作品名:[AD 10][2层] TMS320LF2407A+74LVC4245+MAX232+A82C250 开发板PCB 和原理图- i, ]# o. e e% r+ `
E: C6 T2 y. {: B3 N' B文件描述
# ]0 R; M" ?1 `1 J- i! R! k8 f, F1. 作品用途:开发板
. f" c: O# X7 _3 Q5 [' x2. 软件版本:AD 10, v. l6 X, F- y" U. ]
3. 层数:2层板$ U/ |6 w+ G( p4 e# R
4. 用到的主要芯片:TMS320LF2407A+74LVC4245+MAX232+A82C250
4 V( A# _8 V# }& S2 K% R0 T5. PCB尺寸:76.5mm*68mm
1 P" l6 i! Z3 x' _2 o1 F! u5 h0 n& C% I0 J- k' ^
作品截图如下:
4 ~: X- p5 s2 `5 Y顶层截图:- W+ o- @7 [( \
/ d' n1 B; a$ R" R
; d! i: k; H& }+ d- \底层截图:
' q, E3 F0 O+ j6 Z1 O
& z5 Q" b2 \9 @+ s9 o+ ]0 f4 C2 K) z$ |$ ]: r
全层截图:
8 [9 t# v6 j, C0 F% v: T4 Y' d
7 C8 {% ]9 }' Q5 Y* B
- `0 K2 x) l4 |: ~* i叠层信息截图如下:
6 |8 w8 l7 m* W8 a9 A% E3 ]% h
o$ k5 E% r% x1 z) } o
; v) q _" x7 ~2 _; m2 V) L8 P! h
BOM:
4 |& [5 P2 |5 q, p* TComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 220UF | C4, C101 | 7343 | 2 | 4.7uF | C12 | 3528 | 1 | 3.3nF | C14 | 0805N | 1 | 0.15uF | C15 | 0805N | 1 | 10uF | C17, C73, C74, C81, C82 | 3528 | 5 | 10uF | C18 | 1206 | 1 | 104 | C97, C100, C102 | 1206 | 3 | IN5819 | D1 | IN4148 | 1 | CON8 | J1, J3, J11, J12 | CON8 | 4 | EVA | J2 | CON13 | 1 | KEY-4 | J4 | DIP8 | 1 | EVB | J5 | CON13 | 1 | POEER-IN | J7 | C2 | 1 | RS-232 | J8, J13 | DB9RA/M | 2 | DSP-JTAG | J9 | IDC14W | 1 | SPI | J10 | SIP4 | 1 | LF50 | J14 | 2217-33 | 1 | CXDG | L8 | 1206 | 1 | TL431 | Q1 | TO-92A | 1 | 120 | R1 | 1206 | 1 | R | R2 | 1206 | 1 | 10K | R3 | 1206 | 1 | 1K | R4 | 1206 | 1 | 2K | R5 | 1206 | 1 | 10k | R6, R7, R9, R10, R11, R13, R14, R18, R19, R22, R23, R24, R26, R27 | 0805N | 14 | 100K | R8 | 0805N | 1 | 24 | R12 | 0805N | 1 | 10k | R15, R16 | 0805 | 2 | 2.2K | R17 | 0805 | 1 | 2.2K | R20 | 0805N | 1 | 250K | R21 | VR5 | 1 | 100 | R144, R145 | 0805 | 2 | TMS320LF2407A | U1 | TQFP-144 | 1 | A82C250 | U2 | SO8 | 1 | TLE2142 | U3 | SO8 | 1 | 74LVC4245 | U4, U18 | TSSOP24 | 2 | 1117-33 | U42 | SOT223 | 1 | MAX232 | U51 | SOJ-16 | 1 | 20MHZ | X2 | OSC4 | 1 |
$ \2 `$ q$ w8 Q) c附件:- _) Y0 n) B9 y
原理图和PCB源文件如下:" G) H* L$ u0 K, H! f: o
, W; X$ `7 a( M+ `
9 G5 r. m/ |/ I/ Z. e |
