Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1N4148S | 1N4148S | bas32l_ll34 | DISCRETE | 2 | D2; D6 |
1N4148S | 1N4148S | x_bas32l_ll34 | DISCRETE | 2 | D56; D58 |
2USB_RJ45_2LED_2 | 2USB_RJ45_2LED_2 | rj45_usbx2_tx-rh-3 | IO | 1 | USB_LAN1 |
2X30_XDP_CONN_T | 2X30_XDP_CONN_T | x_btb60pf-rh | IO | 1 | JXDP1 |
BATHOLD_D2_2 | BATHOLD_D2_2 | bat2p_black-rh | DISCRETE | 1 | BAT1 |
BHEAD1X4_2_5MM_7 | BHEAD1X4_2_5MM_7 | bh1x4-2.5pitch_white-hf | IO | 1 | WIFI_BT_LED1 |
BHEAD2X10_NP20 | BHEAD2X10_NP20 | h2x10[20]m-2pitch_black-rh | IO | 1 | F_USB1 |
BZ256 | BZ256 | buzzer-lf | DISCRETE | 1 | BZ1 |
C0402 | C0402 | c0.022u16x0402-rh | DISCRETE | 2 | C1; C204 |
C0402 | C0402 | c1u16x50402-hf | DISCRETE | 8 | C2; C69; C70; C72; C75; C132; C133; C298 |
C0402 | C0402 | c0.22u16x0402-hf | DISCRETE | 3 | C4; C10; C18 |
C0402 | C0402 | c0.33u6.3x50402-rh | DISCRETE | 1 | C5 |
C0402 | C0402 | x_c0.022u25x0402 | DISCRETE | 1 | C6 |
C0402 | C0402 | c0.22u16x0402 | DISCRETE | 34 | C7; C14; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C345 |
C0402 | C0402 | c0.1u16x0402 | DISCRETE | 79 | C8; C15; C20; C21; C26; C28; C40; C41; C46; C47; C48; C49; C50; C88; C90; C92; C93; C96; C99; C100; C101; C169; C189; C191; C205; C215; C218; C238; C239; C243; C258; C268; C274; C297; C300; C304; C307; C347; C362; C366; C371; C372; C373; C374; C407; C409; C413; C414; C416; C417; C419; C422; C423; C424; C426; C427; C429; C438; C441; C451; C452; C457; C458; C467; C501; C503; C506; C513; C516; C517; C543; C555; C558; C559; C560; C564; C568; C609; C612 |
C0402 | C0402 | c6800p50x0402-hf-1 | DISCRETE | 1 | C9 |
C0402 | C0402 | c0.01u16x0402 | DISCRETE | 19 | C12; C140; C223; C348; C379; C492; C493; C494; C495; C496; C497; C498; C499; C532; C533; C534; C535; C551; C595 |
C0402 | C0402 | c68p50n0402-rh | DISCRETE | 1 | C17 |
C0402 | C0402 | c220p50n0402 | DISCRETE | 4 | C19; C27; C33; C36 |
C0402 | C0402 | c820pf50x0402 | DISCRETE | 1 | C22 |
C0402 | C0402 | x_c1800p50x0402-rh | DISCRETE | 1 | C23 |
C0402 | C0402 | x_c47p50n0402 | DISCRETE | 2 | C24; C37 |
C0402 | C0402 | c2200p50x0402 | DISCRETE | 4 | C31; C32; C113; C203 |
C0402 | C0402 | c1000p50x0402-rh | DISCRETE | 1 | C34 |
C0402 | C0402 | c330p25n0402 | DISCRETE | 1 | C35 |
C0402 | C0402 | c1500p50x0402 | DISCRETE | 1 | C39 |
C0402 | C0402 | c330p16n0402-rh | DISCRETE | 1 | C43 |
C0402 | C0402 | x_0.1u/16v/x/4 | DISCRETE | 6 | C44; C356; C382; C586; C614; C615 |
C0402 | C0402 | c1000p16x0402 | DISCRETE | 1 | C45 |
C0402 | C0402 | 15p50n0402 | DISCRETE | 3 | C51; C53; C64 |
C0402 | C0402 | c0.1u16y0402 | DISCRETE | 10 | C52; C59; C60; C61; C82; C89; C91; C97; C102; C388 |
C0402 | C0402 | c0.022u25x0402 | DISCRETE | 4 | C55; C57; C351; C439 |
