1. 作品用途:HI3520 2 VGA
2. 软件版本:allegro17.2
3. 层数:2层
5. PCB尺寸:118*66 mm
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA96-32-1609M | MT41J256M16RE-15E-D_0_BGA96-32- | K4B2G1646Q-BYMA | IC | 1 | U10 |
DIP_4MM2_8PIN | SIP-2X4PIN-4_2MM_DIP_4MM2_8PIN_ | SIP-2x4PIN-4_2mm | IC | 1 | J106 |
F0805 | FUSE2_1_F0805_100MA | 100mA | IC | 1 | F3 |
HD1X4_79 | J-CON-4_HD1X4_79_NC | NC | IC | 1 | J93 |
HSOD323 | DZ_L_0_HSOD323_GBLC24C-LF-T7 | GBLC24C-LF-T7 | IC | 1 | D76 |
HSOD523 | DZ_L_0_HSOD523_BSD5C051U | BSD5C051U | IC | 12 | D9; D10; D11; D16; D33; D35; D38; D39; D40; D48; D49; D50 |
HSOD523 | DZ_L_0_HSOD523_NC_BSD5C051U | NC_BSD5C051U | IC | 2 | D32; D34 |
ID-BOARD | ID-BOARD_0_ID-BOARD_NC | NC | IC | 6 | ID1; ID2; ID3; ID4; ID5; ID6 |
J-CAR-32-3 | J-CAR-32_J-CAR-32-3_J-CAR-32 | J-CAR-32 | IC | 1 | J6 |
JK_3_127 | J-CAR-3_JK_3_127_SIP-1.27/NC | SIP-1.27/NC | IC | 1 | J107 |
LED_DIP_254 | LED_0_LED_DIP_254_LED_R | LED_R | IC | 1 | D19 |
MC-146 | X_2_MC-146_32.768KHZ | 32.768KHZ | IC | 1 | X2 |
MS621FE | Z-BATTERY_MS621FE_NC_MS621FE | NC_MS621FE | IC | 1 | U36 |
QFN76-15P7-TH | NVP6124B_1_QFN76-15P7-TH_NVP612 | NVP6124B_76QFN | IC | 1 | U35 |
QFP256HA-040-2828L | HI3520DV300_VI_0_QFP256HA-040-2 | HI3520DV300_VI | IC | 1 | U8 |
SC0402 | C_0_SC0402_1UF/6.3V | 1UF/6.3V | IC | 56 | C192A; C47; C51; C55; C60; C79; C80; C81; C83; C88; C90; C92; C96; C97; C127; C130; C132; C141; C142; C161; C163; C212; C215; C225; C236; C266; C267; C268; C270; C271; C272; C273; C289; C290; C1242; C1252; C1260; C1261; C1264; C1265; C1266; C1267; C1268; C1269; C1270; C1272; C1273; C1274; C1275; C1284; C1285; C1286; C1287; C1288; C1289; C1417 |
SC0402 | C_0_SC0402_100NF | 100NF | IC | 95 | C2; C4; C11; C12; C16; C18; C19; C20; C23; C24; C25; C26; C27; C29; C30; C31; C34; C40; C43; C44; C45; C46; C49; C50; C52; C53; C54; C56; C58; C59; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C75; C76; C77; C89; C110; C155; C168; C211; C1182; C1187; C1188; C1191; C1210; C1211; C1243; C1245; C1246; C1249; C1250; C1253; C1290; C1299; C1301; C1322; C1323; C1375; C1376; C1377; C1378; C1380; C1381; C1383; C1384; C1385; C1403; C1406; C1409; C1412; C1418; C1419; C1420; C1426; C1433; C1434; C1439; C1446; C1448; C1480; C1481; C1484; C1485; C1486; C1488; C1493 |
SC0402 | C_0_SC0402_100NF_ | 100NF | IC | 13 | C95; C118; C119; C121; C122; C123; C124; C125; C129; C131; C133; C134; C135 |
SC0402 | C_0_SC0402_1.2NF | 1.2NF | IC | 11 | C98; C242; C253; C1404; C1407; C1410; C1413; C1436; C1441; C1490; C1495 |
SC0402 | C_0_SC0402_10PF | 10PF | IC | 8 | C106; C227; C228; C241; C1437; C1442; C1491; C1496 |
SC0402 | C_0_SC0402_470NF | 470NF | IC | 6 | C126; C128; C1435; C1440; C1489; C1494 |
SC0402 | CAP NP_0_SC0402_10NF | 10nF | IC | 1 | C197 |
SC0402 | C_0_SC0402_100NF/25V_ | 100NF/25V | IC | 2 | C1314; C1428 |
SC0402 | C_0_SC0402_100NF/25V | 100NF/25V | IC | 8 | C1320; C1321; C1368; C1369; C1374; C1379; C1427; C1449 |
SC0402 | C_SC0402_10NF | 10NF | IC | 2 | C1343; C1344 |
SC0402 | C_SC0402_1.2NF | 1.2NF | IC | 2 | C1355; C1363 |
SC0402 | C_SC0402_6.8NF | 6.8NF | IC | 2 | C1362; C1366 |
SC0402 | C-SMD_SC0402_100NF | 100NF | IC | 1 | C1415 |
SC0402 | C_0_SC0402_6.8NF | 6.8NF | IC | 4 | C1438; C1443; C1492; C1497 |
SC0402 | C_0_SC0402_NC | NC | IC | 2 | C1482; C1483 |
SC0603 | C_0_SC0603_10UF/6.3V | 10UF/6.3V | IC | 33 | C6; C17; C99; C101; C120; C189; C190; C191; C213; C247; C285; C314; C1254; C1255; C1276; C1277; C1278; C1279; C1281; C1282; C1283; C1315; C1387; C1389; C1405; C1408; C1411; C1414; C1444; C1445; C1447; C1487; C1498 |
SC0603 | 10UF,6_0.3V,20%,SMD0805_SC0603_ | 10UF/6.3V | IC | 1 | C198 |
SC0603 | C_0_SC0603_22UF/6.3V | 22UF/6.3V | IC | 5 | C246; C313; C1271; C1280; C1416 |
SC1206 | C_0_SC1206_NC_10UF/25V | NC_10UF/25V | IC | 2 | C1397; C1398 |
SC1210 | CP_0_SC1210_100UF/6.3V | 100UF/6.3V | IC | 2 | C112; C312 |
SC1210 | C_0_SC1210_100UF/6.3V | 100UF/6.3V | IC | 4 | C1392; C1394; C1395; C1421 |
SL0603 | LB_0_SL0603_BLM15BD601SN1D | BLM15BD601SN1D | IC | 5 | LB1; LB2; LB80; LB83; LB90 |
SL0603 | LB_0_SL0603_BLM15HG102SN1D | BLM15HG102SN1D | IC | 9 | LB10; LB11; LB12; LB74; LB79; LB94; LB95; LB96; LB97 |
SL0805 | Z-FUSE_SL0805_100MA | 100mA | IC | 1 | F2 |
SL0805 | FUSE2_1_SL0805_0.5A | 0.5A | IC | 1 | F6 |
SL0805 | LB_0_SL0805_600R | 600R | IC | 7 | LB23; LB27; LB28; LB107; LB112; LB113; LB114 |
SL1812 | FUSE2_1_SL1812_1.5A | 1.5A | IC | 2 | F4; F5 |
SL7870 | L_SL7870_22UH | 22UH | IC | 2 | L13; L14 |
SL7870 | L_0_SL7870_100UH | 100UH | IC | 1 | L15 |
SMD-2X8_1_27 | PIN2X7_0_SMD-2X8_1_27_PIN2X8-1. | pin2x8-1.27mm | IC | 1 | J25 |
SMT4_1_27 | SIP2_0_SMT4_1_27_SIP4-1_27 | SIP4-1_27 | IC | 1 | J108 |
SMT8X10 | CP_0_SMT8X10_470UF/25V | 470UF/25V | IC | 1 | C1400 |
SOD-214 | DIODE_2_SOD-214_SS34 | SS34 | IC | 2 | D80; D100 |
SOD-523 | D_A_1_SOD-523_RB521S-30 | RB521S-30 | IC | 1 | D4 |
SOD-523 | DIODE_2_SOD-523_NC_RB521S-30 | NC_RB521S-30 | IC | 1 | D41 |
SOD-523 | DIODE_2_SOD-523_RB521S-30 | RB521S-30 | IC | 4 | D42; D101; D102; D106 |
SOD-523 | DIODE_3_SOD-523_NC_RB521S-30 | NC_RB521S-30 | IC | 1 | D47 |
SOP8H-50-154C | MP1484EN_SOP8H-50-154C_MP1484EN | MP1484EN | IC | 2 | U45; U46 |
SOP_16_S | SN74HC4060_SOP_16_S_SN74HC4060 | SN74HC4060 | IC | 1 | U52 |
SOT23 | D-DDAK_SOT23_BAV99 | BAV99 | IC | 1 | D7 |
SOT23-BCE | NPN_0_SOT23-BCE_2N3904 | 2N3904 | IC | 8 | Q2; Q3; Q4; Q8; Q9; Q11; Q12; Q22 |
SOT23-GDS | MOSFET N_0_SOT23-GDS_AO3415 | AO3415 | IC | 1 | Q6 |
SOT23B | ADM809_0_SOT23B_PT7M7809RTE | PT7M7809RTE | IC | 1 | U2 |
SOT89-BCE | 2N3906_0_SOT89-BCE_2SB1260 | 2SB1260 | IC | 1 | Q1 |
SOT-23-BCE | BAT54C/SOT_SOT-23-BCE_BAT54C/SO | BAT54C/SOT | IC | 1 | D105 |
SOT-23-BCE | TP74N33_SOT-23-BCE_TP74N33 | TP74N33 | IC | 1 | U43 |
SOT-26 | X1689_SOT-26_X1689 | X1689 | IC | 1 | U49 |
SOT-89 | HT7533_SOT-89_SGM2200-3.3 | SGM2200-3.3 | IC | 1 | U48 |
SOT-223 | AMS1117-1.2V_SOT-223_AMS1117-1. | AMS1117-1.2v | IC | 1 | U1 |
SPL0505H | L_0_SPL0505H_2.2UH L5020 | 2.2UH L5020 | IC | 4 | L3; L9; L16; L17 |
SR0402 | R_0_SR0402_0R_NC | 0R_NC | IC | 1 | R2 |
SR0402 | R_0_SR0402_100R | 100R | IC | 3 | R3; R77; R775 |
SR0402 | R_0_SR0402_1K 1% | 1K 1% | IC | 10 | R6; R44; R106; R107; R781; R782; R958; R962; R971; R972 |
SR0402 | R_0_SR0402_33R | 33R | IC | 17 | R7; R11; R26; R37; R73; R220; R758; R761; R762; R763; R764; R765; R766; R767; R768; R769; R770 |
SR0402 | R_0_SR0402_1MEG | 1MEG | IC | 1 | R24 |
SR0402 | R_0_SR0402_0R | 0R | IC | 2 | R34; R195 |
SR0402 | R_0_SR0402_10K 1% | 10K 1% | IC | 28 | R51; R118; R127; R134; R175; R184; R186; R232; R233; R760; R833; R953; R954; R955; R956; R957; R959; R961; R965; R970; R974; R976; R1003; R1012; R1016; R1022; R1023; R1024 |
SR0402 | R_0_SR0402_75R | 75R | IC | 9 | R53; R59; R61; R62; R79; R80; R81; R82; R1004 |
SR0402 | R_0_SR0402_10K_NC | 10K_NC | IC | 5 | R57; R105; R131; R183; R187 |
SR0402 | R_0_SR0402_200R 1% | 200R 1% | IC | 1 | R58 |
SR0402 | R_0_SR0402_12K 1% | 12K 1% | IC | 3 | R60; R1049; R1099 |
SR0402 | R_0_SR0402_100K 1% | 100K 1% | IC | 9 | R70; R72; R190; R951; R966; R967; R1010; R1036; R1092 |
SR0402 | R_0_SR0402_1K 1%_ | 1K 1% | IC | 4 | R135; R136; R137; R138 |
SR0402 | R_0_SR0402_240R 1%_ | 240R 1% | IC | 1 | R158 |
SR0402 | R_0_SR0402_200K | 200K | IC | 1 | R193 |
SR0402 | R_0_SR0402_24.3K 1% | 24.3K 1% | IC | 1 | R208 |
SR0402 | R_0_SR0402_392K 1% | 392K 1% | IC | 1 | R209 |
SR0402 | R_0_SR0402_26.1K 1% | 26.1K 1% | IC | 2 | R210; R1040 |
SR0402 | R_0_SR0402_69.8K 1% | 69.8K 1% | IC | 1 | R211 |
SR0402 | R_0_SR0402_604K 1% | 604K 1% | IC | 1 | R212 |
SR0402 | R_1_SR0402_33R | 33R | IC | 4 | R244; R245; R247; R248 |
SR0402 | R_1_SR0402_5.6K 1% | 5.6K 1% | IC | 1 | R246 |
SR0402 | R_0_SR0402_1K | 1K | IC | 2 | R282; R1002 |
SR0402 | R_0_SR0402_240R 1% | 240R 1% | IC | 1 | R745 |
SR0402 | R_0_SR0402_NC_2.2K | NC_2.2K | IC | 1 | R774 |
SR0402 | R_SR0402_75R | 75R | IC | 1 | R944 |
SR0402 | R_SR0402_1K | 1K | IC | 3 | R945; R946; R1055 |
SR0402 | R_SR0402_22R | 22R | IC | 2 | R985; R986 |
SR0402 | R_SR0402_10K 1% | 10K 1% | IC | 1 | R987 |
SR0402 | R_SR0402_26.1K 1% | 26.1K 1% | IC | 1 | R988 |
SR0402 | R_SR0402_10K | 10K | IC | 1 | R989 |
SR0402 | R_SR0402_44.2K 1% | 44.2K 1% | IC | 1 | R991 |
SR0402 | R_0_SR0402_10K | 10K | IC | 11 | R1000; R1001; R1030; R1031; R1039; R1041; R1042; R1095; R1097; R1098; R1100 |
SR0402 | R_0_SR0402_6.8K | 6.8K | IC | 2 | R1009; R1013 |
SR0402 | R_0_SR0402_22R | 22R | IC | 2 | R1011; R1015 |
SR0402 | R_0_SR0402_100K | 100K | IC | 2 | R1014; R1094 |
SR0402 | R_0_SR0402_20K 1% | 20K 1% | IC | 2 | R1034; R1093 |
SR0402 | R_0_SR0402_8.66K 1% | 8.66K 1% | IC | 1 | R1035 |
SR0402 | R_0_SR0402_NC | NC | IC | 3 | R1038; R1043; R1066 |
SR0402 | R_0_SR0402_5.6K 1% | 5.6K 1% | IC | 2 | R1050; R1056 |
SR0603 | R_0_SR0603_270R 1% | 270R 1% | IC | 2 | R41; R42 |
SR0603 | R_0_SR0603_NC | NC | IC | 1 | R1017 |
SR1206 | R_0_SR1206_2.2K | 2.2K | IC | 1 | R952 |
SRN8-0804 | RESISTOR DIP 4_0_SRN8-0804_33R | 33R | IC | 4 | RA1; RA2; RA3; RA4 |
SRN8-0804 | RND8-4_0_SRN8-0804_33R | 33R | IC | 1 | RN1 |
TO-252 | AMS1117-1.2V_TO-252_AMS1117-3.3 | AMS1117-3.3v | IC | 1 | U50 |
TONG_2_2_4_0 | ID-BOARD_0_TONG_2_2_4_0_NC | NC | IC | 4 | M1; M2; M3; M4 |
TSOT23-8 | MP2122_0_TSOT23-8_MP2122 | MP2122 | IC | 1 | U17 |
WAFER_2X7_3_0_90 | WAFER_2X7_3_0_90_WAFER_2X7_3_0_ | WAFER_2x7_3_0_90 | IC | 1 | J105 |
WSON8-50-0806L | W25Q128BV_0_WSON8-50-0806L_MX25 | MX25L12835F | IC | 1 | U5 |
XTAL-3225 | X_B_0_XTAL-3225_24MHZ | 24MHZ | IC | 1 | X1 |
