查看: 218|回复: 0
[allegro17.2][8层]TWR-K21D50M Kinetis K21 50 MHz MCU塔式系统模块(MK21FN1M0VM...
发表于 2020-1-14 16:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][8层]TWR-K21D50M Kinetis K21 50 MHz mcu塔式系统模块(MK21FN1M0VMC10+BK-883+MC9S08JM60CLD)原理图和pcb文件
文件描述:
1. 作品用途:TWR-K21D50M Kinetis K21 50 MHz MCU塔式系统模块
2. 软件版本:allegro17.2
3. 层数:8层
4. 用到的主要芯片:MK21FN1M0VMC10+BK-883+MC9S08JM60CLD
5. PCB尺寸:3543*2356 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:% m9 L. D  f* s7 y" ^2 b
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0603LEDLED_0603LED_IC_0.8MM_370-76477_BLUEIC1D9
BGA121_0P65_8X8MMMK21FN1M0VMC10_121P_BGA121_0P65MK21FN1M0VMC10IC1U6
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE22C1; C6; C8; C10; C13; C15; C21; C200; C201; C203; C204; C206; C207; C209; C210; C211; C214; C215; C219; C220; C221; C222
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C2; C3; C212; C218
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1000PFDISCRETE1C4
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C208
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE8C5; C19; C20; C202; C205; C213; C216; C217
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.1M4.7uFDISCRETE1C7
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J14
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO1J19
CONN-MMC_SD_OPTMMC_SD_CONN_2405_CONN-MMC_SD_OPMMC-SD ConnectorIO1P200
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J1
CON_MICROUSBB_9F_0P65_SM_RAMICRO_USB_CONN_9PIN_CON_MICROUS1050170001IO1J2
CON_SKT1X6_THCONN_HDR_6X1_CON_SKT1X6_TH_IO_8HDR 1X6IO1JP1
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO2J3; J4
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_9HDR_2x4IO3J11; J15; J17
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO8J6; J9; J10; J12; J16; J21; J22; J23
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO4J7; J8; J13; J24
HDR202_TSM_SMCONN_HDR_2X2_HDR202_TSM_SM_IO_9HDR_2X2IO1J18
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J5
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE4L1; L2; L3; L4
IND_1608IND_IND_1608_DISCRETE_0.95MM_18100 OHM@100MHZDISCRETE2L200; L201
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC3D1; D4; D5
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC2D2; D6
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC2D7; D8
LQFP44MC9S08JM60CFGE_LQFP44_IC_1.60 MMC9S08JM60CLDIC1U200
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R43
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U7
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE27R9; R10; R11; R20; R36; R37; R46; R47; R50; R51; R53; R57; R58; R200; R201; R203; R205; R206; R215; R217; R219; R220; R221; R222; R223; R235; R236
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110MDISCRETE1R14
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_4.99KDISCRETE1R19
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__41.0KDISCRETE4R40; R41; R45; R48
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_3270DISCRETE2R42; R54
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__5330DISCRETE2R49; R52
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_11.3KDISCRETE1R202
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_218KDISCRETE1R204
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__233DISCRETE4R213; R214; R224; R226
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__32.2KDISCRETE1R218
RC0402_25RES_RC0402_25_DISCRETE_0.6MM_470DISCRETE8R238; R239; R240; R241; R242; R243; R244; R245
RC0402_25RES_RC0402_25_DISCRETE_470-3045100DISCRETE1R246
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE23R1; R2; R3; R4; R5; R8; R12; R13; R21; R38; R39; R207; R208; R209; R210; R211; R212; R216; R229; R231; R232; R233; R234
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_4.70KDISCRETE3R6; R7; R44
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_41.0MDISCRETE2R228; R230
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT200
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D3
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC3U4; U5; U201
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC2U202; U205
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q1
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U203
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U204
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC1D200
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q200
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC2U3; U8
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO9TP1; TP2; TP3; TP4; TP6; TP7; TP9; TP10; TP11
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO4TP5; TP8; TP12; TP13
TSM2X12_SMDCONN_HDR_12X2_TSM2X12_SMD_IO_9.HDR_2X12IO1J20
TSSOP14SN74LVC126A_TSSOP14_TSSOP14_IC_SN74LVC126APWG4IC1U2
UQFN10_0P4_1P45X1P85PI3USB102_UQFN_10P_UQFN10_0P4_1PI3USB102ZMEIC1U206
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X200
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y2
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzIC1Y200
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
2 `( h2 ~7 R1 Z  A% @% Z  a
GMT+8, 2025-7-21 22:25 , Processed in 0.140625 second(s), 28 queries , Gzip On.
