查看: 883|回复: 6
[allegro17.2][2层]HI3520DV3DMEB_VER_B(HI3520DV300+P2441+NVP6124)原理图和pcb...
发表于 2020-1-8 15:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][2层]HI3520DV3DMEB_VER_B(HI3520DV300+P2441+NVP6124)原理图和pcb文件
文件描述:
1. 作品用途:HI3520DV3DMEB_VER_B
2. 软件版本:allegro17.2
3. 层数:2层
4. 用到的主要芯片:HI3520DV300+P2441+NVP6124
5. PCB尺寸:6400*3511 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA96-32-1609MBGA96-32-1609MH5TQ4G63AFR_RDCIC1U10
CAPC2-100-250CAPC2-100-250220UFIC1C240
DB15-3RF-ADB15-3RF-A17HE_R13150_73HC2IC1J12
DFN2510P10E_AZ1045DFN2510P10E_AZ1045AZ1045-04FIC2U3; U18
HOLE160-8STARHOLE160-8STAR138MIL_STAR_HOLE_TO_M3_AIC4M1; M2; M3; M4
HSC0402HSC04022.2UFIC5C3; C9; C15; C21; C22
HSL1008HSL10082.2UHIC3L8; L9; L10
HSOD323AHSOD323AD_AIC2D14; D15
HSOD882HSOD882ESD8V0R1B_02LRHDISCRETE20D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D11; D12; D13; D16; D20; D21; D26; D27; D28; D29
HSX2-0302HSX2-030232.768KHZIC1X2
HSX4-0302BHSX4-0302B27MHZDISCRETE2OSC1; X1
ID-BOARDID-BOARDPCB_MARKPOINTIC6ID1; ID2; ID3; ID4; ID5; ID6
IDC20-DTM1-AIDC20-DTM1-AHU5_200PNA_S53T_FAIC1J26
MJ8-SRLFYMJ8-SRLFYE5J88_14LJ24_LIC1J18
MLF6-065-0202LMLF6-065-0202LHPA00615DRVRIC1U20
PSW3-RAPSW3-RARA22KKFR0FL_D1IC1S2
PWC0103-M-CPWC0103-M-CDC2026_00IC1J8
QFN64-050-0909LHQFN64-050-0909LHRTL8211EGIC1U31
QFP14X14_128_16QFP14X14_128_16NVP6124IC1U35
QFP256HA-040-2828LQFP256HA-040-2828LHI3520DV300IC1U8
RUSB19-050-1512RUSB19-050-1512IC1J16
SAC6666SAC6666100UFDISCRETE1C10
SATA7-MSATA7-M67491_1032IC2J9; J10
SBAT2-13ASBAT2-13ABR_1225F1ANIC1U16
SC0402SC04021NFDISCRETE180C2; C4; C11; C12; C14; C16; C18; C19; C20; C23; C24; C25; C26; C27; C29; C30; C31; C33; C34; C35; C36; C37; C39; C40; C41; C43; C44; C45; C46; C47; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C92; C94; C95; C96; C97; C98; C106; C107; C118; C119; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C141; C142; C151; C155; C161; C163; C168; C186; C187; C192; C200; C201; C202; C203; C204; C205; C206; C207; C211; C212; C215; C227; C228; C236; C241; C242; C253; C260; C261; C262; C263; C264; C266; C267; C268; C269; C270; C271; C272; C273; C289; C290; C311; C419; C420; C421; C422; C423; C563; C1143; C1182; C1187; C1188; C1191; C1210; C1211; C1242; C1243; C1245; C1246; C1249; C1250; C1252; C1253; C1254; C1260; C1261; C1264; C1265; C1266; C1267; C1268; C1269; C1270; C1272; C1273; C1274; C1275; C1284; C1285; C1286; C1287; C1288; C1289; C1290
SC0603SC0603100NFDISCRETE41C32; C73; C99; C101; C110; C116; C120; C139; C143; C150; C154; C189; C190; C191; C194; C195; C213; C225; C285; C293; C294; C295; C296; C306; C307; C314; C575; C576; C661; C662; C663; C1255; C1256; C1262; C1276; C1277; C1278; C1279; C1281; C1282; C1283
SC0805SC080522UFDISCRETE10C6; C17; C38; C42; C208; C246; C249; C310; C312; C1258
SC1206SC12061NFDISCRETE2C13; C1263
SC1206CSC1206CIC2C1271; C1280
SC1210BSC1210B22UFDISCRETE4C5; C7; C193; C1179
SCAPC2-0606SCAPC2-060647UFDISCRETE2C1; C8
SD0805-LEDSD0805-LEDLEDIC4D19; D23; D24; D25
SD1710ASD1710A1SMA13CAT3GDISCRETE1D18
SD1714DSD1714DTISP4350H3BJR_SIC1D22
SEN3-100CSEN3-100C3638AIC1D17
SF6127SF61270451005MRLDISCRETE1F1
SIP-1PSIP-1PTSW_101_23_F_SIC5J3; J5; J6; J15; J27
SIP-4P-200SIP-4P-200P2441IC1J23
SL0402SL0402BLM15HG102SN1DIC14LB1; LB2; LB10; LB11; LB12; LB74; LB79; LB80; LB83; LB90; LB94; LB95; LB96; LB97
SL0603SL06034.7NHIC3L5; L6; L7
SL0805SL0805LFBK2125HS101_TDISCRETE3LB15; LB16; LB98
SL1206SL1206MGLB3216_060T_LFIC6LB6; LB23; LB27; LB28; LB99; LB100
SL1210SL1210FCFBMH3225HM601NTDISCRETE2LB19; LB20
SL2828SL28284.7UHIC2L1; L4
SOT23-5BSOT23-5BSN74LVC1G125DBVRIC1U13
SOT23-6LSOT23-6LAZC199-04SIC1U19
SOT23BSOT23BPT7M7809RTEIC1U2
SOT23_5SOT23_5SY8088IC1U1
SPL0505HSPL0505H4.7UIC1L3
SR0402SR04020IC179R1; R2; R3; R4; R7; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R23; R24; R26; R28; R32; R36; R37; R38; R39; R43; R44; R45; R46; R51; R52; R53; R55; R56; R57; R59; R60; R61; R62; R63; R65; R66; R67; R70; R72; R73; R74; R77; R79; R80; R81; R82; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R101; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R131; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R158; R168; R169; R170; R171; R173; R175; R178; R179; R183; R184; R186; R187; R194; R195; R209; R212; R218; R220; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R269; R271; R282; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R345; R745; R746; R747; R748; R749; R750; R758; R759; R760; R761; R762; R763; R764; R765; R766; R767; R768; R769; R770; R771
SR0603SR06030DISCRETE32R6; R9; R10; R22; R25; R31; R33; R34; R41; R42; R54; R58; R68; R69; R76; R190; R193; R203; R208; R210; R211; R221; R437; R683; R685; R751; R752; R753; R754; R755; R756; R757
SR1206SR12061KIC1R78
SRN8-0804SRN8-080433DISCRETE1RN1
SSW-PUSHSSW-PUSHTL3301AF160RGIC1S1
STC3528STC3528220UF/NCDISCRETE3C112; C247; C313
STFM24-40-280STFM24-40-280G24_0413ERIO1T1
TSOT23-8TSOT23-8MP2122IC3U12; U15; U17
USB8-1715USB8-1715UB11123_8D3_4FDISCRETE1J2
VAF6-1914VAF6-1914AV3-8_4-15IC1J19
VAF12-RFVAF12-RFAV8_84_13T_PBDISCRETE1J13
WBC0104-49TWBC0104-49TSDW12501_4A_HWIC2J1; J25
WSON8-50-0806LWSON8-50-0806LMX25L12835EIC1U5
WSON8-MX25L12835ZNWSON8-MX25L12835ZN8PIN_SPI_FLASHIC1U4
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
. M+ g& w( m$ R! Q5 \$ p
    2021-3-1 15:52
  • 签到天数: 42 天
    [LV.5]常住居民I
    发表于 2020-11-3 17:37 | 只看该作者
    二维而且是
    郁闷
    2020-11-24 15:01
    发表于 2020-11-24 14:44 | 只看该作者
    楼主,能跑起来吗
    发表于 2020-11-24 20:20 | 只看该作者
    感觉好复杂啊啊
    2025-1-18 15:49
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2021-3-27 16:49 | 只看该作者
    111111111111
    " O! d$ w" T9 G9 R
    发表于 2021-5-10 11:01 | 只看该作者
    GMT+8, 2025-7-5 04:46 , Processed in 0.156250 second(s), 28 queries , Gzip On.
