查看: 445|回复: 4
[allegro16.6][4层] 一个WIFI 通信模块核心板(AR9342+DDR+SKY85735)pcb文件
发表于 2020-1-11 11:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
! r/ g5 Q" y2 X8 f6 v7 C" W; u* }[allegro16.6][4层] 一个WIFI 通信模块核心板(AR9342+DDR+SKY85735)pcb文件: B7 e. v- S  W6 w! [( r% ]
9 j% F; n- w4 G9 {9 t( L% \
文件描述:- z3 f1 ^( J) h: D8 u
; C& R! _; r& `# `( k0 [' s1. 作品用途: 一个WIFI 通信模块核心板3 E" B( h, I0 b
2. 软件版本:allegro16.6
2 A4 n) }3 u: G+ W: W# O3. 层数:4层
$ p4 P, W9 W4 F5 V( \5 y4 X6 x4. 用到的主要芯片:AR9342+DDR+SKY857352 D# E% Z2 O# b% u* U8 H
5. pcb尺寸: 1836* 1181.1 MIL/ ~1 X) ]% l% B9 u' x4 s7 H
8 |0 v7 o, ?0 A! g+ k
作品截图如下:
7 \$ h/ A% {2 x5 K5 U0 [: d' \9 P, M0 l
顶层截图:
2 C% T5 V7 D1 a3 X0 q
0 `3 m- E' S+ E- B% l  r* [底层截图:
; y" Z! s" _9 n% G4 T. q 7 V& V' o# b( r' Z; \
% U7 y! t2 U8 ?全层截图:
+ p2 [" ^5 ~/ y$ `# ~0 [6 E9 {9 J , \7 p8 F  ~' T# s0 t4 x
* O5 e) ~; W" i/ D8 s' V
6 c( R' W' N9 `! q
. ~0 v. z& j" y4 L# T  {" Q8 Z1 v
BOM:
- H+ [- D4 J/ `+ @
Bill of Material Report (Condensed)
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_CLASS
QUANTITY
REFDES
名称
类型
属性
类别
数量
位号
BGA-84-9X15-3
BGA-84-9X15-3
IC
U3
C0805
C0805
IC
14
C4; C6; C7; C9; C11;  C127; C137; C148; C182; C223; C393; C394; C733; C743
CAP-0201
CAP-0201
IC
109
C3; C27; C28; C48;  C53; C54; C55; C56; C57; C60; C61; C62; C75; C78; C81; C111; C112; C125;  C134; C135; C136; C138; C146; C147; C155; C156; C157; C161; C174; C176; C177;  C178; C179; C180; C183; C193; C194; C195; C196; C203; C204; C205; C206; C215;  C216; C217; C218; C219; C220; C228; C230; C291; C398; C422; C423; C424; C427;  C428; C430; C431; C432; C433; C436; C437; C438; C439; C441; C442; C443; C446;  C447; C564; C567; C717; C737; C738; C739; C740; C741; C742; C744; C745; C746;  C747; C748; C751; C974; C987; C995; C997; C998; C999; C1000; C1001; C1002;  C1004; C1006; C1007; C1008; C1010; C1011; C1012; C1013; L68; L69; L71; L72;  R612; R618
CAP-0402
CAP-0402
IC
32
C2; C5; C8; C10; C12;  C108; C109; C122; C123; C124; C128; C130; C133; C142; C149; C150; C151; C152;  C160; C163; C170; C171; C181; C187; C213; C214; C734; C735; C994; C996;  C1003; C1005
CAP-0603
CAP-0603
IC
8
C32; C107; C166;  C167; C184; C199; C732; C1009
CON-HRS-UFL
CON-HRS-UFL
IC
J8; J9
CONNS_36PIN_1_27_FT
CONNS_36PIN_1_27_FT
IC
J5
CRY-SMD4-CX101F
CRY-SMD4-CX101F
IC
Y2
HOLE2_5MM
HOLE2_5MM
IC
TP2; TP3
IND-0201
IND-0201
IC
12
C425; C426; C434;  C445; L70; L73; L74; L75; L76; L77; L512; L515
IND-SM-3X3
IND-SM-3X3
IC
L1
QFN12_2X2_SKY85735
QFN12_2X2_SKY85735
IC
U7; U8
QFN-DR-149-EP
QFN-DR-149-EP
IC
U1
RES-0201
RES-0201
IC
51
R1; R2; R5; R12; R15;  R16; R30; R31; R32; R33; R34; R35; R50; R63; R74; R79; R95; R97; R124; R139;  R140; R142; R144; R145; R146; R156; R157; R158; R173; R175; R613; R614; R619;  R620; R629; R630; R631; R632; R633; R636; R638; R639; R640; R721; R747; R754;  R768; R769; R770; R771; R772
RES-0402
RES-0402
IC
12
R4; R14; R83; R85;  R102; R111; R773; R774; R775; R776; R777; R778
RES-0603
RES-0603
IC
10
R198; R202; R203;  R206; R207; R210; R211; R212; R213; R233
SO8-200
SO8-200
IC
U5
TRA-SOT23
TRA-SOT23
IC
Q1
附件:
5 r0 o& l% A+ ?7 `PCB文件如下:
0 `7 e: \: P6 k$ B( u
游客,如果您要查看本帖隐藏内容请回复
) i  K& N2 }* S( w
  B9 X3 H. D0 X
发表于 2020-10-17 14:30 | 只看该作者
想学习一下,谢谢
    2021-9-8 15:29
  • 签到天数: 165 天
    [LV.7]常住居民III
    发表于 2020-11-29 08:55 | 只看该作者
    谢谢楼主分享/ r/ d: F0 \1 s0 b1 n" q9 y7 b+ E7 g
    发表于 2020-12-8 10:12 | 只看该作者
    华为海思新一代PLC-IOT电力载波模组13632813280
    发表于 2022-5-13 12:22 | 只看该作者
    GMT+8, 2025-7-23 06:57 , Processed in 0.125000 second(s), 27 queries , Gzip On.
