查看: 1116|回复: 15
[allegro16.0][14层] Altera ARRIA2GX_PCIE (EP2AGX125F1152+DIMM200+金手指)pc...
发表于 2020-1-8 17:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
4 k& ^  j7 ^0 E6 A9 X[allegro16.0][14层] Altera ARRIA2GX_PCIE (EP2AGX125F1152+DIMM200+金手指)pcb文件
2 M# J7 ^% k! c: a2 `4 R3 l& d0 ^3 N5 b
文件描述:
  V; p1 ~8 p. R0 [
; l6 i4 ~4 p0 w' v2 F( l  t1. 作品用途:Altera ARRIA2GX_PCIE
  o$ \/ y0 [" m0 a2. 软件版本:allegro16.0
7 p' L4 l& N1 b2 z, O3. 层数:14层
/ F+ l" {7 s# c: V0 O4. 用到的主要芯片:EP2AGX125F1152+DIMM200+金手指, _' I$ Z+ O5 `3 x
5. pcb尺寸: 8480*4376 MIL: B+ C/ Q  n$ L: G. m0 H
2 d: _. v8 S; d4 G( D
作品截图如下:8 Q' P/ I- {+ x7 y, g
5 a, i7 `% U! e* Q" ]
顶层截图:) k8 T5 e: t: ?) O6 b  L
, p) ?+ P( o& {/ {5 ], |
底层截图:- L" ^! Y3 j# B$ s/ ~; x6 a
) x: S! m+ k$ T& `
, S; J" k, K$ K# K2 ?$ P: r全层截图:
+ i; \4 W2 N6 A . ~* y. `7 n7 k1 A
  d2 r& l7 t1 y1 f; ?  O* G  h
BOM:
: `. R: m* Q; c0 o* d8 |
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0402_1000PF1000pFIC5C10; C12; C183; C205; C208
402CAP_NP_0402_0.033UF0.033uFIC1C13
402RESISTOR_0402_20.0K20.0KIC2R24; R140
402RESISTOR_0402_100K100KIC2R32; R34
402RESISTOR_0402_22.1K22.1KIC1R125
603CAP_0603_0.1UF0.1uFIC2C38; C209
BCC-9688E1111CAA_0_BCC-96_88E111188E1111IC1U24
BGA-165IS61VPS51236A_BGA-165_IS61VPS51IS61VPS51236AIC1U22
C-0402CAP_C-0402_0.1U0.1uIC220C4; C5; C22; C45; C46; C47; C54; C55; C56; C60; C61; C63; C64; C65; C66; C68; C72; C73; C74; C75; C79; C80; C81; C82; C83; C89; C90; C91; C92; C120; C121; C122; C123; C127; C128; C129; C130; C131; C132; C139; C146; C147; C158; C160; C161; C163; C164; C165; C166; C181; C184; C192; C193; C194; C195; C196; C197; C201; C202; C203; C210; C211; C214; C215; C217; C220; C221; C222; C223; C224; C225; C226; C227; C228; C229; C230; C236; C237; C238; C241; C242; C243; C245; C246; C247; C248; C249; C250; C251; C259; C263; C267; C270; C276; C277; C278; C279; C281; C282; C283; C284; C285; C286; C289; C290; C291; C292; C295; C296; C297; C314; C315; C316; C317; C318; C319; C320; C321; C322; C325; C326; C327; C328; C329; C330; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345; C346; C347; C348; C349; C350; C353; C354; C355; C356; C357; C359; C360; C362; C364; C365; C366; C367; C369; C372; C374; C376; C377; C379; C380; C390; C391; C402; C403; C404; C405; C406; C407; C410; C411; C413; C414; C415; C416; C417; C418; C420; C422; C423; C424; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434; C435; C436; C437; C440; C441; C442; C444; C445; C446; C447; C448; C449; C450; C451; C452; C453; C454; C455; C456; C457; C458; C459; C460; C461; C462; C463; C464; C465; C466; C467; C468
