查看: 3013|回复: 11
请教大家个IBIS模型的问题,谢谢
发表于 2009-11-12 21:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用TI的DM642做板子# H1 `( n' f; K  n$ _
现在在做仿真
1 ?9 u# \. G0 W3 A5 YDM642共有548个管脚* r4 _* z$ M4 ^2 G
在TI网站上面下载的DM642的模型,里面只定义了277个,
7 |6 C7 p6 J! c在转化为DML模型后用cadence作仿真时候加载模型的时候弹出这样的错误
( `( a) j+ W8 L- `- H, f; y- R+ Y
allegro PCB SI Board L 15.700000 p007 (v15-7-42E)
1 I( b: N" m- M7 A/ J( h/ @7 e8 ^; u# m8 ]  (c) Copyright 2004 Cadence Design Systems, Inc.
$ Y, @) g+ E6 h& T- k: ?. {% I' C
6 H" Z' U6 M) ?  DesignLink : There is no active DesignLink.
- T9 n% N- D& J' w% W9 b  Date       : Nov 12 21:09:43 2009# {4 A- i/ W8 ]7 g  X6 ]
/ K5 M# K$ m4 W, S7 n# Q******************************************************************************* d1 z  a. v$ l6 O8 C# h
INFO >>  The victim net(s) checked are : ; ~1 f6 [7 a0 P5 x2 p! K  U1 p
         DM642-3_pads +1_4V
% ~- B4 s+ ^, b******************************************************************************
% @6 f9 ~$ [* x% I% G3 QINFO >>  Geometry window = 10mil
' i- o: ~1 Y7 s6 a  v: o5 ~: m' `******************************************************************************
( \6 m* p# u, _4 ]& ?% a' T( XINFO >>  No neighbor nets were found.
* z( k# T6 [4 |. L******************************************************************************
# R3 ]) f- a# u, a/ QERROR >>  Discrete component pin(s) with wrong PINUSE property:; P! A3 b- E) _7 f6 m* h
          Pin      Component       Pin Use       Signal Model       Design
3 t; J$ @7 j$ F* }          ---      ---------       -------       ------------       ------
; Z1 @4 C, o3 j6 ]& W* _% ]          C1          U1-            BI          DM642_GDK           DM642-3_PADS
8 a' O2 A+ m0 g8 H. h          E1          U1-            BI          DM642_GDK           DM642-3_PADS
& y( j3 p" i1 x          F1          U1-            BI          DM642_GDK           DM642-3_PADS# F9 r* j, B  |( ]. I; U$ P
          G1          U1-            BI          DM642_GDK           DM642-3_PADS% S* s" }6 d7 r3 W
          J1          U1-            BI          DM642_GDK           DM642-3_PADS
  g* F2 F6 Y1 N/ Y1 w. q7 ~# T' o          K1          U1-            BI          DM642_GDK           DM642-3_PADS2 \. q, ^% t; P( D0 R2 |0 z
          M1          U1-            BI          DM642_GDK           DM642-3_PADS
! }5 M: u# D1 `3 Y4 k5 J          N1          U1-            BI          DM642_GDK           DM642-3_PADS
3 Z8 H- R; t, [. G. q5 A( c/ O          P1          U1-            BI          DM642_GDK           DM642-3_PADS0 M0 X" @' W2 R5 _' |7 K
          R1          U1-            BI          DM642_GDK           DM642-3_PADS
$ r$ C* `; r" J' t! D% Z: O5 A          U1          U1-            BI          DM642_GDK           DM642-3_PADS# A) ]# W$ E+ x9 g
          V1          U1-            BI          DM642_GDK           DM642-3_PADS
) I) a5 X9 g4 x6 T          Y1          U1-            BI          DM642_GDK           DM642-3_PADS
6 Q/ K2 {  D9 k2 |/ f) a          AA1         U1-            BI          DM642_GDK           DM642-3_PADS' X- G: ~! ~  @, x
          AC1         U1-            IN          DM642_GDK           DM642-3_PADS/ N* g$ d* B" h: c
          AD1         U1-            BI          DM642_GDK           DM642-3_PADS
+ l/ B1 M: x  n* \          E2          U1-            IN          DM642_GDK           DM642-3_PADS
5 \% X" }+ H5 s" u          F2          U1-            BI          DM642_GDK           DM642-3_PADS
: o. R( U0 N# o' c- Q          G2          U1-            BI          DM642_GDK           DM642-3_PADS" J3 B7 i9 V* t& n( ^
6 `( p2 S* u/ ^" S, D4 F: y  q请问这个问题该如何解决呀?
# r( q3 {: Q8 X谢谢各位赐教) w4 _' Y8 [" g" e  q. b% J; ]
我是菜鸟,请各位多多帮忙$ V1 H1 I  \, f/ y
谢谢
 楼主| 发表于 2009-11-12 21:27 | 只看该作者
按理说TI给的模型应该不会有问题呀?. N8 W  z8 e3 I  j
那是哪里出问题了呀
% G0 W9 {8 |+ Y; t4 \" C/ h
! j. R& t4 Q' v4 C4 o) o! B搞不懂,导师逼的急: r: S- {" M, H9 u) ]
麻烦大家了
8 y0 [1 G/ z- P9 B. x/ {" B4 _谢谢
 楼主| 发表于 2009-11-12 21:28 | 只看该作者
这个事模型打开后这样:
; j3 g% p/ Z/ ]) Z* l3 t) b* {|
. A; h3 \" R* ~7 D# j2 s% E[Component]     DM642_GDK- U: A8 V. G9 w, ^) \! W% E/ ]- |( [
[Manufacturer]  Texas Instruments
! E; O0 t9 H1 i$ u[Package]
8 B# d& |; K& j3 s1 ^|Variable  Typ         Min       Max
! C1 M9 v& J! a& h" T# G$ x6 TR_pkg     0.12581866  0.0708    0.1927
& K3 U. x8 R& [$ m* @# P# q7 XL_pkg     2.32E-09    1.26E-09  3.57E-09
: B. N3 I! R% m9 i, b% qC_pkg     1.14E-12    6.40E-13  1.77E-12) R) h, R, I* A5 c7 p' K. G; _
3 X! h9 |' t0 I9 B' e% N3 O8 G[Pin]     signal_name  model_name        R_pin     L_pin     C_pin
% c: v9 w- F! ]4 ^C1        PCLK         BPCI66T           0.1647    2.94E-09  1.24E-12
0 y( p( |/ Y9 c- N& mB4        NMI          IT33THYPD         0.1574    2.92E-09  1.37E-120 ]5 h; N+ q6 i' H# F
A4        TINP0        IT33THYPD         0.1714    3.17E-09  1.50E-129 {* A3 x; f& d1 c# R3 k0 p
C5        TOUT0        BT3325CTPD        0.1355    2.49E-09  1.22E-12
& d! \* B- x) l& FB5        TOUT1        BT3325CTPU        0.1504    2.77E-09  1.35E-12
# m/ {7 C3 w0 p0 U4 X1 q/ VA5        TINP1        IT33THYPD         0.1652    3.05E-09  1.47E-12
! ?$ z# t. J3 D1 g7 C+ P6 Z+ u2 iD6        CLKOUT4      BT3315DTHYPU      0.1173    2.16E-09  1.06E-12# r7 M# j% y- q, l* E
C6        CLKOUT6      BT3315DTHYPU      0.1352    2.50E-09  1.19E-120 ]6 {/ Z+ s) b7 ^; v$ {' @- d$ _: Q7 B' e
C7        VP2CTL2      BT3325CTHYPD      0.1341    2.47E-09  1.19E-12
打开后有30个警告:  p5 W3 m1 H6 i* G- |  g
: q1 v$ V7 N( {WARNING (line 6846) - GND Clamp Typical data is non-monotonic
) a" X' n- g6 M6 x9 oWARNING (line 7520) - GND Clamp Maximum data is non-monotonic
+ Q2 Z$ u2 I8 Q1 HWARNING (line 7521) - GND Clamp Typical data is non-monotonic
$ i. @& n+ {) o/ i, X3 e' t% gWARNING (line 7544) - GND Clamp Minimum data is non-monotonic
8 f2 }8 A& w) VWARNING (line 7586) - POWER Clamp Maximum data is non-monotonic
0 s3 @( a! M( `  s) NWARNING (line 7766) - GND Clamp Maximum data is non-monotonic# g6 r5 d0 k* O3 }/ K' h+ X
WARNING (line 7768) - GND Clamp Typical data is non-monotonic: c$ Y7 M1 T- ?  v
WARNING (line 7934) - POWER Clamp Maximum data is non-monotonic
- f8 o- B5 Q6 _) q- r- c' e4 L; r- S
Errors  : 0" x" _5 J5 i$ h6 J, _3 ^
Warnings: 30
 楼主| 发表于 2009-11-12 21:31 | 只看该作者
我错在哪里了呢?
发表于 2009-11-13 08:52 | 只看该作者
俺也想知道商家提供的IBIS模型中Pin和实际元件的引脚名字不同,且数量不同时,如何处理?
发表于 2009-11-16 20:08 | 只看该作者
pin脚不同这问题好解决,只要找到与你想要的管脚同样类型的就可以拿来进行仿真了。
发表于 2009-11-19 16:24 | 只看该作者
lz 你有dm642的模型?我也想用,但是找不到
发表于 2010-11-17 07:53 | 只看该作者
数量不同可以忽略
发表于 2010-11-17 10:54 | 只看该作者
"ERROR >>  Discrete component pin(s) with wrong PINUSE property"% V7 j) L9 |  I* R
* T8 P/ t4 a9 o4 \( `) s  l1 N根据这条信息,应该是器件属性错设成了discrete, 改成IC试试
发表于 2010-11-30 16:34 | 只看该作者
应该是DISCRETE分立元件的属性设置错误了
发表于 2010-12-21 17:36 | 只看该作者
在你的pcb版图中讲pin的map提出来,贴到你的ibis model中,只需将所要仿真的pin model补上,保存后再转成dml模型再试试
GMT+8, 2025-7-20 20:37 , Processed in 0.109375 second(s), 24 queries , Gzip On.
