查看: 720831|回复: 16
[allegro17.2][4层]NXP官方IMX6ULL的demo板(KSZ8081RNB+DDR+SiI9022A)原理图和pc...
发表于 2020-1-13 15:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]NXP官方IMX6ULL的demo板(KSZ8081RNB+DDR+SiI9022A)原理图和pcb文件
文件描述:
1. 作品用途:NXP官方IMX6ULL的demo板
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:KSZ8081RNB+DDR+SiI9022A
5. PCB尺寸:4250*5120 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402_CCCAP_NP_0402_CC_DISCRETE_0.55MM_0.1uFDISCRETE96C902; C904; C1001; C1002; C1003; C1004; C1005; C1006; C1007; C1008; C1009; C1010; C1011; C1013; C1015; C1017; C1102; C1104; C1105; C1107; C1108; C1110; C1201; C1208; C1302; C1303; C1306; C1307; C1308; C1309; C1311; C1312; C1313; C1314; C1315; C1402; C1403; C1407; C1408; C1415; C1418; C1420; C1421; C1423; C1424; C1502; C1504; C1505; C1506; C1507; C1508; C1602; C1604; C1605; C1606; C1607; C1608; C1701; C1702; C1706; C1802; C1804; C1805; C1806; C1808; C1810; C1812; C1815; C1817; C1824; C1903; C1905; C2002; C2011; C2102; C2104; C2106; C2107; C2110; C2129; C2130; C2131; C2133; C2136; C2137; C2138; C2139; C2140; C2147; C2148; C2149; C2150; C2151; C2152; C2153; C2154
0402_CCCAP_NP_0402_CC_DISCRETE_0.65MM_4.7uFDISCRETE17C1014; C1016; C1301; C1305; C1310; C1404; C1409; C1414; C1417; C1422; C1801; C1803; C1807; C1811; C1816; C1902; C2132
0402_CCCAP_NP_0402_CC_DISCRETE_0.6MM_21.0UFDISCRETE7C1202; C1203; C1207; C1209; C1705; C2003; C2134
0402_CCCAP_NP_0402_CC_DISCRETE_0.55 _156PFDISCRETE4C1204; C1206; C1210; C1212
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_2220PFDISCRETE2C1410; C1413
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_315PFDISCRETE6C1416; C1419; C1425; C1426; C1427; C1428
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_40.22UFDISCRETE2C1704; C1904
0402_CCCAP_NP_0402_CC_DISCRETE_0.55M_50.1uFDISCRETE2C2001; C2006
0402_CCCAP_NP_0402_CC_DISCRETE_0.74 MM0.01UFDISCRETE1C2005
0402_CCINDUCTOR_FERRITE_0402_CC_DISCRE120 OhmDISCRETE5L903; L904; L905; L1401; L1402
0402_CCRES_0402_CC_DISCRETE_470-75394_0DISCRETE88R903; R904; R905; R906; R912; R917; R919; R920; R921; R922; R923; R924; R925; R926; R927; R928; R929; R930; R931; R932; R933; R934; R935; R936; R937; R938; R939; R940; R941; R942; R943; R944; R945; R946; R1001; R1008; R1017; R1018; R1024; R1110; R1117; R1120; R1121; R1201; R1202; R1203; R1206; R1208; R1211; R1301; R1404; R1407; R1411; R1412; R1413; R1417; R1420; R1423; R1424; R1425; R1426; R1427; R1428; R1429; R1430; R1431; R1432; R1433; R1434; R1435; R1633; R1634; R1635; R1636; R1701; R1705; R1706; R1707; R1708; R1709; R1715; R1716; R1801; R1803; R1804; R1805; R1806; R1909
