作品名:[AD 10][2层] TL494CJ+TLV5638+MIC4102 超屌的 3D封装库 数控充电器PCB和原理图) o( l- x6 q- K6 E) _* U* N6 ^
9 l. }0 L+ H! H7 }3 l; O6 X文件描述
0 \; u5 H9 U7 s+ |. g; N J" N! O1. 作品用途:数控充电器: H& m3 Q+ N; \' B8 }
2. 软件版本:AD 105 \! o: v- D7 K' l$ n) j7 X
3. 层数:2层板% O2 M4 k) N f' C
4. 用到的主要芯片:TL494CJ+TLV5638+MIC41026 ^7 p- E4 g4 F6 |7 G$ V( I0 y9 L
5. PCB尺寸:99.95mm*99.95mm
' ?" @2 @9 }8 X( g; }# b# Y9 J/ ^) N& S1 I6 D; ^
作品截图如下:
. t' B8 Z- L( L3 L8 Y顶层截图: j; x- C, [# j o$ G4 m8 m7 h3 O# Y' p# F
0 J! j9 M4 ?' C6 U4 v. E8 n$ B% V+ ~- S
底层截图:0 U3 k; L% P% ]- N& |+ ^: n
* W2 a0 t7 f( r: l
$ k' h, P) i2 ~! c. n4 @全层截图:8 v# U" ^/ z! k6 i
3 y, c) N2 X( J
( b% X, K3 C3 _5 v0 G. |- R$ Q叠层信息截图如下:7 o; @* r5 z0 q0 A$ Z: [. |1 |
) G- g4 l3 B# Q8 @$ Q
0 K% i3 F( } J6 _* G
BOM:
2 u( K# A/ q5 x& M+ SComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10nF | C1, C5 | CBB_474 | 2 | Cap Pol 2.5x6.3 | C2, C3 | C13x20 | 2 | Cap Chip 0805 | C4, C8 | WIMA MKP10 0.22 | 2 | Cap Pol | C6, C7 | CAPPR7.5-16X20 | 2 | Cap Pol 2.5x6.3 | C9, C10 | CAP_25V_100uf | 2 | Cap Chip 0805 | CC1, CC4, CC5, CC6, CC7, CC8, CC9, CC10, CC11, CC12, CC13, CC14, CC15, CC16, CC17, CC18, CC19, CC20 | CC0805 | 18 | Cap Chip 0805 | CC2, CC3 | CC2012-0805 | 2 | Resistor Chip 0805 | CR1, CR2, CR3, CR4, CR5, CR6, CR7, CR8, CR9, CR10, CR11, CR12, CR13, CR14, CR15, CR16, CR17 | CR0805 | 17 | Diode Glass | D1, D2 | DO-35 | 2 | Fuse | F1 | FUSE | 1 | CONNECT-2 | J1, J2, J3 | HB-9500 2P | 3 | INDUCTOR | L1 | INDUCTOR_120UH | 1 | INDUCTOR | L2 | INDUCTOR_100UH | 1 | Header 3 | P1, P2, P4 | HDR1X3 | 3 | Header 3X2 | P3 | HDR2X3 | 1 | Header 5X2 | P5 | IDC2.54-10 | 1 | MOSFET-N | Q1, Q2 | TO220_3 | 2 | Resistor AXIAL0.3 | R1 | constantan_wire | 1 | Resistor AXIAL0.3 | R2, R3 | AXIAL-0.3 | 2 | Res Adj Pot Small | RP1, RP2 | 3296W | 2 | INA210 | U1 | SOT23-6 | 1 | TL494CJ | U2 | SOP16 | 1 | MIC4102 | U3 | SOIC8 | 1 | PC817 | U4 | DIP-4_N | 1 | LM2596 | U5 | TO220_5 | 1 | LM1117 | U6 | SOT-223 | 1 | TLV5638 | U7 | SOP8 | 1 |
6 V8 k' \& u, K: A; v$ |* ~0 T9 c' f
$ V3 [% L2 `& V附件:1 m* f) n; J: M/ t6 u- q
原理图和PCB源文件如下:
# z/ G. P; N+ U/ j
$ Y% z" [1 ^; | |
