Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1N5819 | ZHCS1000/SOT_0_1N5819_1N5819 | 1N5819 | IC | 1 | D1 |
3D16 | INDUCTOR_3D16_INDUCTOR | INDUCTOR | IC | 1 | L2 |
9X5P120BOM | 9X5P120_9X5P120BOM_9X5 | 9X5 | IC | 1 | J1 |
3528 | BEAD_ FERRITE_3528_FUSE 2A | fuse 2A | IC | 1 | L1 |
BAR2PTS02 | SIP2_BAR2PTS02_SIP2 | SIP2 | IC | 3 | JP1; JP2; JP3 |
BAT_1220 | BATTERYHOLDER_0_BAT_1220_BATTER | BatteryHolder | IC | 1 | J4 |
BR20 | HDR_2X10_TH_BR20_BR20-H | BR20-H | IC | 1 | J8 |
BUZZER | SPEAKER_BUZZER_BEEP | Beep | IC | 1 | LS1 |
C0603 | DECOUPLING CAPACITOR_C0603_1000 | 1000pF | IC | 4 | C1; C2; C3; C4 |
C0603 | C0603_C0603_100N | 100n | IC | 24 | C5; C9; C10; C11; C12; C13; C14; C15; C21; C22; C25; C26; C29; C30; C36; C37; C38; C39; C40; C41; C43; C44; C45; C46 |
C0603 | C0603_C0603_22P | 22p | IC | 2 | C16; C17 |
C0603 | C1206_C0603_10U | 10u | IC | 3 | C18; C23; C28 |
C0603 | C0603_C0603_470P | 470p | IC | 4 | C19; C20; C33; C34 |
C0603 | C0603_C0603_1U | 1u | IC | 2 | C24; C27 |
C0805 | CE1206_C0805_10U | 10u | IC | 1 | C7 |
C0805 | CE_SMT_C0805_22U | 22u | IC | 1 | C8 |
C1206 | C1206_C1206_10U | 10u | IC | 1 | C35 |
CE1206 | CE1206_CE1206_10U | 10u | IC | 2 | C42; C47 |
CONN40P05 | AT070TN83 V.1_CONN40P05_AT070TN | AT070TN83 V.1 | IC | 1 | U1 |
CON_3_WDC001_575 | DC POWER JACK_CON_3_WDC001_575_ | DC POWER JACK | IC | 1 | J3 |
C_6032 | CE_SMT_C_6032_22U | 22u | IC | 1 | C6 |
C_6032 | FK-V-330UF-16V_C_6032_220UF/10V | 220uF/10V | IC | 2 | C31; C32 |
DBV5 | SC189_DBV5_VALUE | Value | IC | 1 | U2 |
FB-2P | C0603_FB-2P_BA091 | BA091 | IC | 1 | B1 |
FPC4 | HEADER 4_FPC4_FPC4 | FPC4 | IC | 1 | J2 |
HR2X3 | CON6A_HR2X3_CON6A | CON6A | IC | 1 | J13 |
HR911105A | HR911105A_0_HR911105A_J0026D21B | J0026D21B | IC | 1 | J17 |
JEDEC_MS026_BBC_LQFP7X7_48 | DM9161AE_0_JEDEC_MS026_BBC_LQFP | DM9161AEP | IC | 1 | MN3 |
JUMPER3 | CON3_JUMPER3_CON3 | CON3 | IC | 1 | J7 |
JUMPER4 | 4 HEADER_JUMPER4_4 HEADER | 4 HEADER | IC | 1 | J6 |
JUMPER4 | CON4_JUMPER4_CON4 | CON4 | IC | 1 | J12 |
JUMPER4 | CON4_JUMPER4_IIC | IIC | IC | 1 | J14 |
JUMPER5 | CON5_JUMPER5_UART0 | UART0 | IC | 1 | J11 |
MINIUSBA | USB_MICROAB_0_MINIUSBA_10104111 | 10104111-0001LF | IC | 1 | J20 |
OSC4SM_126X98_039 | OSCILLATOR_OSC4SM_126X98_039_50 | 50MHz | IC | 1 | Y2 |
PJ-326A | AUDIO JACK 3.5MM, NO SW_0., SMT | AUDIO JACK 3.5mm, no sw., SMT | IC | 2 | J15; J16 |
PW16 | MAX3232_PW_16_PW16_VALUE | Value | IC | 1 | U3 |
R0603 | BEAD_ FERRITE_R0603_220R | 220R | IC | 1 | L4 |
R0603 | R0603_R0603_0 | 0 | IC | 8 | R1; R2; R3; R4; R5; R6; R7; R8 |
R0603 | R0603_R0603_10K | 10k | IC | 5 | R9; R10; R11; R30; R31 |
R0603 | R0603_R0603_120R | 120R | IC | 1 | R12 |
R0603 | R0603_R0603_5.6K | 5.6K | IC | 4 | R13; R14; R15; R16 |
R0603 | R0603_R0603_33R | 33R | IC | 1 | R17 |
R0603 | R0603_R0603_47K | 47k | IC | 4 | R18; R19; R37; R39 |
R0603 | R0603_R0603_0R | 0R | IC | 3 | R20; R35; R36 |
R0603 | R0603_R0603_22R | 22R | IC | 4 | R21; R27; R28; R29 |
R0603 | R0603_R0603_49.9R | 49.9R | IC | 4 | R22; R23; R24; R25 |
R0603 | R0603_R0603_1.5K | 1.5k | IC | 4 | R26; R40; R42; R43 |
R0603 | R0603_R0603_6.8K | 6.8k | IC | 1 | R32 |
R0603 | R0603_R0603_470R | 470R | IC | 2 | R33; R34 |
R0603 | R0603_R0603_82K | 82k | IC | 1 | R38 |
R0603 | R0603_R0603_100K | 100k | IC | 1 | R41 |
R0603P8 | RESISTOR DIP 4_R0603P8_10K | 10K | IC | 1 | RN1 |
R0603P8 | RR0402_R0603P8_10K | 10K | IC | 4 | RR1; RR4; RR5; RR6 |
R0603P8 | RN0402_R0603P8_22R | 22R | IC | 2 | RR2; RR3 |
R0805 | BEAD_ FERRITE_R0805_220OHM AT 1 | 220ohm at 100MHz | IC | 1 | L3 |
SOP8-50-150A | SN65HVD234_SOP8-50-150A_SN65HVD | SN65HVD230DR | IC | 1 | MN1 |
SOT-23A | NPN_SOT-23A_S9013 | S9013 | IC | 1 | Q1 |
SSOP_28_026_220X400_78 | WM8731_0_SSOP_28_026_220X400_78 | WM8731SEDS | IC | 1 | MN2 |
SUBD9M | DSUB9_M_SUBD9M_DB9M_R | DB9M_R | IC | 2 | J9; J10 |
SW1_2SMT_8X3R7 | SWITCH2_0_SW1_2SMT_8X3R7_SWITCH | Switch | IC | 2 | BP1; BP2 |
TF | PJS008-2110-0_0_TF_PJS008-2110- | PJS008-2110-0 | IC | 1 | J5 |
TP_KEYSTONE_5012 | TEST_POINT_TP_KEYSTONE_5012_TP | TP | IC | 5 | TP1; TP2; TP3; TP4; TP5 |
USB_A_SH | HEADER 6_USB_A_SH_HEADER 6 | HEADER 6 | IC | 2 | J18; J19 |
XTAL4_3P2X2P5_SMD | CRYSTAL_4PIN_XTAL4_3P2X2P5_SMD_ | 12.288MHz | IC | 1 | Y1 |
附件:
