查看: 990|回复: 8
[allegro17.2][2层]HI3521ADMEB_VER_C(HI3521AV100+NVP6124+RTL8211EG)原理图和p...
发表于 2020-1-8 15:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][2层]HI3521ADMEB_VER_C(HI3521AV100+NVP6124+RTL8211EG)原理图和pcb文件
  K6 a2 H* d& Z
文件描述:
1. 作品用途:HI3521ADMEB_VER_C
2. 软件版本:allegro17.2
3. 层数:2层
4. 用到的主要芯片:HI3521AV100+NVP6124+RTL8211EG
5. PCB尺寸:异形
- D1 r" ?" P  M* A) m' i6 d
作品截图如下:
6 J$ t' E" H  ~' ~3 t
顶层截图:
  ~7 g! p; i) A8 m: L
底层截图:
全层截图:
6 Q# ?' v* O1 \
% }6 D' u. D6 @( t1 c; c: L
BOM:
1 W, j. B( C# l. j2 ~7 u, `: R, L9 Z
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA96-32-1609MBGA96-32-1609MH5TQ4G63AFR_RDCIC2U10; U11
BGA437-32-2323BBGA437-32-2323BHI3521AV100IC1U8
CAPC2-100-250CAPC2-100-250220UFIC1C240
DB9-2RMDB9-2RMDBR30_09K1206IC1J21
DB15-3RF-ADB15-3RF-A17HE_R13150_73HC2IC1J12
DFN2510P10E_AZ1045DFN2510P10E_AZ1045AZ1045-04FIC2U3; U18
GND12GND12TESTIC1TS1
HOLE160-8STARHOLE160-8STAR138MIL_STAR_HOLE_TO_M3_AIC4M1; M2; M3; M4
HSC0402HSC04022.2UFIC11C3; C9; C15; C21; C22; C23; C24; C25; C26; C27; C290
HSL1008HSL10082.2UHIC3L8; L9; L10
HSOD323AHSOD323AD_AIC2D14; D15
HSOD882HSOD882ESD8V0R1B_02LRHDISCRETE28D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D11; D12; D13; D16; D20; D21; D25; D26; D27; D28; D29; D30; D31; D32; D33; D34; D35; D36
HSX2-0302HSX2-030232.768KHZIC1X2
HSX4-0302BHSX4-0302B27MHZDISCRETE2OSC1; OSC2
HSX4-0302BHSX4-0302B24MHZDISCRETE1X1
ID-BOARDID-BOARDPCB_MARKPOINTIC6ID1; ID2; ID3; ID4; ID5; ID6
IDC20-DTM1-AIDC20-DTM1-AHU5_200PNA_S53T_FAIC1J11
MJ8-SRLFYMJ8-SRLFYE5J88_14LJ24_LIC1J18
MLF6-065-0202LMLF6-065-0202LHPA00615DRVRIC1U20
MOLEX_47151MOLEX_47151HDMIIC1J16
PSW3-RAPSW3-RARA22KKFR0FL_D1IC1S2
PWC0103-M-CPWC0103-M-CDC2026_00IC1J8
QFN64-050-0909LHQFN64-050-0909LHRTL8211EGIC1U31
QFP14X14_128_16QFP14X14_128_16NVP6124IC2U35; U36
SAC6666SAC6666100UFDISCRETE1C10
SATA7-MSATA7-M67491_1032IC2J9; J10
SBAT2-13ASBAT2-13ABR_1225F1ANIC1U16
SC0402SC04021UFIC36C2; C47; C128; C137; C140; C141; C142; C161; C163; C192; C211; C212; C213; C215; C266; C267; C268; C270; C271; C272; C273; C289; C1192; C1195; C1198; C1199; C1200; C1201; C1206; C1207; C1210; C1211; C1212; C1242; C1245; C1253
SC0402SC0402100NFIC120C11; C14; C18; C28; C29; C31; C33; C34; C35; C36; C39; C40; C43; C46; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C100; C102; C103; C105; C109; C111; C113; C119; C120; C121; C122; C123; C124; C125; C126; C127; C130; C131; C132; C133; C134; C136; C151; C155; C168; C186; C188; C214; C238; C260; C261; C262; C263; C264; C269; C275; C419; C420; C421; C422; C423; C1143; C1182; C1187; C1188; C1191; C1196; C1202; C1203; C1204; C1205; C1209; C1243; C1246; C1249; C1250; C1252
SC0402SC04024.7UFIC2C16; C1241
SC0402SC0402220NFIC2C19; C20
SC0402SC0402100NF/NCIC1C37
SC0402SC040222PFIC3C41; C227; C228
SC0402SC040233PFIC2C106; C241
SC0402SC04021NFIC6C107; C114; C115; C242; C253; C563
SC0402SC0402470NFIC5C118; C135; C210; C236; C1197
SC0402SC04024PF/NCIC6C139; C154; C293; C294; C295; C296
SC0402SC040222NFIC1C187
SC0603SC06031UFIC2C12; C1144
SC0603SC060310UFIC21C30; C42; C44; C45; C99; C101; C129; C167; C189; C190; C191; C194; C195; C196; C197; C198; C311; C313; C314; C575; C576
SC0603SC0603100NFIC11C32; C72; C108; C110; C116; C117; C143; C150; C231; C304; C1168
SC0603SC06034.7UFIC4C48; C661; C662; C663
SC0603SC060310NFIC10C200; C201; C202; C203; C204; C205; C206; C207; C306; C307
SC0603SC06032.2UFIC2C225; C226
SC0805SC080522UFDISCRETE3C6; C17; C247
SC0805SC080547UFDISCRETE1C38
SC0805SC080510UFDISCRETE4C208; C209; C232; C249
SC1206SC12061NFIC1C13
SC1206SC120610UFIC1C317
SC1206CSC1206C100UFDISCRETE4C246; C248; C310; C1285
SC1210BSC1210B22UFDISCRETE5C4; C5; C7; C193; C1179
SCAPC2-0606SCAPC2-060647UFDISCRETE2C1; C8
SD0805-LEDSD0805-LEDLEDIC1D19
SD0805-LEDSD0805-LEDSD0805-LEDIC2D23; D24
SD1710ASD1710A1SMA13CAT3GDISCRETE1D18
SD1714DSD1714DTISP4350H3BJR_SDISCRETE1D22
SEN3-100CSEN3-100C3638AIC1D17
SF6127SF61270451005MRLIC1F1
SIP-1PSIP-1PTSW_101_23_F_SIC4J3; J4; J5; J6
SIP-4P-200SIP-4P-200P2441IC1J23
SL0402SL0402BLM15HG102SN1DIC12LB1; LB2; LB10; LB11; LB12; LB74; LB79; LB80; LB83; LB94; LB95; LB96
SL0402SL0402BLM15BD601SN1DIC1LB18
SL0603SL06034.7NHIC3L5; L6; L7
SL0805SL0805LFBK2125HS101_TIC10LB3; LB4; LB5; LB7; LB15; LB16; LB23; LB27; LB28; LB66
SL1206SL1206MGLB3216_060T_LFIC6LB6; LB8; LB9; LB13; LB14; LB17
SL1210SL1210FCFBMH3225HM601NTDISCRETE2LB19; LB20
SL2828SL28284.7UHIC1L4
SOP16-26-208-255SOP16-26-208-255ICL3232EIA_TIC1U14
SOT23-5BSOT23-5BSN74LVC1G125DBVRIC1U13
SOT23-5CSOT23-5CNC7SV08P5XIC1U6
SOT23-6LSOT23-6LAZC199-04SIC1U19
SOT23BSOT23BPT7M7809RTEIC1U2
SOT23_5SOT23_5SY8088IC1U1
SPL0505HSPL0505H4.7UIC3L1; L2; L3
SR0402SR04021KIC19R2; R43; R44; R45; R46; R105; R106; R107; R127; R131; R135; R136; R137; R138; R282; R741; R742; R743; R744
SR0402SR0402100IC1R3
SR0402SR040282KIC3R4; R5; R98
SR0402SR040210IC36R8; R29; R92; R93; R94; R95; R96; R97; R124; R125; R126; R139; R140; R141; R142; R143; R145; R146; R157; R159; R160; R161; R162; R163; R165; R166; R167; R174; R180; R185; R188; R189; R194; R202; R205; R220
SR0402SR040222IC12R11; R18; R52; R53; R123; R144; R164; R192; R736; R737; R738; R739
SR0402SR040233IC15R12; R13; R14; R15; R16; R17; R20; R103; R108; R109; R110; R111; R112; R113; R132
SR0402SR04020IC33R19; R21; R25; R26; R32; R34; R55; R65; R66; R67; R73; R74; R87; R88; R90; R91; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R169; R170; R171; R173; R178; R182; R187
SR0402SR040233/NCIC2R23; R40
SR0402SR04021MEGIC1R24
SR0402SR040211KIC2R27; R28
SR0402SR040210KIC5R30; R38; R48; R49; R63
SR0402SR04020/NCIC6R31; R33; R35; R37; R181; R217
SR0402SR04024.7KIC47R36; R75; R89; R104; R114; R118; R119; R128; R201; R206; R207; R222; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R329; R330; R331; R332; R333; R334; R336; R337; R339; R340; R341; R342; R345
SR0402SR04022KIC2R39; R56
SR0402SR0402100KIC11R51; R70; R72; R115; R120; R134; R175; R179; R183; R186; R196
SR0402SR04024.7K/NCIC4R57; R71; R184; R343
SR0402SR040275IC12R59; R61; R62; R64; R79; R80; R81; R82; R83; R84; R85; R86
SR0402SR040212KIC1R60
SR0402SR0402120IC1R77
SR0402SR040220KIC1R99
SR0402SR040211.3KIC2R100; R101
SR0402SR040227KIC1R121
SR0402SR040213.7KIC1R122
SR0402SR04025.1KIC1R133
SR0402SR0402240IC3R158; R740; R745
SR0402SR040239.2KIC1R168
SR0402SR04025.6KIC2R214; R269
SR0402SR0402121KIC1R218
SR0402SR040251KIC1R271
SR0603SR060336.5KIC1R1
SR0603SR06031KIC3R6; R7; R130
SR0603SR060310KIC2R9; R50
SR0603SR06037.68KIC1R10
SR0603SR0603510IC3R22; R68; R69
SR0603SR0603270IC2R41; R42
SR0603SR060310K/NCIC1R47
SR0603SR060375IC2R54; R437
SR0603SR0603200IC1R58
SR0603SR0603620IC1R76
SR0603SR06034.7KIC3R102; R116; R117
SR0603SR06034.7K/NCIC1R129
SR0603SR0603100KIC1R190
SR0603SR060363.4KIC1R191
SR0603SR0603200KIC2R193; R195
SR0603SR060340.2KIC2R197; R198
SR0603SR06030IC2R199; R200
SR0603SR06030/NCIC1R203
SR0603SR060324.3KIC1R208
SR0603SR060312.7KIC1R209
SR0603SR060326.1KIC1R210
SR0603SR060369.8KIC1R211
SR0603SR060314.7KIC1R212
SR0603SR060331.6KIC1R213
SR0603SR060349.9IC1R221
SR0603SR06032.49KIC1R685
SR0603SR0603100IC2R728; R729
SR1206SR12061KIC1R78
SSW-PUSHSSW-PUSHTL3301AF160RGIC1S1
STC3528STC3528220UFIC4C104; C112; C234; C312
STFM24-40-280STFM24-40-280G24_0413ERIO1T1
SW4_6M6X5M4SW4_6M6X5M4EMR_0415_T_V_T_RIC2SW1; SW2
TSOT23-8TSOT23-8MP1494SIC1U9
TSOT23-8TSOT23-8MP1495SIC2U12; U15
TSOT23-8TSOT23-8MP2122IC1U17
USB8-1715USB8-1715UB11123_8D3_4FDISCRETE1J2
VAF6-1914VAF6-1914AV3-8_4-15IC1J19
VAF12-RFVAF12-RFAV8_84_13T_PBDISCRETE2J13; J14
WBC0104-49TWBC0104-49TSDW12501_4A_HWIC1J1
WSON8-50-0806LWSON8-50-0806LMX25L125635EIC1U5
WSON8-MX25L12835ZNWSON8-MX25L12835ZN8PIN_SPI_FLASHIC1U4
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
5 U/ Y$ {- ?, N- E" j) i
发表于 2020-11-11 11:22 | 只看该作者
下来学习学习正好用到
9 m) C6 u3 M, q/ I% o
发表于 2021-12-12 01:34 | 只看该作者
谢谢分享
发表于 2021-12-16 15:12 | 只看该作者
下载下来学习. t# `  y/ w4 F
    2025-9-12 15:02
  • 签到天数: 810 天
    [LV.10]以坛为家III
    发表于 2022-3-11 13:10 | 只看该作者
    dddddddddddddddd  X9 H6 E% _% U, u3 y. p
    发表于 2022-4-28 14:54 | 只看该作者
    dddddddddddddddd
    2025-9-11 15:42
  • 签到天数: 577 天
    [LV.9]以坛为家II
    发表于 2022-5-16 21:05 | 只看该作者
    看看,学习一下。努力  n; ?, E9 |( e* M! D' w
    GMT+8, 2025-9-13 07:46 , Processed in 0.171875 second(s), 28 queries , Gzip On.
