PSoC Development Kit使用CY8C5868AXI-LP0参考板(PPPC232LJBN-RC+DF11Z-12DS-2V+RSM)原理图和pcb文件4 R) y, |( N6 z% I0 Q
, A& n7 B! `& T文件描述:
/ G, T" } |+ a( r/ C3 j6 ?' [4 q, K! I: v( G, z. G0 i% u
1. 作品用途:CY8CKIT-001C, PSoC Development Kit使用CY8C5868AXI-LP0参考板
7 h3 B2 j& N& u/ N( g2. 软件版本:allegro16.2
% o9 B# {' c* d. [! c3. 层数:2层
, J9 `- D& c! Z* J" O( R+ d4. 用到的主要芯片:PPPC232LJBN-RC+DF11Z-12DS-2V+RSM
/ i; G/ W$ O, g. ?5. pcb尺寸: 8937.01*6296.72 MIL
. D, `$ ~2 U" S" N, V; Q3 v5 o( @ h1 c) ]
作品截图如下:& ~9 P$ y! E# n5 w
9 c! m `. w* y% g% u2 B
顶层截图:
$ o+ V+ K: m1 M+ v
9 m' A, |, B8 p1 P( K! r0 `- A底层截图:& ~* G6 G1 |* d% X N# \0 R
: W5 k) N- ] j- @* u( p
D4 O( z) p; V5 v# Q, N
全层截图:! e+ O" u) s9 V8 s" e" c
9 {! b7 V# w1 u4 a! m! |6 ]% e
4 A3 J! {/ Y6 R; c: ~; w& ]
叠层阻抗信息如下:
4 f) t6 V/ v0 a L O, x2 e
4 [/ N) R0 i: @# _BOM:
# v* j1 K8 Z& R/ o QBill of Material Report (Condensed) | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | 8-MSOP | LP3982IMM-ADJ/NOPB | LP3982IMM-ADJ | DISCRETE | 1 | U4 | BATTHLDR_F9V | BATTHLDR_F9V | BAT 9V FEMALE | IC | 1 | BH2 | BATTHLDR_M9V | BATTHLDR_M9V | BAT 9V MALE | IC | 1 | BH1 | C-AECAP-B | 10UFD_ELECT_25V | 10 uFd 25v | IC | 4 | C1; C3; C9; C30 | C-AECAP-E | CAP330UF | 330 uFd 25v | DISCRETE | 1 | C2 | C-CC0402 | 10NFD_0402_A | 10 nFd | DISCRETE | 1 | C10 | C-CC0603 | 1P0UFD_0603_25V | 1.0 uFd | DISCRETE | 2 | C4; C25 | C-CC0603 | 0P1UFD_0603_A | 0.1 uFd | DISCRETE | 10 | C11; C13; C14; C15; C16; C21; C22; C26; C27; C28 | C-CC0603 | C1608X8R1H333K | 33 nFd | DISCRETE | 1 | C24 | C-CC0805 | 0P33UFD_0805 | 0.33 uFd | DISCRETE | 1 | C17 | C-CC0805 | ECJ_2YB1H104K | 0.1 uFd | DISCRETE | 2 | C20; C23 | C-CC1210 | 10UFD_1210_16V | 10 uFd 16v | DISCRETE | 2 | C12; C29 | CR-LED1206 | LED_GREEN1206 | LED Green | IC | 1 | D1 | CR-LED1206 | LED_RED1206 | LED Red | IC | 4 | D3; D4; D5; D6 | CSB-300CIR-S | CSB_CIR_S | CapSense | IC | 2 | CSB1; CSB2 | CSS5 | CAPSENSE LINEAR SLIDER 5 SEG_CS | CapSense Linear Slider 5 Seg | IC | 1 | CSS1 | DF11-12DS-2V | DF11Z-12DS-2V | 6x2 RECP 2mm SMT | IO | 1 | P17 | DO214 | 10MQ040NTRPBF | DIODE SCHOTTKY 40V | DISCRETE | 1 | D2 | HDR2 | 9-146280-0-02 | 2 PIN HDR | IO | 3 | J10; J11; J14 | HDR3X2 | 67996-206HLF | 3x2 HEADER | IO | 4 | J2; J3; J4; J5 | HDR3 | HDR3_G | 3 PIN HDR | IO | 4 | J6; J7; J8; J12 | HDR20X2 | PPPC202LJBN-RC | 20x2 RECP RA | IO | 3 | P5; P7; P8 | HDR23X2 | PPPC232LJBN-RC | 23x2 RECP RA | IO | 1 | P6 | J-LCM-S01602DSR-16 | 929850-01-16-RA-LCD | LCD HEADER W/BACKLIGHT | IO | 1 | P18 | JK-PJ-102A | PJ102A | POWER JACK P-5 | IO | 1 | J1 | MINIBSMT | MINIBSMT | USB MINI B | IC | 1 | J9 | P-DB9F | P_DB9F | DB9 FEMALE | IC | 1 | P15 | R-CR0402 | 100K_0402 | 100K | DISCRETE | 1 | R14 | R-CR0603 | 1K_0603 | 1K | DISCRETE | 10 | R1; R21; R22; R23; R24; R25; R26; R28; R29; R30 | R-CR0603 | ERJ-3GEYJ121V | 120 5% | DISCRETE | 1 | R10 | R-CR0603 | 200_0603 | 200 ohm | DISCRETE | 1 | R15 | R-CR0603 | 0_0603 | ZERO | DISCRETE | 9 | R16; R18; R41; R42; R43; R44; R45; R46; R47 | R-CR0603 | 100_0603 | 100 ohm | DISCRETE | 2 | R17; R19 | R-CR0603 | NO_LOAD_0603_R | NO LOAD | DISCRETE | 2 | R27; R49 | R-CR0603 | ERJ-3EKF6041V | 6.04K | DISCRETE | 7 | R32; R33; R34; R35; R36; R37; R38 | R-CR0603 | ERJ-3GEYJ204V | 200K 5% | DISCRETE | 1 | R39 | R-CR0603 | 100K_1P_0603 | 100K | DISCRETE | 1 | R48 | R-CR0805 | NO_LOAD_0805_R | NO LOAD | DISCRETE | 1 | R40 | R-CR1210 | MF-USMF010-2 | 100mA | DISCRETE | 1 | F1 | R-POT-91A | 91AR10KLF | 10K | DISCRETE | 1 | R20 | R-POT-3361 | 3361P-1-501GLF | 500 Ohm | DISCRETE | 1 | R11 | R-POT-D8AA | POT_10K_D8AA | POT 10K | IC | 1 | R31 | RCP16X2-0P05-SMT | RSM-116-02-S-D-LC | 16x2 RECP | IO | 4 | P1; P2; P3; P4 | RECP4X1 | 929850-01-04-RA | 4x1 RECP | IO | 1 | P16 | RECP6X1-VERT | 929850-01-06-RA | 6X1 RECP | IO | 1 | P9 | RECP8X1-VERT | RECP8X1 | RECP 8X1 | IO | 1 | P12 | RECP12X1-VERT | 929850-01-12-RA | 12X1 RECP | IO | 1 | P14 | RECP17X1-VERT | 929850-01-17-RA | 17X1 RECP | IO | 1 | P19 | RECPT-8POS-DIP | RECPT-8POS-DIP | 8 PIN DIP SOCKET | IO | 1 | U8 | S-B3F-1002 | B3F-1022 | SW PUSHBUTTON | IO | 3 | SW1; SW2; SW4 | SOD123 | MMSZ4685T1G | 3.6V 500mW | DISCRETE | 1 | D7 | SOD323 | TVS_SOD323 | 5V 350W | IC | 1 | TVS1 | SOIC-16 | SN65C3232ED | SN65C3232 | DISCRETE | 1 | U6 | SOT23-6 | SN65220 | SN65220 | IC | 1 | U5 | SOT-89 | AP130-33YRL-13 | AP130-33YRL-13 | DISCRETE | 1 | U11 | SW_SPDT_1101M2S3CQE2 | SPDT | SPDT | IC | 1 | SW3 | TO252 | AP1117D50L-13 | AP1117D50L | DISCRETE | 1 | U2 | TP-43R_S | TP-43R_R | RED | DISCRETE | 5 | TP1; TP2; TP3; TP4; TP14 | TP-43R_S | TP-43R_W | WHITE | DISCRETE | 4 | TP18; TP19; TP56; TP58 | TP-43R_S | TP-43R_B | BLACK | DISCRETE | 9 | TP30; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39 | TP-60SQ_TOP | TP-60SMT | TP-60SMT | IO | 25 | TP5; TP7; TP12; TP20; TP22; TP23; TP24; TP25; TP40; TP41; TP42; TP43; TP44; TP45; TP57; TP59; TP60; TP61; TP62; TP63; TP64; TP65; TP66; TP67; TP68 | TSSOP20 | GTL2003PW | GTL2003PW | DISCRETE | 1 | U7 | 附件:
1 Z! A$ z9 T8 ] i0 f0 D3 | m6 u: I I a原理图和PCB文件如下:
: g5 w( o5 X- s1 ~
, C( a" M, e0 Z' t7 g1 C& T% j- M4 d; e+ J' m3 P# {
