作品名:[AD 10][2层] UPC1237+LM4766+LM337+NE5532 功放板PCB和原理图
2 W+ Z. d! m/ T; V
* j8 c# ^( u/ g. C. t& h4 O文件描述0 e) x) I q6 r- `* C( [
1. 作品用途:功放板$ g$ O- J2 V8 [5 Q) Y
2. 软件版本:AD 10
5 r) n7 |. c& Z3. 层数:2层板 c. S( d9 z- L6 |7 p) G
4. 用到的主要芯片:UPC1237+LM4766+LM337+NE5532
. G% ?# ?8 A# x3 F, J# t5. PCB尺寸:198.2mm*134.9mm
" n6 b+ I4 V( c5 F a% U( N- [9 z+ E) p6 N
作品截图如下:9 _8 V' e3 e! H$ ~/ U7 ~8 r& F3 p+ r
全层截图:
! P" t% ?9 ~- I" A% ?, B$ m
7 Q w2 [1 e1 w* G' L c
8 L4 O; y! z4 V# Q' a) I* j: f
叠层信息截图如下:7 o3 O8 X- }2 ?
# \' a) H! N4 Z/ q# c$ R
0 J7 j1 \) O( v7 GBOM:1 d$ A& X9 |. f0 i, l
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | C1, C2 | 10000uf/25v 电容 | 2 | | C3, C4, C9, C10, C11, C15, C16, C17, C18, C27, C28 | RAD-0.1 | 11 | | C5, C6, C12, C14, C19, C20, C23, C24, C25 | RB 0.1/0.2 | 9 | | C7, C8, C13, C26, C29 | 220UF/16V | 5 | Cap | C21, C22 | RAD-0.1 | 2 | | D1, D2, D3, D4 | DO-41 | 4 | | D5, D7, D8, D9, D10 | DIODE-0.4 | 5 | Diode | D6 | DIODE-0.4 | 1 | Relay-DPDT | K1 | 双刀双掷继电器 | 1 | U2 | LM337 | LM317+散热片(24/16) | 1 | | NE5532 | DIP-8 | 1 | AC 22V | P1 | 变压器 | 1 | LED | P2 | HDR1X2 | 1 | L OUT | P3 | 接线柱 | 1 | R OUT | P4 | 接线柱 | 1 | IN | P5 | HDR1X3 | 1 | Res1 | R1, R2, R22 | AXIAL-0.3 | 3 | | R3, R4, R5, R6, R7, R8, R9, R10, R11, R12, R13, R14, R15, R16, R17, R18, R19, R20, R21, R23, R24, R25, R26, R27, R28 | AXIAL-0.3 | 25 | | RS1, RS2 | VR5 | 2 | 50K | RW1 | 双联电位器 | 1 | LM317 | U1 | LM317+散热片(24/16) | 1 | UPC1237 | U3 | UPC1237 | 1 | LM4766 | U4 | LM4766 | 1 |
& J4 r5 c2 i( q4 I" f附件:
1 x/ l& T$ A) _5 K/ A6 R( z原理图和PCB源文件如下:
* E7 g0 ~5 \+ u$ M) o$ X8 U& b" k+ d( D5 Q
) b( {% S( k( i: _9 c1 g9 x; r) k. h! y+ `% G
