查看: 591|回复: 5
[allegro17.2][8层]Hi3519V101DMEB海思4K解码板(SII9136CTU-3+HI3519V101+H5TQ4G6...
发表于 2020-1-8 14:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][8层]Hi3519V101DMEB海思4K解码板(SII9136CTU-3+HI3519V101+H5TQ4G63AFR-RDC)原理图和pcb文件
文件描述:
1. 作品用途:Hi3519V101DMEB海思4K解码板
2. 软件版本:allegro17.2
3. 层数:8层
4. 用到的主要芯片:SII9136CTU-3+HI3519V101+H5TQ4G63AFR-RDC
5. PCB尺寸:123.82*93.86 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BCC7-080-0301LBCC7-080-0301LRCLAMP3346PTNTIC1D2
BGA96-32-1609GBGA96-32-1609GH5TQ4G63AFR-RDCIC2U12; U26
DFN2510P10E_AZ1045DFN2510P10E_AZ1045CLAMP0524PIC2U21; U22
HBGA524-16-2424HBGA524-16-2424HI3519V101IC1U3
HEAD0101-T-BHEAD0101-T-BNCIO4J4; J5; J6; J18
HSC0201HSC02011UIC35C16; C18; C19; C20; C22; C31; C32; C144; C145; C146; C147; C148; C149; C150; C152; C153; C154; C155; C156; C175; C183; C184; C306; C307; C308; C309; C310; C312; C313; C314; C340; C341; C349; C350; C351
HSC0201HSC0201220NFIC8C26; C27; C343; C344; C345; C346; C347; C348
HSC0201HSC0201100NFIC10C28; C29; C30; C33; C38; C39; C40; C41; C42; C55
HSC0201HSC02011UFIC1C151
HSC0402HSC04022.2UFIC6C12; C13; C14; C23; C24; C121
HSC0402-TAHSC0402-TA330NDISCRETE2C4; C6
HSD0603-LEDHSD0603-LEDLEDIC1D14
HSL0201-TBHSL0201-TBBLM03AG102SN1DISCRETE10LB1; LB5; LB6; LB7; LB14; LB17; LB18; LB19; LB25; LB26
HSL1008HSL10082.2UHDISCRETE6L3; L5; L6; L7; L9; L10
HSOD882HSOD882PESD5V0S1BL315IC10D4; D5; D6; D7; D10; D11; D15; D17; D23; D24
HSOT-SC70-DCKHSOT-SC70-DCKSN74LVC1G125DCKRIC1U11
HSR0201HSR020110KDISCRETE2R1; R151
HSR0402-TAHSR0402-TA560DISCRETE2R150; R152
HSX2-0302HSX2-030232.768KHZIC1X2
HSX4-0302HSX4-030224MHZIC1X1
HSX4-0302HSX4-030225MHZIC1X3
ID-BOARDID-BOARDPCB_MARKPOINTIO6ID1; ID2; ID3; ID4; ID5; ID6
MJ8-SR-BZ-AMJ8-SR-BZ-A1_406541_1IO1J14
MLF6-065-0202LMLF6-065-0202LTPS2553DRVRIC1U1
MLF8M-050-0202LMLF8M-050-0202LMP2162GQH_ZIC2U13; U31
MOLEX_47151MOLEX_47151HDMIIC1J17
MSOP8A-26-118MSOP8A-26-118PAM8303DBSCIC1U7
MTH_C6MMD3P2MMMTH_C6MMD3P2MMHOLEIC4M1; M2; M3; M4
PWC0103-M-NPWC0103-M-NDC2026_00IO1J12
QFN16-050-0303LHQFN16-050-0303LHMP6507IC1U20
QFN40-8211FIQFN40-8211FIRTL8211FI-CGIC1U2
QFP100HD-050-1414LQFP100HD-050-1414LSII9136CTU-3IC1U25
RUSB9-180-0726ARUSB9-180-0726AA4E0911_A_30_T_BIO1J8
SBAT2-13ASBAT2-13ABR_1225F1ANIC1U24
SC0402SC04025.6PFIC1C1
SC0402SC04021NFIC7C2; C137; C140; C141; C213; C249; C254
SC0402SC040247PFIC2C9; C10
SC0402SC04021UFIC34C11; C15; C85; C114; C118; C119; C132; C133; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C176; C177; C178; C248; C261; C262; C266; C267
SC0402SC0402100NFIC86C34; C35; C36; C37; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C56; C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C86; C87; C88; C89; C90; C91; C92; C93; C94; C97; C98; C99; C100; C101; C103; C104; C109; C112; C117; C143; C206; C218; C236; C250; C251; C252; C253; C269; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C283; C284; C285; C286; C287
SC0402SC040222PFIC2C57; C239
SC0402SC040215PFIC4C105; C122; C221; C222
SC0402SC0402680PFIC2C130; C131
SC0402SC040227PFIC2C138; C139
SC0402SC040233PFIC2C179; C180
SC0402SC040222NFIC3C181; C182; C270
SC0402SC04024.7UFIC7C185; C186; C187; C188; C311; C315; C316
SC0402SC0402NCIC1C200
SC0402SC04021NF/NCIC2C208; C211
SC0402SC040210NFIC1C212
SC0402SC040210PFIC2C214; C215
SC0402SC040218PFIC2C219; C220
SC0402-BGASC0402-BGA2.2UFDISCRETE2C17; C21
SC0603SC06032.2UF/NCIC2C25; C120
SC0603SC06032.2UFIC2C95; C96
SC0603SC0603100NFIC7C106; C107; C108; C110; C111; C113; C257
SC0603SC06031UFIC5C115; C116; C123; C129; C268
SC0603SC0603220PFIC2C135; C136
SC0603SC060310UFIC25C142; C224; C225; C226; C227; C228; C229; C230; C231; C233; C234; C235; C240; C241; C242; C243; C244; C245; C246; C247; C255; C256; C271; C272; C333
SC0603SC06034.7UFIC2C210; C232
SC0603SC060310UF/NCIC2C237; C238
SC0805SC080510UFDISCRETE6C3; C7; C8; C84; C217; C223
SC0805BSC0805B22UFDISCRETE4C5; C102; C128; C201
SC1206SC120647UFDISCRETE4C189; C190; C191; C194
SC1206SC120622UFDISCRETE11C192; C193; C195; C196; C197; C198; C199; C202; C203; C205; C207
SC1206SC12061NFDISCRETE5C204; C216; C258; C259; C260
SC1210SC1210100UFDISCRETE3C263; C264; C265
SC1210BSC1210B22UFDISCRETE5C124; C125; C126; C127; C134
SCAPC2-280-327SCAPC2-280-327220UFDISCRETE1C209
SD0805-LEDSD0805-LEDLEDIC2D3; D18
SD1710ASD1710A1SMA13CAT3GIC1D1
SD1714ASD1714ADIODEIC1D22
SD1714DSD1714DTISP4350H3BJR_SIC4D16; D19; D20; D21
SDC10-1315SDC10-1315DM3ND_SF_PEJ800IO2J1; J2
SED90-F-ASED90-F-AMIPI_90_CON_FIC1J3
SF6127SF61270451005MRLIC1F1
SGM8903SGM8903SGM8903IC1U4
SHEAD-4P-49SHEAD-4P-4953398_0471IC5J9; J13; J16; J20; J25
SHEAD-8P-49SHEAD-8P-4986_101_40801_1IC1J10
SHEAD-8P-49SHEAD-8P-4953398_0871IC2J11; J15
SIP-2PSIP-2PTSW_102_23_F_SIO2J23; J24
SL0402SL0402BLM15HG102SN1DDISCRETE5LB4; LB10; LB22; LB23; LB24
SL0402SL0402NCDISCRETE2LB8; LB9
SL0603SL0603MGLB1608_030T_LFIC2LB11; LB12
SL0805SL08054.7UHIC1L13
SL0805SL0805MGLB2012_220T_LFIC7LB2; LB3; LB13; LB15; LB16; LB20; LB21
SL0805BSL0805B100NHDISCRETE1L11
SL2828SL28284.7UHIC1L2
SOP8-20-91SOP8-20-9174AVCH2T45DCIC2U8; U14
SOP8-50-150SOP8-50-150ADM706RARIC1U6
SOP8-50-150SOP8-50-150TLV2372IDRIC1U19
SOP16-50-300ASOP16-50-300AMX25L25635FMI_16PINIC1U15
SOP48-20-720ASOP48-20-720ANANDFLASH/NCIC1U9
SOT23SOT23PMOS-GSDIC4Q1; Q2; Q3; Q9
SOT23SOT23NPN-BECIC5Q4; Q5; Q6; Q7; Q8
SOT23SOT23PMOS-GSD/NCIC1Q10
SOT23-6BSOT23-6BRT9065GE_AIC3U16; U17; U23
SOT23-6LSOT23-6LCLAMP0504DTIC1U10
SPL0303ASPL0303A4.7UIC1L12
SPL0404LSPL0404L3.9UHDISCRETE1L1
SPL0404LSPL0404L1UHDISCRETE1L4
SPSW6-TSPSW6-TTMG_533_T_RIO2S1; S2
SR0402SR0402100IC5R4; R7; R14; R65; R271
SR0402SR04024.7KIC45R5; R18; R57; R66; R67; R70; R71; R73; R74; R82; R83; R85; R102; R120; R143; R158; R161; R193; R208; R210; R212; R213; R214; R215; R216; R217; R218; R222; R223; R224; R225; R226; R227; R230; R240; R244; R245; R246; R247; R265; R266; R308; R309; R310; R313
SR0402SR04020/NCIC23R6; R10; R13; R16; R17; R27; R38; R41; R52; R55; R64; R112; R144; R169; R171; R172; R178; R229; R258; R272; R291; R306; R324
SR0402SR0402510/NCIC2R8; R260
SR0402SR040247KIC2R9; R47
SR0402SR040216.9KIC1R11
SR0402SR040221.5KIC2R12; R88
SR0402SR0402200KIC1R15
SR0402SR040233IC10R19; R21; R22; R23; R24; R29; R30; R43; R134; R235
SR0402SR040210IC2R20; R32
SR0402SR04020IC26R26; R33; R34; R35; R36; R40; R44; R54; R113; R170; R173; R174; R175; R255; R256; R257; R259; R273; R288; R289; R302; R303; R304; R307; R325; R326
SR0402SR04021MEGIC2R28; R37
SR0402SR04021KIC21R42; R45; R46; R53; R81; R164; R183; R184; R185; R187; R192; R199; R200; R202; R236; R239; R243; R248; R276; R305; R314
SR0402SR04022.2KIC1R48
SR0402SR040210KIC23R51; R56; R60; R61; R62; R63; R68; R69; R80; R84; R87; R96; R153; R154; R155; R156; R157; R159; R188; R253; R274; R277; R311
SR0402SR040215KIC2R58; R59
SR0402SR04024.7K/NCIC27R72; R75; R77; R95; R101; R121; R122; R123; R124; R125; R128; R129; R130; R131; R133; R160; R189; R203; R209; R211; R219; R220; R221; R228; R233; R234; R312
SR0402SR040211.5KIC1R76
SR0402SR0402470K/NCIC2R78; R79
SR0402SR040210K/NCIC2R86; R90
SR0402SR040275IC2R89; R107
SR0402SR0402100KIC20R91; R92; R94; R97; R98; R99; R100; R126; R127; R132; R191; R252; R254; R263; R264; R278; R285; R316; R317; R318
SR0402SR04022.7KIC2R110; R111
SR0402SR040275KIC1R116
SR0402SR040251KIC4R117; R118; R162; R163
SR0402SR040222KIC3R119; R141; R147
SR0402SR040222IC7R135; R296; R297; R298; R299; R300; R301
SR0402SR040212KIC1R136
SR0402SR040233KIC2R137; R146
SR0402SR0402240IC3R139; R140; R261
SR0402SR04028.2KIC1R142
SR0402SR0402510IC2R179; R262
SR0402SR040211KIC2R181; R182
SR0402SR040280.6KIC1R194
SR0402SR040282KIC2R195; R196
SR0402SR0402243KIC2R197; R198
SR0402SR040224KIC1R232
SR0402SR040291KIC2R237; R238
SR0402SR0402270IC1R241
SR0402SR04022KIC3R249; R250; R279
SR0402SR04025.6KIC1R251
SR0402SR04024.02KIC1R275
SR0402SR040220KIC1R287
SR0402SR04026.8KIC2R292; R293
SR0402SR0402NCIC1R329
SR0603SR0603100/NCIC1R2
SR0603SR0603100IC1R3
SR0603SR0603150KIC1R31
SR0603SR06035.1KIC2R49; R50
SR0603SR06031.1KIC8R93; R103; R104; R105; R106; R108; R109; R138
SR0603SR060311.3KIC2R114; R115
SR0603SR060324.3KIC2R145; R149
SR0603SR06037.68KIC1R148
SR0603SR060330.9KIC1R176
SR0603SR0603470IC1R177
SR0603SR060312.7KIC1R186
SR0603SR060327KIC2R190; R201
SR0603SR06034.7KIC1R231
SR0603SR06030IC2R280; R281
SR0603SR06032IC2R283; R284
SR0603SR060340.2KIC1R286
SR0603SR06032.49KIC1R294
SR0603SR0603120K/NCIC1R295
SR0603SR0603120KIC1R320
SR0805SR080510KIC1R39
SR0805SR080575IC4R180; R282; R290; R319
SR1206SR12060DISCRETE1R25
SRN8-0804SRN8-080433DISCRETE5RN1; RN7; RN8; RN9; RN10
SRN8-0804SRN8-08044.7KDISCRETE5RN2; RN3; RN4; RN5; RN6
SSW-PUSHSSW-PUSHTL3301AF160RGIO1S3
STFM24-40-280STFM24-40-280G24_0413ERIC1T1
SW4_6M6X5M4SW4_6M6X5M4EMR_0415_T_V_T_RIC1SW1
TP24-SMDTP24-SMDTEST-SMDIO2TP1; TP2
TSOT23-8TSOT23-8MP2143IC1U18
TSOT23-8TSOT23-8MP1495SIC2U27; U28
TSOT23-8TSOT23-8MP2122IC1U29
VAF6-1406EVAF6-1406E32110058IO2J29; J30
WSON8-MX25L12835ZNWSON8-MX25L12835ZNMX25L12835ZN/NCIC1U5
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
9 P! r1 d+ L! w! k% f( h
    无聊
    2020-8-23 15:35
  • 签到天数: 7 天
    [LV.3]偶尔看看II
    发表于 2020-12-13 15:20 | 只看该作者
    感谢楼主分享
    “来自电巢APP”
    擦汗
    2021-9-6 15:33
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2020-12-22 10:15 | 只看该作者
    海思给出的开发资料实在是太详细了,觉得至少相对于国内企业来说,海思提供的配套开发文档实在是太详细太详细,不知道海思为了文档化养了多少人专门来干这件事情,海思不愧是全球
    发表于 2021-10-26 17:35 | 只看该作者
    感谢楼主,感谢HW
    “来自电巢APP”
    发表于 2021-11-16 21:17 | 只看该作者
    好东西要分享
    GMT+8, 2025-7-3 11:25 , Processed in 0.156250 second(s), 27 queries , Gzip On.
