Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
402 | CAP_0.1UF_X5R_6.3V_20% 0201 _40 | 0.1uf,6.3V | IC | 100 | C3; C20; C27; C28; C29; C30; C31; C33; C35; C36; C37; C38; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C56; C57; C58; C59; C60; C61; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C92; C93; C94; C97; C98; C99; C100; C101; C102; C103; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C116; C117; C119; C120; C121; C124; C127; C128; C129; C130; C131; C132; C135; C145; C147; C149; C150; C152; C154; C155; C158; C159 |
402 | CAP_2.2UF_X5R_6.3V_10%_0402_402 | 2.2uF,6.3V | IC | 8 | C16; C17; C18; C125; C144; C146; C148; C151 |
402 | CAP_470PF_X7R_25V_10%_0402_402_ | 470pF,6.3V | IC | 1 | C19 |
402 | CAP_18PF_COG_50V_5%_0402_402_18 | 18pF,50V | IC | 4 | C21; C22; C25; C26 |
402 | CAP_1.0UF_X5R_10V_10%_0402_402_ | 1uF,10V | IC | 6 | C24; C89; C90; C91; C104; C134 |
402 | CAP_0.001_X7R_50V_5%_0402_402_0 | 0.001uf,50V | IC | 2 | C32; C123 |
402 | 470PF/5%/50V/C0G/0603_0_0402_47 | 470pF,6.3V | IC | 1 | C136 |
402 | CAP_0402_100PF_COG_50V_402_15PF | 15pF,DNI | IC | 4 | C137; C138; C139; C140 |
402 | CAP_0402_0.1UF_X5R_10V_402_0.02 | 0.022uF,10V | IC | 1 | C141 |
402 | CAP_30PF_COG_50V_5%_0402_402_30 | 30pF,50V | IC | 2 | C142; C143 |
402 | CAP_0.1UF_X5R_6.3V_20% 0201 __1 | 47pf,6.3V | IC | 16 | C156; C157; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173 |
402 | RES_100K_1/16W_1%_0402_402_100K | 100K,1% | IC | 22 | R1; R56; R65; R66; R67; R68; R76; R77; R78; R79; R80; R82; R83; R84; R85; R86; R87; R88; R89; R94; R95; R165 |
402 | RES_1.5K_1/16W_5%_0402_402_1.5K | 1.5K,1% | IC | 4 | R3; R4; R119; R146 |
402 | RES_4.75K_1/16W_1%_0402_402_0,1 | 0,1% | IC | 10 | R5; R6; R7; R9; R50; R51; R159; R160; R161; R162 |
402 | RES_4.75K_1/16W_1%_0402_402_0,D | 0,DNI | IC | 1 | R8 |
402 | RES_470_1/10W_5%_0402_402_470K, | 470K,1% | IC | 1 | R10 |
402 | RES_470_1/10W_5%_0402_402_280K, | 280K,1% | IC | 1 | R11 |
402 | RES_470_1/10W_5%_0402_402_4.75K | 4.75K,5% | IC | 5 | R12; R71; R72; R73; R74 |
402 | RES_10K_1/16W_1%_0402_402_10K,1 | 10K,1% | IC | 29 | R14; R52; R53; R54; R96; R98; R100; R101; R102; R103; R104; R105; R106; R107; R108; R109; R110; R111; R135; R145; R148; R150; R151; R152; R153; R154; R155; R157; R158 |
402 | RES_1M_1/16W_1%_0402_402_1M,1% | 1M,1% | IC | 1 | R17 |
402 | RES_33_0402_0402_33 | 33 | IC | 4 | R18; R21; R28; R167 |
402 | RES_0_1/16W_1%_0402_402_0,1% | 0,1% | IC | 6 | R19; R20; R27; R29; R142; R149 |
402 | RES_4.7K_0402_402_49.9,1% | 49.9,1% | IC | 5 | R22; R120; R121; R122; R123 |
402 | RES_4.75K_1/16W_1%_0402_402_4.7 | 4.75K,1% | IC | 6 | R23; R24; R25; R26; R163; R164 |
402 | RES_33_0402_0402_22 | 22 | IC | 1 | R45 |
402 | RES_33_0402_0402_0 | 0 | IC | 3 | R46; R47; R48 |
402 | RES_100K_1/16W_1%_0402_402_0,1% | 0,1% | IC | 1 | R49 |
402 | RES_100K_1/16W_1%_0402_402_10_1 | 100K,1%,DNI | IC | 16 | R55; R57; R58; R59; R60; R61; R62; R63; R64; R69; R70; R81; R90; R91; R92; R93 |
402 | RES_100K_1/16W_1%_0402_402_100, | 100,1% | IC | 1 | R75 |
402 | RES_10K_1/16W_1%_0402_402_1.5K, | 1.5K,1% | IC | 1 | R97 |
402 | RES_4.75K_1/16W_1%_0402_402_1.5 | 1.5K,1% | IC | 3 | R112; R113; R114 |
402 | RES_4.75K_1/16W_1%_0402_402_10K | 10K,1% | IC | 4 | R115; R116; R117; R118 |
402 | 100-1/10W-1%-0603_4_402_10,1%,D | 10,1%,DNI | IC | 1 | R124 |
402 | 100-1/10W-1%-0603_4_402_100,1% | 100,1% | IC | 5 | R125; R126; R129; R134; R138 |
402 | RES_100_1/10W_5%_0402_402_100,1 | 100,1% | IC | 5 | R127; R128; R131; R133; R139 |
402 | RES_470_1/10W_5%_0402_402_470,5 | 470,5% | IC | 2 | R130; R132 |
402 | RES_10K_1/16W_1%_0402_402_0,1% | 0,1% | IC | 1 | R137 |
402 | RES_0_1/16W_1%_0402_402_0,1%,DN | 0,1%,DNI | IC | 1 | R140 |
402 | RES_1M_1/16W_1%_0402_402_1M,1%, | 1M,1%,DNI | IC | 1 | R141 |
402 | RES_10K_1/16W_1%_0402_402_10,1% | 10,1% | IC | 1 | R143 |
402 | RES_12.1K_1/16W_1%_0402_402_12. | 12.1K,1% | IC | 1 | R144 |
402 | RES_1.5K_1/16W_5%_0402_402_1._1 | 1.5K1% | IC | 1 | R147 |
402 | RES_0_1/16W_1%_0402_402_10K,1% | 10K,1% | IC | 1 | R156 |
402 | RES_22.6K_1/16W_1%_0402_402_27K | 27K,1% | IC | 1 | R166 |
805 | CAP_10UF_Y5V_10V_10%_0805_805_1 | 10uF,10V | IC | 24 | C1; C2; C4; C7; C8; C9; C10; C11; C12; C13; C14; C15; C39; C40; C55; C62; C77; C95; C96; C118; C122; C126; C133; C153 |
805 | RES_0.1_0805_805_.1,0805 | .1,0805 | IC | 1 | R136 |
2520 | IND_2.2UH_2.6A_10%_SMD_2520_LQM | LQM2HPN2R2MG0L | IC | 3 | L1; L2; L3 |
AM33XX_15X15 | IC_AM335X_ZCZ_AM33XX_15X15_XAM3 | XAM3359AZCZ100 | IC | 1 | U5 |
BGA96_T9_P8_9X14 | MT47H256M8_7_BGA96_T9_P8_9X14_M | MT41K256M16HA -125:E | IC | 1 | U12 |
BGA153_P14_P5_11P5X13 | MEM_MNAND_2GB_BGA153_P14_P5_11P | MEM_MNAND_2GB | IC | 1 | U13 |
CONN3-PWR-PJ102A | POWER_JACK_CONN3-PWR-PJ102A_PJ- | PJ-200A | IC | 1 | P1 |
CONN19_HDMI | CONN_HDMI_TYPED_CONN19_HDMI_101 | 10118241-001RLF | IC | 1 | P6 |
DCK5_2P15X1P4 | IC_SN74LVC1G06DCK_0_DCK5_2P15X1 | SN74LVC1G06DCK | IC | 1 | U3 |
DCK5_2P15X1P4 | IC_SN74LVC1G07DCK_DCK5_2P15X1P4 | SN74LVC1G07DCK | IC | 1 | U16 |
DGN-16X60 | TPS2061_1_DGN-16X60_TPS2051 (DG | TPS2051 (DGN) | IC | 1 | U8 |
HEADER10X2_SMD | HDR_10X2_CJTAG_0_HEADER10X2_SMD | CTI JTAG,DNI | IC | 1 | P2 |
HEADER23X2 | HDR_46_F_2_0.1_0.1_HEADER23X2_F | FEMALE HEADER 2x23 | IC | 2 | P8; P9 |
LED_0603 | LED_LTST-C150GKT_0_LED_0603_DIS | LTST-C191TBKT | DISCRETE | 5 | D1; D2; D3; D4; D5 |
MTGH200C125D_PL | MHOLE_MTGH200C125D_PL_MHOLE | MHOLE | IC | 4 | MTG1; MTG2; MTG3; MTG4 |
OSC4_61X65LS_79X98SMD | OSC_12MHZ_1.3V_OSC4_61X65LS_79X | 24.576MHZ | IC | 1 | Y4 |
POLYSW200-5638-310 | PTC_RXEF010_POLYSW200-5638-310_ | PTC_RXEF010 | IC | 1 | RT1 |
QFN32_5X5MM_EP3P3MM | LAN8710 QFN32_1_QFN32_5X5MM_EP3 | LAN8710A | IC | 1 | U14 |
QFN64S9X9P5 | IC_TDA19988_HVQFN64_5_QFN64S9X9 | TDA19988 | IC | 1 | U11 |
RD205SMD_250D | CAP_100UF_TANT_6.3V_3528-21_RD2 | 100uF,6.3V | IC | 1 | C34 |
RJ45-7499010211A | CONN_RJ45_MAG_WE_0_RJ45-7499010 | LPJ0011BBNL | IC | 1 | P5 |
SD-MICRO-SCHA5B0300 | MICROSD_CONN_8_SD-MICRO-SCHA5B0 | SCHA5B0200 | IC | 1 | P10 |
SIP6 | HEADER 6_SIP6_HEADER 6 | HEADER 6 | IC | 1 | J1 |
SM-7351-IND-0805 | FER_180_200_0_SM-7351-IND-0805_ | 150OHM800mA | IC | 5 | FB1; FB2; FB3; FB4; FB7 |
SM-7351-IND-0805 | FER_180_200_0805_SM-7351-IND-08 | 150OHM800mA | IC | 1 | FB5 |
SM-7351-IND-0805 | FER_180_200_0_SM-7351-IND-080_1 | 0.1 Ohm,0805 | IC | 1 | FB8 |
SM-7351-RES-0402 | RES_SM-7351-RES-0402_240 | 240 | IC | 1 | R99 |
SMINI6-F3-B | RN1907_SMINI6-F3-B_DMC56404 | DMC56404 | IC | 2 | Q1; Q2 |
SO8-25X75 | PWR_TLV70233DBV_0_SO8-25X75_TL5 | TL5209 | IC | 1 | U4 |
SOD323 | DIO_SR305_TH_0_SOD323_RB751V40, | RB751V40,115 | IC | 1 | D8 |
SOP8_DCT | IC_SN74AUC1G74_SOP8_DCT_SN74AUC | SN74AUC1G74 | IC | 1 | U6 |
SOT23-5 | MEM_24LC32_SOT23-5_SOT23-5_24LC | 24LC32A | IC | 1 | U7 |
SW4SMD_63X161LS | SW_KT11P2JM_2_SW4SMD_63X161LS_D | KMR231GLFS | DISCRETE | 2 | S1; S3 |
SW4SMD_63X161LS | SW_KT11P2JM_1_SW4SMD_63X161LS_D | KMR231GLFS | DISCRETE | 1 | S2 |
TP1-8040 | TESTPT1_TP1-8040_TESTPT1 | TESTPT1 | IC | 2 | TP1; TP4 |
TP60C33D | TESTPT1_TP60C33D_TESTPT1 | TESTPT1 | IC | 5 | TP5; TP6; TP7; TP8; TP9 |
TP60C_SMD | TESTPT1_TP60C_SMD_TESTPT1 | TESTPT1 | IC | 2 | TP2; TP3 |
TSSOP10 | 32CTQ030/TO_1_TSSOP10_IP4283CZ1 | IP4283CZ10-TT | IC | 2 | D6; D7 |
USB5MINI_4SHIELDED_SMD-5 | MINI-USB-AB-SOCKET_USB5MINI_4SH | USB5MINI | IC | 1 | P4 |
USB_A_SH | CONN_54819-0578_2_USB_A_SH_IO_8 | 87520-0010BLF | IO | 1 | P3 |
U_6_DRY | PROT_TPD4S012_U_6_DRY_TPD4S012 | TPD4S012 | IC | 2 | U9; U10 |
U_8_DCU | IC_SN74LVC2G241_1_U_8_DCU_SN74L | SN74LVC2G241 | IC | 1 | U15 |
U_48_RSL | PWR_TPS65217_2_U_48_RSL_TPS6521 | TPS65217C | IC | 1 | U2 |
XTAL4_126-216SMD | CRYS_32_768KHZ_SMD32_1_XTAL4_12 | 32.768KHz MC-306 | IC | 1 | Y1 |
XTAL150SMD_125X196 | CRYS_24MHZ_SCC_0_XTAL150SMD_125 | 24MHz | IC | 1 | Y2 |
XTAL150SMD_125X196 | SUNTSU ITEMP 25MHZ _0.005% 20PF | 25.000MHz | IC | 1 | Y3 |
附件:
