作品名:[AD 10][2层] 驱动AT070TN92 LCD的工控板(STM32F103+SSD1963+TPS61040)原理图、PCB源文件- n8 d& j6 |% w# z* K( P# L" L; R
1 y6 O3 l* O" S% n3 R, A# ]文件描述
4 h# F! T+ ?; [: S {1. 作品用途:工控板
# M( R6 ?7 @" k0 w2. 软件版本:AD 101 t/ { N6 e. T9 [9 @
3. 层数:2层板$ s' u. I( j, h0 F$ w# K0 B
4. 用到的主要芯片:STM32F103+SSD1963+TPS61040
" J( d& G5 n1 S$ N4 X5. PCB尺寸:94mm*74mm
, L8 s- x! l; O+ l% q3 X
6 Y/ x* `3 S2 U( R作品截图如下:+ o+ T7 F9 R$ B+ A3 U- R: i$ R
顶层截图:
) i/ I- t( S1 v2 x
3 }& N i# x# j+ ~* Y
底层截图:' r0 Y9 t2 q& `: G: g& T
7 a, i% r" r+ u7 t7 ~9 f& t6 G
全层截图:) M% U! ?' M4 O' h5 N0 A& F
. v; q3 f# U1 U: e( {& X3 R
叠层信息截图如下:; v' B( p( q0 E! o' _3 w* R& R
: K2 n* j3 f0 E" @0 K
BOM:
1 }! i/ ]1 q# d4 NComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | BATTERY | BT1 | BATT | 1 | 20pF | C1, C2, C3, C4, C5, C6 | 0805 | 6 | 1uF/25V | C7, C8, C9 | 1206 | 3 | 104 | C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40, C41, C42, C43, C44, C45, C46, C47, C48, C49, C50, C51, C52, C53, C54, C55 | 0805 | 46 | 105 | C56 | 0805 | 1 | 10uF/25V | C57, C58, C59 | 3528 | 3 | 100pF | C60 | 0805 | 1 | 100uF/16V | C61 | 7343 | 1 | LED | D1 | 0805 | 1 | 1N5819 | D2, D3, D4, D5 | 1206 | 4 | 1N45819 | D6 | 1206 | 1 | 5.6V | D7 | 1206 | 1 | CON10 | J1 | IDC10 | 1 | CON2 | J2 | SIPW2 | 1 | CON4 | J3, J4, J5 | FPC4/1.0 | 3 | CON3 | J6 | DIP3P | 1 | 10uH | L1, L2 | 3528 | 2 | 100uH | L3 | l7X7 | 1 | AT070TN92 | LCD1, LCD2, LCD3 | FPC50 | 3 | MINI_USB | MiniUSB1 | MINIUSB | 1 | PNP1 | Q1 | SOT23 | 1 | NPN1 | Q2 | SOT23 | 1 | 5K1 | R1 | 0805 | 1 | 0 | R2, R3, R4, R5 | 0805 | 4 | 1K2 | R6 | 0805 | 1 | 100 | R7, R8, R9, R10 | 0805 | 4 | 10K | R11, R12, R13, R14 | 0805 | 4 | 2M | R15 | 0805 | 1 | 27K | R16 | 0805 | 1 | 3.3K | R17 | 0805 | 1 | 2K | R18 | 0805 | 1 | 0.22 | R19 | 0805 | 1 | 20K | R20 | 0805 | 1 | 2K7 | R21 | 0805 | 1 | 47K | R22, R23 | 0805 | 2 | 27 | R24, R25 | 0805 | 2 | 1K5 | R26, R27 | 0805 | 2 | 120K | R28 | 0805 | 1 | 1K8 | R29 | 0805 | 1 | STM32F103VCT6 | U1 | TQFP100 | 1 | SSD1963QL9 | U2 | TQFP128/0.4 | 1 | TPS61040 | U3, U4 | SOT23-5 | 2 | ADS7843 | U5 | TSSOP16 | 1 | AT45DB161D | U6 | SOIC8 | 1 | MC34063A | U7 | SO-8 | 1 | MAX232CE | U8 | SO-16 | 1 | MAX809TD | U9 | SOT23 | 1 | LM1117 | U10 | SOT223 | 1 | SG2001-1.2 | U11 | SOT23-5 | 1 | 12M | Y1, Y2 | CY3X7 | 2 | 32768 | Y3 | M3X8 | 1 | | | | | 附件:6 z# O! J u* I" }
原理图和PCB源文件如下:& @$ W: V; g- ]7 I3 X
# d4 I% }" x" I& V* l
+ E" d- v3 [8 d |
