Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | IC | 3 | U10; U11; U12 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | DISCRETE | 7 | C4; C12; C13; C14; C29; C36; C42 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.33UF | DISCRETE | 2 | C7; C16 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 5pF | DISCRETE | 4 | C8; C10; C44; C47 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 1000pF | DISCRETE | 4 | C9; C11; C43; C46 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 33PF | DISCRETE | 1 | C15 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 10PF | DISCRETE | 3 | C17; C18; C20 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 1.8pF | DISCRETE | 1 | C19 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 12PF | DISCRETE | 4 | C21; C22; C23; C24 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 1PF | DISCRETE | 1 | C25 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | DISCRETE | 3 | C26; C49; C50 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | DISCRETE | 2 | C28; C33 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 22PF | DISCRETE | 2 | C30; C31 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 47PF | DISCRETE | 2 | C35; C48 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_4 | 10PF | DISCRETE | 1 | C45 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C27 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.2_1 | 2.2UF | DISCRETE | 1 | C32 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | DISCRETE | 1 | C34 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 10UF | DISCRETE | 3 | C1; C2; C3 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWER SYSTEM | IO | 1 | J16 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | IO | 1 | J6 |
CON5_USB_RA_SMT | USB_MINI_AB_RECEPTACLE_CON5_USB | CONN USB MINI-B | IO | 1 | J15 |
CON_2RH_10_50 | CONN_HDR_5X2_CON_2RH_10_50_IO_3 | HDR 2X5 | IO | 1 | J13 |
CON_FTSH_19M_50_SM | CONN_HDR_19_CON_FTSH_19M_50_SM_ | HDR_19P | IO | 1 | J11 |
CON_SMA_EDGE_062 | SMB_CON_SMA_EDGE_062_IO_4.08 MM | SMA | IO | 1 | J4 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | IO | 2 | J9; J10 |
F_ANTENNA_DIG528-2 | F_ANTENNA_F_ANTENNA_DIG528-2_IC | F_Antenna | IC | 1 | ANT1 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | IO | 4 | J5; J28; J29; J30 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71 MM_ | HDR 1X2 TH | IO | 3 | J8; J12; J27 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 5 | J3; J19; J20; J21; J24 |
HDR203 | CONN_HDR_3X2_HDR203_IO_8.5MM_21 | HDR 2X3 | IO | 2 | J1; J2 |
HDR304 | HDR_3X4_HDR304_IO_8.58MM_210-79 | HDR 3X4 | IO | 2 | J17; J18 |
IND_0402 | INDUCTOR_IND_0402_DISCRETE_0.55 | 2.2nH | DISCRETE | 1 | L5 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 3 | L4; L6; L7 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 M_1 | 330 OHM | DISCRETE | 1 | L8 |
IND_IHLP_2020 | INDUCTOR_IND_IHLP_2020_DISCRETE | 3.3uH | DISCRETE | 1 | L1 |
LED2_2P34_2P1X1P25 | LED_LED2_2P34_2P1X1P25_IC_0.9MM | BLUE | IC | 4 | D5; D6; D7; D8 |
LED0805 | LED_LED0805_IC_0.9MM_370-76462_ | GREEN | IC | 1 | D4 |
LED_0603 | LED_LED_0603_IC_0.8MM_370-75080 | ORANGE | IC | 1 | D9 |
LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | IC | 1 | D11 |
LGA63_0P5_8X8 | MKW21D_LGA_63P_LGA63_0P5_8X8_IC | MKW21D256V | IC | 1 | U3 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | PK20DX128VFM5 | IC | 1 | U6 |
