查看: 343|回复: 1
[AD 10][4层]隔离型4轨推挽式IGBT门驱动电源板(LM5030MM/NOPB+TPS27082LDDC+LP295...
发表于 2020-1-9 15:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][4层]隔离型4轨推挽式IGBT门驱动电源板(LM5030MM/NOPB+TPS27082LDDC+LP2954AIM/NOPB)原理图和PCB源文件& z( k8 D9 N/ Z  n
+ f4 g. {! C) q3 j( e7 M文件描述
1 e' v4 _5 O1 |; I! t( f; v
* D5 |$ ]/ {! c0 t+ D1. 作品用途:隔离型4轨推挽式IGBT门驱动电源板* G4 z5 L4 _7 Y# S( I, a* w
' v( f- z% K5 X2 w; b2. 软件版本:AD 10
8 M& ~' q! m# n9 F
( {4 C5 v! e5 p' e# k$ N3. 层数:4层板3 I+ \+ R+ I/ I9 z" G% M
, Y! V/ _: ]! N, z3 r7 U4. 用到的主要芯片:LM5030MM/NOPB+TPS27082LDDC+LP2954AIM/NOPB2 k8 f0 b* D/ w
" L; [  m* X) D* s+ C) S) O, P
5. PCB尺寸:145mm*100mm
$ {7 d3 j6 d! C6 R  i, T- W; M" f5 [  U5 @9 W
1 o+ ~% Y' F) j2 z* z1 }) E; R
作品截图如下:. R8 V+ _9 r" t+ v
0 O' b$ f6 q7 L, A顶层截图:
4 U& y: c' W8 V5 |
$ U1 q4 B- w: b7 I
& l. m6 I6 K1 a5 I8 ~6 d底层截图:
5 x% P+ `  Y* P# D& k! k 7 S( f0 @. P2 S. |4 \" a
. e; y! ]9 z# P+ q" f' S+ N; \全层截图:/ i5 m( u1 d1 G6 k4 V# }2 L; K+ A
# r- a' Y6 p  e, q0 h9 _: ~
, W$ _) G0 ?5 Q4 v叠层信息截图如下:4 v6 u5 D. B- N. f/ R7 s
- i3 \1 {( U) S3 [" _4 N
1 f$ N2 [1 O+ }0 T) b( f+ L. c& ]BOM:1 {/ z/ {7 F) Y9 x% X
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
EEE-FK1K470PC1SM_RADIAL_G
1uF/63VC2CAPSMT_62_D55
22uF/16VC31206
C2012C0G1E223JC40805
GRM216R71E102KA01DC5, C7, C80805_HV
CC0805KRX7R9BB471C60805_HV
22uF/35VC9, C59SM_RADIAL_D
10uF/50VC10, C11, C12, C22, C23, C24, C35, C36, C37, C47, C48, C49, C60, C61, C62, C72, C73, C741206_190
18
EEE-FK1V470PC13, C14, C17, C18, C25, C26, C29, C30, C38, C39, C42, C43, C50, C51, C54, C55, C63, C64, C67, C68, C75, C76, C79, C80SM_RADIAL_D
24
100pFC15, C27, C40, C52, C65, C770805
4.7uF/25VC16, C28, C41, C53, C66, C780805
B37947K9103J62C19, C200805_HV
10uF/16VC21, C33, C46, C58, C71, C830805
10nFC31, C32, C44, C45, C56, C57, C69, C70, C81, C820805
10
EEE-FC1V220PC34SM_RADIAL_D
08055C104JAT2AC84, C85, C86, C87, C88, C89, C90, C91, C92, C93, C94, C950805_HV
12
282841-2CONN1TEC_282841-2
CON-OSTVN02A150CONN2CN2_MTB_P100_PD80_D1.1_S5.54X6.5_STACK
CON-OSTVN04A150CONN3, CONN4, CONN5, CONN6, CONN7, CONN8TB_OSTVN04A150_4P
B260A-13-FD1SMA
DNPD2, D3D_SOD123
B190-13-FD4, D5, D6, D7, D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21SMA
18
FiducialFID1, FID2, FID3, FID4, FID5, FID6Fiducial10-20
NY PMS 440 0025 PHH1, H2, H3, H4NY PMS 440 0025 PH
1902CH5, H6, H7, H8Keystone_1902C
JUMPER_2X100MILJ1, J2, J3, J4, J5, J6HDR100_1X2
MSS1210-225KEL1IND_MSS1210
Size: 0.65" x 0.20 "LBL1Label_650x200
LED_LG L29K-G2J1-24-ZLD1, LD2, LD3, LD4, LD5, LD6, LD7, LD8, LD9, LD10, LD11, LD12, LD13, LD14, LD15, LD16, LD17, LD18, LD19, LD20, LD21, LD22, LD23, LD24LED0603AA
24
CSD88539NDQ1SO-8
CSD19533Q5AQ2, Q3TRANS_NexFET_Q5A
CRCW08050000Z0EAR1, R3, R7, R9, R10, R11, R13, R15, R18, R19, R21, R22, R31, R32, R41, R42, R51, R52, R61, R62, R71, R720805_HV
22
CRCW08051K00FKEAR20805_HV
RC0805FR-0726K7LR40805_HV
ERJ-6ENF1003VR5, R24, R34, R44, R54, R64, R740805_HV
CRCW080510K0FKEAR60805_HV
ERJ-6ENF2492VR80805_HV
CRCW080522R0JNEAR12, R140805_HV
CRCW08051K15FKEAR160805_HV
ERJ-8RQFR22VR171206
CRCW080510K0JNEAR20, R25, R26, R29, R30, R35, R36, R39, R40, R45, R46, R49, R50, R55, R56, R59, R60, R65, R66, R69, R70, R75, R76, R790805_HV
24
ERJ-6GEYJ125VR23, R33, R43, R53, R63, R730805_HV
RR1220P-334-DR27, R37, R47, R57, R67, R770805_HV
CRCW0805102KFKEAR28, R38, R48, R58, R68, R780805_HV
ERJ-8GEY0R00VR801206
750342312T1, T2, T3Wurth_750342312
LM5030MM/NOPBU1MUB10A_N
TPS27082LDDCU2DDC0006A_N
LP2954AIM/NOPBU3, U5, U7, U9, U11, U13M08A_N
TPS7A3001DGNU4, U6, U8, U10, U12, U14DGN_8P
MMSZ5242B-TPZ1SOD-123
. E" `: E  s& O; z; t
附件:5 K) p7 Q: ^: I1 \
0 t* p6 \, _' f) ]+ x  `9 \原理图和PCB源文件如下:! x8 j8 h7 T; b
游客,如果您要查看本帖隐藏内容请回复
4 x& @- {9 H# ]& a. Z* v9 |4 B
: Z8 E1 _% |0 s8 t) n  B7 }3 m+ V* C9 r
+ B0 W9 C1 W( ]( F+ d& q; \, ^' q& I
发表于 2022-9-24 18:37 | 只看该作者
驱动原理是什么呢
“来自电巢APP”
GMT+8, 2025-7-1 16:32 , Processed in 0.109375 second(s), 28 queries , Gzip On.
