查看: 238|回复: 0
[allegro16.6][6层]160-MSPS Analog-to-Digital Converter Evaluation Module 评估...
发表于 2020-1-7 17:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 dokidoki 于 2020-1-7 17:18 编辑 3 |3 }' C4 S: y! B9 h
- Z4 m  l" y6 I* ~; I1 h[allegro16.6][6层]160-MSPS Analog-to-Digital Converter Evaluation Module 评估模块(ADC32XX+CON_SMVT+THS4541RGT)原理图和pcb文件
* l* J! e) U+ [: B4 L5 {5 ~: [
" J, U8 N' x4 F" M9 U1 G文件描述:
" @, }& o5 x. k; ?
( G4 g3 l, w2 U$ i' ]% [1. 作品用途: 160-MSPS Analog-to-Digital Converter Evaluation Module 评估模块
' X- [0 x5 t: ]2. 软件版本:allegro16.6: b  W+ t" o: q% A# N7 {) R4 l
3. 层数:6层
5 q0 ~8 Z# V% Q9 g' e  k+ O& O: c$ t4. 用到的主要芯片:ADC32XX+CON_SMVT+THS4541RGT
; u- A7 c, B; y8 I% n+ \1 n* ~5. pcb尺寸: 4800*3825 MIL) i3 @" }6 ]0 y# a5 T! n$ s  S! w
# F" [" F: |. O+ o8 O作品截图如下:% q& i5 o' C! u5 R: ~
6 I5 J9 y$ F3 F
顶层截图:
6 e8 l5 t% {1 F: t( I
4 T6 _6 c- z. [( C底层截图:
' I# C9 e( ]; s& J0 O4 i9 r' H
- f& L- @/ W1 l- a; y 1 t- _+ u- Q( ~- _% u% Z5 K) o
全层截图:
( R; \1 I+ ~% D; ?# w0 [/ J! @/ {6 ^% X
0 R: s6 u6 P6 e! `' kBOM:
: m4 I, X7 |  o; H/ \
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP_0402_0.1UF_0402_.1UF_10%.1uFIC4C1; C7; C8; C14
402CAP0603_0402_11PF_1%11pFIC2C2; C9
402CAP_0402_0.1UF_H_0402_.1UF_10%.1uFIC4C3; C4; C10; C11
402CAP0603_0402_.1UF_10%_.1uFIC10C5; C6; C12; C13; C45; C48; C69; C173; C174; C194
402CAP0402_0402_.1UF_10%_.1uFIC16C29; C30; C31; C32; C33; C34; C35; C36; C37; C42; C43; C44; C46; C47; C169; C170
402CAP0402_0402_.22UF_+/-10%_.22uFIC4C38; C39; C40; C41
402CAP NP_0_0402_.1UF_10%_.1uFIC2C50; C54
402CAPACITOR_NP_1_0402_.1UF_10%.1uFIC10C59; C60; C62; C65; C70; C72; C188; C190; C198; C200
402CAPACITOR_NP_1_0402_0.01UF_10%0.01uFIC4C66; C68; C191; C196
402CAP_0402_33PF_0402_33PF33pFIC2C180; C205
402CAP_0402_18PF_0402_180PF180pFIC2C181; C206
402IND_0402_0402_39NH39nHIC4L1; L4; L5; L8
402IND_0402_H_0402_00IC2L2; L6
402RES_0402_49.9_0402_49.9_1%49.9IC8R1; R6; R10; R12; R15; R19; R24; R26
402RES_0402_ZERO_0402_00IC12R2; R13; R16; R27; R120; R121; R135; R136; R137; R138; R141; R144
402RES_0402_4.99_0402_9.099.09IC4R3; R14; R139; R142
