作品名:[AD 10][6层] TERAWINS T100 +TSC2003+BA6247FP 做的车载TFT 显示屏板 PCB共享. Q i$ U' G& D
3 z* D+ t7 {( H7 E* c4 S文件描述0 j- f2 X- y3 ^+ j. @ c
1. 作品用途:车载TFT 显示屏板$ c0 Z6 N- X+ g" W
2. 软件版本:AD 10. o3 h; ]* I3 h& V
3. 层数:6层板) W+ \1 w, Q# O+ E
4. 用到的主要芯片:TERAWINS T100 +TSC2003+BA6247FP: a- c8 B, t# A& b: u; C
5. PCB尺寸:164.7mm*120.7mm
2 M5 N+ Y p! [0 {; }8 w: g
2 p; D6 y- n3 \5 V; @& G# K作品截图如下:/ a4 Y4 i; W+ i
顶层截图: i5 x) `: k* g* m- g
' _' h7 p& W- S8 b' I
* T0 z& P6 }" Z: W- j底层截图:/ d" \1 W5 [% _ J
9 a! w* r. w& Y
9 r$ C# x- M, ^8 \+ s N. j/ S全层截图:
* ~% O% X4 z- ?9 F( W
3 ^, ~8 C6 n5 \* x3 R! p
3 ^+ Y2 C H/ U! ]
叠层信息截图如下:9 V& C9 N) e6 |* r" j. ?2 y
$ z* e* q! Y& F; W# Z; T( w
9 e$ n0 z- M4 s, m% v& w. _BOM:
" [* I# X8 V. z) }Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | T POINT R | 2V5, FIB201, PWM201, TP201, VB, VG, VR | p1 | 7 | > | < | TS3M | 1 | > | > | TS2M | 1 | AS/PS | AS/PS | TS3M | 1 | 680pF | C11, C12, C15, C16, C30, C31 | C0603 | 6 | 330pF | C13, C14, C17, C18, C32, C33 | C0603 | 6 | 224 | C19, C34, C35, C110, C111 | C0603 | 5 | 104 | C21, C22, C23, C26, C27, C161, C504, C506, C907, C908 | C0603 | 10 | 821 | C24, C25 | C0603 | 2 | 1uF | C28, C29, C152, C153, C154, C155, C212 | C0603 | 7 | 47nF | C112 | C0603 | 1 | 0.1uF | C113, C114, C115, C116, C117, C118, C119, C120, C121, C122, C123, C124, C125, C126, C127, C128, C129, C130, C131, C132, C133, C134, C135, C136, C137, C138, C139, C140, C141, C142, C143, C144, C145, C146, C147, C148, C149, C150, C151 | C0603 | 39 | 100pF | C156, C157, C158 | C0603 | 3 | 22PF | C159, C160 | C0603 | 2 | 47uF/E | C213, E16 | E-SMD | 2 | 47uF/10V | C214, C215, C216, E15 | E-SMD | 4 | 100uF/E | C217 | E D型 | 1 | 103 | C900, C902, C903, C905, C912 | C0603 | 5 | 105 | C901, C904, C909, C910 | C0603 | 4 | 225 | C906 | C0603 | 1 | 474 | C913 | 22P(3KV)A | 1 | 474 | C914 | C0603 | 1 | CON26 | CN11 | 26P0.5T | 1 | 4P | CN500 | 4P1.0T | 1 | | CN800 | 2PH | 1 | 5819 | D1 | SMD5822 | 1 | LED | D3, D9, D10, D50 | LED-0805 | 4 | IN4148 | D4, D5 | SOD-80 | 2 | LED | D49 | LED0805 - DUPLICATE | 1 | 10uF/E | E11, E12, E13 | E-SMD | 3 | 10uF/E | E14 | E1206 | 1 | 100uF/16V | E17 | E-SMD | 1 | 100uF/E | E18, E19 | E-SMD | 2 | 100UF/16V | E21 | E D型 | 1 | 100u/16V | E22, E23 | E D型 | 2 | 47UF/25V | E24, E25, E26 | E D型 | 3 | 10U/6.3V | E110, E111, E112 | E1206 | 3 | 47uF/10V | E500, E502 | E-B | 2 | 22uF/16 | E900, E901 | E D型 | 2 | CON40_1 | J1 | CN40(0.5) | 1 | 9PIN | J3 | CN9(1.0) | 1 | 2.7uH | L1, L3, L11, L12, L13, L14 | 0805R | 6 | 10UH | L4 | 0805R | 1 | FB | L15, L16, L17 | 0805R | 3 | 10UH | L18 | L1210 | 1 | 102UH | L21, L23 | BCR63B | 2 | 102UH | L22 | R1206 | 1 | 10UH | L24 | R1206 | 1 | *** | L100 | R0805 | 1 | 10uH | L504 | R0805 | 1 | L | L900 | L-D10A | 1 | MICROPHONE | MIC300 | MICROPHONE | 1 | MONO | MONO | TS3M | 1 | PA | PA | TS2M | 1 | 3904 | Q11, Q12, Q13 | SOT-23 | 3 | 8550 | Q900 | SOT-23 | 1 | C103 | Q901 | SOT-23 | 1 | 18 | R11, R12, R13, R14, R48, R49 | R0603 | 6 | 56 | R15, R16, R17, R18, R50, R51 | R0603 | 6 | 151 | R19, R110, R111 | R0603 | 3 | 2.2R | R21, R22, R23 | R1206 | 3 | 180R | R24 | R0603 | 1 | 910 | R25 | R0603 | 1 | 270R | R26, R27, R28, R29, R52 | R0603 | 5 | 39K | R53 | R0603 | 1 | 220R | R54, R55, R500, R501 | R0603 | 4 | 27K | R112, R113, R114, R214 | R0603 | 4 | 10K | R115, R116, R117, R118, R125, R126, R127, R154, R156, R157, R160, R906, R909 | R0603 | 13 | 511 | R119, R120, R121 | R0603 | 3 | 100 | R122, R123, R124 | R0603 | 3 | 1M | R128 | R0603 | 1 | 33 | R129, R130, R131, R132, R133, R134, R135, R136, R137, R138, R139, R140, R141, R142, R143, R144 | R0603 | 16 | 47K | R145, R146 | R0603 | 2 | 11K | R147, R148 | R0603 | 2 | NC | R149 | R0603 | 1 | 4.7K | R150 | R0603 | 1 | 0 | R151, R152 | R0603 | 2 | 1.2K | R153, R904 | R0603 | 2 | 20K | R155 | R0603 | 1 | 2K | R159, R161 | R0603 | 2 | 12K | R211, R212, R216 | R0603 | 3 | 1K | R213 | R0603 | 1 | 18K | R215 | R0603 | 1 | 8.2K | R217 | R0603 | 1 | *** | R310, R314 | R0603 | 2 | 51K | R503 | R0603 | 1 | 100K | R900, R903 | R0603 | 2 | 2.2K | R901 | R0603 | 1 | 330K | R902 | R0603 | 1 | 22K | R905 | R0603 | 1 | 4.3K | R907 | R0603 | 1 | 10R | R908 | R0603 | 1 | | TP202 | p1 | 1 | TERAWINS T100 | U1 | T100 | 1 | NJM3414AM | U2 | SOM-8D | 1 | 5291 | U3, U4 | SOP-8 | 2 | 78M05 | U5 | SOT-252-3 | 1 | RT9164-33CG/PT7117 | U6, U7 | SOT-223 | 2 | RT9164-25CG | U9 | SOT-223 | 1 | KIA7032 | U11 | KIA7035(TO-92) | 1 | TSC2003 | U500 | TSSOP16 | 1 | TSSOP20 | U900 | TSSOP20 | 1 | INVERT-U19.8 | U901 | INVERT_UI9.8 | 1 | INVERTER | U902 | INVERTER | 1 | T POINT R | VCOM_IN, VCOM_OUT | TP | 2 | 1K | VR201 | VR | 1 | 5K | VR202 | VR | 1 | 27MHZ | Y201 | HC-49S | 1 |
- y/ v h; h. ^+ w: [附件:
3 l9 `) r2 r6 nPCB源文件如下:
" |1 F4 a) |3 C& x
. I0 I6 q/ s4 a* z" q8 P3 F, ], R( m [
