查看: 230|回复: 0
[allegro16.3][4层] CircuitCo 的 SN74AVC32T的参考设计(TFP410+ TLV320AIC3106...
发表于 2020-1-13 14:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][4层]  CircuitCo 的 SN74AVC32T的参考设计(TFP410+  TLV320AIC3106+HDR)原理图和pcb文件
/ T. W% J  x& z+ B+ u
7 k" A/ b" D, A! J7 n6 b文件描述:% m2 N/ _, s) X1 t! K% K4 U8 Y  T
# M* b& o, n5 n  [, T
1. 作品用途: CircuitCo 的 SN74AVC32T的参考设计
' [$ }- M& I9 w' s+ q! R0 F( f2. 软件版本:allegro16.3
* M! G8 t2 T# a& K3 \3. 层数:4层2 M! f9 b1 V  ?- |/ H& S6 r
4. 用到的主要芯片:TFP410+  TLV320AIC3106+HDR2 v1 K# I2 C$ l4 k9 d  v
5. pcb尺寸: 异形
- {( P5 t  I; A* ]  @1 x% d0 f* W( a4 s4 u6 \
作品截图如下:
* q7 n& n3 a" O6 N6 }: \- w* t8 u  e
# a& n' q) e* o3 @/ a! _顶层截图:4 ~/ [0 C) ?  j' L! _: ?% J
# }$ `: [3 R" k& R
底层截图:/ s2 s# T1 z9 i7 b, B& d6 {
- G" q' a/ a1 G: h0 k2 k6 h + I7 l( L+ ~% i" F$ Y9 |. d9 p
全层截图:5 e% S; t9 [% s4 ~9 R0 {
/ ?1 B8 e: g! t% j5 ^% h 2 ?) @: u- x0 c- O) V; X0 B5 o
叠层阻抗信息如下:
' \4 |, o( E. C6 R/ h- ] ; J. R; f- z: l" \
BOM:
6 B8 p2 y$ j1 p& [1 l; H- ^
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
4020.01UFCAPACITOR16V10%0402_402_00.01uFIC14C5; C6; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C81
402CAP,0.1UF_402_0.1UF0.1uFIC19C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C18; C19; C20; C21; C22; C23; C50; C51; C79
402CAP_0402_47PF_COG_50V_402_47PF47pFIC4C48; C49; C53; C61
4020.1UFCAPACITOR16V10%0402_402_0.0.1uFIC5C52; C54; C57; C60; C63
402CAP_0402_0R1UF_X7R_10V_402_0.1U0.1uFIC1C78
402CAP,0.1UF_402_0.1UF, DNI0.1uF, DNIIC1C80
402ZEROOHMRESISTOR1/16W0402_402_3333,DNIIC1R1
402RES_33_0402_402_33,402
33,402
IC20R16; R18; R20; R22; R24; R26; R28; R31; R33; R35; R36; R38; R40; R42; R44; R45; R58; R60; R62; R64
402RES_33_0402_402_10,402
10,402
IC20R37; R39; R41; R43; R52; R54; R59; R63; R65; R66; R69; R70; R74; R75; R76; R77; R78; R79; R80; R81
402RES_10K_0402_402_10K10KIC4R86; R90; R94; R95
402RES_510_0402_402_510510IC1R87
402RES_1K_0402_402_1.1K1.1KIC2R88; R92
402RES_4.7K_0402_402_4.75K4.75KIC5R89; R93; R116; R117; R118
402RES_10K_0402_402_10K,DNI10K,DNIIC1R91
402RES_0_0402_402_RES_0_0402,DNIRES_0_0402,DNIIC3R96; R97; R98
402ZEROOHMRESISTOR1/16W0402_402__133IC1R108
402RES_33_0402_402_3333IC2R109; R110
402RES_0_402_DISCRETE_28K_1%28KDISCRETE1R112
402RES_0_402_DISCRETE_56.2K_1%56.2KDISCRETE1R113
402RES_470_1/10W_5%_0402_402_5.6K,5.6K,5%IC2R114; R115
402RES_470_1/10W_5%_0402_402_470,5470,5%IC2R119; R120
402RES_100K_1/16W_1%_0402_402_100K100K,1%IC2R121; R122
402RES_470_1/10W_5%_0402_402_10K10KIC1R123
402RES_33_402_DISCRETE_0, DNI_1%0, DNIDISCRETE2R130; R132
402RES_33_402_DISCRETE_0_1%0DISCRETE2R131; R133
805CAP_10UF_Y5V_10V_10%_0805_805_110uF,10VIC5C1; C2; C3; C4; C17
805CAP,10UF_805_10UF,080510uF,0805IC5C55; C56; C58; C59; C62
805RES_0.1_0805_805_.1,0805.1,0805IC1R111
BGA96-ZKE74AVC8T245_0_BGA96-ZKE_74AVC32T74avc32t245IC1U1
C1210-70X10247UFCAPACITOR16V20%1206_C1210-747uFIC2C46; C47
CUI-SJ1-3513-SMTCONN_STEREO_CUI-SJ1-3513-SMT_PHPHONOJACK STEREO-R, DNIIC2P6; P7
DCU8-10X50TXS0102DCU_DCU8-10X50_TXS0102DCTXS0102DCUIC1U3
DRB8-14X33-PADTPS73701_0_DRB8-14X33-PAD_TPS73TPS73701DRBR, DNIIC1U7
F603-41X39PGB0010603MR_F603-41X39_PGB0010PGB0010603MRIC4D1; D2; D3; D4
HDMI-SMT-W-FLANGECONN_HDMI_1_HDMI-SMT-W-FLANGE_CCONN_HDMIIC1P4
HEADER10X2HDR_10_F_2_0.1_HEADER10X2_HDR5XHDR5x2IC1P3
HEADER23X2HDR_46_F_2_0.1_0.1_HEADER23X2_FFEMALE HEADER 2x23IC2P1; P2
IND603-24X32FER_MMZ1608R301A_IND603-24X32_MMMZ1608R301AIC5FB1; FB2; FB3; FB7; FB8
IND603-24X32IND,MMZ1608R301A_IND603-24X32_MMMZ1608R301AIC1FB6
LED0805-1LED_LTST-C150GKT_LED0805-1_DISC598-8170-107FDISCRETE2D5; D6
PAP64-12X70TFP410_PAP64-12X70_TFP410TFP410IC1U2
POLYSW200-5638-310PTC_RXEF010_POLYSW200-5638-310_PTC_RXEF010IC1RT1
QFN48_25VTLV320AIC3106_2_QFN48_25V_TLV32TLV320AIC3106IC1U6
SMINI6-F3-BRN1907_SMINI6-F3-B_DMC56404DMC56404IC1Q1
SOIC_8CAT24C256W_SOIC_8_CAT24C256WCAT24C256WIC1U8
SOIJ8_287CAT24C256W_2_SOIJ8_287_25AA102425AA1024, DNIIC1U9
SWDIP4_100-339SMDSW DIP-2_SWDIP4_100-339SMD_SW DSW DIP-2IC1SW1
TP1-8040T POINT A_0_TP1-8040_T POINT AT POINT AIC2TP1; TP2
XTAL6_5P2X7P5_SMDOSCILLATOR_0_XTAL6_5P2X7P5_SMD_12MHz,FXO-HC735-12IC1Y1
附件:0 ^; v! {" Z& Q4 q/ F# I* `( R
原理图和PCB文件如下:
& Q( U; c3 A: a$ s' [4 i5 s- v! @+ t4 y% {
游客,如果您要查看本帖隐藏内容请回复
, `% N6 v# u; P: N; _( P. P
CircuitCo 的 SN74AVC32T的参考设计(TFP410 TLV320AIC3106 HDR).rar
842.73 KB, 下载次数: 0, 下载积分: 威望 -50
GMT+8, 2025-7-24 12:48 , Processed in 0.125000 second(s), 29 queries , Gzip On.