0402_CCRES_0402_CC_DISCRETE_470-75597_100KDISCRETE8R913; R1102; R1105; R1119; R1303; R1305; R1402; R2003
0402_CCRES_0402_CC_DISCRETE_470-75557_10KDISCRETE25R914; R1016; R1025; R1103; R1109; R1118; R1207; R1304; R1306; R1307; R1406; R1410; R1509; R1607; R1807; R1808; R1810; R1811; R1819; R1820; R1905; R1919; R2008; R2101; R2105
0402_CCRES_0402_CC_DISCRETE_470-75626_4.7KDISCRETE7R1006; R1013; R1520; R1525; R1529; R1614; R1623
0402_CCRES_0402_CC_DISCRETE_470-30905_4.3KDISCRETE1R1015
0402_CCRES_0402_CC_DISCRETE_470-75636_2.2KDISCRETE2R1019; R1020
0402_CCRES_0402_CC_DISCRETE_470-31028_51.1KDISCRETE1R1021
0402_CCRES_0402_CC_DISCRETE_470-75555_1KDISCRETE31R1414; R1415; R1416; R1419; R1421; R1422; R1501; R1504; R1508; R1518; R1519; R1523; R1524; R1530; R1531; R1532; R1534; R1606; R1615; R1616; R1621; R1622; R1626; R1628; R1629; R1630; R1632; R1906; R1907; R2004; R2005
0402_CCRES_0402_CC_DISCRETE_470-75607_220DISCRETE4R1505; R1507; R1603; R1605
0402_CCRES_0402_CC_DISCRETE_470-30927_6.49KDISCRETE2R1515; R1613
0402_CCRES_0402_CC_DISCRETE_470-75609_22KDISCRETE1R1711
0402_CCRES_0402_CC_DISCRETE_470-76089_51DISCRETE1R1712
0402_CCRES_0402_CC_DISCRETE_0.4 MM_47010KDISCRETE3R1713; R1714; R2002
0402_CCRES_0402_CC_DISCRETE_470-76240_100KDISCRETE1R1809
0402_CCRES_0402_CC_DISCRETE_470-31093_200KDISCRETE2R1812; R1816
0402_CCRES_0402_CC_DISCRETE_470-31122_360KDISCRETE1R1813
0402_CCRES_0402_CC_DISCRETE_470-75591_100DISCRETE1R1915
0402_CCRES_0402_CC_DISCRETE_0.40 MM_47100KDISCRETE1R2009
0402_CCRES_0402_CC_DISCRETE_0.4MM_470-1MDISCRETE10R2107; R2108; R2109; R2110; R2111; R2112; R2113; R2114; R2115; R2116
0603_CCCAP_NP_0603_CC_DISCRETE_1.016MM10uFDISCRETE14C901; C903; C1103; C1401; C1405; C1406; C1809; C1814; C1901; C2009; C2101; C2103; C2108; C2109
0603_CCCAP_NP_0603_CC_DISCRETE_0.9MM_14.7uFDISCRETE2C1109; C1112
0603_CCCAP_NP_0603_CC_DISCRETE_1MM_15022UFDISCRETE7C1411; C1412; C1501; C1503; C1601; C1603; C2135
0603_CCBEAD_0_0603_CC_DISCRETE_0.95MM_120OHMDISCRETE9L1102; L1104; L1403; L1801; L1901; L2002; L2003; L2101; L2102
0603_CCRES_0603_CC_DISCRETE_470-80866_0DISCRETE2R1026; R1405
0603_CCRES_0603_CC_DISCRETE_0.55 MM_474.70KDISCRETE1R1802
0603_CCRES_0603_CC_DISCRETE_470-75402_3.3KDISCRETE2R2001; R2012
0603_CCRES_0603_CC_DISCRETE_470-75399_2.2KDISCRETE1R2006
0805_CCCAP_NP_0805_CC_DISCRETE_1.45 MM47uFDISCRETE5C1106; C1703; C2004; C2127; C2128
