1. 作品用途:MRB-KW0x 面向Kinetis KW0x系列MCU的模块化参考设计电路板
2. 软件版本:allegro17.2
3. 层数:4层
5. PCB尺寸:2000*2600 mil
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.635MM | 10PF | DISCRETE | 7 | C1; C7; C8; C11; C23; C45; C46 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.5MM_1 | 3.3pf | DISCRETE | 1 | C2 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55MM_ | 6.8PF | DISCRETE | 3 | C3; C12; C13 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_2 | 5.6PF | DISCRETE | 1 | C4 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_3 | 100PF | DISCRETE | 2 | C5; C6 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_4 | 7.5pF | DISCRETE | 1 | C9 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.64 MM | 47PF | DISCRETE | 1 | C10 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.635_1 | 0.1UF | DISCRETE | 1 | C14 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55 MM | 2.0PF | DISCRETE | 1 | C15 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_1 | 220PF | DISCRETE | 2 | C16; C18 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.74 MM | 0.01UF | DISCRETE | 1 | C17 |
0402_CC | INDP_0402_CC_DISCRETE_0.55 MM_1 | 5.6NH | DISCRETE | 2 | L1; L3 |
0402_CC | INDUCTOR_0402_CC_DISCRETE_0.55M | 0.0068UH | DISCRETE | 2 | L2; L4 |
0402_CC | INDUCTOR_0402_CC_DISCRETE_0.5_1 | 33nH | DISCRETE | 2 | L5; L6 |
0402_CC | INDUCTOR_0402_CC_DISCRETE_0.5_2 | 0.0047UH | DISCRETE | 1 | L7 |
0402_CC | INDUCTOR_0402_CC_DISCRETE_0.55 | 0.002uH | DISCRETE | 1 | L9 |
0402_CC | RES_0402_CC_DISCRETE_470-30454_ | 100 | DISCRETE | 1 | R19 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | DISCRETE | 9 | C19; C20; C21; C24; C30; C33; C37; C38; C39 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6 M | 11pF | DISCRETE | 2 | C22; C25 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | DISCRETE | 2 | C27; C28 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 12PF | DISCRETE | 2 | C34; C35 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 1000pF | DISCRETE | 1 | C36 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 9.0PF | DISCRETE | 2 | C41; C42 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | DISCRETE | 1 | C29 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1UF | DISCRETE | 1 | C32 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 0.47UF | DISCRETE | 1 | C40 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 10uF | DISCRETE | 1 | C44 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.6MM | 10UF | DISCRETE | 1 | C26 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.397 | 4.7UF | DISCRETE | 1 | C43 |
CON5_USB_MINI_A_SMT | USB_MINI_B_SKT_CON5_USB_MINI_A_ | CONN USB MINI-B 1x5 | IO | 1 | J16 |
CON_2RH_10_50 | CONN_HDR_5X2_CON_2RH_10_50_IO_3 | HDR 2X5 | IO | 1 | J5 |
CON_SMA_8363 | CON5_SMA_MMCX_CON_SMA_8363_IO_9 | CON_1_SMA | IO | 2 | J1; J2 |
HDR2X4 | CONN_HDR_4X2_HDR2X4_IO_8.6MM_21 | HDR_2X4 | IO | 1 | J13 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | IO | 7 | J3; J4; J6; J7; J9; J10; J11 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.65MM_2 | HDR TH 1X3 | IO | 1 | J8 |
HDR202_100_TH | CONN_HDR_2X2_HDR202_100_TH_IO_8 | 961204-6404-AR | IO | 1 | J12 |
HDR210_MIRRORED | CONN_HDR_10X2_HDR210_MIRRORED_I | HDR_10X2 | IO | 1 | J15 |
HDR_3X5_100_TH | HDR3X5_HDR_3X5_100_TH_IO_8.58MM | HDR 3X5 | IO | 1 | J17 |
HDR_9X2_TSW_MIRRORED | CONN_HDR_9X2_HDR_9X2_TSW_MIRROR | HDR 2X9 | IO | 1 | J14 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05 MM_ | 330 OHM | DISCRETE | 1 | L8 |
JUMP1X4-6040 | HDR-1X4_JUMP1X4-6040_IO_5.21 MM | HDR_1X4 | IO | 1 | J18 |
LED2_0805 | LED_LED2_0805_IC_0.9MM_370-7646 | GREEN | IC | 1 | D1 |
LED2_0805 | LED_LED2_0805_IC_0.9MM_370-76_1 | RED | IC | 1 | D4 |
LGA60_0P5_8X8 | MKW01Z128_LGA_0_LGA60_0P5_8X8_I | MKW01Z128 | IC | 1 | U1 |
MH125-160 | MOUNT_HOLE_MH125-160_IC_0.1 MM_ | 125 | IC | 4 | BH1; BH2; BH3; BH4 |
QFN24_0P65_5X5 | USB2SERA10CFK_QFN24_0P65_5X5_IC | USB2SERA10CFK | IC | 1 | U3 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7561 | 330 | DISCRETE | 1 | R3 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 4.7K | DISCRETE | 1 | R6 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 15K | DISCRETE | 1 | R12 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3000 | 1M | DISCRETE | 1 | R14 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7555 | 10K | DISCRETE | 2 | R15; R20 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | DISCRETE | 2 | R16; R17 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 4.7K | DISCRETE | 2 | R2; R4 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | DISCRETE | 8 | R5; R7; R8; R9; R10; R11; R21; R22 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7794 | 422 | DISCRETE | 1 | R13 |
SOD123 | DIODE_SCHTKY_SOD123_IC_1.45MM_4 | MBR0520LT1G | IC | 2 | D2; D3 |
SOT-23-5 | LP2992X_5P_SOT-23-5_IC_1.22 MM_ | LP2985AIM5-3.3 | IC | 1 | U2 |
SW2_6P1X3P7_SM | SW_PB_2P_SW2_6P1X3P7_SM_IC_2.5M | SKQYAFE010 | IC | 1 | SW1 |
TESTPOINT_135_070MIL | TESTLOOP_TESTPOINT_135_070MIL_I | TESTLOOP | IO | 2 | TL1; TL2 |
TPAD_040 | TESTLOOP_TPAD_040_IC_0.1MM_211- | TPAD_040 | IC | 22 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22 |
TPAD_040 | TESTLOOP_TPAD_040_IO_0.1MM_211- | TPAD_040 | IO | 2 | TP23; TP24 |
TP_TH_063 | TESTLOOP_TP_TH_063_IO_8.13MM_21 | TESTLOOP_BLACK | IO | 1 | TP25 |
XTAL2-3P2X1P5-SM | CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.9 | 32.768KHZ | IC | 1 | Y2 |
XTAL2_8_4P5_SM | XTAL_CS10_XTAL2_8_4P5_SM_IC_2.2 | 4MHz | IC | 1 | Y3 |
XTLOSC4_3P2X2P5MM_SM | XTAL_13Y_XTLOSC4_3P2X2P5MM_SM_I | 32MHZ | IC | 1 | Y1 |
