Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C0603 | CAPACITOR_0_C0603_1UF | 1uF | IC | 1 | C9 |
CC0603 | CAPACITOR_0_CC0603_10UF | 10uF | IC | 20 | C1; C2; C3; C5; C6; C7; C8; C10; C11; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C39 |
CC0603 | CAPACITOR_0_CC0603_4.7UF | 4.7uF | IC | 6 | C24; C25; C27; C32; C36; C37 |
CC0603 | CAPACITOR_0_CC0603_1UF | 1uF | IC | 2 | C34; C35 |
CC0603 | CAPACITOR_0_CC0603_1NF | 1nF | IC | 5 | C40; C41; C42; C43; C44 |
CD32 | INDUCTOR_CD32_1.5UH | 1.5uH | IC | 6 | L1; L2; L3; L4; L5; L6 |
DC_002 | BNC-2_DC_002_BNC-2 | BNC-2 | IC | 1 | J50 |
DFN8P0_65B2_00X2_00 | WPM4005_11_DFN8P0_65B2_00X2_00_ | WPM1481 | IC | 1 | Q1 |
IDC-10 | HEADER 5X2_IDC-10_HEADER 5X2 | HEADER 5X2 | IC | 1 | J34 |
LED0805 | LED_2_LED0805_GLED | GLED | IC | 1 | D8 |
LED0805 | LED_2_LED0805_RLED | RLED | IC | 1 | D9 |
QFN49P0_40B6_00X6_00H0_85 | AXP22X_7_QFN49P0_40B6_00X6_00H0 | AXP216 | IC | 1 | U1 |
R0603 | R_R0603_10K | 10K | IC | 1 | R3 |
R0603 | R_R0603_47K | 47k | IC | 1 | R4 |
R0603 | R_R0603_1K | 1K | IC | 2 | R107; R153 |
R0805 | R_R0805_0R01 | 0R01 | IC | 1 | R1 |
SIP-3 | CON3_SIP-3_DC5SET | DC5SET | IC | 1 | J56 |
SIP-3 | CON3_SIP-3_PWREN | PWREN | IC | 1 | J57 |
SIP-3 | CON3_SIP-3_ELDOIN | ELDOIN | IC | 1 | J60 |
SOT-23 | NMOS_XP151_SOT23_1_SOT-23_XP151 | xp151 | IC | 1 | Q24 |
SW4_SMD | SW_PUSH_SW4_SMD_PWRON KEY | PWRON KEY | IC | 1 | SW1 |
TP_PAD | TEST POINT_0_TP_PAD_PWRON | PWRON | IC | 1 | TP18 |
TP_PAD | TEST POINT_0_TP_PAD_TS | TS | IC | 1 | TP19 |
TP_PAD | TEST POINT_0_TP_PAD_PMU_SCK | PMU_SCK | IC | 1 | TP20 |
TP_PAD | TEST POINT_0_TP_PAD_GPIO1 | GPIO1 | IC | 1 | TP21 |
TP_PAD | TEST POINT_0_TP_PAD_DRIVEVBUS | DRIVEVBUS | IC | 1 | TP23 |
TP_PAD | TEST POINT_0_TP_PAD_IRQ | IRQ | IC | 1 | TP24 |
TP_PAD | TEST POINT_0_TP_PAD_PMU_SDA | PMU_SDA | IC | 1 | TP25 |
TP_PAD | TEST POINT_0_TP_PAD_GPIO0 | GPIO0 | IC | 1 | TP26 |
TP_PAD | TEST POINT_0_TP_PAD_DCDC1 | DCDC1 | IC | 1 | TP32 |
TP_PAD | TEST POINT_0_TP_PAD_DCDC2 | DCDC2 | IC | 1 | TP33 |
TP_PAD | TEST POINT_0_TP_PAD_GND | GND | IC | 5 | TP34; TP35; TP38; TP46; TP50 |
TP_PAD | TEST POINT_0_TP_PAD_DCDC4 | DCDC4 | IC | 1 | TP36 |
TP_PAD | TEST POINT_0_TP_PAD_DCDC3 | DCDC3 | IC | 1 | TP37 |
TP_PAD | TEST POINT_0_TP_PAD_DCDC5 | DCDC5 | IC | 1 | TP48 |
TP_PAD | TEST POINT_0_TP_PAD_VINT | VINT | IC | 1 | TP56 |
TP_PAD | TEST POINT_0_TP_PAD_VREF | VREF | IC | 1 | TP57 |
TP_SMD | TEST POINT_0_TP_SMD_PS | PS | IC | 1 | TP13 |
TP_SMD | TEST POINT_0_TP_SMD_ACIN | ACIN | IC | 1 | TP14 |
TP_SMD | TEST POINT_0_TP_SMD_VBUS | VBUS | IC | 1 | TP15 |
TP_SMD | TEST POINT_0_TP_SMD_PMOS_D | PMOS_D | IC | 1 | TP16 |
TP_SMD | TEST POINT_0_TP_SMD_LX_CHG | LX_CHG | IC | 1 | TP17 |
TP_SMD | TEST POINT_0_TP_SMD_DCDC1 | DCDC1 | IC | 1 | TP28 |
TP_SMD | TEST POINT_0_TP_SMD_VIN_CHG | VIN_CHG | IC | 1 | TP30 |
TP_SMD | TEST POINT_0_TP_SMD_PMOS_S | PMOS_S | IC | 1 | TP52 |
TP_SMD | TEST POINT_0_TP_SMD_PMOS_G | PMOS_G | IC | 1 | TP54 |
TP_VIA210 | TEST POINT_2_TP_VIA210_DCDC1 | DCDC1 | IC | 1 | TP39 |
TP_VIA210 | TEST POINT_2_TP_VIA210_GND | GND | IC | 4 | TP40; TP42; TP44; TP82 |
TP_VIA210 | TEST POINT_2_TP_VIA210_DCDC2 | DCDC2 | IC | 1 | TP41 |
TP_VIA210 | TEST POINT_2_TP_VIA210_DCDC3 | DCDC3 | IC | 1 | TP43 |
TP_VIA210 | TEST POINT_2_TP_VIA210_DCDC4 | DCDC4 | IC | 1 | TP45 |
TP_VIA210 | TEST POINT_2_TP_VIA210_DCDC5 | DCDC5 | IC | 1 | TP47 |
TP_VIA210 | TEST POINT_2_TP_VIA210_ALDO1 | ALDO1 | IC | 1 | TP49 |
TP_VIA210 | TEST POINT_2_TP_VIA210_ALDO2 | ALDO2 | IC | 1 | TP51 |
TP_VIA210 | TEST POINT_2_TP_VIA210_ALDO3 | ALDO3 | IC | 1 | TP53 |
TP_VIA210 | TEST POINT_2_TP_VIA210_ELDO1 | ELDO1 | IC | 1 | TP63 |
TP_VIA210 | TEST POINT_2_TP_VIA210_ELDO2 | ELDO2 | IC | 1 | TP66 |
TP_VIA210 | TEST POINT_2_TP_VIA210_GPIO1LDO | GPIO1LDO | IC | 1 | TP71 |
TP_VIA210 | TEST POINT_2_TP_VIA210_PS | PS | IC | 1 | TP73 |
TP_VIA210 | TEST POINT_2_TP_VIA210_VBUS | VBUS | IC | 1 | TP74 |
TP_VIA210 | TEST POINT_2_TP_VIA210_ACIN | ACIN | IC | 1 | TP75 |
TP_VIA210 | TEST POINT_2_TP_VIA210_BAT | BAT | IC | 1 | TP76 |
TP_VIA210 | TEST POINT_2_TP_VIA210_VCC-RTC | VCC-RTC | IC | 1 | TP78 |
TP_VIA210 | TEST POINT_2_TP_VIA210_CHGLED | CHGLED | IC | 1 | TP81 |
USB_MINI_AB | USB_SOCKET_USB_MINI_AB_MINI_AB | Mini_AB | IC | 1 | P1 |
附件:
