Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA60F | IS42S16100E_BGA60F_IS42S16100F- | IS42S16100F-5BL | IC | 1 | U901 |
BGA100F | AT32UC3A4256J_BGA100F_AT32UC3A4 | AT32UC3A4256J-C1UR | IC | 1 | U900 |
C0402 | C_GENERIC_C0402_10NF_ | 10nF | IC | 1 | C104 |
C0402 | C_GENERIC_C0402_100NF_10% | 100nF | IC | 38 | C200; C201; C202; C203; C204; C205; C206; C207; C208; C209; C210; C211; C212; C213; C214; C217; C218; C600; C601; C613; C700; C702; C705; C706; C710; C711; C904; C910; C911; C912; C913; C916; C917; C918; C919; C920; C921; C922 |
C0402 | CAP-100NF-0603-25V-X7R_C0402_1U | 1uf | IC | 1 | C215 |
C0402 | C_GENERIC_C0402_10PF_CAP 10UF | 10pF | IC | 2 | C219; C902 |
C0402 | CAP-18PF-0603-50V-COG_C0402_18P | 18pF | IC | 2 | C300; C301 |
C0402 | CAP-18PF-0603-50V-COG_C0402_12P | 12pF | IC | 2 | C302; C303 |
C0402 | CAP_NP_C0402_DISCRETE_24PF | 24PF | DISCRETE | 2 | C704; C709 |
C0402 | CAP-100NF-0603-25V-X7R_C0402_2. | 2.2uf | IC | 6 | C708; C905; C908; C909; C914; C915 |
C0402 | CAP-18PF-0603-50V-COG_C0402_22P | 22pF | IC | 2 | C900; C901 |
C0402 | C_GENERIC_C0402_1NF_5% | 1nF | IC | 1 | C906 |
C0603 | CAP_NP_C0603_DISCRETE_100PF | 100PF | DISCRETE | 1 | C92 |
C0603 | CAP-100NF-0603-25V-X7R_C0603_4. | 4.7uf | IC | 2 | C602; C701 |
C0603 | CAP_NP_C0603_DISCRETE_2.2UF | 2.2UF | DISCRETE | 1 | C603 |
C0805 | C_GENERIC_C0805_10UF_10% | 10uF | IC | 5 | C216; C220; C612; C713; C714 |
F0603 | FBEAD_1_F0603_470OHM@100MHZ | 470ohm@100MHz | IC | 6 | L200; L201; L202; L700; L701; L901 |
H2M | TSW 2PTS-DROIT_1_H2M_HEADER2-10 | HEADER2-100 | IC | 2 | J200; J203 |
H2M_SHORT | TSW 2PTS-DROIT_1_H2M_SHORT_HEAD | HEADER2-100 | IC | 1 | J201 |
H2X2LMZ | HDR 7X2_3.100"_H2X2LMZ_HEARDER | Hearder 2x2 | IC | 1 | J101 |
H2X3MZ | CONN_HDR_3X2_H2X3MZ_IO_CONN_HDR | CONN_HDR_3X2 | IO | 1 | J506 |
H2X10LMZ | CONN_HDR_10X2_H2X10LMZ_IO_SKT_2 | SKT_2x10 | IO | 2 | J401; J402 |
H2X10MZ | CONN_HDR_10X2_H2X10MZ_IO_SKT_2X | SKT_2x10 | IO | 1 | J406 |
H2X18MZ | CONN_HDR_18X2_H2X18MZ_IO_CONN_H | CONN_HDR_18X2 | IO | 1 | J507 |
H8M | CONN_HDR_8X1_H8M_IO_CONN_HDR_8X | CONN_HDR_8X1 | IO | 5 | J501; J502; J503; J504; J505 |
H10M | CONN_HDR_10X1_H10M_IO_CONN_HDR_ | CONN_HDR_10X1 | IO | 1 | J500 |
HS2X10JZ | CONN_HDR_10X2_19_HS2X10JZ_IO_CO | CONN_HDR_10X2_19 | IO | 1 | J403 |
HS2X15_2MZ | CONN_HDR_15X2_HS2X15_2MZ_IO_CON | CONN_HDR_15X2 | IO | 1 | J400 |
LED0805 | LED_SMALL_LED0805_GREEN | Green | IC | 1 | D301 |
LQPF144P5 | SAMV71Q21_2_LQPF144P5_SAME70Q21 | SAME70Q21 | IC | 1 | U200 |
QFN24_1P5M | KSZ8081RNACA_QFN_24P_QFN24_1P5M | KSZ8081RNACA | IC | 1 | U700 |
R0402 | RES_R0402_DISCRETE_1.5K | 1.5K | DISCRETE | 2 | R55; R56 |
R0402 | RES_R0402_DISCRETE_10K | 10K | DISCRETE | 13 | R67; R69; R70; R71; R600; R601; R602; R603; R604; R606; R611; R612; R702 |
R0402 | R_GENERIC_R0402_100K_1% | 100K | IC | 8 | R106; R607; R608; R609; R610; R613; R614; R617 |
R0402 | R_GENERIC_R0402_330R_1% | 330R | IC | 12 | R107; R303; R900; R904; R905; R910; R911; R912; R913; R914; R915; R921 |
R0402 | R_GENERIC_R0402_39R_1% | 39R | IC | 6 | R110; R206; R238; R300; R916; R917 |
R0402 | R_GENERIC_R0402_22R_1% | 22R | DISCRETE | 29 | R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140 |
R0402 | R_GENERIC_R0402_0R_5% | 0R | IC | 37 | R122; R201; R202; R203; R204; R205; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R234; R235; R236; R400; R401; R402; R403 |
R0402 | RES_R0402_DISCRETE_4.7K | 4.7K | DISCRETE | 2 | R231; R232 |
R0402 | R_GENERIC_R0402_5.62K_ | 5.62K | IC | 1 | R233 |
R0402 | RES_R0402_DISCRETE_47K | 47K | DISCRETE | 2 | R615; R616 |
R0402 | RES_R0402_DISCRETE_470 | 470 | DISCRETE | 2 | R701; R703 |
R0402 | R_GENERIC_R0402_1K_ | 1K | IC | 3 | R902; R903; R906 |
R0402_SHORT | PAD_R0402_SHORT_PAD | PAD | IC | 2 | J300; J301 |
R0603 | R_GENERIC_R0603_0R_5% | 0R | IC | 2 | R623; R624 |
R0603 | RES_R0603_DISCRETE_6.49K | 6.49K | DISCRETE | 1 | R704 |
R0603 | R_GENERIC_R0603_6.81K_ | 6.81K | IC | 1 | R918 |
R0805_SHORT | PAD_R0805_SHORT_PAD | PAD | IC | 1 | J901 |
RJ45_RB1-125B_P12_4 | CONN_RJ45_8P_SH_RJ45_RB1-125B_P | RJ45 | IO | 1 | J700 |
SD11_6B280X180 | SD CARD SOCKET_SD11_6B280X180_S | SD Card SOCKET | IC | 1 | J600 |
SOP8_1JA | BD33IC0WEFJ-E2_0_SOP8_1JA_BD33I | BD33IC0WEFJ-E2 | IC | 1 | U601 |
SOT23_6TR_A | FDC6312P_SOT23_6TR_A_FDC6312P | FDC6312P | IC | 2 | Q109; Q110 |
SOT143B | PRTR5V0U2X_0_SOT143B_PRTR5V0U2X | PRTR5V0U2X | IC | 2 | D302; D902 |
SWS4B60S_A | B3S_2_SWS4B60S_A_TP-1138 | TP-1138 | IC | 2 | SW100; SW300 |
TP30 | TESTLOOP_TP30_IO_TPAD_030 | TPAD_030 | IO | 16 | TP100; TP200; TP201; TP300; TP600; TP900; TP901; TP902; TP903; TP904; TP905; TP906; TP907; TP908; TP909; TP910 |
UDFN8CR | AT24MAC402-MAHM-T_UDFN8CR_AT24M | AT24MAC402-MAHM-T | IC | 1 | U600 |
USBMICRO5_6A_A | USB_MINI_AB_RECEPTACLE_USBMICRO | MICRO USB AB 5 | IO | 2 | J302; J900 |
X2S32X15 | CM415_0.768KHZ_X2S32X15_32.768 | 32.768 kHz | IC | 1 | XC300 |
X4S32X25 | CRYSTAL13_X4S32X25_IC_25MHZ | 25MHZ | IC | 1 | XC700 |
X4S50X32 | 12MHZ_0_X4S50X32_12MHZ | 12MHz | IC | 2 | XC301; XC900 |
附件:
