查看: 542|回复: 1
[allegro16.6][6层] Ambiq Micro APOLLO3参考板(APOLLO3+CXD5603GF+GT24L24A2Y)...
发表于 2020-1-10 18:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
, G6 O9 p1 K2 f- s! m
[allegro16.6][6层] Ambiq Micro APOLLO3参考板(APOLLO3+CXD5603GF+GT24L24A2Y)pcb文件
' e; Y9 J4 }" q+ M  G& L' G8 o
( q- S# P" T: Y/ u& p6 C文件描述:. G# c$ x: r& l
  m& M/ K3 }* |* c( s, f
1. 作品用途: Ambiq Micro APOLLO3参考板' x5 |. K$ ^, k' d: G
2. 软件版本:allegro16.6
" G% Y) x, N# D$ ^3. 层数:6层
" M- ?# k4 n# D0 k# b) d& G, z) b4. 用到的主要芯片:APOLLO3+CXD5603GF+GT24L24A2Y  K3 e" @8 ?+ L, }
5. pcb尺寸: 1102.363*1260.582 MIL
9 W. d! C, M2 G6 T9 r7 W
3 x6 E$ Q3 \  Q. o3 t0 x' i作品截图如下:7 p: V9 K# D, W. r
& l* D" I3 ~0 o2 |7 |: E3 R) |顶层截图:, g7 ~1 ?. X. c: s* g
" ]- k" G* b8 j" d9 G4 X+ }
底层截图:
3 n$ U3 `( V/ ?8 a4 B% b
7 B( m+ J. l' A! Z' A- S* o# n2 d, f" U' ]5 K
全层截图:
4 J5 u8 k; B' P5 l% N, w! c
/ D/ ~$ a" j- k! W4 }! E' I
8 [: E  k2 ]3 J/ W0 nBOM:
; \/ F, g4 h0 t# d5 m& R0 b
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
ANT_DIPANT_ANT_DIP_ANTANTIC4L6; L9; L13; L14
BAT_L2_5XW1_5X0_6HTEST POINT_1_BAT_L2_5XW1_5X0_6HTest PointIC1J21
BGA81_L5XW5X0H8APOLLO3_BGA_BGA81_L5XW5X0H8_APOAPOLLO3_BGAIC1U1
BM6P-DS-L4_6XW2_2X0_6H-0_35AYF530635_13_BM6P-DS-L4_6XW2_2XBM6P-DS-L4_6XW2_2X0_6H-0_35IC2J23; J24
BM10P-DS-L4_6XW2_2X0_6H-0_35AYF530635_12_BM10P-DS-L4_6XW2_2BM10P-DS-L4_6XW2_2X0_6H-0_35IC1J22
BM16P-DS-L4_6XW2_2X0_6H-0_35AYF530635_11_BM16P-DS-L4_6XW2_2BM16P-DS-L4_6XW2_2X0_6H-0_35IC1J2
BMI160BMI160_0_BMI160_BMI160BMI160IC1U26
C0201CAP_C0201_2.2UF2.2uFIC4C1; C2; C9; C65
C0201CAP_C0201_1UF1uFIC5C4; C6; C7; C8; C10
C0201CAP_C0201_0.47UF0.47uFIC1C5
C0201CAPACITOR_C0201_1PF1PFIC1C11
C0201CAPACITOR_C0201_1.2PF1.2PFIC1C12
C0201CAPACITOR_C0201_9PF9pFIC2C14; C15
C0201CAP_C0201_DISCRETE_10PF10PFDISCRETE2C16; C19
C0201CAP_C0201_0.1UF 02010.1uF 0201IC3C24; C70; C71
C0201CAPACITOR NON-POL_C0201_0.1UF0.1uFIC12C27; C44; C46; C49; C50; C51; C52; C53; C54; C55; C58; C62
C0201CAP NP_C0201_1UF1uFIC5C28; C39; C40; C72; C73
C0201CAP NP_C0201_0.1UF0.1uFIC2C30; C34
C0201CAPACITOR NON-POL_C0201_1UF1uFIC1C32
C0201CAP_C0201_56PF56pFIC2C42; C67
C0201CAPACITOR NON-POL_C0201_0.001UF0.001uFIC1C43
C0201CAPACITOR NON-POL_C0201_0.01UF0.01uFIC1C45
C0201CAPACITOR_C0201_33PF33pfIC1C47
C0201CAPACITOR NON-POL_C0201_3.3PF3.3pFIC1C48
C0201CAPACITOR NON-POL_C0201_100PF100pFIC1C56
C0201CAPACITOR NON-POL_C0201_33PF33pFIC1C57
C0201CAP_C0201_47NF47NFIC1C66
C0201CAP_C0201_NP/100PFNP/100pFIC1C68
C0402CAP_C0402_4.7UF4.7uFIC1C3
C0402CAP NP_C0402_10UF10uFIC2C31; C41
C0402CAPACITOR NON-POL_C0402_10UF/6.10uF/6.3VIC3C59; C60; C63
C0402CAPACITOR NON-POL_C0402_10UF10uFIC1C64
C0402CAP NP_C0402_4.7UF4.7uFIC3C77; C78; C79
C0603CAPACITOR NON-POL_C0603_22UF22uFIC1C61
CSP_1L55_0W85_0H6MO1552G_CSP_1L55_0W85_0H6_SIT15SIT1552IC1U17
DFN3_1L0_0W6_0H5MOSFET P_1_DFN3_1L0_0W6_0H5_PMOPMOSIC6Q3; Q4; Q5; Q7; Q9; Q10
DFN3_1L0_0W6_0H5_NPNNPN_0_DFN3_1L0_0W6_0H5_NPN_PMBTPMBT3904MIC2Q6; Q8
DFN8_2W0_3L0_0H9CW2015_DFN_0_DFN8_2W0_3L0_0H9_CCW2015_DFNIC1U58
DFN8_3L0_2W0_0H8GT24L24A2Y_DFN8_3L0_2W0_0H8_GT2GT24L24A2YIC1U9
DFN8_8L0_6W0_0H55MT29F4G01ADAGDWB_0_DFN8_8L0_6W0MT29F4G01ADAGDWBIC1U10
DFN10L3_1XW3_1X0_8HCE3150B_4_DFN10L3_1XW3_1X0_8H_CCW6304IC1U13
ESD0402DIODE BI-DIR TRIG_ESD0402_LXES1LXES1UBAA1-096IC2D6; D12
ESD0402DIODE BI-DIR TRIG_ESD0402_NP/SENP/SESDFBP05CIC1D7
ESD0402DIODE BI-DIR TRIG_ESD0402_SESDFSESDFBP05CIC1D8
FID_1MMPAD_FID_1MM_SW-SW-IC2MARK1; MARK2
GS_32LC_11L3_4W5_3H15BAL_3855_GS_32LC_11L3_4W5_3H15_GS-32LCIC1U57
L0201INDUCTOR_L0201_1.8NH1.8nHIC1L3
L0201INDUCTOR_L0201_00IC1L4
L0201INDUCTOR_1_L0201_10NH10nHIC1L7
L0201INDUCTOR_1_L0201_8.2NH8.2nHIC1L8
L0402FB_L0402_DISCRETE_120R @100MHZ120R @100MHzDISCRETE5FB1; FB2; FB3; FB4; FB5
L0603INDUCTOR_L0603_2.2UH/400MA/06032.2uH/400mA/0603IC1L1
L0603INDUCTOR_L0603_1UH/400MA/06031uH/400mA/0603IC1L2
L0805INDUCTOR_1_L0805_2.2UH2.2uHIC1L10
L0806INDUCTOR_1_L0806_2.2UH2.2uHIC1L11
MSMQFN8P_4X3_1_05HMSM26D4030H1R_MSMQFN8P_4X3_1_05MSM26D4030H1RIC1U11
NT2016SANT2016SA_NT2016SA_NT2016SANT2016SAIC1U16
PAD1_5CHARGETEST POINT_PAD1_5CHARGE_TEST POTest PointIC4TP7; TP8; TP9; TP10
PAD_1TP-VIA_PAD_1_TP-30PAD-16DRLTP-30PAD-16DRLIC19T33; T34; T35; T36; T37; T38; T39; T40; T52; T55; T58; T59; T60; T61; T62; T63; T64; T65; T66
R0201RESISTOR_0_R0201_10K10kIC8R1; R2; R46; R47; R48; R49; R63; R64
R0201R_R0201_10K10KIC5R11; R61; R67; R127; R132
R0201R_R0201_3.9K3.9KIC6R13; R19; R43; R123; R133; R134
R0201RESISTOR_R0201_100K100KIC4R30; R32; R44; R45
R0201RESISTOR_R0201_10R10RIC1R31
R0201RESISTOR_R0201_100R100RIC3R33; R36; R37
R0201RESISTOR_R0201_2.7K2.7KIC2R34; R35
R0201RESISTOR_R0201_200K200KIC1R38
R0201RESISTOR_R0201_3.3K3.3KIC2R39; R40
R0201RESISTOR_R0201_1K81k8IC2R41; R42
R0201RESISTOR_R0201_10K10KIC4R50; R51; R52; R58
R0201RESISTOR_R0201_00IC2R53; R56
R0201R_R0201_NP/0NP/0IC1R57
R0201R_R0201_NPNPIC1R62
R0201RESISTOR_R0201_5.1OHM/02015.1ohm/0201IC1R65
R0201RESISTOR_R0201_3.9K3.9KIC2R66; R125
R0201R_R0201_0.47K0.47KIC1R68
R0201R_R0201_0.1K0.1KIC1R69
R0201RESISTOR_R0201_10OHM/020110ohm/0201IC1R124
R0201R_R0201_20K20KIC1R126
SAFFB1G56KB0F5FSAFFB1G56KB0F5F_SAFFB1G56KB0F5FSAFFB1G56KB0F5FIC1U20
SNT-6P-1_57X1_8X0_48HS85S1A_C_0_SNT-6P-1_57X1_8X0_48S85S1A_CIC1U23
SOD-723DIODE_SOD-723_1SS400G1SS400gIC1D9
SOD-923SMBJ5_1.0A_SOD-923_PESDLC9D5VBPESDLC9D5VBIC1D10
SOD-923SMBJ5_2.0A_SOD-923_PESDLC9D5VBPESDLC9D5VBIC1D11
SOT23-3_3L0_3W0_1H25CE8808_SOT23-3_3L0_3W0_1H25_CE8CE8808C300MIC1U25
ST-1114RHSW_TC_SPST_2_ST-1114RH_ST-1186LST-1186LAIC1KEY1
ST-1190SW2PIN_ST-1190_SW2PINSW2PINIC1SW1
USON8_3L0_2W0_0H6_0E2_1E6FT25H16_USON8_3L0_2W0_0H6_0E2_1W25Q16FWIC1U22
WL-CSP8L1_28W1_28P0_4H0_5ST480MC_WL-CSP8L1_28W1_28P0_4H0QMC7983IC1U6
WLCSP-8P-1_45X1_48X0_36HRP512_WLCSP-8P-1_45X1_48X0_36H_RP512IC1U24
X2SON4-L1W1H0_4TLV707_2_X2SON4-L1W1H0_4_RP122KRP122K331D-TRIC1U15
X2SON8_1L4_1W_0H4LSF0102DQER_X2SON8_1L4_1W_0H4_LLSF0102DQERIC1U21
XFBGA49_2_L985_2W985_0H4CXD5603GF_0_XFBGA49_2_L985_2W98CXD5603GFIC1U18
XSON6_1L1_0W7_0H4BGU8103_XSON6_1L1_0W7_0H4_BGU81BGU8103IC1U19
XTAL2_3L2_1W5_0H8CRYSTAL2_XTAL2_3L2_1W5_0H8_FC-1FC-135IC1Y2
XTAL4_2L0_1W6_0H6_0P65CRYSTAL4_0_XTAL4_2L0_1W6_0H6_0P32MHZIC1Y1
附件:# z: A; o& J5 M$ M, K
PCB文件如下:
6 D. R9 W8 g" u/ D% I* c
游客,如果您要查看本帖隐藏内容请回复
$ c3 h6 o, [. w* |8 @+ [2 z$ E7 p4 ~  J
发表于 2021-4-9 13:26 | 只看该作者
下载学习一下,谢谢。
GMT+8, 2025-7-7 19:39 , Processed in 0.140625 second(s), 27 queries , Gzip On.
