Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402_BGA | 0402_BGA | 0.1UF 16V Y5V 0402 | IC | 88 | CD2; CD3; CD4; CD5; CD6; CD7; CD8; CD9; CD11; CD12; CD13; CD14; CD15; CD16; CD17; CD18; CD19; CD20; CD21; CD22; CD23; CD24; CD25; CD27; CD28; CD29; CK2; CK8; CK9; CK10; CK11; CK12; CK14; CK15; CK16; CK17; CK18; CK20; CK21; CK22; CK23; CK24; CK26; CK27; CK28; CK29; CK30; CK31; CK32; CK33; CK34; CK35; CK36; CK37; CK38; CK39; CK40; CK41; CK42; CK43; CK44; CK45; CK46; CK47; CK49; CK50; CK55; CP8; CP11; CP17; CP19; CP21; CP23; CP24; CP26; CP27; CP31; CP34; CP37; CP38; CP39; CP40; CP45; CP47; CP49; CP50; CP53; CP57 |
0402_BGA | 0402_BGA | 1UF 6.3V X5R 0402 T | IC | 1 | CD26 |
0402_BGA | 0402_BGA | 18P 50V 0402 NPO | IC | 2 | CK3; CK4 |
0402_BGA | 0402_BGA | 1UF 16V X5R 0402 T | IC | 10 | CK51; CK52; CK53; CK54; CK56; CK61; CK62; CK63; CP61; CP63 |
0402_BGA | 0402_BGA | 4.7UF 6.3V 0402 X5R T | IC | 9 | CP5; CP28; CP35; CP42; CP43; CP46; CP51; CP52; CP54 |
0402_BGA | 0402_BGA | 18P 50V 0402 NPO /NI | IC | 2 | CP15; CP30 |
0402_BGA | 0402_BGA | 22P 50V NPO 0402 | IC | 2 | CP32; CP44 |
0402_BGA | 0402_BGA | 100P 50V NPO 0402 | IC | 1 | CP62 |
0402_BGA | 0402_BGA | 0 0402 | IC | 8 | RD1; RD6; RP24; RP35; RZ3; RZ5; RZ7; RZ10 |
0402_BGA | 0402_BGA | 1K 0402 | IC | 4 | RD2; RP30; RP31; RP34 |
0402_BGA | 0402_BGA | 2.2K 1% 0402 | IC | 2 | RD3; RD7 |
0402_BGA | 0402_BGA | 120 0402 | IC | 2 | RD4; RD5 |
0402_BGA | 0402_BGA | 240 1% 0402 | IC | 3 | RD8; RD9; RK3 |
0402_BGA | 0402_BGA | 10K 0402 | IC | 2 | RK21; RP33 |
0402_BGA | 0402_BGA | 100 0402 | IC | 3 | RK22; RP8; RP16 |
0402_BGA | 0402_BGA | 100K 1% 0402 | IC | 3 | RK23; RP6; RP18 |
0402_BGA | 0402_BGA | 10K 0402 /NI | IC | 1 | RK32 |
0402_BGA | 0402_BGA | 47K 0402 /NI | IC | 2 | RP5; RP17 |
0402_BGA | 0402_BGA | 120K 1% 0402 | IC | 2 | RP7; RP19 |
0402_BGA | 0402_BGA | 10K 1% 0402 | IC | 2 | RP9; RP20 |
0402_BGA | 0402_BGA | 180K 1% 0402 | IC | 2 | RP10; RP21 |
0402_BGA | 0402_BGA | 100K 0402 /NI | IC | 2 | RP11; RP22 |
0402_BGA | 0402_BGA | 10M 0402 | IC | 1 | RP12 |
0402_BGA | 0402_BGA | 470 0402 | IC | 1 | RP23 |
0402_BGA | 0402_BGA | 4.7K 1% 0402 | IC | 1 | RP28 |
0402_BGA | 0402_BGA | 6.2K 1% 0402 | IC | 1 | RP29 |
0402_BGA | 0402_BGA | 47K 0402 | IC | 1 | RP32 |
0402_BGA | 0402_BGA | 0 0402 /NI | IC | 5 | RS30; RZ4; RZ6; RZ8; RZ9 |
0402_BGA | 0402_BGA | 4.7K 0402 | IC | 2 | RZ1; RZ2 |
ATC2603_QFN68_0_4 | ATC2603_QFN68_0_4 | ATC2603C QFN68 | IC | 1 | UP1 |
ATM7059_496 | ATM7059_496 | S500 | IC | 1 | U1 |
AZ5123 | AZ5123 | AZ5123-01F.R7G | IC | 1 | MK1 |
BGA96_P080_10X14MM | BGA96_P080_10X14MM | H5TQ4G63CFR-RDC | IC | 2 | UD1; UD2 |
C0402 | C0402 | 0.1UF 16V Y5V 0402 | IC | 1 | CK60 |
C0603 | C0603 | 10UF 6.3V X5R 0603 T | IC | 22 | CD1; CD10; CK7; CK13; CK19; CK25; CK48; CP3; CP6; CP7; CP10; CP14; CP16; CP18; CP20; CP22; CP25; CP29; CP33; CP36; CP41; CP48 |
C0603 | C0603 | 22UF 6.3V X5R 0805 | IC | 2 | CP55; CP56 |
PAD120-4-ECX | PAD120-4-ECX | MT /NI | IC | 4 | MH1; MH2; MH3; MH4 |
R0402 | R0402 | 0 0402/NI | IC | 1 | |
R0805 | R0805 | 0 0805 | DISCRETE | 2 | RP25; RP27 |
SMD-SW-MTA2-WNC-2P | SMD-SW-MTA2-WNC-2P | MTA2-WNC-Q-TR /NI | IC | 1 | SW1 |
SMD-SW-MTA2-WNC-2P | SMD-SW-MTA2-WNC-2P | MTA2-WNC-Q-TR | IC | 2 | SW2; SW3 |
SMDLED_2P_0805-20051213 | SMDLED_2P_0805-20051213 | GREEN CHIP LED 0805 | IC | 1 | LED1 |
SMD_CHOKE_4X4_4H2MM | SMD_CHOKE_4X4_4H2MM | CHOKE 2.2UH 3A 4.3X4.7 SMD | IC | 4 | LP1; LP2; LP3; LP5 |
SMD_CHOKE_4X4_4H2MM | SMD_CHOKE_4X4_4H2MM | CHOKE 4.7UH 2A 4.3X4.7 SMD | IC | 1 | LP4 |
SOT23-5 | SOT23-5 | RT8059 TSOT23-5 | IC | 2 | UP2; UP3 |
SOT23-123 | SOT23-123 | AP2138N-1.5V SOT23 | IC | 1 | UP4 |
SOT23-GDS | SOT23-GDS | P5103EMG SOT23 | IC | 1 | QP3 |
SOT23_123 | SOT23_123 | 2N3906 SOT23 | DISCRETE | 1 | QP2 |
SOT23_ARC | SOT23_ARC | AM431 SOT23 | IC | 1 | DP1 |
SRP-P260 | SRP-P260 | FUSE 0805 2.6A 35mOHM | IC | 1 | FSH1 |
TP30 | TP30 | TP /NI | IC | 13 | TP16; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP35; TP36; TP39 |
XTAL-3_2X2_5MM | XTAL-3_2X2_5MM | 24MHZ 12PF 30PPM 3.2X2.5 | IC | 1 | YK1 |
XTAL-CM315 | XTAL-CM315 | 32.768KHZ_CITIZEN | IC | 1 | YP1 |
附件:
