作品名:[AD 10][2层]STM32F103ZET6开发板(AT24LC02+PRTR5V0U2X+SN65HVD230)原理图和PCB源文件+ B. m3 N5 G7 t6 y. a
5 }5 E5 s$ O, W4 ]文件描述
?4 s+ f% m& o' ^& j5 H& m! Q0 W- N: K1 j' _5 k1 I5 ^
1. 作品用途:STM32F103ZET6开发板& \0 E: H V" N
( n, n9 [5 H& ^, |' w2. 软件版本:AD 10
! o! a: P5 G: D
: P8 s6 H4 W- \3. 层数:2层板
* P! g; L4 L+ {* M) p. t: u* K5 I. {" Y; u2 a# j' x
4. 用到的主要芯片:AT24LC02+PRTR5V0U2X+SN65HVD230
$ P1 ^6 E# T+ @+ l1 }% a5 K( W8 q& _9 y3 u2 O
5. PCB尺寸:140mm*100mm' F* G1 l8 S- C2 P3 P5 n5 k
% G; u8 d. [% X4 a7 C
8 o' I& {; m, j5 Q+ h作品截图如下:3 z6 S2 ]$ e4 e2 R6 `
4 S8 u9 U# D, M% G$ q1 P: z" i顶层截图:
' p+ R& Y! y! S1 i4 g3 m% Q
% I7 I$ f6 j5 f# j
, L5 u. G6 x7 C6 _0 {% z4 G8 G底层截图:" I7 z1 T" w/ `( j1 v
9 A" }4 f, H: O7 l; a# d5 }9 E( C. o1 H. b4 a
全层截图:1 W6 W0 x% ^8 |/ t# e3 t
A9 G: {& u/ z& m! F, A
- u3 ^9 P2 K) W; C; L5 B, i% Q叠层信息截图如下:
7 j( e0 _: p7 C
- w, c* l5 k9 E, q
" {8 R1 y+ `. q3 `$ c) PBOM:$ \: N" u$ \, J7 V; y# J9 I( ?
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | Connector to Mother board | 3.2_TFT_Touch_LCD module | HDR2X16 | 1 | Header 4X2 | ADC, POWER-3.3V, POWER-5V | HDR2X4 | 3 | RESET | B1 | PB10 | 1 | BEAD | BEAD1, L2 | 0603 | 2 | | BOOT0, BOOT1, JP3, JP9, SW1, SW2, SW3, SW4 | SIP3 | 8 | CR1220 holder | BT1 | BATTERY | 1 | 10uF | C1 | 1608[0603] | 1 | 10pF | C11, C12 | 0603 | 2 | 20pF | C13, C14 | 0603 | 2 | 100nF | C15, C16, C18, C36, C37, C38, C39, C40, C42, C43, CF1, CF2, CF3, CF4, CF5, CF6, CF7, CF8, CF9, CF10, CF11 | 0603P | 21 | 100nF | C23, C29, C30, C46, C48 | 0603 | 5 | 10uF | C26, C27, C31, C32 | C0805 | 4 | 10nF | C33, C35 | 0603 | 2 | 10uF | C34 | 0603 | 1 | Header 2 | CAN | HDR1X2 | 1 | miniUSB-A | CN4 | USB-min | 1 | DC-5V | CN8 | DC10B | 1 | LED2 | D2, D3 | D0603 | 2 | ENC28J60 module | ENC28J60 module | HDR2X5 | 1 | Header 30 | GPIO1, GPIO2, GPIO3 | HDR1X30 | 3 | | JP1, JP2 | SIP2 | 2 | JTAG-20PIN | JTAG | IDC20_JTAG | 1 | Green | LD3 | D0603 | 1 | Orange | LD4 | D0603 | 1 | Red | LD5 | D0603 | 1 | Blue | LD6 | D0603 | 1 | nRF24L01 | nRF24L01 Module | HDR2X5 | 1 | 100K | R1, R8, R23, R24, R25, R26, R27 | J1-0603 | 7 | 4K7 | R2, R58, R79, R80 | 0603 | 4 | 47K | R3, R4, R38, R39, R40, R41, R42 | 0603 | 7 | 10K | R32, R35, R37, R47, R50, R57, R89 | 0603 | 7 | 0 | R33, R34, R43, R44, R51, R52, R53, R63, R77, R81, R82, R91 | 0603 | 12 | 1.5K | R45 | 0603 | 1 | 36K | R48 | 0603 | 1 | 120 | R54 | 0603 | 1 | Res3 | R59, R61 | 0603 | 2 | 0Ω | R60 | J1-0603 | 1 | 47 | R62 | 0603 | 1 | 600 | R68, R69, R71, R74 | 0603 | 4 | do not fit | R76 | 0603 | 1 | 330 | R83 | 0603 | 1 | 220K | R84 | 0603 | 1 | 100 | R85, R86 | 0603 | 2 | DB9-female | RS232-1 | DB9/M | 1 | DB9-male | RS232-2 | DB9/M | 1 | SW-PB | S1, S2, S3 | BUTTOM_SP | 3 | 9013 | T1 | SOT-23 | 1 | PRTR5V0U2X | U1 | SOT143B | 1 | SD_CARD | U2 | SDCARD | 1 | STM32F103ZET6 | U5 | LQFP144_M | 1 | SN65HVD230 | U7 | SO8 | 1 | DS18B20 | U8 | TO-92 | 1 | AT24LC02 | U9 | SO8_N | 1 | ASM1117-3.3 | U12 | SOT230P700X180-4N | 1 | MAX3232 | U13 | TSOP128P640X110-16M | 1 | IS64WV51216BALL | U14 | TSOP80P1180X10-44M | 1 | URF04 | Ultrasonic module | HDR1X5 | 1 | VS1003b-Module | VS1003b-Module | HDR1X10 | 1 | 32.768 KHz | X2 | R38 | 1 | 8MHz (with socket) | X3 | DIP_XAL(5MM) | 1 | SMAJ5.0A-TR | Z1 | 1R1C | 1 |
9 P; @$ B2 c7 L& M0 E& q, Z附件:! N( ~( X+ j8 \' k: W' n! w. {2 e
4 Q" [9 A* \ a& h! ~& q! ]原理图和PCB源文件如下: p. F+ a0 i3 O8 B
5 o& Y, _+ E- H K% {7 r1 t$ J
1 t+ i3 w" K& w! a6 A9 z' y
+ t% \* H9 U4 ^! Y) n
0 \1 w) J. g3 K( ?
