查看: 674|回复: 4
[allegro16.6][6层] circuitco AM335X参考板(AM335X_ZCZ+FT2232LQFN64+DDR)pcb文件
发表于 2020-1-16 14:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
8 A* }* `  C. Y9 e: m# _/ J
  @$ q1 @6 a# s3 O: Z  k
: p0 q  r$ P8 [( J6 {7 f文件描述:
3 @" v  W7 z* {+ M8 _0 T0 ?/ Z* R4 |+ r
1. 作品用途:circuitco AM335X参考板1 ]- w- V4 l$ f" F3 r. `
2. 软件版本:allegro16.6( i+ S* a7 ~  o3 N3 U0 Y, y! ]- j# Y
3. 层数:6层' V2 e% ~+ r) h  s6 I) S- E0 C
4. 用到的主要芯片:AM335X_ZCZ+FT2232LQFN64+DDR9 Z* w- R9 k6 N  @- F8 T
5. pcb尺寸: 2750*3500 MIL& {- {# h# d2 B6 H3 p( K
9 F! \* ?; {. q7 w$ ]作品截图如下:! Y9 J1 g3 A) i2 u% Z
6 T) {. Q  ^4 _2 @0 S7 k8 m; `
顶层截图:% B5 X$ m0 K6 a3 X% d" C7 j+ n" k
: Z) U2 [1 [7 r% ^7 n: B/ G% Q底层截图:% h, O3 o" u% r. `. \' M5 g
6 c- A7 M  t5 v% o" r; I  I
) S0 d. \4 J3 |& \( p7 ]
全层截图:8 Z6 s6 ^, |* L$ G. e+ G  Y
3 X# q! Z! K1 Q6 g1 l" i" D
8 q$ y* O: q8 c
3 e- D5 F. z( N; \  S) wBOM:3 G$ H; [3 l3 a
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0.1UF_X7R_16V_10% 0402 _4020.1uf,16VIC14C4; C111; C164; C186; C202; C216; C217; C218; C219; C225; C226; C227; C228; C229
402CAP_0.01UF_X7R_16V_10%_0402_4020.01uf,16VIC83C30; C31; C33; C35; C38; C39; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C94; C95; C96; C97; C99; C100; C101; C102; C103; C104; C105; C107; C108; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C127; C185; C223; C224
402CAP_25PF_NPO_100V_5%_0805_0402_25pF,50VIC2C32; C34
402CAP_18PF_COG_50V_5%_0402_402_1818pF,50VIC4C36; C37; C221; C222
402CAP_0.001_X7R_50V_5%_0402_402_00.001uf,50VIC1C40
402CAP_1.0UF_X5R_10V_10%_0402_402_1uF,10VIC5C91; C92; C93; C106; C131
402CAP_1.0UF_X5R_10V_10%_0402_40_11uF,10V,DNIIC1C110
402RES_100K_1/16W_1%_0402_402_10_3100KIC1R8
402RES_10K_1/16W_1%_0402_402_10K,110K,1%IC14R11; R34; R90; R213; R214; R215; R216; R217; R218; R219; R249; R251; R252; R261
402RES_1.1K_1/16W_1%_0402_402_1K1KIC5R29; R257; R258; R259; R260
402RES_100K_1/16W_1%_0402_402_10_2100K,1%IC16R30; R31; R91; R99; R102; R105; R108; R109; R112; R113; R114; R116; R117; R119; R120; R122
402RES_1M_1/16W_1%_0402_402_1M, DN1M, DNIIC1R32
402RES_0_1/16W_1%_0402_402_00IC5R33; R35; R36; R88; R220
402RES_33_0402_402_33,0402
330,402
IC45R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R80; R81; R82; R83
402RES_33_0402_402_22,0402
220,402
IC2R78; R79
402RES_2.2K_1/16W_1%_0402_402_2.2K2.2K,1%IC4R84; R85; R248; R250
402RES_50_2W_1%_4124_0402_49.9,1%49.9,1%IC1R86
402RES_100K_1/16W_1%_0402_402_9.1K9.1K,1%IC3R92; R94; R95
402RES_100K_1/16W_1%_0402_402_9._19.1K,1%,DNIIC1R93
402RES_100K_1/16W_1%_0402_402_10_1100K,1%,DNIIC13R96; R97; R98; R101; R103; R104; R106; R107; R110; R111; R115; R118; R121
402RES_100K_1/16W_1%_0402_402_100K100K,1%.DNIIC1R100
402ZEROOHMRESISTOR1/16W0402_402_00IC1R131
402RES_100K_1/16W_1%_0402_402_10K,10K,1%IC1R188
402RES_0_1/16W_1%_0402_402_0,DNI0,DNIIC6R190; R191; R192; R194; R195; R196
402RES_100_1/10W_5%_0402_402_100,5100,5%,DNIIC1R193
402RES_1M_1/16W_1%_0402_402_1.6M,11.6M,1%IC1R230
402RES_1M_1/16W_1%_0402_402_180K,1180K,1%IC1R231
402RES_100K_1/16W_1%_0402_402_392K392K,1%IC1R232
402RES_0_1/16W_1%_0402_402_0,1%0,1%IC12R239; R240; R241; R242; R243; R244; R245; R246; R256; R262; R263; R266
402RES_10K_1/16W_1%_0402_402_100K100KIC1R247
402RES_12.1K_1/16W_1%_0402_402_12.12.1K,1%IC1R253
402RES_0_1/16W_1%_0402_402_0, DNI0, DNIIC1R267
805CAP_10UF_Y5V_10V_10%_0805_805_110uF,10VIC6C41; C42; C64; C79; C98; C201
805CAP_22UF_X5R_6.3V_120%_0805_80522uF,6.3VIC1C126
805CAP_10UF_Y5V_10V_10%_0805_0805_2.2uF, 25VIC2C203; C204
7343CAP POL_7343_47UF47uFIC1C2
6605728-1CONNECTORRJ45_10_100MB_6605728-RJ-45 10_100MbIC2J2; J3
AM33XX_15X15IC_AM335X_ZCE_2_AM33XX_15X15_AMAM335X_ZCZIC1U5
BGA84_8X12P5_P8MMMEM_MT47H64M16_FBGA84_1_BGA84_8MT47H128M16RT-25E:CIC1U7
BLM18AFERRITEEMI600OHM500MASMD0603_BL600OHM500mAIC2FB4; FB7
CHKFOOTPRINT4.7UH30%0.9ASMD_CHKFOOTPRINT_4.4.7uHIC1L1
CON14_P5MM_3P75X9P5SMDCONN FLEX 14_CON14_P5MM_3P75X9P10051922-1410ELFIC1J13
CONN_OSTTC02CONN_LEADSCREWDOWN_2PIN_CONN_OSOSTTC022162, DNIIC1J14
DA2304DA2304-ALB_DA2304_DA2304DA2304IC1L5
DBV5TPS61041DBV_DBV5_TPS61041DBVTPS61041DBVIC1U27
DCK5SN74LVC1G06DCK_0_DCK5_SN74LVC1GSN74LVC1G06DCKIC1U22
DCK5SN74LVC1G07DCK_DCK5_SN74LVC1G07SN74LVC1G07DCKIC1U23
DO157LS_116X220SMADIODE_5ARECT_REV40V_3_DO157LS_1B340A-13-FIC1D33
HDR2X20_50LSCONN PCB 20X2_HDR2X20_50LS_CONNCONN PCB 20x2IC1J9
HDR2X25_50LSCONN PCB 25X2_HDR2X25_50LS_CONNCONN PCB 25x2IC1J12
HEADER10X2_SMDHDR_10X2_CJTAG_0_HEADER10X2_SMDCTI JTAG,DNIIC1P2
HTQFP_48PINTLK110_2_HTQFP_48PIN_TLK110TLK110IC2U12; U14
IND108SMD_110X102INDUCTOR_IND108SMD_110X102_VLF3VLF3010AT-2R2M1R0IC1L6
IND_354SMD_400SQINDUCTOR IRON_IND_354SMD_400SQ_68uHIC1L7
LED4_1210SMD-1598-8610-307F_LED4_1210SMD-1_59598-8610-307FIC2D4; D5
LQFP64_10X10IC_FT2232H_LQFP64_LQFP64_10X10_FT2232LQFN64IC1U8
MBR0520LDIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1IC3D12; D13; D32
MC-306CRYS_32_768KHZ_SMD32_MC-306_32.32.768KHz MC-306IC1Y1
MELF0102RES_10K_1/16W_1%_0402_MELF0102_49.9, MELFIC1R268
MELF0102RES_10K_1/16W_1%_0402_MELF010_11.2K, MELFIC8R269; R270; R271; R272; R273; R274; R275; R276
NORCOMP_DB9F_SMDCONN_DSUB9F_NORCOMP_DB9F_SMD_COConn_DB9FIC1J8
PW8SN74CBQ3306APW_PW8_SN74CBQ3306ASN74CBQ3306APWIC1U29
RAPC712CONN_PWRJACK_RAPC712_RAPC712_RARAPC712IC1J1
SC70-5LM94022_SC70-5_LM94022LM94022IC1U6
SD-MICRO-SCHA5B0300MICROSD_CONN_8_SD-MICRO-SCHA5B0SCHA5B0200IC1P3
SIP2_50LSCONN PCB 2_SIP2_50LS_CONN PCB 2CONN PCB 2IC3J4; J5; J7
SIP3_50LSCONN PCB 3_SIP3_50LS_CONN PCB 3CONN PCB 3IC2J6; J10
SM-7351-CAP-04020.01UFCAPACITOR16V10%0402_SM-730.01uFIC16C1; C143; C144; C147; C148; C150; C158; C159; C162; C163; C166; C167; C169; C175; C191; C200
SM-7351-CAP-04020.1UFCAPACITOR16V10%0402_SM-7350.1uFIC29C3; C128; C129; C130; C132; C133; C134; C135; C136; C138; C139; C140; C141; C142; C145; C146; C153; C154; C155; C156; C157; C160; C161; C172; C173; C176; C211; C212; C238
SM-7351-CAP-04021UFCAPACITOR16V10%0402_SM-7351-1uFIC3C5; C28; C29
SM-7351-CAP-04022.2UFCAPACITOR6.3V20%SMDX5R04022.2uFIC9C8; C18; C19; C20; C21; C24; C25; C26; C27
SM-7351-CAP-04020.1UFCAPACITOR16V10%0402_SM-7_10.01uFIC1C15
SM-7351-CAP-040215PFCAPACITOR50V10%SMD0402_SM-715pFIC2C149; C151
SM-7351-CAP-0402100PFCAPACITOR16V10%0402_SM-735100pFIC2C177; C178
SM-7351-CAP-04022.2UF16V10%SMD0805_SM-7351-CAP-2.2uFIC2C190; C198
SM-7351-CAP-04020.001UFCAPACITOR50V5%0402_SM-730.001uFIC1C192
SM-7351-CAP-04020.1UFCAPACITOR50V10%0402_SM-7350.1uFIC2C193; C194
SM-7351-CAP-04021UFCAPACITOR10V10%0402_SM-7351-1uFIC1C199
SM-7351-CAP-040215PFCAPACITOR50V10%SMD0402_SM_110pFIC1C206
SM-7351-CAP-04023.3UFCAPACITOR16V10%0603_SM-7_11uF/16VIC4C207; C208; C209; C210
SM-7351-CAP-04020.001UFCAPACITOR50V5%0402_SM-_10.022uFIC9C215; C230; C231; C232; C233; C234; C235; C236; C237
SM-7351-CAP-06034.7UFCAPACITOR6.3V20%SMDX5R06034.7uFIC5C7; C16; C17; C22; C23
SM-7351-CAP-0603CAP_4.7UF_X5R_6.3V_10%_0603_SM-4.7uFIC2C109; C220
SM-7351-CAP-06034.7UFCAPACITOR16V20%TANT_SM-7354.7uFIC1C170
SM-7351-CAP-06033.3UFCAPACITOR16V10%0603_SM-7354.7uFIC1C174
SM-7351-CAP-080510UFCAPACITOR16V10%0805_SM-735110uFIC11C6; C9; C10; C11; C12; C13; C14; C137; C152; C168; C171
SM-7351-CAP-08052.2UF16V10%SMD0805_SM-7351-CA_12.2uFIC2C213; C214
SM-7351-CAP-120610UFCAPACITOR50V10%1206_SM-735110uF,50VIC3C196; C197; C205
SM-7351-IND-0805FER_180_200_0_SM-7351-IND-0805_150OHM800mAIC6FB1; FB2; FB3; FB10; FB11; FB12
SM-7351-IND-0805FERBEAD_180OHM200MA_SM-7351-IND150OHM800mAIC4FB5; FB6; FB8; FB9
SM-7351-RES-0402150OHM1/16W1%SMD0402_SM-7351-RE150IC19R1; R18; R123; R124; R125; R126; R204; R206; R207; R208; R209; R210; R211; R212; R221; R222; R227; R228; R229
SM-7351-RES-04024.7KOHMRESISTOR1/16W0402_SM-7354.7KIC2R2; R3
SM-7351-RES-0402ZEROOHMRESISTOR1/16W0402_SM-7350IC9R6; R7; R15; R28; R151; R173; R187; R198; R199
SM-7351-RES-040210KOHMRESISTOR1/16W0402_SM-735110KIC23R10; R12; R14; R17; R87; R132; R133; R134; R135; R136; R137; R150; R158; R172; R175; R203; R205; R233; R234; R235; R254; R255; R264
SM-7351-RES-040210KOHMRESISTOR1/16W0402_SM-73_13.24KIC1R13
SM-7351-RES-0402100KOHMRESISTOR1/16W0402_SM-7351KIC10R127; R128; R129; R130; R223; R224; R225; R226; R236; R237
SM-7351-RES-0402330OHM1/16W5%SMD0402_SM-7351-RE330IC6R138; R142; R143; R160; R164; R165
SM-7351-RES-04022.2KOHMRESISTOR1/16W0402_SM-7352.2KIC24R139; R140; R141; R144; R152; R153; R154; R155; R156; R157; R161; R162; R163; R166; R167; R176; R177; R178; R179; R180; R181; R184; R201; R202
SM-7351-RES-04022.2KOHMRESISTOR1/16W0402_SM-7_12.2K, DNIIC1R145
SM-7351-RES-040249.9OHMRESISTOR1/16W0402_SM-73549.9IC8R146; R147; R148; R149; R168; R169; R170; R171
SM-7351-RES-04024.99KOHMRESISTOR1/16W0402_SM-734.99KIC2R159; R174
SM-7351-RES-0402100KOHMRESISTOR1/16W0402_SM-7_1100KIC2R182; R183
SM-7351-RES-040233OHMRESISTOR1/16W5%0402_SM-73533IC2R185; R186
SM-7351-RES-0402R_SM-7351-RES-0402_4.7K4.7KIC3R189; R197; R238
SM-7351-RES-040210KOHMRESISTOR1/16W0402_SM-73_212.1KIC1R265
SM-7351-RES-0603ZEROOHMRESISTOR1/16W0603_SM-7350IC13R4; R5; R9; R16; R19; R20; R21; R22; R23; R24; R25; R26; R27
SM-7351-RES-060325KOHM1/10W0.1%SMD0603_SM-7351-25KIC1R200
SM-SO-SC70-5SN74LVC1G08DCKT_SC70_SM-SO-SC70SN74LVC1G08IC2U13; U15
SMCJ36CADIODE_SMCJ36CA_SMCJ36CA_SMCJ26CSMCJ26CAIC1D23
SMDSC70-5TPS71718_SMDSC70-5_TPS71718TPS71718IC1U2
SMINI6-F3-BRN1907_SMINI6-F3-B_DMC56404DMC56404IC5Q1; Q2; Q3; Q4; Q5
SM_LED_0603LED_GREEN_SM_LED_0603_GREEN LEDGreen LEDIC14D3; D6; D8; D9; D10; D11; D24; D25; D26; D27; D28; D29; D30; D31
SM_LED_0603LED_RED_SM_LED_0603_RED LEDRed LEDIC1D7
SM_OSC_ABM3CRYSTAL25MHZABM3_SM_OSC_ABM3_2525MHzIC1Y4
SO8_W_DUBISO1050_SO8_W_DUB_ISO1050ISO1050IC1U20
SOD-123DIODE_5ARECT_REV40V_2_SOD-123_MMBRX140-TPIC1D22
SOIC8_265W25Q64_SOIC8_265_W25Q64W25Q64IC1U19
SOIC-8TPS5410D_SOIC-8_TPS5410DTPS5410DIC1U28
SOIC_8TPS76650_SOIC_8_TPS76650TPS76650IC1U18
SOIC_8CAT24C256W_SOIC_8_CAT24C256WCAT24C256WIC1U21
SOT23-6IC_93C46B_SSOT23-6_SOT23-6_93C493C46B_SOT23-6IC1U17
SW3_4X2P5SW_DP_MOM_SW3_4X2P5_DISCRETE_B3B3U-1100DISCRETE1S1
TFBGA48M29W128G_0_TFBGA48_M29W160EB70ZM29W160EB70ZA6EIC1U10
TH_TP_5002TESTPOINTTHROUGHHOLE_TH_TP_5002TPIC1TP3
TP60C_SMDTESTPT1_TP60C_SMD_TESTPT1TESTPT1IC3TP7; TP8; TP9
TP_SMD1MMCIRCLETESTPOINT_SMD1MMCIRCLE_TP_SMD1MTP1mmIC17TP1; TP4; TP5; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23
TQFP-100CY7C024AV/025AV/026AV_0_TQFP-10CY7C024AV/025AV/026AVIC1U9
TVSOP-48SN74ALVCH16374DGV_0_TVSOP-48_SNSN74ALVCH16374DGVIC1U11
USB-MINI-SMT-NUMMINI-USB-AB-SOCKET_USB-MINI-SMTmini USB-BIC1P4
U_8_DCUIC_SN74AUP2G08_8-VSSOP_U_8_DCU_SN74AUP2G08IC2U3; U4
U_16_DTPIC2810_U_16_D_TPIC2810TPIC2810IC1U26
U_16_DWISO1176T_U_16_DW_ISO1176TISO1176TIC1U16
U_28_PWPSN65HVS882_U_28_PWP_SN65HVS882SN65HVS882IC1U25
U_48_RSLTPS65910_0_U_48_RSL_TPS65910TPS65910IC1U1
VLCF5020T2.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHIC3L2; L3; L4
XTAL4_3P2X2P5_SMDCRYS_24MHZ_SCC_XTAL4_3P2X2P5_SM24MHzIC1Y2
XTAL4_3P2X5SMDXTAL_HC-49SMT12.000MHzIC1Y6
附件:
6 M, s4 Z. E. Z- e) _PCB文件如下:
9 z6 T: i- j: u4 J+ U! B8 a
游客,如果您要查看本帖隐藏内容请回复
& d9 u- m( R) m0 j8 l
# [3 l3 U4 F9 U
发表于 2023-8-21 16:26 | 只看该作者
看看,参考学习下
发表于 2024-7-11 09:35 | 只看该作者
XUEXIXUEYI
    2025-4-3 15:12
    发表于 2024-7-13 10:07 | 只看该作者
    % W0 w4 P, q' K! V3 W: }
    XUEXIXUEYI
    发表于 2024-12-4 11:47 | 只看该作者
    看看,参考学习下
    GMT+8, 2025-6-20 01:11 , Processed in 0.109375 second(s), 27 queries , Gzip On.
