查看: 5213|回复: 3
请教:OrCAD10.5产生Allegro netlist出错!
发表于 2008-3-24 14:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教高手,下面的错误信息是什么意思呀?0 A$ B) z  ~) g( q" ?
说明:用9.2版orcad就没有错误,线路图是用9.2版画的!12 X0 O4 E: @/ o8 G- g
谢谢!!!!!!
; C# ~" q  N2 b# t$ k8 N1 \& a+ a8 K, B
) q0 ^; Y! _7 F' }: b
********************************************************************************5 t( z0 s5 u, z3 d  i( ]: I/ s) K1 {
8 x( |+ L5 M. A' I# ]0 ?! M* Netlisting the design ; F5 g0 f* P$ m% T3 s7 F& `
) g2 X# v5 ~1 Z********************************************************************************# s' r- t" k, v3 L$ [# d6 l
Design Name:" s  ~% M0 M  l/ g: F5 q
D:\orcad\01261125.dsn
5 d- c) m/ o+ v/ YNetlist Directory:2 N! @; `: G8 T; |. F
D:\orcad\allegro1 G0 z. L, R7 O; t
Configuration File:
) t1 Y9 O% F+ j4 I8 L3 CD:\cadence\SPB_15.5.1\tools\capture\allegro.cfg2 W  g/ e2 R7 z# x% N
Spawning... "D:\Cadence\SPB_15.5.1\tools\capture\pstswp.exe" -pst -d "Drcad\01261125.dsn" -n "D:\orcad\allegro" -c "D:\Cadence\SPB_15.5.1\tools\capture\allegro.cfg" -v 3 -j "CB Footprint"
' @1 u9 O8 D2 X, ^: M% o( K% ]#19 Error   [ALG0013] Conflicting values of following Component Definition properties found on C10 and C1 for part "C0402".
& T, R- z% A; r+ X: E. @% y! T              VALUE
- `/ i' }! S. x0 |5 x#20 Error   [ALG0013] Conflicting values of following Component Definition properties found on C102 a
! N$ z- X% J, C) |nd C1 for part "C0402".
# z$ j* X! P* O3 I1 o( b2 @              VALUE  i; R1 _6 R. @* n
#21 Error   [ALG0013] Conflicting values of following Component Definition properties found on C103 and C1 for part "C0402".
, T; ?! ^/ y4 ]2 v* P3 g              VALUE' y1 G/ s1 z" b+ H# Z: T' @% D
#22 Error   [ALG0013] Conflicting values of following Component Definition properties found on C11 and C1 for part "C0402".
& U* w8 @$ ~& {( P! m) B; r              VALUE$ s. h2 q( p+ h6 }$ X# c5 h
#23 Error   [ALG0013] Conflicting values of following Component Definition properties found on C12 and C1 for part "C0402".# e. Q6 h$ d% ]4 t
              VALUE
' D! c6 ?/ x4 B. a/ e6 J, D#24 Error   [ALG0013] Conflicting values of following Component Definition properties found on C13 and C1 for part "C0402".
1 |0 `; q+ W5 ~- o4 d, Q: A              VALUE
+ d$ N  I4 T* H1 T; y#25 Error   [ALG0013] Conflicting values of following Component Definition properties found on C133 and C1 for part "C0402".
- [! t3 y, C6 ~- u8 n              VALUE! W3 c* h( W  Q7 f' {
#26 Error   [ALG0013] Conflicting values of following Component Definition properties found on C134 and C1 for part "C0402".* h! k8 i9 }) s1 T
              VALUE
. y0 t5 ?$ u* w0 |8 r#27 Error   [ALG0013] Conflicting values of following Component Definition properties found on C1392 [2 V' O7 |1 G6 i3 }  @7 p
and C1 for part "C0402".5 W" t" u3 S$ R0 ~" p
) [" G, @- X+ _- G4 g* c( E' W
[ 本帖最后由 killerljj 于 2008-3-27 17:44 编辑 ]
发表于 2008-3-24 20:07 | 只看该作者
原帖由 killerljj 于 2008-3-24 14:46 发表
7 H8 c2 T( N: x5 r  w9 E% ]请教高手,下面的错误信息是什么意思呀?
' G. H0 P+ l6 m" D3 s& D谢谢!!!!!!4 l4 x* ~) y3 e" n* t& b6 @
9 B0 W4 k( V% O! ]& b0 v
- ?! ?/ W* b* O2 k3 S********************************************************************************8 {& K: m0 k' S1 n2 x  B& L' R+ {
) }9 s, v; L( _1 u7 s/ A: E* Netlisting the design ) h% S2 F0 [: m/ C* F
" O! Z6 L! v( ]. R7 X3 N/ \; h# t************************ ...
/ f4 |# n8 \- x7 P4 P1 Z. }
3 q' M/ a8 _! _" ~把C10 和C1 的属性调出来看看,分析一下才能知道
 楼主| 发表于 2008-3-25 13:11 | 只看该作者
是不是因为Value不同呀?
4 Z9 |% d, U) n如下图所示:
发表于 2009-8-10 16:23 | 只看该作者
顶起,我也是这个错误
GMT+8, 2025-8-24 09:19 , Processed in 0.109375 second(s), 27 queries , Gzip On.
