查看: 224|回复: 0
[allegro17.2][12层]TWR-K70F120M Kinetis K70 120 MHz塔式系统模块(PK70FN1M0VMJ...
发表于 2020-1-14 16:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][12层]TWR-K70F120M Kinetis K70 120 MHz塔式系统模块(PK70FN1M0VMJ12+CON_2X10+PCI)原理图和pcb文件
文件描述:
1. 作品用途:TWR-K70F120M Kinetis K70 120 MHz塔式系统模块
2. 软件版本:allegro17.2
3. 层数:12层
4. 用到的主要芯片:PK70FN1M0VMJ12+CON_2X10+PCI
5. PCB尺寸:3543*3174 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA256_1P0_17X17PK70FN1M0VMJ15_256P_BGA256_1P0_PK70FN1M0VMJ12IC1U53
CASE_PCAP_POL_CASE_P_1.2MM_150-78548_47uFIC1C54
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M27pFDISCRETE2C19; C20
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UFDISCRETE4C2; C22; C25; C82
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE59C3; C4; C5; C7; C9; C13; C14; C15; C16; C17; C18; C23; C24; C26; C28; C29; C30; C31; C33; C34; C37; C38; C42; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C75; C76; C79; C80; C86; C87; C88
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C8; C10; C77; C78
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1000PFDISCRETE1C43
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C74
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE6C6; C11; C12; C27; C35; C39
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UFDISCRETE1C81
CC1206_OVCAP_NP_CC1206_OV_DISCRETE_1.27M1UFDISCRETE1C137
CC1210CAP_NP_CC1210_DISCRETE_2.42 MM_47uFDISCRETE4C133; C134; C135; C136
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uFIC2C1; C21
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J7
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J13
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J11
CON_SDCARD_8F_SM_RACONN_MICRO_SD_CARD_REVERSED_CONConn MicroSDIO1J15
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO1J3
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO2J4; J5
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIRIC1D1
FBGA_84_0P8_8X12P5MT47H64M16_84P_FBGA_84_0P8_8X12MT47H64M16HR-25:HIC1U10
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_9HDR_2x4IO1J6
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO10J1; J2; J8; J10; J12; J16; J18; J19; J20; J21
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO1J17
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J14
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZIC5L1; L4; L6; L7; L8
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHMDISCRETE1L12
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE1L2
IND_IHLP_2020INDUCTOR_IND_IHLP_2020_DISCRETE0.47uHDISCRETE2L9; L10
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_OR + ELECTRODEIC1D7
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_YEL + ELECTRODEIC1D8
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_GRN + ELECTRODEIC1D11
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED2_ELECTRODEIC1D12
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D2
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D3
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC2D4; D5
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R52
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U5
QFN24_4X4MM_FSLTC3618_CUST_QFN24_4X4MM_FS_IC_LTC3618IC1U56
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPDIC1Q1
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4733DISCRETE5R12; R41; R42; R89; R90
RC0402_25RES_RC0402_25_0.4MM_470-80310_110kIC14R13; R14; R306; R310; R311; R313; R317; R318; R319; R325; R326; R327; R336; R338
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__2330DISCRETE1R15
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__31.0KDISCRETE6R16; R17; R58; R64; R67; R77
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_1270DISCRETE1R18
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410kDISCRETE30R19; R20; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R53; R56; R69; R70; R71; R73; R74; R75; R76; R79; R80; R81; R82; R84; R86; R87
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__610.0KDISCRETE2R25; R60
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_418KDISCRETE1R38
RC0402_25RES_RC0402_25_DISCRETE_0.35MM_40DISCRETE1R39
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_24.99KDISCRETE1R40
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110MDISCRETE2R78; R133
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__72.2KDISCRETE1R83
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_68DISCRETE2R94; R122
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE3R118; R128; R130
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__522DISCRETE1R212
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_0DISCRETE57R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R21; R22; R23; R43; R44; R45; R46; R47; R48; R49; R50; R51; R57; R59; R61; R62; R63; R65; R66; R68; R72; R85; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R109; R115; R116; R132; R134; R135; R139; R140; R141; R142; R342; R343
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_14.70KDISCRETE2R54; R55
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_31.0MDISCRETE1R93
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_4100DISCRETE1R337
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1422.0KDISCRETE1R339
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_2210.0KDISCRETE1R341
RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_40DISCRETE6R88; R91; R92; R137; R138; R143
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT2
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D10
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U2
SOIC1474-125_14P_SOIC14_IC_1.75MM_31274HCT125IC1U6
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q2
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U3
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC2D9; D13
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q3
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U7
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC4T1; TP8; TP18; TP19
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACKIC2TP15; TP17
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020IO9TP21; TP22; TP28; TP29; TP34; TP35; TP36; TP37; TP38
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040IC12TP2; TP3; TP4; TP5; TP6; TP9; TP10; TP11; TP12; TP13; TP14; TP20
TPAD_040TESTLOOP_TPAD_040_IO_0.1MM_211-TPAD_040IO5TP26; TP27; TP30; TP31; TP33
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U8
TSOP48_18P5X12P4MT29F2G16AADWP_TSOP48_18P5X12P4MT29F2G16ABAEAWP:EIC1U14
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125IC1U9
TSSOP-1474_04_TSSOP-14_IC_1.2MM_312-753SN74LVC04APWE4IC1U4
XTAL4_3P3X2P6_SM_FLCRYSTAL_JXS63_XTAL4_3P3X2P6_SM_12MHZIC1Y5
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y3
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzIC1Y4
XTLOSC4_SMCLKGEN-SM_XTLOSC4_SM_IC_1.75MM_50MHZIC1Y1
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
3 O) l( _- R% l$ O
GMT+8, 2025-7-21 22:25 , Processed in 0.156250 second(s), 28 queries , Gzip On.