C-0402CAP_C-0402_0.01U0.01uIC14C6; C98; C101; C179; C185; C189; C190; C240; C385; C392; C393; C396; C400; C439
C-0402CAP_C-0402_22N22nIC38C11; C206; C253; C254; C256; C257; C258; C260; C261; C262; C264; C265; C268; C271; C272; C273; C274; C275; C298; C299; C300; C301; C303; C305; C306; C307; C308; C309; C310; C311; C312; C313; C358; C361; C363; C368; C370; C373
C-0402CAP_C-0402_15P15pIC1C15
C-0402CAP_C-0402_30P30pIC1C16
C-0402CAP_C-0402_0.47U0.47uIC12C58; C186; C187; C188; C212; C213; C216; C231; C235; C266; C269; C381
C-0402CAP_C-0402_22P22pIC2C94; C108
C-0402CAP_C-0402_DNIDNIIC4C143; C151; C156; C204
C-0402CAP_C-0402_4700P4700pIC1C150
C-0402CAP_C-0402_47P47pIC2C152; C155
C-0402CAP_C-0402_4.7N4.7nIC1C157
C-0402CAP_C-0402_0.001U0.001UIC2C167; C180
C-0402CAP_C-0402_1U1uIC8C252; C255; C302; C304; C375; C378; C383; C386
C-0402CAP_C-0402__0.1U0.1uIC1C371
C-0603CAP_C-0603_10U10uIC35C1; C18; C19; C20; C25; C26; C37; C52; C62; C67; C69; C71; C76; C86; C87; C93; C106; C107; C115; C116; C117; C124; C125; C138; C173; C177; C198; C218; C232; C280; C294; C387; C388; C412; C438
C-0603CAP_C-0603_15P15pIC1C3
C-0603CAP_C-0603_2.2U2.2uIC6C14; C17; C24; C85; C234; C324
C-0603CAP_C-0603_1U1uIC13C21; C43; C48; C49; C104; C105; C113; C114; C154; C162; C171; C178; C207
C-0603CAP_C-0603_4.7U4.7uIC11C27; C36; C59; C70; C112; C153; C159; C172; C244; C384; C443
C-0603CAP_C-0603_0.047U0.047uIC4C96; C100; C397; C401
C-0603CAP_C-0603__4.7U4.7uIC1C103
C-0603CAP_C-0603_2.2N2.2nIC3C133; C333; C335
C-0603CAP_C-0603_150P150pIC6C134; C137; C332; C334; C395; C399
C-0603CAP_C-0603_DNIDNIIC2C135; C142
C-0603CAP_C-0603_0.01U0.01uIC4C148; C149; C287; C288
C-0603CAP_C-0603_27P27pIC2C239; C331
C-0603CAP_C-0603_2700P2700pIC2C394; C398
C-0603CAP_C-0603_1200P1200pIC2C419; C421
C-0603_X2YCAP_X2Y_C-0603_X2Y_10N10nIC6C174; C175; C293; C323; C351; C408
C-0603_X2YCAP_X2Y_C-0603_X2Y_0.1U0.1uIC5C176; C191; C219; C233; C409
C-0603_X2YCAP_X2Y_C-0603_X2Y_0.22U0.22uIC2C352; C382
C-0805CAP_C-0805_10U10uIC4C7; C42; C53; C57
C-0805CAP_C-0805_1U1uIC1C136
C-0805CAP_C-0805_22U22uIC6C168; C169; C170; C182; C199; C200
C-1206CAP_C-1206_10U10uIC2C126; C140
C-1206CAP_C-1206_DNIDNIIC1C144
C-1210CAP_C-1210_22U22uIC18C2; C29; C30; C31; C32; C34; C35; C39; C40; C41; C44; C77; C78; C84; C95; C99; C111; C141
C-1210CAP_C-1210_100U100uIC9C23; C88; C97; C102; C109; C110; C118; C119; C389
C-1210CAP_C-1210_DNIDNIIC1C145
CA-AVE-0603-8CA_CA-AVE-0603-8_0.1U0.1UIC20CN1; CN2; CN3; CN4; CN5; CN6; CN7; CN8; CN9; CN10; CN11; CN12; CN13; CN14; CN15; CN16; CN17; CN18; CN19; CN20
CAPT7343CAPT_CAPT7343_330U/6.3V330u/6.3VIC4C8; C9; C28; C33
CAPT7343CAPT_CAPT7343_68U/16V68u/16VIC2C50; C51
CON-2X4_2-54MMJUMPER 2X4_CON-2X4_2-54MM_JUMPEJUMPER 2x4IC1J9
CON-2X5MR_2-54MMHEADER 2X5_CON-2X5MR_2-54MM_JTAJTAG ConnectorIC1J5
CON-2X5_2-54MMHEADER 2X5_CON-2X5_2-54MM_JTAGJTAGIC1J15
CON-QSH-180AQSH_HSM_CON-QSH-180A_DNIDNIIC1J1
CON-QSH-180AQSH_HSM_CON-QSH-180A_ASP-122953ASP-122953-03IC1J2
CON-SMD2X7_2-54MMHDR2X7_CON-SMD2X7_2-54MM_HDR2X7HDR2X7IC1J3
DO-214ABSCHOTTKYDIODE_0_DO-214AB_FM540FM540IC1D17
EASY_BGA-64PC28FXXXP30B85_EASY_BGA-64_PC48PC48F4400P0VB00IC1U23
FAN_CON2CON2_MLX_22_23_2021_FAN_CON2_POPower - FANIC1J13
FBGA-96MT41J64M16_DDR3_0_FBGA-96_MT41JMT41J64M16LAIC1U13
FBGA-256EPM2210GF256_FBGA-256_(S1+S2),(EPM2210_F256FBGAIC1U32
FBGA-1152EP2AGX260F1152_7_FBGA-1152_(S1+EP2AGX125F1152IC1U19
FID35RFIDUCIAL_FID35R_FIDUCIALFIDUCIALIC10FID1; FID2; FID3; FID4; FID5; FID6; FID7; FID8; FID9; FID10
HOLDER-COIN-CELL_1220BATTERY_0_HOLDER-COIN-CELL_1220DNIIC1BT1
IND-1608INDUCTOR-1_IND-1608_2.2U2.2uIC1L1
IND-2525INDUCTOR-1_IND-2525_3.3UH3.3uHIC1L3
IND-2525INDUCTOR-1_IND-2525_2.2U2.2uIC1L4
IND-2525INDUCTOR-1_IND-2525_0.82UH0.82uHIC2L7; L8
IND-4040INDUCTOR-1_IND-4040_6.8UH6.8uHIC1L2
IND-5050INDUCTOR-1_IND-5050_6.8UH6.8uHIC1L6
JACK-DC_2MMJACK-DC_JACK-DC_2MM_DC INPUT JADC Input JACKIC1J4
JACK-RJ45-8P10C-NJACK-RJ45-8P10C-B_JACK-RJ45-8P1Jack-RJ45-8P10C-BIC1J8
JACK-SMA-6-5_MMJACK-SMA_JACK-SMA-6-5_MM_EXT CLEXT CLOCK_nIC1J10
JACK-SMA-6-5_MMJACK-SMA_JACK-SMA-6-5_MM_EXT _1EXT CLOCK_pIC1J11
JACK-SMA-6-5_MMJACK-SMA_JACK-SMA-6-5_MM_CLOCKCLOCK OUTIC1J12
JACK-USB-BFMJACK-USB-BFM_JACK-USB-BFM_USB BUSB B-TYPEIC1J6
