1. 作品用途:NRF52832方案
2. 软件版本:allegro17.2
3. 层数:2层
5. PCB尺寸:异形
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
ANTP | ANTENNA_ANTP_AT15-B | AT15-B | IC | 1 | E1 |
BRE-3728 | MOTOR AC_1_BRE-3728_BER-3728 | BER-3728 | IC | 1 | M1 |
C0201 | CAP NP_C0201_1UF | 1uF | IC | 3 | C1; C21; C28 |
C0201 | CAP NP_C0201_0.1UF | 0.1uF | IC | 12 | C3; C6; C7; C8; C18; C19; C22; C23; C25; C29; C35; C36 |
C0201 | CAP NP_C0201_12PF | 12pF | IC | 3 | C4; C10; C15 |
C0201 | CAP NP_C0201_20PF | 20PF | IC | 2 | C5; C9 |
C0201 | CAP NP_C0201_100PF | 100pF | IC | 1 | C11 |
C0201 | CAP NP_C0201_NC | NC | IC | 2 | C12; C17 |
C0201 | CAP NP_C0201_2.2UF | 2.2uF | IC | 2 | C13; C14 |
C0201 | CAP NP_C0201_0.8PF | 0.8pF | IC | 1 | C16 |
C0402 | CAP NP_C0402_4.7UF | 4.7uF | IC | 4 | C2; C20; C27; C33 |
C0402 | CAP NP_C0402_0.1UF | 0.1uF | IC | 1 | C31 |
C0603 | CAP NP_C0603_2.2UF | 2.2uF | IC | 1 | C32 |
D0402 | DIODE BI-DIR TRIG_D0402_BTR04F1 | BTR04F15 | IC | 1 | D2 |
DFN-10 | IQS263_3_DFN-10_IQS263 | IQS263 | IC | 1 | U2 |
FPC0_7X13 | QG-6428TSWKG01_FPC0_7X13_QG-642 | QG-6428TSWKG01 | IC | 1 | J1 |
FPC10X0_4 | 24_5804_010_FPC10X0_4_24_5804_0 | 24_5804_010 | IC | 1 | CN2 |
FPC10X0_4_B | 24_5804_0_FPC10X0_4_B_24_5804_0 | 24_5804_010 | IC | 1 | CN1 |
L0201 | INDUCTOR_L0201_3.9NH | 3.9nH | IC | 1 | L3 |
L0201 | INDUCTOR_L0201_NC | NC | IC | 1 | L4 |
L0402 | INDUCTOR_L0402_15NH | 15nH | IC | 1 | L1 |
L0603 | INDUCTOR_L0603_10UH | 10uH | IC | 1 | L2 |
L2016 | INDUCTOR_L2016_LQH2MCN100M52 | LQH2MCN100M52 | IC | 1 | L5 |
LGA12 | KX022-1020_LGA12_KX022-1020 | KX022-1020 | IC | 1 | U1 |
QFN48 | NRF52832_0_QFN48_NRF52832 | NRF52832 | IC | 1 | U3 |
R0201 | CAP NP_R0201_0.1UF | 0.1uF | IC | 3 | C24; C26; C34 |
R0201 | CAP NP_R0201_1UF | 1uF | IC | 1 | C30 |
R0201 | RESISTOR_R0201_330R | 330R | IC | 3 | R1; R2; R3 |
R0201 | RESISTOR_R0201_10K | 10K | IC | 5 | R4; R5; R6; R7; R8 |
R0201 | RESISTOR_R0201_NC | NC | IC | 1 | R9 |
R0201 | RESISTOR_R0201_16K_1% | 16K_1% | IC | 1 | R11 |
R0201 | RESISTOR_R0201_2K | 2K | IC | 1 | R18 |
R0201 | RESISTOR_R0201_810K 1% | 810K 1% | IC | 1 | R19 |
R0201 | RESISTOR_R0201_1M | 1M | IC | 1 | R20 |
R0201 | RESISTOR_R0201_155K 1% | 155K 1% | IC | 1 | R21 |
R0201 | RESISTOR_R0201_560K | 560K | IC | 1 | R22 |
R0201 | RESISTOR_R0201_1M_1% | 1M_1% | IC | 3 | R23; R24; R25 |
R0201 | RESISTOR_R0201_196K_1% | 196K_1% | IC | 1 | R26 |
R0603 | RESISTOR_R0603_25.5R | 25.5R | IC | 1 | R17 |
R-XBGA-N6 | TPS61046_0_R-XBGA-N6_TPS61046 | TPS61046 | IC | 1 | U9 |
SOD523 | DIODE SCHOTTKY_SOD523_SD103AX | SD103AX | IC | 2 | D1; D3 |
SOT23 | NPN BCE_0_SOT23_MMBT3904 | MMBT3904 | IC | 1 | Q1 |
SOT23 | XC6206P332MR_3_SOT23_XC61CC3302 | XC61CC3302MR-G | IC | 1 | U5 |
SOT23-5 | XC6206P332MR_2_SOT23-5_XC6215B3 | XC6215B332MR-G | IC | 1 | U6 |
SOT23-5 | XC6802A42XMR-G_SOT23-5_XC6802A4 | XC6802A42XMR-G | IC | 1 | U8 |
TEST_0_8MM | T POINT S_TEST_0_8MM_RX | RX | IC | 1 | T1 |
TEST_0_8MM | T POINT S_TEST_0_8MM_TX | TX | IC | 1 | T2 |
TEST_0_8MM | T POINT S_TEST_0_8MM_SWDIO | SWDIO | IC | 1 | T3 |
TEST_0_8MM | T POINT S_TEST_0_8MM_SWDCLK | SWDCLK | IC | 1 | T4 |
TEST_0_8MM | T POINT S_TEST_0_8MM_3V3 | 3V3 | IC | 1 | T5 |
TEST_0_8MM | T POINT S_TEST_0_8MM_GND | GND | IC | 1 | T6 |
TEST_1_2MM | T POINT S_TEST_1_2MM_B+ | B+ | IC | 1 | P1 |
TEST_1_2MM | T POINT S_TEST_1_2MM_B- | B- | IC | 1 | P3 |
USON8L | W25Q80BLEEK_0_USON8L_W25Q80BLEE | W25Q80BLEEK | IC | 1 | U4 |
VUSB_A | T POINT S_VUSB_A_VUSB | VUSB | IC | 1 | P2 |
VUSB_A | T POINT S_VUSB_A_GND | GND | IC | 1 | P4 |
WLCSP8 | YAS537_WLCSP8_YAS537A | YAS537A | IC | 1 | U7 |
X2012 | CRYSTAL_X2012_32.768KHZ | 32.768KHz | IC | 1 | X2 |
X2520 | CRYSTAL1-4/SM_0_X2520_32MHZ | 32MHz | IC | 1 | X1 |