0805_CCCAP_NP_0805_CC_DISCRETE_1.4MM_11000pFDISCRETE1C1111
0805_CCRES_0805_CC_DISCRETE_470-75442_0DISCRETE6R1122; R1123; R1124; R2013; R2014; R2106
0805_CCRES_0805_CC_DISCRETE_470-78674_62DISCRETE4R1204; R1205; R1209; R1210
CON1X2_1P25_SMCON1X2_TAB_CON1X2_1P25_SM_IO_3.WF1250201200IO2J1402; J1403
CON3_PWR_THPHONEJACK-3_CON3_PWR_TH_IO_11.2CON_1_PWRIO1J2001
CON4_USB_A_FE_RA_THUSB_A_CON4_USB_A_FE_RA_TH_IO_8.USB_TYPE_AIO1J1101
CON6_AUDJACK_RA_THCONN_AUDIOJACK_6P_CON6_AUDJACK_SPJ-31060ADIO1J1401
CON9_SDCARD_28X29MM_SMTSD_SOCKET_SMT_CON9_SDCARD_28X29SD01A-01202IO1P1701
CON14_FPC_0P5_RA_SMT_1CONN_HDR_7_CON14_FPC_0P5_RA_SMTCON 1X14IO1J1802
CON50_FPC_0P5_RA_SMT_1CONN_1_CON50_FPC_0P5_RA_SMT_1_2FPC05050-08100IC1J901
CON_1X2_RJ45_1P27_TH_RARJ45_MAG_LED_24P_CON_1X2_RJ45_1CON_2XRJ45IO1J1501
CON_BBC_40P_0P4_SM_MIRRORFX12B-40P_CON_BBC_40P_0P4_SM_MICONN PLUG 40IO1J1801
CON_FPC_20_0P5_RA_F050_1CON20_0_CON_FPC_20_0P5_RA_F050_FPC20IO1J1701
CON_RA_HDMI_19P_0P5_SMATOM010130010052_HDMI_19P_CON_RCON HDMI 1X19IO1J1001
CON_USB_TYPE_B_SMMICRO_USB_CONN_11PIN_CON_USB_TYMICRO_USB_TYPEBIO2J1102; J1901
CON_W2B_8M_1P25_SM_RACON_W2B_8P_CON_W2B_8M_1P25_SM_RCON_8PIO1J1201
DFN_10_0P4_2X2_BMAG3112_DFN_10P_DFN_10_0P4_2X2_MAG3110IC1U1302
DIODE2_SOD523DIODE_TVS_BIDIR_DIODE2_SOD523_IESD5B5.0ST1GIC7TVS1101; TVS1201; TVS1401; TVS1402; TVS1403; TVS1404; TVS2002
HDR_20M_100_THCONN_HDR_10X2_HDR_20M_100_TH_IOBH25420B301IO1J1902
IND4_CHOKE_0805DLW43_IND4_CHOKE_0805_DISCRETE_90OHMDISCRETE3L1103; L1105; L1902
IND0603_CCINDUCTOR_FERRITE_IND0603_CC_DIS470 OhmDISCRETE4L901; L902; L1501; L1601
LED_0606LED4_DUAL_OG_LED_0606_IC_0.7MM_LED ORANGE/GREENIC1D1903
LED_DUAL_3025MM_SMLED_DUAL_SEP_RG_LED_DUAL_3025MMLED_RED-GRNIC1D2003
MH315-158T_6PMOUNTING_HOLE_ATX_6P_MH315-158TMOUNTING HOLEIC2U2102; U2103
MIC_WM-63PRMIC_POM_MIC_WM-63PR_IC_2.4MM_51EM6022PIC1P1401
MLP6_2X2MM_SLUGFDMA530PZ_MLP6_2X2MM_SLUG_IC_0.FDMA530PZIC2Q2002; Q2003
PLATED_HOLE_120_220MILMOUNT_HOLE_PLATED_HOLE_120_220MMOUNTING HOLEIC4BH2101; BH2102; BH2103; BH2104
QFN5X3_0P5_3X3FXLS8471Q_16P_QFN5X3_0P5_3X3_ICFXLS8471QIC1U1301
QFN28_5X5MM_3P3_EPCP2102_QFN28_5X5MM_3P3_EP_IC_1MCP2102IC1U1901
QFN32_0P5_EP3P3KSZ8081RNB_32P_QFN32_0P5_EP3P3_KSZ8081RNBIC2U1501; U1601
QFN32_S142EPWM8960_QFN_33P_QFN32_S142EP_IC_WM8960IC1U1401
SC_75PNP_SC_75_IC_0.9 MM_480-78465_MMMBT3906TT1GIC1Q2001
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U1101
SO8_1P27_4X5MC33901WEF-8P_SO8_1P27_4X5_IC_1MC34901WEFIC2U1201; U1202
SODIMM_200_STD_0P6_SM_1SD200_0_SODIMM_200_STD_0P6_SM_1DDR2 SODIMM 200IO1J2101
