1. 作品用途:PCY液压检测仪
2. 软件版本:allegro17.2
3. 层数:2层
5. PCB尺寸:54.24*40.83 mm
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
805 | R_0_0805_10R | 10R | IC | 1 | R9 |
2016 | CRYSTAL_SX-8_2016_24MHZ | 24MHz | IC | 1 | Y2 |
AT24LC128C | AT24LC128C_1_AT24LC128C_AT24LC1 | AT24LC128C | IC | 1 | U3 |
B2B-XH-A | CON2_B2B-XH-A_SFM-27 | SFM-27 | IC | 1 | J3 |
B2B-XH-A | CON2_B2B-XH-A_BAT | BAT | IC | 1 | J4 |
B3B-XH-2 | COM3_B3B-XH-2_B3B-XH-2 | B3B-XH-2 | IC | 1 | J2 |
C0603 | CAP_0_C0603_15PF/16V | 15pf/16V | IC | 2 | C1; C2 |
C0603 | CAP NP_C0603_100NF/16V | 100nf/16V | IC | 13 | C3; C4; C13; C14; C15; C18; C19; C21; C22; C23; C24; C26; C29 |
C0603 | CAP NP_C0603_1UF/16V | 1uf/16V | IC | 6 | C5; C6; C12; C17; C20; C28 |
C0603 | CAP NP_C0603_2.2NF/16V | 2.2nf/16V | IC | 1 | C7 |
C0603 | CAP NP_C0603_10NF/16V | 10nf/16V | IC | 1 | C8 |
C0603 | CAP_0_C0603_NC | NC | IC | 2 | C9; C10 |
C0603 | CAP_0_C0603_100NF/16V | 100nf/16V | IC | 1 | C11 |
C0603 | CAP NP_C0603_22NF/16V | 22nf/16V | IC | 1 | C30 |
CRY_3215 | CRYSTAL_CRY_3215_32.768KHZ | 32.768KHz | IC | 1 | Y1 |
CY8C4127LQI-BL453 | CY8C4127LQI-BL453_0_CY8C4127LQI | CY8C4127LQI-BL453 | IC | 1 | U1 |
LFB182 | LFB182G45SG9A213_0_LFB182_LFB18 | LFB182G45SG9A213 | IC | 1 | U2 |
MINI_PCIE | MINI_PCIE_0_MINI_PCIE_MINI_PCIE | MINI_PCIE | IC | 1 | P1 |
MTHOLE3_5 | FH_MTHOLE3_5_FH | FH | IC | 2 | MT1; MT2 |
P_5 | CON5_P_5_P-5 | P-5 | IC | 1 | J1 |
R0603 | LM_R0603_NC | NC | IC | 1 | L1 |
R0603 | LM_R0603_300R @100MHZ | 300R @100MHz | IC | 3 | L2; L3; L4 |
R0603 | R_0_R0603_300K | 300K | IC | 1 | R1 |
R0603 | R_0_R0603_4K7 | 4K7 | IC | 4 | R2; R4; R7; R13 |
R0603 | R_0_R0603_100K | 100K | IC | 1 | R3 |
R0603 | RES2_R0603_300K | 300K | IC | 1 | R5 |
R0603 | RES2_R0603_10K | 10K | IC | 1 | R6 |
R0603 | RES2_R0603_100K | 100K | IC | 1 | R8 |
R0603 | R_0_R0603_2K | 2K | IC | 1 | R10 |
R0603 | R_0_R0603_10K | 10K | IC | 4 | R11; R12; R14; R15 |
R0603 | R_R0603_120K | 120K | IC | 1 | R16 |
SC0805 | C_0_SC0805_10UF/16V | 10uf/16V | IC | 2 | C16; C25 |
SC0805 | CAP NP_0_SC0805_10UF/16V | 10uf/16V | IC | 1 | C27 |
SLDA52-2R510G-S1TF | ANTENNA-2_SLDA52-2R510G-S1TF_AN | ANTENNA-2 | IC | 1 | E1 |
SOT23 | BAT54S_SOT23_BAT54S | BAT54S | IC | 1 | DN1 |
SOT23 | FETP-GSD_0_SOT23_SI2333DDS | Si2333DDS | IC | 2 | Q1; Q3 |
SOT23 | NPN-BEC_0_SOT23_3904 | 3904 | IC | 2 | Q2; Q4 |
SOT23-5 | RT9193_0_SOT23-5_RT9193-33 | RT9193-33 | IC | 1 | U4 |
TP1 | TP_TP1_TP | TP | IC | 2 | T1; T2 |