402R_0402_0_5%0IC19R4; R11; R18; R25; R62; R65; R67; R68; R69; R70; R84; R85; R86; R113; R114; R116; R117; R118; R119
402RES_0402_24.9_0402_24.924.9IC4R5; R9; R21; R22
402RES0603_0402_0_5%0IC4R7; R8; R20; R23
402RES0603_0402_1K_1%1KIC2R57; R87
402R_4_0402_10K_1%_10KIC1R58
402RES0603_0402_49.9_1%_ERJ-3EKF4949.9IC2R59; R63
402RES0603_0402_100_1%_100IC10R60; R61; R64; R66; R104; R149; R150; R151; R152; R153
402R_0402_22_1%22IC4R71; R72; R73; R74
402RES_0402_1K_0402_1K1KIC1R75
402RES_0402_1K_0402_00IC4R76; R77; R80; R81
402RES_0402_1K_0402_105K105KIC1R78
402RES_0402_1K_0402_143K143KIC1R79
402RES_0402_1K_0402_20K20KIC1R82
402R_1_0402_DISCRETE_25.5K_1%_25.5KDISCRETE2R83; R115
402RES_0402_249_0402_205205IC4R92; R93; R127; R128
402RES_0402_249_0402_499499IC4R94; R95; R129; R130
402RES0402_0402_5959IC4R96; R98; R131; R133
402RES0603_0402_49.9_1%_49.9IC4R97; R108; R124; R132
402RES_0402_249_0402_442442IC2R101; R134
402RES_0402_249_0402_35.735.7IC4R109; R110; R125; R126
402RES0402_0402_6.26.2IC4R145; R146; R147; R148
603CAP0603_0603_10NF10nFIC1C49
603CAP0603_0603_47PF47pFIC2C52; C53
603CAP NP_0_0603_1.0UF_10%_1.0uFIC8C58; C64; C74; C187; C195; C199; C207; C208
603CAP NP_1_0603_1.0UF_10%1.0uFIC2C71; C192
603CAP NP_0_0603_.01UF_5%_.01uFIC1C168
603CAP_0603_1000PF_0603_10NF10nFIC2C189; C209
603IND0603_0603_11PF_1%11pFIC2L3; L7
603IND0603_0603_250NH250nHIC4L23; L24; L26; L27
603RES0603_0603_22IC2R106; R122
603RES0603_0603_20K20KIC2R107; R123
805CAP NP_1_0805_10UF_10%10uFIC3C57; C67; C197
805CAP_1206_2.2UF_0805_10UF_10%10uFIC1C61
805CAP0201_0805_47UF_10%_47uFIC2C73; C193
805FERRITE_BEAD_0805_1K @ 100MHZ1K @ 100MHzIC2FB8; FB9
805R_0805_0.2_1%0.2IC2RS1; RS2
1206FUSE_0_1206_FUSE 2.0A 63V FASTFUSE 2.0A 63V FASTIC1F1
1206FERRITE_BEAD_1206_68 OHM @ 100M68 OHM @ 100MHzIC1FB1
1206FERRITE_BEAD_1206_68 OHM @ 10_168 OHM @ 100MHzIC1FB2
1206_BEAD_NFM31PBEAD_NFM31P_1206_BEAD_NFM31P_2727uFIC1FB3
1210CAP NP_0_1210_47UF_10%47uFIC1C55
1210CAP_1210_22UF_1210_22UF22uFIC2C56; C63
1806FERRITE_BEAD_1806_1K @ 100MHZ1K @ 100MHzIC3FB4; FB5; FB7
C-0603_X2YCAP_X2Y_C-0603_X2Y_0.22UF0.22uFIC2C160; C210
CON_RAPC722_JACK_THVT_3CONN JACK PWR_CON_RAPC722_JACK_CONN JACK PWRIC1J15
CON_SMRT_USBMNE20_FUSB_MINI_AB_MNE20-5G5P10_CON_SMUSB_MINI_ABIC1J14
CON_SMVT_120POS_QTH_SAMTEC_RT1CON_SMVT_120POS_QTH_SAMTEC_CON_QTH-060-01-F-D-A-RT1IC1J13
DBV5TPS2400_DBV5_TPS2400TPS2400IC1U3
DBV5INA138_DBV5_INA138INA138IC2U6; U9
DIODE_MBRB2515LMBRB2515L_5_DIODE_MBRB2515L_MBRMBRB2515LIC1D2
HDR_THVT_1X2_100_MJUMPER_1X2_100_HDR_THVT_1X2_100HEADER_1x2_100_430LIC4JP2; JP3; JP4; JP5
HDR_THVT_1X3_100_MJUMPER_1X3_SMT_HDR_THVT_1X3_100Jumper_1x3IC1JP1
HDR_THVT_1X3_100_MSMD_JUMPER_1X3_HDR_THVT_1X3_100HDR, THVT, 3POSIC2JP6; JP7
IND_SM_LQH44P_1515IND_POWER_1.5UH_IND_SM_LQH44P_11uHIC1L17
LED_1206LED_GREEN_1206_LED_1206_LED GRELED GREENIC1D1
QFN20_RGW_P65PITCHTPS7A4700_QFN20_RGW_P65PITCH_TPTPS7A4700IC2U5; U8
QFN48_RGZ_RTCADC32XX_QFN48_RGZ_RTC_ADC32XXADC32XXIC1U1
QFN_16_124X124_PWRPADTHS4541RGT_QFN_16_124X124_PWRPATHS4541RGTIC2U7; U10
SJP3_JUMPER_0603JUMPER_1X3_SMT_SJP3_JUMPER_0603Jumper_1x3_SMTIC2SJP1; SJP2
SMA_RECP_250X250SMA-END_PLUG_ROUND_SMA_RECP_250SMA_END_RNDIC4J1; J2; J3; J4
SMA_THVT_312X312SMA-THVT_142-0701-201_REC_SMA_TSMB_THVT_RECIC4J9; J10; J11; J12
SON_DSG_8TPS62080_SON8_SON_DSG_8_TPS6208TPS62080IC1U4
SON_Q5B_8CSD18532Q5B_SON_Q5B_8_CSD18532QCSD18532Q5IC1Q1
SOT_23_321DIODE_BAV99_SOT_23_321_BAV99BAV99IC2D3; D4
SSOP_28_413X221_26FT245RL_0_SSOP_28_413X221_26_FTFT245RLIC1U2
SW_RESET_PTS635SW PUSHBUTTON_1_SW_RESET_PTS635SW PUSHBUTTONDISCRETE1SW1
TANT_ACAP POL-B_10UF_10V_TANT_A_4.7UF4.7uFIC1C51
TESTPOINT_62DIATESTLOOP_BLACK_TESTPOINT_62DI_1Testloop_RedIC1TP4
TESTPOINT_62DIATESTLOOP_BLACK_TESTPOINT_62DIA_Testloop_BlackIC5TP5; TP9; TP10; TP11; TP12
TFMR_6_RF_DUAL_FOOTPRINTTFMR_6_WBC1-1TLB_TFMR_6_RF_DUALADT1-1WTIC4T1; T2; T3; T4
TFMR_6_RF_DUAL_FOOTPRINTXFMR_6_JTX-4-10T_TFMR_6_RF_DUALADT4-6WT+IC2T9; T10
TP_THVT_060_RNDTP_THVT_060_RND-RED_TP_THVT_060TP_THVT_060_RND-REDIC1TP1
TP_THVT_100_RNDTESTPOINT_BLUE_TP_THVT_100_RND_REDIC1TP8
附件:: G. I% y' {' b# S' ]
PCB文件如下:
1 _8 ]* `& j3 y& k0 T: i/ W
) s8 Q) s& Y( F/ ^  k1 O. A
游客,如果您要查看本帖隐藏内容请回复
GMT+8, 2025-7-21 04:58 , Processed in 0.125000 second(s), 28 queries , Gzip On.
