查看: 222|回复: 0
[allegro15.0][18层] CY7C65630 CY7C65640 做的USB HUB(CY7C65630+LT1763CS8-3...
发表于 2020-1-16 16:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
7 b! j) l0 X* ?5 `, u" y# Z+ C: W
[allegro15.0][18层] CY7C65630  CY7C65640 做的USB  HUB(CY7C65630+LT1763CS8-3.3+USB)pcb文件, I6 P$ L! V$ p
  M$ ^' G( j4 S* B
文件描述:
+ }3 P0 I$ w$ r& t0 x% q7 u; D$ M* K  a* H+ f# g# t) ~9 f5 r
1. 作品用途:CY7C65630  CY7C65640 做的USB  HUB
+ A& z/ x/ t) y- `2. 软件版本:allegro15.0
: H( m. J8 I" E3. 层数:18层
8 s4 W; q3 N/ @/ g; F' q& }4. 用到的主要芯片:CY7C65630+LT1763CS8-3.3+USB' f+ K4 w0 ?* `3 H
5. pcb尺寸: 8937.01*6296.72 MIL5 L$ {( i# n; g+ x+ |& m
# ~& {) J0 e1 K/ w- j
作品截图如下:
. h% K  E6 f2 y) w: u! g2 e% ~, M
" q8 i& H* L( J0 m顶层截图:
0 q. y5 j3 k0 P; Y  g9 ?  D; r
; K3 N1 J, d' Q% |" L) b! `底层截图:
4 V! }( g/ q; o8 C! f# T/ z. u
" N3 h7 i& |- C" v4 u5 z
$ L1 p$ @# ~: x3 d' v3 C全层截图:5 \5 x$ w% q" V# C0 ]; K
  k& q8 o; R- o+ y9 m, q. C
# J7 l( j  A+ R! l4 F" \. m! m6 [4 N7 g
叠层阻抗信息如下:
& F4 _& p4 `2 K' U2 o + l. ], }  w# e
BOM:. B1 C& y, j8 z3 g1 s* O
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C-CC04020P1UFD_0402_A0.1 uFdIC12C7; C14; C15; C16; C25; C26; C27; C28; C29; C30; C31; C32
C-CC04021000PFD_04021000 pFdIC8C18; C19; C20; C33; C34; C35; C36; C37
C-CC0603ECU-V1H103KBV0.01 uFdIC6C8; C10; C21; C22; C23; C24
C-CC060312PFD_060312 pFdIC2C12; C13
C-CC12062P2UFD_CER_16V2.2 uFd 16vIC4C5; C6; C11; C17
C-PCC352822UFD_TANT_16V22 uFd Lo ESR 10VIC1C9
C-RADIAL-1X2P5220UFD_ELECT_RADIAL220 uFd 16vIC4C1; C2; C3; C4
CR-LEDLX3044LTL-4261NLED RedIC1D1
CR-LEDLX3044CR-LEDLX3044LED GreenIC4D3; D5; D7; D9
CR-LEDLX3044LTL-4251NLED YellowIC4D4; D6; D8; D10
CR-SMINI2PDIODE_MA2J111DIODE MA2J111IC1D2
D-SD05SD05SD05IC1D11
F-FUSE-1206F-FUSE-1206-5AFUSE 5AIC1F1
HDR2103185_2PWR LEDIC1J5
HDR2103185_2LEDSIC1J6
J-RAPC722RAPC722RAPC722IC1J12
L-IND0805220OHM_0805FERRITE 2AIC1L1
QFN56HX2LP_QFN56CY7C65630 / CY7C65640IC1U8
R-CR060310K_060310KIC6R1; R4; R5; R6; R7; R10
R-CR060315K_060315KIC1R2
R-CR0603680_0603680IC11R3; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35
R-CR0603100K_0603100KIC1R9
R-CR0805150K_0805150KIC1R11
R-CR0805NO_LOAD_0805_RNO LOADIC6R12; R13; R14; R15; R16; R17
SO8LT1763CS8-33LT1763CS8-3.3IC1U2
SO8MIC2026_SO8MIC2026-2YMIC1U3
SO8MIC2076_SO8MIC2026-2YMIC1U4
SO825LC040_SO825LC040 SO8IC1U5
SW_DPDT_1201M2S3CQE2DPDTDPDTIC1SW1
T-DLP11SL_IND_T_DLP11SDLP11SIC5T1; T2; T3; T4; T5
TP-43RTP-43RGNDIC2TP1; TP3
TP-43RTP-43RVCC_5VIC1TP2
TP-43RTP-43RVCC_3.3IC1TP4
TV-20R_2TV-36RTV-20RIC1TV1
USB_A_90_X2USB_A_90_X2USB A RA STACKEDIC2J1; J2
USB_B_90USB_B_90USB B RAIC1P1
Y-XTAL-FXFX240001824MHz 12pF CrystalIC1Y1
附件:
5 V6 D- b. C3 q. K7 |1 a/ PPCB文件如下:
' b* f+ s2 U9 q% }% ^  `( ?4 r  n
游客,如果您要查看本帖隐藏内容请回复
3 N* v1 M5 [6 X! Q6 d
; Q' q  j) w  g( j/ A9 C
GMT+8, 2025-7-23 04:39 , Processed in 0.125000 second(s), 28 queries , Gzip On.
