查看: 236|回复: 0
[allegro16.6][4层] ADI参考板(AD7173+ADG704BRMZ+ADR4540BRZ)pcb文件
发表于 2020-1-7 17:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
! S9 r+ W: C" C, i[allegro16.6][4层] ADI参考板(AD7173+ADG704BRMZ+ADR4540BRZ)pcb文件
( O1 U' U0 \0 a: @9 K2 a; F( d6 P) v8 V9 r
文件描述:
0 _9 L+ `9 Y$ N2 H7 k4 U2 f$ o5 K, [& \) b! r- D
1. 作品用途: ADI参考板) Y6 ]( k$ e; y3 y& H5 y
2. 软件版本:allegro16.6' C! A5 u6 ~5 V$ W4 H2 C/ l- [
3. 层数:4层
3 o' _7 o% q: \4. 用到的主要芯片:AD7173+ADG704BRMZ+ADR4540BRZ$ A+ a4 {) v2 M
5. pcb尺寸: 5200*3400 MIL3 Q- ]) k; t4 q4 R6 Q
: i1 v: x( E3 O, W6 n* ^3 O* ~作品截图如下:
1 e: c+ A# B: o. J  K2 |" i+ \# W% l% ~3 V3 m" A# s
顶层截图:: b# ]' F0 Y1 y, S* z
4 `( v. v7 w! @: ^- z& K底层截图:
  d6 G4 N0 Y- u/ J, ~" x4 x
' \6 \" ~0 U' Z- I5 X+ L$ m0 l9 N  M6 U' O/ `3 X
全层截图:( b- c8 F$ K6 ]" p
! x- n! l+ U: Q. G3 U1 u# A
$ [+ c$ r( s- i- D7 s% x6 hBOM:
; O8 G$ E8 P& V. K* G$ F* g
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C0402CAP_SM-10UF,10V,20,E020928,C04B10uFDISCRETE4C70; C71; C77; C78
C0402CAP_SM-0.1UF,10V,10,E020421,C0B0.1uFDISCRETE6C72; C73; C74; C75; C76; C80
C0603CAP_SM-16PF,100V,5,E021766,C06B16pFDISCRETE8C1; C2; C3; C4; C7; C8; C9; C10
C0603CAP_SM-82PF,50V,5,E000414,C060A82PFDISCRETE4C5; C6; C11; C12
C0603CAP_SM-0.1UF,25V,20,E011438,C0B0.1uFDISCRETE6C13; C14; C19; C20; C33; C34
C0603CAP_SM-820PF,50V,5,E000339,C06B820PFDISCRETE4C15; C16; C21; C22
C0603CAP_SM-0.047UF,50V,10,E012649,B0.047uFDISCRETE4C17; C18; C23; C24
C0603CAP_SM-10UF,16V,20,E020896,C06B10uFDISCRETE4C29; C37; C60; C67
C0603CAP_SM-270PF,50V,5,E012697,C06B270pFDISCRETE1C30
C0603CAP_SM-2.2PF,50V,5,E000393,C06B2.2PFDISCRETE1C31
C0603CAP_SM-0.01UF,50V,10,E000421,CB0.01UFDISCRETE2C32; C35
C0603CAP_SM-1UF,25V,10,E006992,C060A1UFDISCRETE5C36; C55; C57; C65; C69
C0603CAP_SM-0.1UF,50V,10,E014757,C0B0.1uFDISCRETE14C38; C42; C43; C45; C46; C48; C49; C56; C59; C61; C62; C63; C66; C68
C0603CAP_SM-0.1UF,25V,10,E007204,C0B0.1UFDISCRETE1C40
C0603CAP_SM-4.7UF,16V,10,E020112,C0B4.7uFDISCRETE2C41; C44
C0603CAP_SM-2.2UF,6.3V,10,E006877,CB2.2UFDISCRETE1C47
C0603CAP_SM-150PF,50V,5,E000416,C06B150PFDISCRETE3C50; C52; C53
C0603CAP_SM-22NF,16V,10,E000327,C06B22NFDISCRETE1C51
C0805CAP_SM-4700PF,50V,5,E012867,C0B4700pFDISCRETE4C79; C81; C82; C83
C1206CAP_SM-0.015UF,250V,10,E021250B0.015uFDISCRETE3C25; C26; C27
C1206CAP_SM-4.7UF,50V,20,E000200,C1B4.7UFDISCRETE1C28
C3216CAPP_SM-10UF,10V,10,E000690,C3B10UFDISCRETE4C39; C54; C58; C64
CNBERG1X3H205LD36CN3P_TH-SAMTECTSW10608GS3PIN,EBSAMTECTSW10608GS3PINIO2JP1; JP2
CNBERG1X6H205LD36CN6P_TH-SAMTECTSW10608GS6PIN,EBSAMTECTSW10608GS6PINIO2P10; P11
CNHDR1X3H335CN3P_TH-1727023,E015204,CNHDR1B1727023IO1P9
CNHRSFX8-120S-SV_ACN120P_V4_SM-FX8-120S-SV(21),EBFX8-120S-SV(21)IO1SDP
CNKEY5001TPCNTP1P_TH-5002,E006153,CNKEY50B5002IO75V_ISO; 5V_SW; AVDD; EXT_REF; HARTCLK; HARTREF; REFOUT
CNKEY5001TPCNTP1P_TH-5001,E005347,CNKEY50B5001IO4DGND; DGND_ISO; GND_ISO1; GND_ISO2
CNTH1X2H335_ACN2P_TH-1727010,E019958,CNTH1XB1727010IO8P1; P2; P3; P4; P5; P6; P7; P8
DO214AA3DIO_SM-S2A-TP,50V,N/A,E006293,BS2A-TPIC1D1
DSML169W103H91DIO_SM-SMAJ10A-13-F,10V,N/A,E0BSMAJ10A-13-FIC4D2; D3; D4; D5
F1812H79FSFUSE_SM-1.1A,33V,E019447,F18B1.1ADISCRETE1F1
L0805FERRITE_SM-1K OHM,N/A,E011583,B1K OHMDISCRETE1E1
LED0603-2DIOLED_SM-LG L29K-G2J1-24-Z,1.BLG L29K-G2J1-24-ZIC1POWER_LED
LSMSQ236H138IND_SM-12UH,20,E020136,LSMSQ23B12uHDISCRETE1L3
LSMSQ299H140IND_V4_SM-1000UH,20,E021773,LSB1000uHDISCRETE2L1; L2
QFN12_3X3_PAD1_6X1_6ADP2441_SM-ADP2441ACPZ,E017338BADP2441ACPZIC1U3
QFN24_4X4_PAD2_1X2_1AD5700_SM-AD5700-1ACPZ,E021240BAD5700-1ACPZIC1U9
QFN40_6X6_PAD3_9X3_9AD7173_8_SM-AD7173-8BCPZ,E0210BAD7173-8BCPZIC1U8
R0402RES_SM-10K,E003751,1/16W,1,R04B10KDISCRETE1R78
R0402RES_SM-30.9K,E008287,1/16W,1,RB30.9KDISCRETE1R80
R0603RES_SM-100K,E010279,1/10W,1,R0B100KDISCRETE3R1; R2; R3
R0603RES_SM-4.99K,E018831,1/10W,0.1B4.99KDISCRETE4R12; R14; R24; R26
R0603RES_SM-4.02K,E006545,1/10W,1,RB4.02KDISCRETE4R13; R15; R25; R27
R0603RES_SM-100,E003668,1/10W,1,R06B100DISCRETE4R28; R30; R40; R42
R0603RES_SM-50,E017801,1/10W,1,R060A50DISCRETE4R32; R33; R44; R45
R0603RES_SM-47K,E004240,1/16W,1,R06B47KDISCRETE4R34; R35; R46; R47
R0603RES_SM-7.15K,E019153,1/10W,1,RB7.15KDISCRETE4R36; R37; R48; R49
R0603RES_SM-100K,E017050,1/10W,1,R0B100KDISCRETE4R38; R39; R50; R51
R0603RES_SM-35.7K,E016592,1/10W,1,RB35.7KDISCRETE1R53
R0603RES_SM-33,E004232,1/16W,1,R060A33DISCRETE9R56; R57; R58; R59; R60; R61; R62; R63; R72
R0603RES_SM-0,E006826,1/10W,5,R0603A0DISCRETE4R64; R65; R75; R76
R0603RES_SM-11.3K,E016950,1/10W,0.1B11.3KDISCRETE1R66
R0603RES_SM-2K,E003711,1/10W,1,R060A2KDISCRETE1R67
R0603RES_SM-49.9K,E015342,1/10W,1,RB49.9KDISCRETE1R71
R0603RES_SM-10K,E003671,1/10W,1,R06B10KDISCRETE2R73; R74
R0603RES_SM-150K,E003672,1/10W,1,R0B150KDISCRETE1R77
R0805RES_SM-402K,E021767,1/8W,0.1,RB402KDISCRETE8R4; R5; R6; R7; R16; R17; R18; R19
R0805RES_SM-49.9K,E008152,1/8W,0.1,B49.9KDISCRETE8R8; R9; R10; R11; R20; R21; R22; R23
R0805RES_SM-100,E003807,1/10W,0.1,RB100DISCRETE4R29; R31; R41; R43
R0805RES_SM-88.7K,E015447,1/8W,1,R0B88.7KDISCRETE1R52
R0805RES_SM-11.8K,E005601,1/8W,1,R0B11.8KDISCRETE1R54
R0805RES_SM-86.6K,E014263,1/8W,1,R0B86.6KDISCRETE1R55
R0805RES_SM-1.2MEG,E003658,1/8W,1,RB1.2MEGDISCRETE2R68; R69
R0805RES_SM-0,E004449,1/8W,N/A,R080A0DISCRETE1R70
R0805RES_SM-3.01K,E003516,1/8W,1,R0B3.01KDISCRETE1R79
SO8ADR45XX_SM-ADR4540BRZ,E017544,BADR4540BRZIC1U5
SOT35374125_V5_SM-74HC1G125GW,E01924B74HC1G125GWIC1U4
SSOP20-4ADUM3151_SM-ADUM3151BRSZ,E0218BADUM3151BRSZIC1U2
SSOP20-4ADUM521X_SM-ADUM5211ARSZ,E0217BADUM5211ARSZIC1U10
TSSOP8IC24FC256_SM-24LC32A-I/ST,E014B24LC32A-I/STIC1U1
USO10ADG704_SM-ADG704BRMZ,E005075,UBADG704BRMZIC2U6; U7
VTH295L492W197H630LD32VAR_TH-56V,E021113,N/A,N/A,VTHB56VDISCRETE4V1; V2; V3; V4
附件:& z7 P" V3 ~7 g6 ~' n/ D' Z
PCB文件如下:$ {0 L6 j# n. K  l; P3 Z
游客,如果您要查看本帖隐藏内容请回复
# n7 w  J* j8 V( C0 h6 {* t) S4 _, {, j$ M2 s
GMT+8, 2025-7-21 04:53 , Processed in 0.140625 second(s), 28 queries , Gzip On.
