作品名:[AD 10][2层]开发板(STM32F103CBT6+LD39050PU33R+LD3985M33R)原理图和PCB源文件
" x* Z: r% J- j! A8 [/ S5 `' W. D* `# L
文件描述
" N& ~* g1 c& K2 d& g: f
6 {4 X& _9 Z* [! g' S% ?4 ]1. 作品用途:开发板
% L' `" [4 v- U2 G( k0 s: j! c7 l+ r* C- Z% n
2. 软件版本:AD 10* t# Z( }4 d, _& M) ^
" ~! Q S. H/ J! |' `0 k+ B3. 层数:2层板
% e4 j% z6 Q3 W) _' F
) e K$ Q# e/ c2 r5 g4. 用到的主要芯片:STM32F103CBT6+LD39050PU33R+LD3985M33R' [& O9 @! z/ i3 A/ i2 s
/ D$ N& J- Z# K' @
5. PCB尺寸:82.5mm*70mm
2 ]2 H$ c8 k \5 C# y6 M9 ^& S. }9 R
' l# w5 Q) F j4 ~9 q9 O* j& V' m
作品截图如下:5 T* w u5 b5 M$ u' W0 N" ? h
/ |. z! z. L7 B% P1 V顶层截图:* \3 _8 o7 S2 g: m+ M
* f5 z- m' E! G& r% O3 j
. n( V1 }7 G& i$ r* O. f1 ^/ ~7 s/ F底层截图:: w" s7 B1 o+ o# Q
7 a: M; j" F) R5 q
+ c6 l- Q ^/ g, O全层截图:4 V i/ M! h$ B7 o- W8 R' T0 ^
R# `% a1 O' G ?' N' G' ^! V$ `2 r1 f8 M7 @: z
叠层信息截图如下:: K3 t; }2 B* ?7 V& ~
! r6 x9 n7 A: u' q8 R3 u3 ~' _8 ?3 f% N& u1 i
BOM:$ T: I. W b- I+ K+ K( {4 U: b
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | USER (Blue) | B1 | PB10 | 1 | TD-0341 [RESET/Black] | B2 | PB10 | 1 | 100nF | C1, C4, C5, C6, C7, C11, C12, C14, C15, C19, C20, C23, C24, C27, C28, C30 | 0603C | 16 | 1uF_X5R_0603 | C2, C13, C18, C21, C29 | 0603C | 5 | 20pF | C3, C8, C10 | 0603C | 3 | 10nF_X7R_0603 | C9 | 0603C | 1 | 10uF(25V) | C16 | TAN-B | 1 | 10uF | C17 | TAN-A | 1 | 2.2uF | C22, C25, C26 | TAN-A | 3 | 10pF[N/A] | C31, C32 | 0603C | 2 | 20pF[N/A] | C33, C34 | 0603C | 2 | 5075BMR-05-SM | CN1 | USB-MINI-B-SMD | 1 | Header 4 | CN2 | 1*4 | 1 | | CN3, CN11, CN12, JP1, JP4, JP6 | SIP2/2.54 | 6 | Header 6X1 | CN4 | 1*6P | 1 | Header 10X1_Female | CN5 | 1*10P_FEMALE | 1 | Header 8X1_Female | CN6, CN9 | 1*8P_FEMALE | 2 | Header 19X2 | CN7, CN10 | 2*19P | 2 | Header 6X1_Female | CN8 | 1*6P_FEMALE | 1 | BAT60JFILM | D1, D2, D3 | SOD323/A | 3 | STPS2L30A | D4 | SMA | 1 | Comment | Designator1 | NUCLEO_black 0.5cm | 1 | Comment | Designator2 | LOGO ESD | 1 | Comment | Designator4 | NUCLEO_black 2cm | 1 | Comment | Designator22 | ST_LOGO_10mm | 1 | | JP5 | SIP3 | 1 | BEAD | L1 | 0603L | 1 | LD_BICOLOR_CMS | LD1 | HSMF-A201 | 1 | Green | LD2 | 0603D | 1 | RED | LD3 | 0603D | 1 | 10K | R1, R2, R3, R12, R26, R33 | 0603R | 6 | 4K7 | R4, R23, R27, R28, R30 | 0603R | 5 | 22 | R5, R8, R13, R22 | 0603R | 4 | 100K | R6, R14, R15 | 0603R | 3 | 2K7 | R7 | 0603R | 1 | 100 | R9, R11, R20, R21, R24, R25, R29 | 0603R | 7 | 36K | R10 | 0603R | 1 | 1K5 | R16 | 0603R | 1 | 0 | R17, R18, R19 | 0603R | 3 | 510 | R31 | 0603R | 1 | 1K | R32 | 0603R | 1 | [N/A] | R34, R35, R36, R37 | 0603R | 4 | Circuit Breaker | SB1, SB2, SB3, SB4, SB5, SB6, SB7, SB8, SB9, SB10, SB11, SB12, SB13, SB14, SB15, SB16, SB17, SB18, SB19, SB20, SB21, SB22, SB23, SB24, SB25, SB26, SB27, SB28, SB29, SB30, SB31, SB32, SB33, SB34, SB35, SB36, SB37, SB38, SB39, SB40, SB41, SB42, SB43, SB44, SB45, SB46, SB47, SB48, SB49, SB50, SB51, SB52, SB53, SB54, SB55, SB56, SB57, SB58, SB59, SB60, SB61, SB62, SB63, SB64, SB65 | JP2_SMD | 65 | 9013 | T1 | SOT-23 | 1 | STS7PF30L | T2 | SO8 | 1 | LD3985M33R | U1 | SOT-23-5L | 1 | STM32F103CBT6 | U2 | QFP48 7X7 | 1 | LD1117S50TR | U3 | SOT-223 | 1 | LD39050PU33R | U4 | DFN6(3X3) | 1 | mcu_LQFP64 | U5 | LQFP64 | 1 | 8MHz(12pF) | X1 | XTAL1 | 1 | 32.768K[N/A] | X2 | XTAL_4SM_8X3R8 | 1 | 8MHz(16pF)[N/A] | X3 | XTAL1 | 1 |
: y6 a2 i6 L0 a& k; k附件:# j! H7 m" Q, X' `) s( t( E2 q! w
! R$ j6 k/ B X( {) T
原理图和PCB源文件如下:
7 D8 W9 d3 [$ s {: m. b, P' b" \: L) K( M2 ]6 [
0 p8 S d" G2 E) P+ W1 i
2 [$ g9 ]* Z8 i/ t
8 f* t4 D3 Z5 a" m) p" `
