Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
402 | CAP,0.1UF_402_0.1UF | 0.1uF | IC | 19 | C1; C2; C3; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C23 |
402 | CAP,0.1UF_0402_0.1UF | 0.1uF | IC | 1 | C4 |
402 | RES_470_1/10W_5%_0402_402_5.6K | 5.6K | IC | 2 | R3; R4 |
402 | RES_4.7K_0402_402_4.75K | 4.75K | IC | 3 | R5; R6; R7 |
402 | RES_4.7K_0402_402_10K | 10K | IC | 4 | R8; R92; R98; R100 |
402 | RES_4.7K_0402_402_33 | 33 | IC | 79 | R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R71; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R93; R94; R95; R96 |
402 | RES_4.7K_0402_402_1K | 1k | IC | 8 | R70; R72; R73; R74; R75; R76; R77; R78 |
402 | RES_4.7K_0402_402_0 | 0 | IC | 3 | R99; R111; R112 |
402 | RES_4.7K_0402_402_0, DNI | 0, DNI | IC | 2 | R109; R110 |
603 | RES_33_0603_DISCRETE_1E_1% | 1E | DISCRETE | 1 | R127 |
603 | RES_33_0603_DISCRETE_0, DNI_1% | 0, DNI | DISCRETE | 4 | R128; R129; R132; R134 |
603 | RES_33_0603_DISCRETE_0_1% | 0 | DISCRETE | 4 | R130; R131; R133; R135 |
805 | CAP_10UF_Y5V_10V_10%_0805_805_1 | 10uF,10V | IC | 2 | C20; C21 |
805 | CAP_10UF_Y5V_10V_10%_0805_805_3 | 30uF,16V DNI | IC | 1 | C22 |
BGA96-ZKE | 74AVC8T245_0_BGA96-ZKE_74AVC32T | 74avc32t245 | IC | 2 | U2; U3 |
C402-25 | CAP NP_C402-25_47NF | 47nF | IC | 1 | C39 |
C402-25 | RES_33_C402-25_DISCRETE_0, DNI_ | 0, DNI | DISCRETE | 4 | R101; R103; R105; R107 |
C402-25 | RES_33_C402-25_DISCRETE_0_1% | 0 | DISCRETE | 4 | R102; R104; R106; R108 |
C402-25 | RES_10K_C402-25_DISCRETE_10R, D | 10R, DNI | DISCRETE | 1 | R119 |
C402-25 | RES_10K_C402-25_DISCRETE_0R_1% | 0R | DISCRETE | 2 | R120; R124 |
C402-25 | RES_10K_C402-25_DISCRETE_18K, D | 18K, DNI | DISCRETE | 1 | R121 |
C402-25 | RES_10K_C402-25_DISCRETE_0R, DN | 0R, DNI | DISCRETE | 3 | R122; R123; R125 |
C402-25 | RES_10K_C402-25_DISCRETE_100K, | 100K, DNI | DISCRETE | 1 | R126 |
C402-25 | RES_10K_C402-25_DISCRETE_10K, D | 10K, DNI | DISCRETE | 1 | R139 |
C805-35X60 | CAP NP_C805-35X60_4.7UF, 25V | 4.7uF, 25V | IC | 2 | C38; C40 |
CON6SMD_P5MMLS_FCI_SFV-1 | CON6_CON6SMD_P5MMLS_FCI_SFV-1_C | CON6 | IC | 1 | P4 |
CON40SMD_P5MMLS_HRS_FH19SC | CON40_CON40SMD_P5MMLS_HRS_FH19S | NHD_4.3-480272MF-ATXI | IC | 1 | P5 |
DCK5 | SN74LVC1G06DCK_0_DCK5_SN74LVC1G | SN74LVC1G06DCK | IC | 2 | U4; U6 |
DRC10-11X33 | TPS61080DRC_0_DRC10-11X33_TPS61 | TPS61080DRC | IC | 1 | U5 |
HEADER10X2 | HDR_10_F_2_0.1_HEADER10X2_MALE | MALE HDR5x2 | IC | 1 | P3 |
HEADER23X2 | HDR_46_F_2_0.1_0.1_HEADER23X2_M | MALE HEADER 2x23 | IC | 2 | P1; P2 |
IND237SMD_287SQ | INDUCTOR_IND237SMD_287SQ_CDRH74 | CDRH74 | IC | 1 | L1 |
IND390SMD_472SQ | INDUCTOR_IND390SMD_472SQ_18UH, | 18uH, DNI | IC | 1 | L3 |
IND-LQH32M | INDUCTOR/SM_IND-LQH32M_4.7UH | 4.7uH | IC | 1 | L2 |
LED2-31SQ | LED_LTST-C150GKT_LED2-31SQ_DISC | LTST-C190GKT | DISCRETE | 2 | D4; D5 |
R402-25 | RES_330_0402_R402-25_470 | 470 | IC | 2 | R97; R137 |
SIP3 | CON3_SIP3_CON3 | CON3 | IC | 1 | J1 |
SIP6 | CON6_SIP6_CON6 | CON6 | IC | 1 | J2 |
SM-7351-RES-0402 | 62OHMRESISTOR1/16W0402_SM-7351- | 130K | IC | 2 | R1; R2 |
SM-7351-RES-0402 | 10KOHMRESISTOR1/16W0402_SM-7351 | 10K | IC | 5 | R113; R114; R115; R117; R118 |
SM-7351-RES-0402 | RES_100K_1/16W_1%_0402_SM-7351- | 100K,1% | IC | 2 | R116; R136 |
SMINI6-F3-B | RN1907_SMINI6-F3-B_DMC56404 | DMC56404 | IC | 1 | Q1 |
SOD-123 | DIODE SCHOTTKY_0_SOD-123_MBRX14 | MBRX140-TP | IC | 1 | D1 |
SOIC_8 | CAT24C256W_SOIC_8_CAT24C256W | CAT24C256W | IC | 1 | U1 |
SOT23-3 | MOSFET_NCHAN_BSS138_SOT23-3_BSS | BSS138, DNI | IC | 1 | Q3 |
SW3_4X2P5 | SW_DP_MOM_SW3_4X2P5_DISCRETE_B3 | B3U-1100 | DISCRETE | 1 | S1 |
SW4-B3F-315X | SW_KT11P2JM_4_SW4-B3F-315X_DISC | B3F-3100 | DISCRETE | 1 | S7 |
SWDIP4_100-339SMD | SW DIP-2_SWDIP4_100-339SMD_SW D | SW DIP-2 | IC | 1 | SW1 |
SWRST4_177X256LS-1 | SW_KT11P2JM_4_SWRST4_177X256LS- | B3F-1000 | DISCRETE | 5 | S2; S3; S4; S5; S6 |
TP60C40D | T POINT A_0_TP60C40D_T POINT A | T POINT A | IC | 1 | TP1 |
TP60C40D | T POINT A_TP60C40D_T POINT A | T POINT A | IC | 2 | TP2; TP3 |
