查看: 300|回复: 0
[allegro17.2][8层]TWR-K64F120M Kinetis K64 MCU塔式系统模块(BK-883+MMC-SD Con...
发表于 2020-1-14 16:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][8层]TWR-K64F120M Kinetis K64 mcu塔式系统模块(BK-883+MMC-SD Connector+CON_2X10)原理图和pcb文件
文件描述:
1. 作品用途:TWR-K64F120M Kinetis K64 MCU塔式系统模块
2. 软件版本:allegro17.2
3. 层数:8层
4. 用到的主要芯片:BK-883+MMC-SD Connector+CON_2X10
5. PCB尺寸:3543*3174 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLPIC6U1; U4; U7; U18; U19; U20
0603LEDLED_0603LED_IC_0.8MM_370-76477_BLUEIC1D9
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE14C2; C38; C39; C500; C508; C509; C510; C511; C513; C519; C520; C521; C525; C526
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M47PFDISCRETE2C14; C15
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE9C16; C20; C21; C33; C46; C502; C504; C506; C512
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_118pFDISCRETE4C36; C37; C44; C45
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.01UFDISCRETE7C48; C505; C507; C518; C522; C523; C524
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_347PFDISCRETE1C527
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uFDISCRETE10C1; C17; C22; C41; C503; C514; C515; C516; C517; C528
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE8C9; C10; C13; C40; C47; C49; C51; C54
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UFDISCRETE1C35
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE1C501
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.3974.7UFDISCRETE1C11
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J11
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO1J17
CONN-MMC_SD_OPTMMC_SD_CONN_2405_CONN-MMC_SD_OPMMC-SD ConnectorIO1P500
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO1J9
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J5
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J3; J4
CON_USB_5_548190572USB_MINI_B_SKT_CON_USB_5_548190CONN USB MINI-B 1x5IO1J2
DQFN14_3X2P5MM74LVC125_DHVQFN_14P_DQFN14_3X2P74LVC125IC1U10
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO19J6; J7; J8; J13; J14; J21; J22; J23; J24; J25; J26; J27; J28; J32; J33; J34; J35; J36; J39
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO8J1; J10; J15; J16; J19; J20; J31; J38
HDR203CONN_HDR_3X2_HDR203_IO_8.71 MM_HDR_2X3IO1J18
HDR204_TSM_SMCONN_HDR_4X2_HDR204_TSM_SM_IO_9HDR_2X4IO3J12; J29; J30
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L6; L7
IND_0805BEAD_IND_0805_DISCRETE_1.05 M_1330 OHMDISCRETE2L8; L9
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZDISCRETE5L500; L501; L502; L503; L504
LED2_2P1X1P5LED_LED2_2P1X1P5_IC_1.4MM_370-7REDIC1D8
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D3
LED_0603LED_LED_0603_IC_0.8MM_370-76537YEL/GRNIC2D4; D5
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D6
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D7
OSC4_2P6X2P1_SMOSC4_KC2520_OSC4_2P6X2P1_SM_IC_50MHzIC1Y1
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015KDISCRETE1R526
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U6
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPPK20DX128VFM5IC1U8
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE12R31; R34; R35; R40; R42; R43; R49; R64; R69; R517; R524; R525
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE7R44; R52; R56; R110; R515; R516; R519
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_270DISCRETE2R45; R95
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__21.0KDISCRETE1R47
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE5R48; R59; R61; R62; R81
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__3330DISCRETE2R57; R83
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__41.0KDISCRETE2R77; R79
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE51R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R16; R17; R18; R19; R20; R21; R22; R25; R28; R29; R105; R106; R107; R108; R109; R500; R501; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511; R512; R513; R514; R527; R528; R529; R530; R531; R532; R533; R534
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_4.70KDISCRETE7R23; R26; R27; R36; R41; R58; R521
RC0603_OVRES_RC0603_OV_DISCRETE_470-758433DISCRETE8R37; R38; R63; R65; R67; R73; R522; R523
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE7R39; R46; R50; R60; R66; R70; R71
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_41.0MDISCRETE1R53
RC0603_OVRES_RC0603_OV_DISCRETE_470-75_11.0MDISCRETE1R75
RC0603_OVRES_RC0603_OV_DISCRETE_470-7579180DISCRETE1R97
RC0603_OVRES_RC0603_OV_DISCRETE_470-75912.7KDISCRETE1R103
RC0603_OVRES_RC0603_OV_DISCRETE_470-754520KDISCRETE1R518
RC0603_OVRES_RC0603_OV_DISCRETE_470-78025.6KDISCRETE1R520
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT500
SKT_BGA144_1_18X18_NSPPK64FN1M0VMD12_BGA_144P_SKT_BGAPK64FN1M0VMD12 +144 BGA SOCKETIC1U11
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D1
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC3U501; U503; U504
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U505
SOT23NPN_SOT23_IC_1.11 MM_480-75151_MMBT2484LIC2Q2; Q500
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U500
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U506
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U507
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC1D500
SSOP8_DCUSN74LVC2T45DCUT_8P_SSOP8_DCU_ICSN74LVC2T45IC1U502
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC1TP4
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO3TP5; TP7; TP9
TPAD_040TESTLOOP_TPAD_040_IC_0.1MM_211-TPAD_040IC8TP1; TP3; TP8; TP10; TP11; TP500; TP501; TP502
TPAD_040TESTLOOP_TPAD_040_IO_0.1MM_211-TPAD_040IO1TP6
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC2U9; U17
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X1
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_8.84MM_230-32.768KHzIC1Y2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
' d5 x: ]- p) B
GMT+8, 2025-7-21 22:24 , Processed in 0.125000 second(s), 28 queries , Gzip On.
