查看: 804|回复: 7
[allegro16.6][6层] Amlogic M802(M801) 平板电脑(M801+HDMI+2片DDR)pcb文件
发表于 2020-1-10 18:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
3 u6 E5 n( i3 m4 Z) E& A) s5 Q; {! Q+ A; E, ?8 u+ Z
[allegro16.6][6层] Amlogic M802(M801) 平板电脑(M801+HDMI+2片DDR)pcb文件) I1 e2 M# F# F
( x: h; r5 X" i/ Z6 ^& ?
文件描述:* t( b6 {$ J3 C) S: N! a( D
! P% a! J# I" n& k( ?1. 作品用途:Amlogic M802(M801) 平板电脑' |. T. p& I( a, l) Z1 j
2. 软件版本:allegro16.6( H4 E& I  W& ~. @4 _' t
3. 层数:6层: ^" a4 \# y7 D
4. 用到的主要芯片:M801+HDMI+2片DDR
/ J: T" M7 \$ }5 G, f8 K+ t5. pcb尺寸: 异形, J( T$ a/ g( L% y7 G
1 R, K& B' ?( A/ Y" ?$ U% R* U  S作品截图如下:/ d7 \: ~- R" P$ [' Y
5 u/ h7 F9 {! ~
顶层截图:
' E% [" ~7 k' x7 V  U; }- L8 X + ]& x) s' y4 ~
底层截图:
+ L0 a$ t: F- T
3 D0 e) X1 Q  f; W- q( s% c$ P- ?- s ' w8 l: t1 l1 [0 f0 f+ f* R- V2 T
全层截图:
/ s% ], A+ T( a, S1 ~" V
4 q3 O$ Q- ~* C3 G! t& t* E3 y" O0 V9 L/ E
BOM:
; L3 @, r) M9 K4 `3 q0 y1 D
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA12-PT05AW8010A_BGA12-PT05_AW8010AFCRAW8010AFCRIC1AU2
BGA96-0P8MMDDR3_96P_16B_2CE_BGA96-0P8MM_H5TQ4G63AFR-PBCH5TQ4G63AFR-PBCIC23U4; 3U5
BGA169-INANDEMMC_V50_BGA169-INAND_NC/SDIN7DP2-8GNC/SDIN7DP2-8GIC14U2
BGA531_0P65AML-M802_BGA531_0P65_(S1+S2+S3+S4+S5+S6+S7)_M801M801IC1U1
C0402CAPNP_C0402_1UF_6.3V1uF_6.3VIC361C1; 1C12; 1C16; 1C20; 1C23; 1C40; 1C41; 1C47; 1C51; 1C55; 1C56; 2C1; 2C4; 2C6; 2C12; 2C15; 2C21; 3C41; 3C42; 5C2; 5C12; 6C5; 6C9; 8C12; 9C3; 9C6; 9C8; 9C12; 9C15; 9C16; 9C17; AC17; AC23; AC29; AC39; EC4
C0402CAPNP_C0402_1NF1nFDISCRETE91C2; 1C45; 1C50; 2C10; 6C2; 6C3; 6C6; 9C11; AC27
C0402CAPNP_C0402_NC/0.1UFNC/0.1uFIC141C3; 1C32; 4C1; 4C7; 4C10; 7C1; 7C12; 7C24; 8C1; 8C4; 8C17; 8C21; AC28; AC40
C0402CAPNP_C0402_0.1UF0.1uFDISCRETE651C4; 1C8; 1C9; 1C10; 1C17; 1C22; 1C28; 1C33; 1C39; 1C43; 1C46; 1C49; 2C2; 2C11; 2C13; 2C17; 2C19; 2C20; 2C23; 2C26; 3C14; 3C15; 3C16; 3C22; 3C23; 3C24; 3C25; 3C26; 3C28; 3C29; 3C30; 3C31; 3C32; 3C33; 3C34; 3C35; 3C36; 3C37; 3C39; 3C40; 4C3; 4C4; 4C6; 4C8; 4C9; 5C3; 5C4; 5C5; 5C11; 5C14; 6C1; 7C8; 8C2; 8C8; 8C18; 9C5; 9C10; 9C13; AC5; AC7; AC8; AC16; AC18; AC19; AC37
C0402CAPNP_C0402_NC/1NFNC/1nFIC41C30; 1C57; 1C58; 1C59
C0402CAPNP_C0402_18PF_5%_NPO18pF_5%_NPOIC51C37; 2C3; 2C7; 2C8; 2C9
C0402CAPNP_C0402_NC/1UF_6.3VNC/1uF_6.3VIC91C63; 1C64; 4C2; 4C11; 7C17; 7C18; 8C3; 8C20; 9C4
C0402CAPNP_C0402_NCNCDISCRETE63C44; 7C16; 7C25; 9C1; 9C2; 9C9
C0402CAPNP_C0402_NC/10PFNC/10pFIC16C4
C0402CAPNP_C0402_NC/22PF_NPO_5%NC/22pF_NPO_5%IC47C4; 7C19; 7C20; 7C21
C0402CAPNP_C0402_NC/10PF_NPONC/10pF_NPOIC17C7
C0402CAPNP_C0402_1.8PF1.8pFIC17C15
C0402CAPNP_C0402_2.7NH2.7nHIC17C27
C0402CAPNP_C0402_NC/100PFNC/100pFIC2AC1; AC2
C0402CAPNP_C0402_100PF100PFDISCRETE2AC24; AC36
C0603CAPNP_C0603_4.7UF_6.3V4.7uF_6.3VIC111C5; 1C6; 1C7; 1C11; 1C21; 1C25; 2C14; 4C5; 9C14; AC38; AC41
C0603CAPNP_C0603_NC/10UF_6.3VNC/10uF_6.3VIC21C27; 7C14
C0603CAPNP_C0603_10UF_6.3V10uF_6.3VIC181C29; 1C31; 1C34; 1C38; 1C44; 2C16; 3C13; 3C21; 3C27; 3C38; 5C6; 5C17; 6C8; 7C2; AC3; AC26; AC34; AC35
C0603CAPNP_C0603_NC/0.1UF_35VNC/0.1uF_35VIC15C1
C0603CAPNP_C0603_NC/4.7UF_6.3VNC/4.7uF_6.3VIC17C23
C0805CAPNP_C0805_22UF_6.3V22uF_6.3VIC181C13; 1C14; 1C15; 1C18; 1C19; 1C24; 1C26; 1C35; 1C42; 1C48; 1C52; 1C53; 1C54; 1C65; 1C66; 2C5; 2C22; 6C7
C0805CAPNP_C0805_NC/22UF_6.3VNC/22uF_6.3VIC11C36
C0805CAPNP_C0805_4.7UF_35V4.7uF_35VIC15C10
CON4-PT2MM-JTAGCON4P_0_CON4-PT2MM-JTAG_NC/CON4PNC/CON4PIC12J1
CON36-B079XAN01B079XAN01_CON36-B079XAN01_B079XAN01B079XAN01IC15J1
CT_A1206CD4.0/2.0_CT_A1206_100UF_4V100uF_4VIC2AC21; AC33
D0402DIODE SCHOTTKY_D0402_AZ5325-01FAZ5325-01FIC26D1; 6D3
D0402DIODE SCHOTTKY_D0402_AZ5725-01FAZ5725-01FIC86D2; 6D4; 6D5; 6D6; 6D7; 6D8; 9D2; 9D3
D0402DIODE SCHOTTKY_D0402_NC/ESDNC/ESDIC3AD1; AD2; AD3
D0402DIODE SCHOTTKY_D0402_NC/AZ5725-01FNC/AZ5725-01FIC2ED1; ED2
DC_SMD_5PINDC-05-06_DC_SMD_5PIN_DC-SUNTY7.85DC-Sunty7.85IC11J1
DFN10-PT04MMA8653FC_DFN10-PT04_MMA8653FCMMA8653FCIC18U5
EMI-TF2010A4XTF2010A4X_EMI-TF2010A4X_4X0R/TF2010A4X900MT4X0R/TF2010A4X900MTDISCRETE2CCA1; CCA2
ESD-RCLAMP0524PRCLAMP0524P_ESD-RCLAMP0524P_AZ1045-04FAZ1045-04FIC29U2; 9U3
FPC4-PT05-LCON-4PIN_SMD_FPC4-PT05-L_FPC-4PINFPC-4PINIC16J1
FPC6-PT05-RCON-6PIN_FPC6-PT05-R_CN_TOUCHCN_TOUCHIC1ECN1
FPC24-PT05-RGC0328_FPC24-PT05-R_GC0308-30MGC0308-30MIC19CN1
HDMI_JSHD_006HDMI_C_HDMI_JSHD_006_HDMI_CHDMI_CIC19J1
JH-RD-W06CON5_2_JH-RD-W06_ST-0279D00-061-182ST-0279D00-061-182IC1AJ1
L0603FB0805_0_L0603_120R/100MHZ_0.3A120R/100MHz_0.3AIC18FB2
L0603FB0805_L0603_120R/100MHZ_0.3A120R/100MHz_0.3AIC29FB1; EFB1
L0603FB0805_L0603_0R0RDISCRETE2AFB1; AFB2
L0805FB0805_0_L0805_120R/100MHZ_3A120R/100MHz_3AIC16FB1
L0805X2L_EXD24CD900U_0_L0805X2_NC/EXD24CD900UNC/EXD24CD900UDISCRETE16L1
L3030INDUCTOR_1_L3030_NC/3.3UH_1ANC/3.3uH_1AIC17L1
L4040INDUCTOR_POWER_L4040_2.2UH_2A2.2uH_2AIC31L4; 1L5; 1L6
L4040INDUCTOR_POWER_L4040_10UH_1.2A10uH_1.2AIC15L1
L5050INDUCTOR_POWER_L5050_1UH_3A_50181uH_3A_5018IC31L1; 1L2; 1L3
MIC-6027CMICROPHONE_0_MIC-6027C_MICROPHONEMICROPHONEIC1AMK1
MS-156ANT_0_MS-156_NCNCIC17J1
QFN16-PT1-3X3MMA8452Q_QFN16-PT1-3X3_NC/MMA8452QNC/MMA8452QIC18U7
QFN24-PT04MPU-6885A_QFN24-PT04_NC/MPU-6500ANC/MPU-6500AIC18U8
QFN44-PT09MMAP6493_6XXX_QFN44-PT09MM_NC/AP6210NC/AP6210IC17M1
QFN48-PT04-6X6MMRN5T618_QFN48-PT04-6X6MM_RN5T618MRN5T618MIC11U2
R0402RESISTOR_R0402_NC/4.7KNC/4.7KIC51R2; 4R15; 7R4; 8R12; ER3
R0402RESISTOR_R0402_10K10KDISCRETE101R4; 1R21; 1R25; 1R26; 2R22; 3R10; 5R1; 5R10; 6R23; 7R5
R0402RESISTOR_R0402_NC/10KNC/10KIC151R5; 1R24; 2R20; 2R21; 2R24; 5R14; 6R1; 6R2; 7R1; 7R2; 7R3; 7R23; 8R5; 8R7; ER7
R0402RES_R0402_1K1KDISCRETE11R7
R0402RESISTOR_R0402_47K47KDISCRETE71R8; 1R32; 4R4; 5R17; 6R10; 7R13; 9R2
R0402RESISTOR_R0402_470K470KDISCRETE41R10; 2R5; 5R18; 7R14
R0402RES_R0402_10K10KDISCRETE11R12
R0402RES_R0402_4.7K4.7KDISCRETE11R13
R0402RESISTOR_R0402_49.9K_1%49.9K_1%IC11R14
R0402RESISTOR_R0402_33.2K_1%33.2K_1%IC11R15
R0402RESISTOR_R0402_75K_1%75K_1%IC11R16
R0402RESISTOR_R0402_10K_1%10K_1%IC21R17; 5R11
R0402RESISTOR_R0402_NC/1KNC/1KIC31R18; 5R19; 7R8
R0402RESISTOR_R0402_100K_1%100K_1%IC31R19; 1R20; 5R12
R0402RES_R0402_NC/10KNC/10KIC11R31
R0402RESISTOR_R0402_0R0RDISCRETE111R34; 1R36; 2R23; 6R11; 6R13; 7R9; 7R10; 7R18; 9R7; 9R20; AR16
R0402RESISTOR_R0402_NC/0RNC/0RIC81R35; 4R3; 4R6; 4R7; 7R7; 7R17; AR15; ER2
R0402RESISTOR_R0402_1K1KDISCRETE72R1; 2R2; 6R5; 6R15; AR21; AR22; ER1
R0402RESISTOR_R0402_22R22RDISCRETE132R3; 2R9; 2R10; 2R11; 2R12; 4R8; 4R9; 4R10; 6R7; 9R8; 9R12; 9R18; 9R19
R0402RESISTOR_R0402_2.2K2.2KDISCRETE102R4; 2R13; 2R14; 2R18; 9R6; 9R9; 9R13; 9R15; AR14; AR32
R0402RESISTOR_R0402_100R100RDISCRETE12R6
R0402RESISTOR_R0402_4.7K4.7KDISCRETE82R7; 2R8; 4R12; 6R6; 9R10; 9R14; 9R21; 9R22
R0402RESISTOR_R0402_240R_1%240R_1%IC42R16; 3R8; 3R9; 3R12
R0402RESISTOR_R0402_NCNCIC92R19; 4R1; 4R2; 4R5; 4R11; 4R13; 4R14; 4R17; 9R5
R0402RESISTOR_R0402_1K_1%1K_1%IC23R2; 3R4
R0402RESISTOR_R0402_NC/240R_1%NC/240R_1%IC33R6; 3R14; 3R15
R0402RESISTOR_R0402_150R150RDISCRETE13R7
R0402RESISTOR_R0402_1.65K_1%1.65K_1%IC15R8
R0402RESISTOR_R0402_536R_1%536R_1%IC15R16
R0402RESISTOR_R0402_4.7K_1%4.7K_1%IC16R8
R0402RESISTOR_R0402_180R_1%180R_1%IC26R9; 6R16
R0402RESISTOR_R0402_NC/100KNC/100KIC36R18; 6R20; AR3
R0402RESISTOR_R0402_NC/22RNC/22RIC57R6; 7R20; 7R21; 7R26; AR13
R0402RESISTOR_R0402_100K100KDISCRETE37R12; 9R1; AR17
R0402RESISTOR_R0402_NC/470KNC/470KIC17R22
R0402RESISTOR_7_R0402_NC/10KNC/10KIC18R10
R0402RESISTOR_R0402_1.5K_1%1.5K_1%IC19R4
R0402RES_R0402_0R0RDISCRETE39R16; 9R17; 9R23
R0402RES_R0402_NC/0RNC/0RIC19R24
R0402RESISTOR_R0402_62K_1%62K_1%IC1AR4
R0402RESISTOR_R0402_120K_1%120K_1%IC2AR5; AR7
R0402RESISTOR_R0402_NC/180KNC/180KIC1AR6
R0402RESISTOR_R0402_2.2R2.2RDISCRETE1AR9
R0402RESISTOR_R0402_NC/33RNC/33RIC2AR10; AR11
R0402RESISTOR_R0402_8.2R8.2RIC2AR18; AR20
R0402RESISTOR_R0402_NC/2.2KNC/2.2KIC2AR19; AR33
R0603RESISTOR_R0603_750R_1%750R_1%IC16R12
R0603RESISTOR_R0603_910R_1%910R_1%IC16R17
R0603RESISTOR_R0603_0R0RDISCRETE19R3
R0805RESISTOR_R0805_0R0RDISCRETE11R3
R0805RESISTOR_R0805_2R2RDISCRETE21R22; 1R23
R0805RESISTOR_R0805_1.62R_1%1.62R_1%IC15R7
RN0402RESARRAY_RN0402_4X10K4x10KIC14RP1
RN0402RESARRAY_RN0402_4X33R4x33RIC29RP1; 9RP2
SHORTER_0402RESISTOR_SHORTER_0402_NCNCIC2AR8; AR12
SOD123H14ASCHOTTKY_SOD123H14A_B5819WB5819WIC51D1; 1D3; 1D4; 1D5; 5D1
SOIC-8-150MIL24C02A_6_SOIC-8-150MIL_NC/512KBYTE_SPI_NORNC/512KByte_SPI_NorIC14U4
SOT23-5BF1303_SOT23-5_WL2803E12-5WL2803E12-5IC11U4
SOT23-5BF1303_SOT23-5_WL2801E18-5WL2801E18-5IC11U7
SOT23-5BF1303_SOT23-5_NC/WL2801E28-5NC/WL2801E28-5IC11U9
SOT23-5U_RT9701_2_SOT23-5_SY6280AAACSY6280AAACIC16U3
SOT23-5BF1303_SOT23-5_NC/WL2801E15-5NC/WL2801E15-5IC19U4
SOT23-6BOOST-SOT236_SOT23-6_SY7208C/SY7152SY7208C/SY7152IC11U5
SOT23-6SY8009BABC_SOT23-6_SY8009BABC/2ASY8009BABC/2AIC11U6
SOT23-6AT1312_0_SOT23-6_SY7200AABCSY7200AABCIC15U2
SOT23-6NL27WZU04_SOT23-6_NC/NL27WZU04DTT1GNC/NL27WZU04DTT1GIC17U4
SOT-23DIODENN_SOT-23_BAT54CBAT54CIC11D2
SOT-23MOSFETP_21_SOT-23_WPM2026WPM2026IC21Q1; 5Q2
SOT-23MOSFETP_21_SOT-23_WPM2015WPM2015IC17Q1
SOT-23T_NPN_SOT-23_PMBT3904PMBT3904IC17Q2
SOT-23MOSFETP_4_SOT-23_WNM2016WNM2016IC29Q2; 9Q3
SPADCON1_SPAD_CON1CON1IC41TP1; 1TP3; AL+1; AL-1
SPAD1CON1_SPAD1_CON1CON1IC11TP2
SR1206SENSE_RES_SR1206_0.02R_1%0.02R_1%IC21R1; 1R11
SW-ST1114RABUTTON_7PIN_SW-ST1114RA_NC/RESET_KEYNC/Reset_KEYIC11SW2
TEST08T_POINT_R_TEST08_T\POINT\RT\POINT\RIC741TP5; 1TP6; 1TP7; 1TP8; 1TP10; 2TP2; 2TP4; 2TP9; 2TP10; 2TP11; 2TP12; 4TP1; 4TP2; 4TP3; 4TP4; 5TP1; 5TP2; 5TP6; 5TP7; 5TP8; 5TP9; 5TP10; 5TP11; 5TP12; 5TP13; 5TP14; 5TP15; 5TP16; 5TP17; 5TP18; 6TP4; 6TP7; 6TP11; 6TP12; 9TP1; 9TP2; 9TP3; 9TP4; 9TP5; 9TP6; 9TP7; 9TP8; 9TP9; 9TP10; 9TP11; 9TP12; 9TP13; 9TP14; 9TP15; 9TP16; 9TP17; 9TP18; 9TP19; 9TP20; 9TP21; 9TP22; ATP2; ATP3; ATP4; ATP5; ATP6; ATP7; ATP10; ATP11; ATP12; ATP13; ETP49; ETP50; ETP51; ETP52; ETP53; ETP54; ETP55; ETP56
TEST08T POINT R_TEST08_T\POINT\RT\POINT\RIC73TP2; 7FM1; 7FM2; 7TP1; 7TP2; 7TP3; 8TP4
TEST08T_POINT_R_TEST08_TESTTESTIC86TP1; 6TP2; 6TP3; 6TP5; 6TP6; 6TP8; 6TP9; 6TP10
TEST12T_POINT_R_TEST12_T\POINT\RT\POINT\RIC81TP9; 2TP1; 2TP3; 2TP5; 2TP6; 2TP7; 2TP8; 2TP13
TEST12T POINT R_TEST12_T\POINT\RT\POINT\RIC28TP1; 8TP5
TFC-01BTFCARD_TFC-01B_TF_SD_SOCKETTF_SD_SOCKETIC16U2
TSOP-48TSD_FLASH_TSOP-48_NC/TSTS35-04G/NCTSXXX2-04G-08GNC/TSTS35-04G/NCTSXXX2-04G-08GIC14U3
TSOP-48NAND-ALL_11_TSOP-48_29F32G08CBACA29F32G08CBACAIC14U5
TSOP-48NAND-ALL_11_TSOP-48_NC/29F32G08CBACANC/29F32G08CBACAIC14U6
USB-P0565-H24-0336JP_USB-0400ASMT_USB-P0565-H24-0336_MICRO USB PORTMicro USB PortIC16CON1
WF-UM02BSEM78P372_1_WF-UM02BS_RTL8188-EUSRTL8188-EUSIC17U1
XT-MC_146CRYSTAL_1_XT-MC_146_XTAL_32.768KHZXTAL_32.768KHzIC12Y1
XT-SMD4P3225SMD_CRYSTAL_XT-SMD4P3225_24MHZ_12PF_20PPM24MHz_12pF_20PPMIC12Y2
XT-SMD4P3225SMD_CRYSTAL_XT-SMD4P3225_NC/26M_16PF_10PPMNC/26M_16pF_10ppmIC27Y2; 7Y3
ZEN056ZEN056_0_ZEN056_NC/ZEN056NC/ZEN056IC11U3
附件:
! f6 s" A  G. a" JPCB文件如下:! M- Q/ _' r- `9 m/ h' J$ D
游客,如果您要查看本帖隐藏内容请回复
发表于 2020-3-29 01:09 | 只看该作者
    2023-7-27 15:05
    发表于 2021-8-27 13:03 | 只看该作者
    谢谢分享
    “来自电巢APP”
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    发表于 2021-9-2 16:04 | 只看该作者
    这个板子有点意思。
    发表于 2023-7-28 15:39 | 只看该作者
    XIEXIE XUEXI YIXIA .
    2024-7-9 15:02
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2023-7-30 17:37 | 只看该作者
    66666666666666666616161616看看
    发表于 2023-8-2 08:46 | 只看该作者
    学习一下,谢谢分享! C+ z* Y$ \2 n5 W( G2 I5 B
    GMT+8, 2025-7-20 19:43 , Processed in 0.156250 second(s), 27 queries , Gzip On.
