Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.01UF | DISCRETE | 3 | C1; C65; C73 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | DISCRETE | 27 | C2; C3; C5; C8; C10; C12; C17; C18; C51; C52; C54; C56; C57; C59; C60; C63; C66; C67; C68; C69; C70; C72; C75; C76; C77; C78; C80 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C11 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | DISCRETE | 2 | C13; C15 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 47PF | DISCRETE | 1 | C64 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1000PF | DISCRETE | 1 | C79 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.473 | 0.47UF | DISCRETE | 2 | C6; C7 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | DISCRETE | 7 | C9; C14; C16; C61; C62; C71; C74 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-785 | 4.7uF | IC | 1 | C4 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J12 |
CON3_JACK_5X15_SM | MJ1-3510-SMT_CON3_JACK_5X15_SM_ | MJ1-3510-SMT | IO | 1 | J16 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IO | 1 | J15 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_B_SKT_CON5_MUSB_AB_0P8 | USB_MINI_B 5 | IO | 1 | J19 |
CON_FTSH_19M_50_SM | CONN_HDR_19_CON_FTSH_19M_50_SM_ | HDR_19P | IO | 1 | J21 |
CON_QFP_64F_20_TH | PCF51JF128_64P_CON_QFP_64F_20_T | MCF51JF128VLH + OTQ-64-0.5-06-00 | IC | 1 | U5 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M__1 | CON_2X10 | IO | 1 | J9 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 2 | J10; J11 |
DIODE_3P2X2P2 | LED_DIODE_3P2X2P2_IC_1.1MM_480- | QTLP610CIR | IC | 1 | D1 |
HDR2X4_TSM_SM | CONN_HDR_4X2_HDR2X4_TSM_SM_IO_9 | HDR_2x4 | IO | 3 | J3; J13; J14 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 9 | J4; J5; J6; J7; J8; J17; J18; J20; J24 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | IO | 2 | J1; J2 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_9 | HDR_2X3 | IO | 2 | J22; J23 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100 OHM@100MHZ | IC | 5 | L50; L51; L52; L53; L54 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 4 | L1; L2; L3; L4 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_1 | LED_OR + ELECTRODE | IC | 1 | D50 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_2 | LED_GRN + ELECTRODE | IC | 1 | D51 |
LED_0603 | LED_LED_0603_IC_1.0MM_370-76472 | YEL/GRN | IC | 2 | D2; D4 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75076 | LED_YELLOW | IC | 1 | D5 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 1 | D6 |
LGA_44_0P65_5X5 | PCF51JF128-44P_LARGE_LGA_44_0P6 | PCF51JF128VHS | IC | 1 | U7 |
LQFP64_0P5_10X10 | PCF51JF128_64P_LQFP64_0P5_10X10 | MCF51JF128VLH | IC | 1 | U6 |
MIC_RF_4P82X3P76 | MINI_MIC_RF_MIC_RF_4P82X3P76_IC | SPM0408HE5H-SB | IC | 1 | U4 |
POT3_3352T | POT_POT3_3352T_DISCRETE_470-801 | 5K | DISCRETE | 1 | R57 |
QFN5X3_0P5_3X3 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | IC | 1 | U3 |
QTLP610 | TRAN_PHOTO_QTLP610_IC_1.1MM_480 | QTLP610CPD | IC | 1 | Q1 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | DISCRETE | 27 | R1; R3; R4; R5; R6; R7; R13; R19; R22; R23; R24; R25; R26; R27; R28; R32; R33; R55; R56; R60; R61; R64; R68; R69; R79; R82; R83 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | DISCRETE | 7 | R2; R17; R18; R20; R21; R34; R35 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | DISCRETE | 3 | R8; R62; R75 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3078 | 270 | DISCRETE | 1 | R14 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 0 | DISCRETE | 1 | R30 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | DISCRETE | 1 | R31 |
RC0402_25 | RES_RC0402_25_DISCRETE__470-760 | 1.0K | DISCRETE | 1 | R70 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7646 | 330 | DISCRETE | 1 | R71 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7648 | 10M | DISCRETE | 1 | R77 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7543 | 4.70K | DISCRETE | 5 | R9; R10; R58; R59; R67 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 11 | R12; R16; R29; R51; R52; R53; R54; R63; R65; R66; R78 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 1.0M | DISCRETE | 1 | R15 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7545 | 100 | DISCRETE | 1 | R11 |
SC-70 | 1G126_SC-70_IC_1.1MM_312-78261_ | SN74LVC1G126 | IC | 1 | U8 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 1 | D3 |
SO6_A | 1T45_SO6_A_IC_1.1MM_312-75172_S | SN74LVC1T45 | IC | 3 | U9; U11; U12 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 2 | U1; U10 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 1 | Q2 |
SOT223 | LT1129CST-3.3_SOT223_IC_1.8MM_3 | MIC2920A-3.3WS | IC | 1 | U50 |
SOT223 | MIC37139-1.8BS-1_SOT223_IC_1.8M | MIC5239-1.8 | IC | 1 | U52 |
SOT-23 | TRAN_NPN_RES_SOT-23_IC_1.3MM_48 | PDTC115T | IC | 1 | Q50 |
SOT_143 | SPB0503_SOT_143_IC_1.22MM_480-7 | SP0503B | IC | 2 | U13; U51 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 2 | SW1; SW2 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8 MM_21 | TEST POINT WHITE | IO | 8 | TP1; TP3; TP4; TP5; TP6; TP7; TP9; TP10 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | IO | 2 | TP2; TP8 |
TQFP44 | MC9S08JM60CFGE_TQFP44_IC_1.60 M | MC9S08JM60CLD | IC | 1 | U53 |
TSSOP20 | 74LVC573A_TSSOP20_IC_1.2MM_312- | 74LVC573A | IC | 1 | U2 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | IC | 1 | X1 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_ | 4MHz | IC | 1 | Y50 |
附件:
