作品名:[AD 10][2层] 86触摸智能开关(STC89C52+MB6S+ATC9501)原理图、PCB源文件3 ?- j% E* y) f7 e2 q( M" `! a
% w+ H* Z, c4 l: k: D- G
文件描述
5 I7 S ?9 j) e6 Z ~2 T* \1. 作品用途:基于单片机的读卡器
& j9 k$ H# ^3 G8 O2. 软件版本:AD 10+ d! p& f7 Y4 j" B" E
3. 层数:2层板
; L' P6 T" x& B& g9 H& ]4. 用到的主要芯片:STC89C52+MB6S+ATC9501/ \* d, j$ H- f
5. PCB尺寸:57mm*54mm
# G2 q1 ] c) M# J9 m# {5 a( t; g) w! ~3 h: ^+ y
作品截图如下:% W% g# u$ a5 ~3 N- R
顶层截图:
( o; H9 Z6 }- _+ t( x. ^& a
# @9 j8 u" h6 a, ]; z5 A3 t
底层截图:
: t% P7 b. f1 K# m8 c5 m; h
, f$ S& E# t* k
全层截图:
+ {! d( Y! V, G* W9 T* c
" r0 f. t. m$ n; k
叠层信息截图如下:
7 o0 }+ U3 U8 R! @: ^
7 X0 Z1 r+ R PBOM:/ r5 W6 e5 Q2 Y! e d1 W
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C6, C7, C8, C9, C10, C11, C32 | 0603C | 7 | 106A | C13, C14 | 3216C | 2 | 4.7uF/400V | C16 | 电解电容8*12MM | 1 | 220uF/25V(台湾GSK ) | C17 | 电解电容6*12MM | 1 | 15P | C18, C19 | 0603C | 2 | 103 | C20, C21 | 0603C | 2 | 22nF | C22 | 0603C | 1 | 33pF | C23 | 0603C | 1 | 47uF | C24 | 1210C | 1 | 0.1nF/XR7/50V/10% | C25 | 1206C | 1 | 10uF | C26 | 1210C | 1 | 1000pF | C27 | 0603C | 1 | 10uF/50V | C31 | 0805C | 1 | CON2 | CB1, CB2 | B1 | 2 | 1N4148 | D1, D2, D3, D4 | SMA | 4 | 1N4007(贴片M7) | D5 | SMA | 1 | HER208 | D6 | DO-15 | 1 | SS14 | D7, D8, D9, D10 | SMA | 4 | CON3 | J5 | XH2.54-3P | 1 | CON1 | J6, J7, J8, J9, J10 | PAD1 | 5 | CON2 | J11, JP3, JP4 | IDC2-2.54 | 3 | CON6 | JP1, JP2 | IDC6-2.54 | 2 | HF32F/012-HS | K1, K2, K3 | HF32F | 3 | CDRH5D28NP-6R8NC | L1 | L_5.7*5.7*3 | 1 | 发光二极管(红) | LED1, LED2, LED3, LED4, LED5, LED6 | 0603D | 6 | 8050 | Q1, Q2, Q3 | SOT23 | 3 | 1K | R1, R2, R3, R4, R5, R6, R7, R8 | 0603R | 8 | 4.7K | R16, R17, R18, R19, R20, R21 | 0603R | 6 | 10K | R22, R23 | 0603R | 2 | 33R | R24, R26 | 0603R | 2 | 33R | R25 | 0805R | 1 | 10M | R27 | 0805R | 1 | 393 | R28 | 0805R | 1 | 3.3R | R29, R30 | 0805R | 2 | 330k | R31 | 0805R | 1 | 1152 | R32 | 0805R | 1 | 1.5K | R33 | 0603R | 1 | 29.4K | R34 | 0603R | 1 | 15K1% | R35 | 0603R | 1 | 4.7K1% | R36 | 0603R | 1 | 1.2k | R42 | 0805R | 1 | TRANS6 | T1 | T1 | 1 | AT24C02 | U2 | SO-8 | 1 | STC89C52 | U3 | PQFP44 | 1 | MB6S | U4 | MBS-1 | 1 | ATC9501 | U5 | SO-8 | 1 | ZIGBEE_PA_SZ2 | U6 | ZIGBEE_SZ2 | 1 | TPS54331 | U7 | SO-8 | 1 | 11.0592M | Y1 | XTAL5 | 1 | 附件:5 {+ R! Z9 B/ g
原理图和PCB源文件如下:, v) N" {' a2 b4 F, ], C+ K
: r- @/ Q, J4 M- G4 c* m" `3 y/ G
0 V" R2 P$ S4 z: g3 F/ D
