Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C335_RAD | CAP_POL_C335_RAD_DISCRETE_7MM_1 | 270uF | DISCRETE | 2 | C17; C18 |
CAP_ALEL_10X10MM_SMT | CAP_POL_CAP_ALEL_10X10MM_SMT_DI | 150UF | DISCRETE | 1 | C15 |
CASE403A_03 | DIODE_CASE403A_03_IC_2.62MM_480 | MURS120T3 | IC | 1 | D1 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.95M | 0.1uF | DISCRETE | 7 | C2; C5; C7; C11; C12; C14; C21 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | DISCRETE | 2 | C8; C20 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.35M | 1uF | DISCRETE | 1 | C16 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.94M | 470PF | DISCRETE | 1 | C22 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 470PF | DISCRETE | 1 | C23 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.35 | 0.1UF | DISCRETE | 4 | C25; C27; C28; C29 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 1uF | DISCRETE | 1 | C24 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8_1 | 10uF | DISCRETE | 1 | C26 |
CCE50X54 | CAP_POL_CCE50X54_DISCRETE_5.4MM | 47UF | DISCRETE | 2 | C3; C4 |
CCE50X54 | CAP_POL_CCE50X54_DISCRETE_5.5MM | 47UF | DISCRETE | 1 | C6 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J5 |
CON2_TB_5MM | TB2_CON2_TB_5MM_IO_10.0MM_210-7 | CON_2_TB | IO | 1 | J2 |
CON3_TB_5MM | TB3_CON3_TB_5MM_IO_10MM_210-776 | CON_3_TB | IO | 1 | J4 |
CR492_315 | CAP_POL_CR492_315_DISCRETE_12.5 | 100uf | DISCRETE | 1 | C1 |
D2PAK_A | MOSFET_N3_D2PAK_A_IC_4.957MM_48 | IRL3714ZSPbF | IC | 1 | Q8 |
DD_PAK_2P3MM | MOSFET_P_DD_PAK_2P3MM_IC_2.4MM_ | FQD11P06 | IC | 1 | Q9 |
DO-213AB | DIODE_DO-213AB_IC_2.67 MM_480-7 | RGL41J | IC | 2 | D21; D22 |
HSMX-C170 | LED_HSMX-C170_IC_0.8MM_370-7578 | HSMY-C170 | IC | 1 | D4 |
HSMX-C170 | LED_HSMX-C170_IC_0.9 MM_370-300 | HSMG-C170 | IC | 6 | D5; D6; D7; D10; D11; D12 |
IND2_8X8 | INDUCTOR_IND2_8X8_DISCRETE_3.5M | 100UH | DISCRETE | 1 | L1 |
IND_18P7X18P7 | INDUCTOR_IND_18P7X18P7_DISCRETE | 10UH | DISCRETE | 1 | L6 |
IND_2012 | INDUCTOR_IND_2012_DISCRETE_0.85 | 1uH | DISCRETE | 2 | L3; L4 |
LED_2P_0805 | LED_LED_2P_0805_IC_0.9MM_370-76 | RED | IC | 2 | D8; D9 |
RAPC722 | DC_POWER_JACK_3_RAPC722_IO_11.0 | CON_1_PWR | IO | 1 | J1 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7595 | 1.0M | DISCRETE | 1 | R1 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7557 | 270 | DISCRETE | 6 | R2; R3; R5; R7; R8; R9 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7598 | 1.0K | DISCRETE | 3 | R4; R6; R10 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7590 | 10K | DISCRETE | 10 | R11; R15; R16; R19; R20; R21; R33; R35; R36; R38 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7660 | 100 | DISCRETE | 8 | R23; R27; R42; R43; R44; R45; R46; R47 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7561 | 3.3K | DISCRETE | 2 | R24; R28 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-3004 | 20K | DISCRETE | 2 | R25; R29 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8010 | 15 OHM | DISCRETE | 1 | R26 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8002 | 9.09k | DISCRETE | 1 | R32 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7546 | 1.0K | DISCRETE | 1 | R34 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7593 | 22 | DISCRETE | 2 | R37; R41 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-75_1 | 100K | DISCRETE | 2 | R39; R40 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-7554 | 100 | DISCRETE | 1 | R30 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-8047 | 4.7 | DISCRETE | 1 | R31 |
SO8 | MC33269D_SO8_IC_1.75MM_315-7826 | MC33269D_3.3 | IC | 1 | U3 |
SO8_1P27_4X5 | MOSFET_N_SO8_SO8_1P27_4X5_IC_1. | IRF8734PbF | IC | 2 | Q2; Q7 |
SO8_1P27_4X5 | MOSFET_N_SO8_SO8_1P27_4X5_IC__1 | IRF7855PbF | IC | 4 | Q3; Q4; Q5; Q6 |
SO8_1P27_4X5 | MC33269D_SO8_1P27_4X5_IC_1.75MM | MC33269DR2-5.0G | IC | 1 | U2 |
SO8_1P27_4X5 | MIC4224_SO_8P_SO8_1P27_4X5_IC_1 | MIC4224YM | IC | 1 | U6 |
SO20W | HIP4081A_SO_20P_SO20W_IC_2.65MM | HIP4081AIBZ | IC | 1 | U7 |
SOD-323-A | DIODE_SCHTKY_SOD-323-A_IC_1.1 M | RB751V40T1G | IC | 2 | D15; D20 |
SOIC8 | LM2594_SO8_SOIC8_IC_1.75MM_315- | LM2594HVM-12 | IC | 1 | U1 |
SOT23-5 | OPAMP_5P_SOT23-5_IC_1.45 MM_TMP | MCP6021T | IC | 1 | U8 |
SOT-23 | DUALDIODE_SERIES_SOT23_SOT-23_I | BAT54S | IC | 2 | D18; D19 |
TSSOP-14 | 74_04_TSSOP-14_IC_1.2MM_312-753 | SN74LVC04APWE4 | IC | 1 | U4 |
XFMR12_148_1272X1064 | 750342182_XFMR_12P_XFMR12_148_1 | 750342182 | IC | 1 | T1 |
XFMR_CST2 | XFMR_CST2_XFMR_CST2_IC_5.3 MM_5 | CST2-125L | IC | 1 | T2 |
