作品名:[AD 10][3层]TW2867+sii9134+CS7123 做的一个底板PCB和原理图# H. O2 E! x/ h
) _* k0 t, B0 W+ C/ p% H& g6 O文件描述( m7 }. t: a" D+ A! B$ Q' |
1. 作品用途:底板
+ O& ^2 O1 m( i f0 g: ^* W2 W2. 软件版本:AD 106 U% D f( z, Y& N/ l3 q+ e
3. 层数:3层板
/ y& Z- v& G* [# w6 s _4. 用到的主要芯片:TW2867+sii9134+CS7123& Q3 J& O2 \2 e& i
5. PCB尺寸:150mm*110.1mm
% O$ P. @5 ]' g- G$ t& P& t7 A
] w2 z5 |2 u6 \' B5 U: R9 U作品截图如下:
& G; j0 b }( ], g' V- N9 Q$ }顶层截图:0 Z% h& s f! ~) o& n A s
" a2 |$ l; u- @% b
8 R, Q; F& f: P( F底层截图: c( A/ J. D0 ~! R
: P1 _0 ?1 c' t+ V0 P
6 `5 g+ Z% Z% q( Y3 ]5 U, f7 w4 Q
全层截图:5 n2 m' y% c5 J0 M( U
% y" I/ r$ J0 q7 L- u1 {
% a4 t8 c+ Q" L8 l$ Z [' K4 j叠层信息截图如下:+ \9 P& y/ _; B" \2 y
; N! k& s! A2 Z) w8 w( p
7 ]% X9 U0 }2 Q0 g" u$ w* m
BOM:9 E) V" r0 \0 Q" u1 }
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 22uf | C1, C8, C18, C24, C26, C34, C60, C74, C85, C90, C101 | 0805 | 11 | 0.1uf | C2, C3, C4, C5, C6, C7, C9, C10, C11, C12, C13, C14, C15, C16, C19, C20, C21, C22, C23, C27, C28, C29, C30, C31, C32, C33, C36, C37, C38, C39, C40, C41, C42, C43, C46, C47, C48, C54, C55, C56, C57, C58, C59, C61, C64, C65, C66, C69, C70, C71, C72, C75, C76, C77, C78, C80, C81, C82, C83, C84, C86, C87, C88, C89, C91, C92, C93, C94, C95, C96, C97, C98, C99, C100, C102, C103, C115, PC19 | 0402C | 78 | 12pf | C17, C25, C50, C51, C52, C53, C62, C63, C67, C68, C73, C79 | 0402C | 12 | 10uf | C35, C44, C45, PC17 | 0805 | 4 | 1uf | C49, PC16 | 0402C | 2 | 22uf | C104, C105, C109, C110, C111, C112, C113, PC5, PC6, PC11, PC12, PC13, PC22 | CAP1210 | 13 | 220uf | C106, C107, C108, C114 | CD8 | 4 | IN4148 | D1 | 1206d | 1 | FUSE | F1 | 1206 | 1 | 220 | FB1, FB2, FB3, FB4, FB5, FB6, FB7, FB8, FB9, FB10, FB11, FB12 | 0805 | 12 | HDMI_1903015 | J1 | HDMI_1903015 | 1 | 1840750-7 | J2 | TE1840808 | 1 | HEADER1X4 | J3 | HEADER1X4 | 1 | TF | J4 | TF_K | 1 | 1981584-1 | J5, J6, J7 | MicroUsb | 3 | LED | LD1, LD2, LD3, LD4, LD5, LD6, LD7, LD8, LD9, MLD0, MLD1, MLD2, MLD3, MLD4, MLD5, MLD6, MLD7 | 0603D | 17 | HEADER | P1, P2 | H0.8X2X60 | 2 | BNC | P3, P4, P5, P6 | RCA | 4 | HEADER20 | P7 | HEADER10X2X2.5 | 1 | Header 2 | P8 | HDR1X2 | 1 | VAG-15 | P9 | VGA-15 | 1 | HEADER20X2 | P10 | HEADER20X2X2.5 | 1 | DC | P11 | DC5.0 | 1 | 10uf | PC1, PC2, PC4, PC7, PC14 | CAP1210 | 5 | 3.3nf | PC8, PC9, PC10, PC15, PC23, PC24 | 0402c | 6 | 100uf | PC18 | CAP1210 | 1 | 1nf | PC20 | 0402c | 1 | 0.33uf | PC21 | 0402c | 1 | MAX1510ETB | PIC1 | DFN10 | 1 | 2.2uh | PL1, PL2, PL3, PL4, PL5, PL6 | IHLP-2020BZ-01 | 6 | 100K | PR1, PR3, PR5, PR6, PR7, PR9, PR12, PR16, PR18, R66, R67, R69 | RES0402 | 12 | 75k | PR2, PR8 | RES0402 | 2 | 309k | PR4, PR17 | RES0402 | 2 | 130K | PR10, PR13 | RES0402 | 2 | 150k | PR11, PR14, PR15 | RES0402 | 3 | 20K1% | PR20 | RES0402 | 1 | 10K | PR21, PR22, R35, R37, R38, R39, R40, R41, R71, R72, R73, R74, R75, R76 | 0402R | 14 | TPS62130 | PU1, PU2, PU4, PU6 | QFN16N 3X3 | 4 | TPS62140 | PU3, PU5 | QFN16N 3X3 | 2 | NPN | Q1 | SOT-23 | 1 | PNP | Q2 | SOT-23AS | 1 | 22 | R1, R3, R48, R49, R50 | REGX4 | 5 | 75 | R2, R6, R10, R13 | 0402R | 4 | 1K | R4, R5, R7, R8, R32, R98, R99 | 0402R | 7 | Res | R9, R11 | 0603 | 2 | 20R | R12, R14, R54, R55, R77, R78, R83, R84, R89, R91, R92, R100, R101 | 0402R | 13 | 1K5 | R15 | 0402R | 1 | 4.7K | R16, R18, R19 | 0402R | 3 | 2.2k | R17, R20, R21, R22, R23, R24, R25, R26, R27, R28, R29, R30, R31, R51, R52, R53, R56, R58, R59, R60, R61, R62, R63, R64, R65, R79, R85, R93, R94, R95, R97 | 0402R | 31 | 22R | R33, R34, R36 | 0402R | 3 | 4K02 | R43 | 0402R | 1 | 22K6 | R44 | 0402R | 1 | 0 | R45, R46 | 0402R | 2 | 1%2K | R47 | 0402R | 1 | 100R | R70 | 0402R | 1 | 1.5K | R80, R86 | 0402R | 2 | 0R | R81, R82, R87, R88 | 0402R | 4 | 150k | R90 | 0402R | 1 | 22k | R96 | 0402R | 1 | 75R | R102, R103, R104 | 0402R | 3 | SW-1 | SW1, SW2, SW3, SW4, SW5 | SW-3X9 | 5 | SW123 | SW6 | SW1-2-3 -B | 1 | HEADER | TP1, TP2 | HDR1X2 | 2 | TW2867 | U1 | LQFP128 | 1 | sii9134 | U2 | TQFP100 | 1 | VSC8601 | U3 | TQFP64 | 1 | STM32F103R6T6 | U4 | LQFP64_N | 1 | PL2303HXA | U5, U6 | SsOP28 | 2 | CY7C68013A-56PVXI | U7 | O56 | 1 | 24LC128 | U8 | SOP8 | 1 | CS7123 | U9 | LQFP48 | 1 | 27MHZ | Y1 | CY5032 | 1 | 25MHZ | Y2 | CY5032 | 1 | 8MHZ | Y3 | CY5032 | 1 | 12MHZ | Y4, Y5 | CY5032 | 2 | 24MHZ | Y6 | CY5032 | 1 | ! Y% Q# k2 r' ?' q! u
附件:
/ z( g' X) B, r+ Y7 }- N$ z原理图和PCB源文件如下:4 `* ~6 C# {7 Z
6 j; Q% o7 O$ S9 d2 ~2 c8 `
/ W) X$ L/ V+ |) I2 x! n N H7 | |