L-0402INDUCTOR_L-0402_BEADBEADIC6L5; L9; L10; L11; L12; L13
LED-0805LED_LED-0805_DNIDNIIC1D1
LED-0805LED_LED-0805_LEDGLEDGIC22D2; D3; D4; D5; D6; D7; D8; D9; D10; D11; D12; D13; D14; D15; D19; D20; D21; D22; D23; D24; D25; D26
LED-0805LED_LED-0805_LEDRLEDRIC1D16
LED-0805LED_LED-0805_LEDBLEDBIC1D18
LQFP-32FT245BM_LQFP-32_FT245BLFT245BLIC1U15
MBGA-100EPM240ZM100EPM240ZM100IC1U10
MTG-250D126MH_MTG-250D126_GNDGNDIC10MTG1; MTG2; MTG3; MTG4; MTG5; MTG6; MTG7; MTG8; MTG9; MTG10
OSC-2-5X4MMSM_CRYSTAL_X42_4_OSC-2-5X4MM_X4X42-25.000-10PIC2Y2; Y4
OSC-3X5MMOSC_OSC-3X5MM_25MHZ25MHZIC1Y3
OSC-3X5MMOSC_OSC-3X5MM_50MHZ50MHzIC1Y5
OSC-3X5MMOSC_OSC-3X5MM_100MHZ100MHZIC1Y6
OSC-5X7MMOSC_OSC-5X7MM_24MHZ24MHZIC1Y1
OSC-5X7MM-6OSC_SMT_PECL_1_OSC-5X7MM-6_155.155.52MHzIC1U25
PCIE-8PORTPCIE_BRACKET_X8_PCIE-8PORT_PCIEPCIe_Edge_X8IC1J14
PSOP-PWP16TPS54550_PSOP-PWP16_TPS54550TPS54550IC1U6
PSOP-PWP16TPS40061_PSOP-PWP16_TPS40061TPS40061IC1U45
QFN-3X3IRF7455PBF_QFN-3X3_CSD16411Q3CSD16411Q3IC6U3; U4; U5; U8; U9; U18
QFN-32CDCM61004_2_QFN-32_CDCM61004CDCM61004IC1U26
QFN-32CDCM61001_5_QFN-32_CDCM61001CDCM61001IC1U30
QFN-36TPS40140_QFN-36_TPS40140TPS40140IC1U41
R-0402RES_R-0402_11IC1R1
R-0402RES_R-0402_10K10KIC39R2; R25; R33; R39; R49; R50; R60; R63; R88; R92; R99; R101; R106; R108; R109; R110; R111; R112; R118; R119; R127; R134; R138; R143; R144; R145; R146; R147; R148; R156; R184; R190; R197; R205; R206; R209; R211; R216; R220
R-0402RES_R-0402_DNIDNIIC26R3; R4; R5; R6; R7; R8; R9; R10; R55; R56; R57; R64; R68; R77; R78; R79; R89; R94; R129; R131; R132; R135; R160; R172; R175; R187
R-0402RES_R-0402_00IC19R11; R12; R13; R14; R15; R16; R17; R18; R69; R70; R71; R128; R130; R159; R161; R165; R166; R203; R207
R-0402RES_R-0402_300K300kIC1R19
R-0402RES_R-0402_200K200kIC1R20
R-0402RES_R-0402_49.949.9IC16R21; R86; R95; R150; R151; R153; R182; R183; R185; R186; R193; R194; R195; R202; R212; R213
R-0402RES_R-0402_2K2kIC4R22; R139; R189; R191
R-0402RES_R-0402_7.32K7.32KIC1R23
R-0402RES_R-0402_29.4K29.4kIC1R26
R-0402RES_R-0402_43.2K43.2kIC1R27
R-0402RES_R-0402_14.3K14.3KIC1R28
R-0402RES_R-0402_30.1K30.1KIC1R29
R-0402RES_R-0402_100K100KIC3R30; R38; R42
R-0402RES_R-0402_1010IC5R31; R40; R58; R59; R90
R-0402RES_R-0402_120120IC9R35; R36; R37; R48; R51; R74; R75; R76; R137
R-0402RES_R-0402_470470IC1R41
R-0402RES_R-0402_1.5K1.5KIC2R43; R62
R-0402RES_R-0402_2222IC2R44; R45
R-0402RES_R-0402_2.4K2.4kIC1R46
R-0402RES_R-0402_2.1K2.1kIC1R47
R-0402RES_R-0402_1K1KIC6R52; R122; R123; R133; R136; R164
R-0402RES_R-0402_4.02K4.02kIC2R53; R54
R-0402RES_R-0402_100100IC8R66; R67; R149; R152; R176; R177; R178; R217
R-0402RES_R-0402_35.7K35.7kIC5R80; R81; R126; R154; R157
R-0402RES_R-0402_57.6K57.6kIC1R83
R-0402RES_R-0402_34.8K34.8kIC1R84
R-0402RES_R-0402_1M1MIC3R85; R96; R169
R-0402RES_R-0402_49.9K49.9kIC2R87; R93
R-0402RES_R-0402_127K127kIC1R91
R-0402RES_R-0402_1.62K1.62kIC1R97
R-0402RES_R-0402_51.1K51.1kIC1R98
R-0402RES_R-0402_2.43K2.43kIC2R100; R113
R-0402RES_R-0402_4.74.7IC2R102; R103
R-0402RES_R-0402_3.32K3.32kIC1R104
R-0402RES_R-0402_7.5K7.5kIC2R105; R107
R-0402RES_R-0402_5656IC1R114
R-0402RES_R-0402_240240IC1R115
R-0402RESISTOR_R-0402_10K10KIC1R120
R-0402RESISTOR_R-0402_2.2K2.2kIC1R121
R-0402RES_R-0402_255K255KIC1R124
R-0402RES_R-0402_1.24K1.24KIC1R155
R-0402RES_R-0402_5.1K5.1KIC7R162; R163; R171; R173; R174; R181; R188
R-0402RES_R-0402_3.4M3.4MIC1R170
R-0402RES_R-0402_4.99K4.99KIC3R192; R196; R199
R-0402RES_R-0402_27.4K27.4kIC2R198; R200
R-0402RES_R-0402_4.7K4.7KIC1R201
R-0402RES_R-0402_590590IC2R204; R208
R-0402RES_R-0402_5.49K5.49kIC1R210
R-0402RES_R-0402_84.584.5IC2R214; R218
R-0402RES_R-0402_124124IC2R215; R219
R-2010RES_R-2010_0.0090.009IC13R61; R65; R73; R82; R116; R117; R141; R142; R158; R167; R168; R179; R180
R-2010RES_R-2010_0.0010.001IC1R72
RA-VEX-0402-8RA-8P4R_RA-VEX-0402-8_100K100KIC2RN1; RN33
RA-VEX-0402-8RA-8P4R_RA-VEX-0402-8_120120IC4RN2; RN3; RN28; RN52
RA-VEX-0402-8RA-8P4R_RA-VEX-0402-8_5656IC38RN4; RN5; RN6; RN7; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN27; RN34; RN35; RN36; RN37; RN38; RN39; RN40; RN41; RN42; RN43; RN44; RN45; RN46; RN47; RN48; RN49
RA-VEX-0402-8RA-8P4R_RA-VEX-0402-8_10K10KIC8RN25; RN29; RN30; RN31; RN32; RN50; RN51; RN53
RA-VEX-0402-8RA-8P4R_RA-VEX-0402-8_4.7K4.7KIC1RN26
SC-70-5TPS71501_SC-70-5_TPS71501TPS71501IC1U20
SC-70-5TPS71725_SC-70-5_TPS71725TPS71725IC1U43
SOCKET-SO-DIMM200SOCKET-SO-DIMM200_SOCKET-SO-DIMSOCKET-SO-DIMM200IC1J7
SOD-123SCHOTTKYDIODE_0_SOD-123_MBR0520MBR0520IC2D27; D28
SOD-123DIODE_SOD-123_1N6263-W (DNI)1N6263-W (DNI)IC2D29; D30
SOIC-8EEPROM_SOIC-8_93LC46B-I/SN93LC46B-I/SNIC2U7; U34
SOIC-8IRF7455PBF_SOIC-8_FDS8690FDS8690IC4U35; U36; U48; U49
SON-10TPS62510_3_SON-10_TPS62510TPS62510IC1U1
SON-10TPS71202_SON-10_TPS71202TPS71202IC1U2
SON-10TPS74801_SON-10_TPS74801TPS74801IC1U21
SON-10TPS74701_SON-10_TPS74701TPS74701IC2U29; U31
SON-10TPS51200_SON-10_TPS51200TPS51200IC2U42; U44
SOT-23-6SN65220DBV_SOT-23-6_SN65220DBVRSN65220DBVRG4IC1U50
SSOP-8TS5A2053_SSOP-8_TS5A2053TS5A2053IC4U37; U40; U51; U52
SSOP-28LTC2418_SSOP-28_LTC2418LTC2418IC2U11; U16
SW-SLIDE_R-6X15SW SLIDE-4P2T_1_SW-SLIDE_R-6X15EG4208AIC1SW1
SW-SMD-8SW-DIP8_SW-SMD-8_USER SWUser SWIC1SW2
SW-SMD-8SW-DIP8_SW-SMD-8_PCIE MODEPCIe ModeIC1SW3
SW-SMD-16SW-DIP16_SW-SMD-16_SW-DIP16SW-DIP16IC1SW4
SW-TACT_SMD-6X6SW-BUTTON_SW-TACT_SMD-6X6_TACTTACT SWIC6PB1; PB2; PB3; PB4; PB5; PB6
TO-252-3AASUD50P04_TO-252-3AA_SUD50P04SUD50P04IC1U12
TSSOP-14MAX3378_0_TSSOP-14_MAX3378EEUD+MAX3378EEUD+IC2U14; U17
TSSOP-14TPS2410PW_TSSOP-14_TPS2410PWTPS2410PWIC4U38; U39; U46; U47
TSSOP-20ICS8543_TSSOP-20_ICS8543ICS8543IC1U33
VQFN-34TPS54617_VQFN-34_TPS54617TPS54617IC2U27; U28
XTL-11-5X4-3MMCRYSTAL_XTL-11-5X4-3MM_6MHZ6MHZIC1X1
附件:- [: x4 a2 I5 P
PCB文件如下:
1 ], E7 t# g7 v/ Y3 `+ _
游客,如果您要查看本帖隐藏内容请回复
1 C1 V# Q2 \9 s$ V  ^$ Q$ i
3 y% m# }4 Q' }9 @  d" Q$ K
发表于 2020-5-9 23:02 | 只看该作者
发表于 2020-5-21 18:32 | 只看该作者
kkkkkkkkkkkkkkkkkk& q% S; `; f1 [* Q+ t' s
发表于 2020-7-2 10:45 | 只看该作者
支持一下,学习学习
! N0 ?6 z5 S# j1 v: f) P
    2025-7-4 15:41
  • 签到天数: 1145 天
    [LV.10]以坛为家III
    发表于 2020-7-11 23:35 | 只看该作者
    谢谢分享
    “来自电巢APP”
    发表于 2020-7-14 09:58 | 只看该作者
    谢谢分享,学习一下
    2025-7-4 15:32
  • 签到天数: 86 天
    [LV.6]常住居民II
    发表于 2020-7-14 12:23 | 只看该作者
    学习一下,谢谢
    发表于 2020-11-28 15:06 | 只看该作者
    学习一下,正需要
    5 A& u5 O2 s3 z: u/ [
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2020-11-30 12:24 | 只看该作者
    PCB欣赏,不是让你发BOM,。一看就是 某天PCB论坛 搞来的资料。。。
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    13#
    发表于 2020-11-30 12:25 | 只看该作者
    威望50?,分享毛线,这种文件不要发了。。
    14#
    发表于 2020-11-30 15:30 | 只看该作者
    111111111111111111111111111111
    郁闷
    2024-4-8 15:07
  • 签到天数: 51 天
    [LV.5]常住居民I
    15#
    发表于 2021-3-22 14:44 | 只看该作者
    好人一生平安
    GMT+8, 2025-7-5 07:33 , Processed in 0.171875 second(s), 27 queries , Gzip On.
