作品名:[AD 10][2层] STM32F401RE开发板原理图+PCB9 @ W0 |6 k" b S$ F5 U
! L/ c9 W" n x( h) G$ `5 d5 ~文件描述
% v4 N3 T# }6 E6 j/ ]1. 作品用途:开发板% U1 x( I; E' _5 @ W
2. 软件版本:AD 10
0 D0 `) g; ^, C# X3. 层数:2层板
* T$ H5 K5 @6 y f v5 D* |4. 用到的主要芯片:STM32F401RE
. ]2 p, i. }/ P, L5. PCB尺寸:63.5mm*82.5mm+ @' k: ]0 k# ?4 {- K9 q
* }! [4 g: N, \& K作品截图如下:
( |$ F" y' J O顶层截图:
% `( c n* x# n- i3 s1 A. U
6 e% M8 r" ]- r( w
+ ~1 ?* s# Z: ^$ S0 l" z
底层截图:, B6 Q& P7 D8 [4 g% f* [! q' J
- P9 l( C K: }
% m) G& I/ s3 E: k, @! e全层截图:) D+ H- m( \" o3 C
3 Q9 W' W& s8 Y7 T5 z% l9 X: C- Z4 R0 ^8 c, T! g, k, I2 @
叠层信息截图如下:
8 r6 N, Y* m( m
/ @, a1 @) f2 a- `% Y9 j4 u: ?5 q1 D* I' N" I# C h
BOM:1 E$ m* s4 Y1 B% d6 ?# z2 H: Q
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | USER (Blue) | B1 | PB10 | 1 | TD-0341 [RESET/Black] | B2 | PB10 | 1 | 100nF | C1, C4, C5, C6, C7, C11, C12, C14, C15, C19, C20, C23, C24, C27, C28, C30 | 0603C | 16 | 1uF_X5R_0603 | C2, C13, C18, C21, C29 | 0603C | 5 | 20pF | C3, C8, C10 | 0603C | 3 | 10nF_X7R_0603 | C9 | 0603C | 1 | 10uF(25V) | C16 | TAN-B | 1 | 10uF | C17 | TAN-A | 1 | 2.2uF | C22, C25, C26 | TAN-A | 3 | 10pF[N/A] | C31, C32 | 0603C | 2 | 20pF[N/A] | C33, C34 | 0603C | 2 | 5075BMR-05-SM | CN1 | USB-MINI-B-SMD | 1 | Header 4 | CN2 | 1*4 | 1 | | CN3, CN11, CN12, JP1, JP4, JP6 | SIP2/2.54 | 6 | Header 6X1 | CN4 | 1*6P | 1 | Header 10X1_Female | CN5 | 1*10P_FEMALE | 1 | Header 8X1_Female | CN6, CN9 | 1*8P_FEMALE | 2 | Header 19X2 | CN7, CN10 | 2*19P | 2 | Header 6X1_Female | CN8 | 1*6P_FEMALE | 1 | BAT60JFILM | D1, D2, D3 | SOD323/A | 3 | STPS2L30A | D4 | SMA | 1 | Comment | Designator1 | NUCLEO_black 0.5cm | 1 | Comment | Designator2 | | 1 | Comment | Designator4 | NUCLEO_black 2cm | 1 | Comment | Designator22 | ST_LOGO_10mm | 1 | | JP5 | SIP3 | 1 | BEAD | L1 | 0603L | 1 | LD_BICOLOR_CMS | LD1 | HSMF-A201 | 1 | Green | LD2 | 0603D | 1 | RED | LD3 | 0603D | 1 | 10K | R1, R2, R3, R12, R26, R33 | 0603R | 6 | 4K7 | R4, R23, R27, R28, R30 | 0603R | 5 | 22 | R5, R8, R13, R22 | 0603R | 4 | 100K | R6, R14, R15 | 0603R | 3 | 2K7 | R7 | 0603R | 1 | 100 | R9, R11, R20, R21, R24, R25, R29 | 0603R | 7 | 36K | R10 | 0603R | 1 | 1K5 | R16 | 0603R | 1 | 0 | R17, R18, R19 | 0603R | 3 | 510 | R31 | 0603R | 1 | 1K | R32 | 0603R | 1 | [N/A] | R34, R35, R36, R37 | 0603R | 4 | Circuit Breaker | SB1, SB2, SB3, SB4, SB5, SB6, SB7, SB8, SB9, SB10, SB11, SB12, SB13, SB14, SB15, SB16, SB17, SB18, SB19, SB20, SB21, SB22, SB23, SB24, SB25, SB26, SB27, SB28, SB29, SB30, SB31, SB32, SB33, SB34, SB35, SB36, SB37, SB38, SB39, SB40, SB41, SB42, SB43, SB44, SB45, SB46, SB47, SB48, SB49, SB50, SB51, SB52, SB53, SB54, SB55, SB56, SB57, SB58, SB59, SB60, SB61, SB62, SB63, SB64, SB65 | JP2_SMD | 65 | 9013 | T1 | SOT-23 | 1 | STS7PF30L | T2 | SO8 | 1 | LD3985M33R | U1 | SOT-23-5L | 1 | STM32F103CBT6 | U2 | QFP48 7X7 | 1 | LD1117S50TR | U3 | SOT-223 | 1 | LD39050PU33R | U4 | DFN6(3X3) | 1 | mcu_LQFP64 | U5 | LQFP64 | 1 | 8MHz(12pF) | X1 | XTAL1 | 1 | 32.768K[N/A] | X2 | XTAL_4SM_8X3R8 | 1 | 8MHz(16pF)[N/A] | X3 | XTAL1 | 1 | 8 e0 k0 m R2 w; K: O/ R0 Y: B
附件:1 Z* U8 H/ A, R# m4 p
原理图和PCB源文件如下:
! ?0 [ v' `7 o* ^3 F; W$ i* S( ~% ~
8 ]4 P( `$ j8 w |
