查看: 291|回复: 0
[allegro17.2][4层]TWR-KW24D5122.4 GHz 802.15.4无线连接(PK20DX128VFM5+PB swit...
发表于 2020-1-14 16:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]TWR-KW24D5122.4 GHz 802.15.4无线连接(PK20DX128VFM5+PB switch+TPS63001)原理图和pcb文件
文件描述:
1. 作品用途:TWR-KW24D5122.4 GHz 802.15.4无线连接
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:PK20DX128VFM5+PB switch+TPS63001
5. PCB尺寸:3543*3175 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLPIC3U10; U11; U12
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UFDISCRETE7C4; C12; C13; C14; C29; C36; C42
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.33UFDISCRETE2C7; C16
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.555pFDISCRETE4C8; C10; C44; C47
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M1000pFDISCRETE4C9; C11; C43; C46
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_133PFDISCRETE1C15
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_210PFDISCRETE3C17; C18; C20
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_21.8pFDISCRETE1C19
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_312PFDISCRETE4C21; C22; C23; C24
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_41PFDISCRETE1C25
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE3C26; C49; C50
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE2C28; C33
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_322PFDISCRETE2C30; C31
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PFDISCRETE2C35; C48
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_410PFDISCRETE1C45
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.2_12.2UFDISCRETE1C32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE1C34
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE3C1; C2; C3
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J16
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO1J6
CON5_USB_RA_SMTUSB_MINI_AB_RECEPTACLE_CON5_USBCONN USB MINI-BIO1J15
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO1J13
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J11
CON_SMA_EDGE_062SMB_CON_SMA_EDGE_062_IO_4.08 MMSMAIO1J4
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J9; J10
F_ANTENNA_DIG528-2F_ANTENNA_F_ANTENNA_DIG528-2_ICF_AntennaIC1ANT1
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2IO4J5; J28; J29; J30
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO3J8; J12; J27
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO5J3; J19; J20; J21; J24
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3IO2J1; J2
HDR304HDR_3X4_HDR304_IO_8.58MM_210-79HDR 3X4IO2J17; J18
IND_0402INDUCTOR_IND_0402_DISCRETE_0.552.2nHDISCRETE1L5
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE3L4; L6; L7
IND_0805BEAD_IND_0805_DISCRETE_1.05 M_1330 OHMDISCRETE1L8
IND_IHLP_2020INDUCTOR_IND_IHLP_2020_DISCRETE3.3uHDISCRETE1L1
LED2_2P34_2P1X1P25LED_LED2_2P34_2P1X1P25_IC_0.9MMBLUEIC4D5; D6; D7; D8
LED0805LED_LED0805_IC_0.9MM_370-76462_GREENIC1D4
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D9
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D11
LGA63_0P5_8X8MKW22D_LGA_63P_LGA63_0P5_8X8_ICMKW24D512VIC1U3
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPPK20DX128VFM5IC1U6
QFN_10_0P5_3X3TPS63001_QFN_10_0P5_3X3_1MM_315TPS63001IC1U1
RC0402_25RES_RC0402_25_DISCRETE_470-75390DISCRETE41R1; R2; R4; R6; R8; R15; R20; R27; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R561; R564; R566
RC0402_25RES_RC0402_25_DISCRETE_470-3032200KDISCRETE1R5
RC0402_25RES_RC0402_25_DISCRETE_470-75_14.7KDISCRETE3R7; R21; R22
RC0402_25RES_RC0402_25_DISCRETE_470-755510KDISCRETE1R9
RC0402_25RES_RC0402_25_DISCRETE_470-7561330DISCRETE1R10
RC0402_25RES_RC0402_25_DISCRETE_470-75360DISCRETE4R13; R14; R94; R95
RC0402_25RES_RC0402_25_DISCRETE_470-7562390DISCRETE4R16; R17; R18; R19
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE4R23; R24; R25; R26
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__2330DISCRETE1R46
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE2R50; R51
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__31.0KDISCRETE7R88; R89; R90; R91; R92; R93; R551
RC0402_25RES_RC0402_25_DISCRETE_470-760627KDISCRETE2R106; R112
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE8R108; R110; R552; R553; R554; R555; R563; R565
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_415KDISCRETE1R109
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_41KDISCRETE1R111
RC0402_25RES_RC0402_25_DISCRETE_470-7624100KDISCRETE1R562
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE2L2; L3
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_41.0MDISCRETE1R12
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_33DISCRETE2R33; R34
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_14.7KDISCRETE1R52
RC0603_OVRES_RC0603_OV_DISCRETE_470-754110KDISCRETE4R100; R105; R107; R560
RC0603_OVRES_RC0603_OV_DISCRETE_470-3029220DISCRETE1R104
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC4D12; D13; D14; D15
SO8_1P27_4X5AT45DB041D-SU_SO8_1P27_4X5_IC_1AT45DB161E-SSHDIC1U13
SOD123DIODE_SCHTKY_SOD123_IC_1.45MM_4MBR0520LT1GIC3D1; D2; D3
SOD-923FDIODE_SOD-923F_IC_0.55MM_TMP-WFCDSQR400BIC1D16
SOT23NPN_SOT23_IC_1.11 MM_480-75151_MMBT2484LIC1Q2
SOT23-6TXB0101_6P_SOT23-6_IC_1.45 MM_3TXS0101IC1U14
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U7
SOT23_ADIODE_2LINE_ESD_SOT23_A_IC_1.15GSOT05C-GS08IC1U8
SOT-23MOSFET_P_SOT-23_1.12MM_480-7791SI2305IC1Q1
SSOP1474-125_14P_SSOP14_IC_2MM_312-7974LVC125ADBIC1U4
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC5SW1; SW2; SW3; SW4; SW6
SW_6P_11X7P31MMSW_6P_SW_6P_11X7P31MM_IC_7.7MM_DPDT SWITCHIC1SW5
TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOPIO3TL1; TL2; TL3
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO13TP100; TP101; TP102; TP103; TP105; TP106; TP107; TP108; TP508; TP509; TP510; TP511; TP512
TPAD_040TESTLOOP_TPAD_040_0.1MM_211-766TPAD_040IC19TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP9; TP10; TP11; TP12; TP14; TP15; TP16; TP17; TP21; TP22; TP27; TP104
TPAD_040TESTLOOP_TPAD_040_IO_0.1MM_211-TPAD_040IO5TP500; TP501; TP502; TP504; TP506
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM_21TESTLOOP_BLACKIO3TP25; TP26; TP507
XFMR_HHM1525_2X1_25MM_6PLDB_21_XFMR_HHM1525_2X1_25MM_6P2400MHz 50OHMIC1Z1
XTAL2-3P2X1P5-SMCRYSTAL_XTAL2-3P2X1P5-SM_IC_0.932.768KHZIC1Y2
XTLOSC4_3P2X2P5MM_SMXTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I32MHZIC1Y1
XTLOSC4_5X3MM_SMCRYSTAL_JXS63_XTLOSC4_5X3MM_SM_8MHZIC1Y3
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
& J8 A. f6 M$ P" N7 H! K' t
GMT+8, 2025-7-21 22:22 , Processed in 0.156250 second(s), 29 queries , Gzip On.