QFN_10_0P5_3X3 | TPS63001_QFN_10_0P5_3X3_1MM_315 | TPS63001 | IC | 1 | U1 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | DISCRETE | 41 | R1; R2; R4; R6; R8; R15; R20; R27; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R561; R564; R566 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3032 | 200K | DISCRETE | 1 | R5 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-75_1 | 4.7K | DISCRETE | 3 | R7; R21; R22 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7555 | 10K | DISCRETE | 1 | R9 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7561 | 330 | DISCRETE | 1 | R10 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 0 | DISCRETE | 4 | R13; R14; R94; R95 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7562 | 390 | DISCRETE | 4 | R16; R17; R18; R19 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 10.0K | DISCRETE | 4 | R23; R24; R25; R26 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 330 | DISCRETE | 1 | R46 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | DISCRETE | 2 | R50; R51 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 1.0K | DISCRETE | 7 | R88; R89; R90; R91; R92; R93; R551 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7606 | 27K | DISCRETE | 2 | R106; R112 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 10.0K | DISCRETE | 8 | R108; R110; R552; R553; R554; R555; R563; R565 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 15K | DISCRETE | 1 | R109 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 1K | DISCRETE | 1 | R111 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7624 | 100K | DISCRETE | 1 | R562 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 2 | L2; L3 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55MM_4 | 1.0M | DISCRETE | 1 | R12 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 33 | DISCRETE | 2 | R33; R34 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-75_1 | 4.7K | DISCRETE | 1 | R52 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | DISCRETE | 4 | R100; R105; R107; R560 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3029 | 220 | DISCRETE | 1 | R104 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | IC | 4 | D12; D13; D14; D15 |
SO8_1P27_4X5 | AT45DB041D-SU_SO8_1P27_4X5_IC_1 | AT45DB161E-SSHD | IC | 1 | U13 |
SOD123 | DIODE_SCHTKY_SOD123_IC_1.45MM_4 | MBR0520LT1G | IC | 3 | D1; D2; D3 |
SOD-923F | DIODE_SOD-923F_IC_0.55MM_TMP-WF | CDSQR400B | IC | 1 | D16 |
SOT23 | NPN_SOT23_IC_1.11 MM_480-75151_ | MMBT2484L | IC | 1 | Q2 |
SOT23-6 | TXB0101_6P_SOT23-6_IC_1.45 MM_3 | TXS0101 | IC | 1 | U14 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | IC | 1 | U7 |
SOT23_A | DIODE_2LINE_ESD_SOT23_A_IC_1.15 | GSOT05C-GS08 | IC | 1 | U8 |
SOT-23 | MOSFET_P_SOT-23_1.12MM_480-7791 | SI2305 | IC | 1 | Q1 |
SSOP14 | 74-125_14P_SSOP14_IC_2MM_312-79 | 74LVC125ADB | IC | 1 | U4 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | IC | 5 | SW1; SW2; SW3; SW4; SW6 |
SW_6P_11X7P31MM | SW_6P_SW_6P_11X7P31MM_IC_7.7MM_ | DPDT SWITCH | IC | 1 | SW5 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_I | TESTLOOP | IO | 3 | TL1; TL2; TL3 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | IO | 13 | TP100; TP101; TP102; TP103; TP105; TP106; TP107; TP108; TP508; TP509; TP510; TP511; TP512 |
TPAD_040 | TESTLOOP_TPAD_040_0.1MM_211-766 | TPAD_040 | IC | 19 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP9; TP10; TP11; TP12; TP14; TP15; TP16; TP17; TP21; TP22; TP27; TP104 |
TPAD_040 | TESTLOOP_TPAD_040_IO_0.1MM_211- | TPAD_040 | IO | 5 | TP500; TP501; TP502; TP504; TP506 |
TP_TH_063 | TESTLOOP_TP_TH_063_IO_8.13MM_21 | TESTLOOP_BLACK | IO | 3 | TP25; TP26; TP507 |
XFMR_HHM1525_2X1_25MM_6P | LDB_21_XFMR_HHM1525_2X1_25MM_6P | 2400MHz 50OHM | IC | 1 | Z1 |
XTAL2-3P2X1P5-SM | CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.9 | 32.768KHZ | IC | 1 | Y2 |
XTLOSC4_3P2X2P5MM_SM | XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I | 32MHZ | IC | 1 | Y1 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | 8MHZ | IC | 1 | Y3 |
