查看: 621|回复: 2
[allegro17.2][4层]采用BCM20737A1KML2G设计的BCM92073X_LE_TAG4 Evaluation and D...
发表于 2020-1-15 16:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]采用BCM20737A1KML2G设计的BCM92073X_LE_TAG4 Evaluation and Debug Kit(3002TR+BCM20737A1KML2G+CP2105-F01-GM)原理图和pcb文件
文件描述:
1. 作品用途:采用BCM20737A1KML2G设计的BCM92073X_LE_TAG4 Evaluation and Debug Kit
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:3002TR+BCM20737A1KML2G+CP2105-F01-GM
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BATHS3_KEY_3002QBATTERY-HOLDER-P2N1_BATHS3_KEY_3002Q_DISCRETE_4.2100 MM_3002TR3002TRDISCRETE1ZB1
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6350 MM_0.1UF0.1uFDISCRETE12C2; C3; C4; C5; C29; C36; C37; C38; C43; C48; C56; C57
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_2.2UF2.2uFDISCRETE1C8
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1UF1uFDISCRETE1C9
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.01UF0.01uFDISCRETE4C10; C12; C13; C32
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_10PF10pFDISCRETE1C11
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF1.8pFDISCRETE2C14; C15
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_1.8PF (DNI)1.8pF (DNI)DISCRETE2C16; C17
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6100 MM_15PF15pFDISCRETE2C18; C19
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_12PF12pFDISCRETE2C20; C21
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_150PF150pFDISCRETE1C22
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.7000 MM_10UF10uFDISCRETE5C25; C34; C44; C49; C55
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.5500 MM_0.1UF0.1uFDISCRETE2C26; C54
CAPC1005_IS0402QCAP_CAPC1005_IS0402Q_DISCRETE_0.6500 MM_4.7UF4.7uFDISCRETE1C35
CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9000 MM_4.7UF4.7uFDISCRETE2C1; C23
CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_1.0000 MM_10UF10uFDISCRETE1C24
CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9500 MM_4.7UF4.7uFDISCRETE1C28
CAPC1608_IS0603QCAP_CAPC1608_IS0603Q_DISCRETE_0.9500 MM_10UF10uFDISCRETE2C30; C31
CAPC2012_IS0805QCAP_CAPC2012_IS0805Q_DISCRETE_1.4500 MM_33UF33uFDISCRETE2C6; C7
CTST200PSS2HDR1X2-J_CTST200PSS2_IO_6.3500 MM_NRPN021PAEN-RCNRPN021PAEN-RCIO1J12
CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9S-M-.100-2X9IO1J10
CTST254PDS18PLG-18-ODD-EVEN-J_CTST254PDS18_IO_8.8900 MM_S-M-.100-2X9 (DNI)S-M-.100-2X9 (DNI)IO2J11; J13
CTST254PSS4PLG-4-J_CTST254PSS4_IO_8.8900 MM_PBC04SAANPBC04SAANIO3J2; J8; J9
FUSC1005_IS0402QDIO-TVS-BIPOLAR-2_FUSC1005_IS0402Q_DISCRETE_0.6000 MM_10V10VDISCRETE4D4; D5; D6; D7
INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_120OHMS120OhmsDISCRETE2FB1; FB2
INDC1005_IS0402QFB_INDC1005_IS0402Q_DISCRETE_0.6000 MM_600OHMS600OhmsDISCRETE1FB3
INDC1005_IS0402QIND-DOT-1_INDC1005_IS0402Q_DISCRETE_0.3500 MM_2.7NH2.7nHDISCRETE1R24
INDS2_MUR_LQM21NQIND_INDS2_MUR_LQM21NQ_DISCRETE_1.4500 MM_4.7UH4.7uHDISCRETE1L2
INDS2_TDK_VLS201610CXQIND-SHIELDED-NO-DOT_INDS2_TDK_VLS201610CXQ_DISCRETE_1.0000 MM_10UH10uHDISCRETE1L1
IPX_20279-001E-01RF-2GND-J_IPX_20279-001E-01_IO_1.2450 MM_20279-001E-0420279-001E-04IO1J1
LEDC1608QDIO-LED_LEDC1608Q_0.9000 MM_LTST-C190CKTLTST-C190CKTIC1D1
LEDS4_KING_APTB1615QLED-DUAL-RED1-GRN2_LEDS4_KING_APTB1615Q_DISCRETE_0.9000 MM_APTB1615SURKCGKC-F01APTB1615SURKCGKC-F01DISCRETE1D3
LGA43P350X300_24_ST-LGA24NLSM9DS1-LGA24_LGA43P350X300_24_ST-LGA24N_IC_1.0270 MM_LSM9DS1LSM9DS1IC1U7
LGA50P300X300_16_ST-LGA16NLIS3DSH-LGA16_LGA50P300X300_16_ST-LGA16N_IC_1.0000 MM_LIS3DSHLIS3DSHIC1U11
LGA50P300X300_16_ST-LGA16NLPS331AP-LGA16_LGA50P300X300_16_ST-LGA16N_IC_1.1500 MM_LPS331APTRLPS331APTRIC1U12
MODS6_ST_HLGA-6LNHTS221-LGA6_MODS6_ST_HLGA-6LN_IC_1.0000 MM_HTS221HTS221IC1U8
QFN50P400X400_24_HS280NUSB-CP2105-QFN24H_QFN50P400X400_24_HS280N_IC_0.8000 MM_CP2105-F01-GMCP2105-F01-GMIC1U6
QFN50P500X500_32_HS370_BCMBCM20736A1KML2G-W1000-27301_QFN50P500X500_32_HS370_BCM_IC_1.0000 MM_BCM20737A1KML2GBCM20737A1KML2GIC1U2
QFN60P250X250_10_ST-LGA-10LNUVIS25-QFN10_QFN60P250X250_10_ST-LGA-10LN_IC_0.8000 MM_UVIS25UVIS25IC1U10
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K10KDISCRETE19R1; R8; R15; R16; R17; R23; R30; R31; R32; R33; R40; R41; R42; R43; R46; R53; R54; R57; R58
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_00DISCRETE17R2; R3; R4; R5; R9; R13; R25; R34; R35; R39; R44; R45; R47; R48; R50; R51; R59
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_1K1KDISCRETE2R6; R7
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_100K100KDISCRETE2R10; R52
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_470470DISCRETE1R11
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10K (DNI)10K (DNI)DISCRETE1R12
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_5.6K5.6KDISCRETE1R14
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_4.7K4.7KDISCRETE2R18; R19
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_200200DISCRETE3R22; R60; R61
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_0 (DNI)0 (DNI)DISCRETE2R26; R27
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_10M10MDISCRETE1R28
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_300K300KDISCRETE1RFB1