SOD_523DIODE_SCHTKY_SOD_523_IC_0.7MM_4RB521S30T1GIC9D901; D1102; D1701; D1702; D1801; D1802; D1905; D1906; D2002
SOD_523_1P4ZDIODE_SOD_523_1P4_IC_0.7MM_480MM5Z5V1ST1GIC1D2001
SOT23-5_AUM1750S-00_5P_SOT23-5_A_IC_1.25UM1750S-00IC2U1802; U1803
SOT23_S6SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4IC2U1102; U1203
SOT323_32SK3018_SOT323_3_IC_0.9MM_480-72SK3018IC7Q1102; Q1103; Q1702; Q1703; Q1801; Q1802; Q2004
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401IC4Q901; Q1101; Q1701; Q2101
SOT-723DZ_DUAL_CK_C1C2A_SOT-723_IC_0.5ESD7CIC1D1101
SSOP8SN74LVC2G126DCTR_SSOP8_IC_1.30SN74LVC2G126IC1U1902
SW4_PB_ESW_SM_P177SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBIC2SW2101; SW2102
SW6_DPDT_11X6MMSW_DPDT_3_SW6_DPDT_11X6MM_IC_9.EG2209AIC1SW2001
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILIC30TP1001; TP1501; TP1601; TP1802; TP1803; TP1901; TP1902; TP1903; TP1904; TP1905; TP1906; TP2001; TP2002; TP2003; TP2101; TP2102; TP2103; TP2104; TP2105; TP2106; TP2107; TP2108; TP2109; TP2110; TP2111; TP2112; TP2113; TP2114; TP2115; TP2116
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO1TP1713
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPIO2TP2129; TP2130
TPAD_015TESTLOOP_TPAD_015_IO_0.1MM_211-TPAD_015IO3TP1502; TP1503; TP1602
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020IO13TP1301; TP1302; TP1303; TP1703; TP1705; TP2117; TP2118; TP2120; TP2121; TP2124; TP2126; TP2127; TP2128
TSSOP1674LV595_TSSOP16_IC_1.1MM_312-7974LV595PWIC1U2101
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
: Q3 c! W6 B4 l; L/ p
推荐
发表于 2021-10-25 21:59 | 只看该作者
学习一下 希望楼主能够分享下
8 A6 S7 Y0 X, }! i/ J
推荐
发表于 2021-7-15 10:27 | 只看该作者
学习一下,希望资料有帮助
$ G: t) W: g2 m
推荐
发表于 2020-10-29 17:17 | 只看该作者
学习一下,希望资料有帮助
    郁闷
    2024-4-8 15:07
  • 签到天数: 51 天
    [LV.5]常住居民I
    发表于 2020-10-31 12:16 | 只看该作者
    楼主好人一生平安
    擦汗
    2021-1-27 15:35
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2020-12-17 09:48 | 只看该作者
    11111111111
    发表于 2021-7-1 16:16 | 只看该作者
    学习下,希望资料有用5 \2 a8 f5 W: \( Q7 m( o. R1 e7 j$ a
    . N8 U# ?) `( P0 T# F- m+ A
    # U& F; U" Y/ t- q+ m
    发表于 2021-7-6 10:07 | 只看该作者
    学习下,希望资料有用7 _0 F$ A8 h) C! w$ x6 h( z6 l
    发表于 2021-7-7 12:41 | 只看该作者
    非常好的资料
    发表于 2022-5-21 15:00 | 只看该作者
    XIEXIE BOSS; Y% _7 @# N+ A, I, F) K* W5 ]2 ^; @
    13#
    发表于 2022-5-21 15:02 | 只看该作者
    非常好的资料
    GMT+8, 2025-7-19 06:58 , Processed in 0.171875 second(s), 30 queries , Gzip On.