RESC1005_IS0402QRES_RESC1005_IS0402Q_DISCRETE_0.4000 MM_240K240KDISCRETE1RFB2
RESC1005_IS0402Q_OPT_ABRES-OPT-B-A_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00DISCRETE2RD5; RD6
RESC1005_IS0402Q_OPT_ABRES-OPT-A-B_RESC1005_IS0402Q_OPT_AB_DISCRETE_0.4000 MM_00DISCRETE1RD7
RESC1608_IS0603QRES_RESC1608_IS0603Q_DISCRETE_0.6000 MM_00DISCRETE1R29
SNSRS4_ROHM_WLGA041W02QBH1780-DFN4_SNSRS4_ROHM_WLGA041W02Q_IC_0.8000 MM_BH1780GLI-E2BH1780GLI-E2IC1U13
SOIC127P780_8_D530NMX25LXXX-DIL8_SOIC127P780_8_D530N_IC_1.7500 MM_MX25L8006EM2I-12GMX25L8006EM2I-12GIC1U3
SON50P200X180_6_USP-6CQXC9236-ADJ-DFN6H_SON50P200X180_6_USP-6CQ_IC_0.6100 MM_XC9236_ADJXC9236_ADJIC1U5
SON50P250X250_8_HS120X020_PRELIMLTC4313-DIL8_0_SON50P250X250_8_HS120X020_PRELIM_IC__DEEP_CHIP (DNI)DEEP_CHIP (DNI)IC1U14
SON55P200X180_6_USP-6ELQXC9265-DFN6H_SON55P200X180_6_USP-6ELQ_IC_0.4000 MM_XC9265B1214R-GXC9265B1214R-GIC1U4
SOT23_B_E_CNPN_SOT23_B_E_C_DISCRETE_1.5600 MM_2SC2712-Y,LF2SC2712-Y,LFDISCRETE1Q1
SOT883_SC-101FET-MOS-N-GSD_SOT883_SC-101_DISCRETE_0.4000 MM_PMZB290UNPMZB290UNDISCRETE1Q3
SPKRS2_MUR_PKLCS1212QSPEAKER_SPKRS2_MUR_PKLCS1212Q_IO_3.0000 MM_PKLCS1212E4001-R1PKLCS1212E4001-R1IO1LS1
SWDPS8_OMRON_A6H-4102SW-DIP-4_SWDPS8_OMRON_A6H-4102_DISCRETE_1.9500 MM_A6H-4101A6H-4101DISCRETE1SW6
SWDPS16_ITT_TDA08H0SK1SW-DIP-8_SWDPS16_ITT_TDA08H0SK1_DISCRETE_2.3000 MM_TDA08H0SB1TDA08H0SB1DISCRETE1SW8
SWPBS4_CK_KMR2XXGSWITCH-PB-13-24_SWPBS4_CK_KMR2XXG_DISCRETE_2.1000 MM_KMR221GLFSKMR221GLFSDISCRETE3SW1; SW2; SW3
SWSLS3_ALPS_SSSS811101SWITCH-SPDT-CP2NC3NO1-4SHLD_SWSLS3_ALPS_SSSS811101_DISCRETE_1.4000 MM_SSSS811101SSSS811101DISCRETE2SW4; SW5
TP_SMD_030RDTP_TP_SMD_030RD_IO__TP-SMT-030-RNDTP-SMT-030-RNDIO12TP5; TP6; TP8; TP9; TP10; TP14; TP15; TP18; TP19; TP20; TP21; TP22
TRACEINV_F_ANTENNA_1_TRACE_INV_F_ANTENNAINV_F_ANTENNAIC1A1
TSOP65P490_8_D300NLTC4313-DIL8_TSOP65P490_8_D300N_IC_1.1000 MM_LTC4313IMS8-1_PBFLTC4313IMS8-1_PBFIC1U9
TSOP65P640_8_D300N24XX512-DIL8_TSOP65P640_8_D300N_IC_1.2000 MM_24FC512-I/ST24FC512-I/STIC1U1
TYCO_1981568-1USB-5P-6SH-J_TYCO_1981568-1_IO_2.5100 MM_1981568-11981568-1IO1J7
XTALS2_ABR_ABS07QXTAL_XTALS2_ABR_ABS07Q_DISCRETE_0.9000 MM_0.03277MHZ0.03277MHzDISCRETE1Y2
XTALS4_3M2X2M5XTAL-1G3G_XTALS4_3M2X2M5_DISCRETE_0.9000 MM_24.000MHZ24.000MHzDISCRETE1Y1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
3 ]9 r! I9 A/ E4 ]8 h7 Y/ H. N# A& n
    2024-8-26 15:16
    发表于 2020-10-19 14:41 | 只看该作者
    支持蓝牙吗?; y" p- @6 \3 q% S0 D2 c
    2023-6-5 15:45
    发表于 2020-11-29 14:39 | 只看该作者
    下载看一下
    GMT+8, 2025-9-14 02:40 , Processed in 0.140625 second(s), 28 queries , Gzip On.