C0402 | C0402 | x_c0.1u16x0402 | DISCRETE | 56 | C56; C159; C182; C196; C197; C201; C213; C219; C221; C246; C248; C251; C257; C263; C267; C269; C273; C275; C277; C278; C279; C281; C284; C285; C294; C299; C303; C305; C308; C346; C352; C357; C359; C363; C364; C369; C376; C378; C381; C384; C385; C400; C415; C425; C449; C456; C472; C479; C482; C483; C489; C539; C549; C561; C572; C623 |
C0402 | C0402 | c1000p50x0402 | DISCRETE | 5 | C58; C202; C387; C440; C473 |
C0402 | C0402 | x_c10p50n0402 | DISCRETE | 11 | C63; C71; C73; C77; C403; C444; C447; C455; C484; C502; C510 |
C0402 | C0402 | x_c0.01u16x0402 | DISCRETE | 9 | C66; C222; C234; C295; C310; C470; C556; C604; C613 |
C0402 | C0402 | c1u6.3x0402 | DISCRETE | 20 | C74; C119; C148; C227; C231; C249; C256; C282; C287; C290; C293; C296; C302; C383; C397; C488; C541; C563; C567; C594 |
C0402 | C0402 | x_3.3p/25n | DISCRETE | 3 | C78; C84; C86 |
C0402 | C0402 | c10p50n0402 | DISCRETE | 5 | C79; C83; C87; C395; C544 |
C0402 | C0402 | c0.1u10x0402 | DISCRETE | 6 | C111; C158; C365; C399; C450; C454 |
C0402 | C0402 | c1u6.3x50402-1 | DISCRETE | 3 | C117; C177; C462 |
C0402 | C0402 | x_c0.1u10x0402-hf-1 | DISCRETE | 1 | C129 |
C0402 | C0402 | x_1uf/6.3v/x/4 | DISCRETE | 5 | C173; C436; C512; C523; C616 |
C0402 | C0402 | c0.018u16x0402-rh | DISCRETE | 1 | C214 |
C0402 | C0402 | x_c1u6.3x50402-hf | DISCRETE | 2 | C216; C242 |
C0402 | C0402 | c33p50x/4 | DISCRETE | 1 | C224 |
C0402 | C0402 | x_c1u6.3x50402-1 | DISCRETE | 2 | C225; C247 |
C0402 | C0402 | c2.2u6.3x0402 | DISCRETE | 2 | C226; C228 |
C0402 | C0402 | c1u6.3y0402-rh | DISCRETE | 8 | C232; C254; C265; C292; C405; C569; C571; C611 |
C0402 | C0402 | c0.022u16x0402 | DISCRETE | 1 | C244 |
C0402 | C0402 | c680p16x0402-rh | DISCRETE | 1 | C280 |
C0402 | C0402 | 0.1u/10v/x/4 | DISCRETE | 1 | C283 |
C0402 | C0402 | 0.1u/10x4 | DISCRETE | 3 | C286; C391; C593 |
C0402 | C0402 | c100p50n0402 | DISCRETE | 1 | C349 |
C0402 | C0402 | x_c1u6.3x50402 | DISCRETE | 2 | C350; C485 |
C0402 | C0402 | c1u6.3x50402-hf | DISCRETE | 2 | C353; C463 |
C0402 | C0402 | 0.1u/16v/x/4 | DISCRETE | 4 | C354; C380; C481; C526 |
C0402 | C0402 | 1000p/50x4 | DISCRETE | 1 | C358 |
C0402 | C0402 | x_c100p50n0402 | DISCRETE | 11 | C360; C486; C487; C507; C508; C519; C520; C521; C522; C557; C565 |
C0402 | C0402 | c180p50n0402 | DISCRETE | 2 | C368; C370 |
C0402 | C0402 | c27p50n0402 | DISCRETE | 4 | C389; C390; C396; C411 |
C0402 | C0402 | 1uf/6.3v/x/4 | DISCRETE | 13 | C401; C442; C448; C468; C478; C480; C500; C509; C587; C588; C589; C590; C592 |
C0402 | C0402 | 1u/6.3x4 | DISCRETE | 3 | C418; C460; C591 |
C0402 | C0402 | c2200p50x0402-hf | DISCRETE | 2 | C428; C445 |
C0402 | C0402 | x_c180p50n0402 | DISCRETE | 9 | C430; C617; C618; C619; C620; C621; C622; C624; C625 |
C0402 | C0402 | c22p50n0402-hf | DISCRETE | 2 | C432; C550 |
C0402 | C0402 | x_c0.1u16y0402 | DISCRETE | 2 | C434; C435 |
C0402 | C0402 | x_0.1uf/16v/x/4 | DISCRETE | 1 | C453 |
C0402 | C0402 | c0.01u25x0402 | DISCRETE | 1 | C459 |
C0402 | C0402 | 0.1uf/16v/x/4 | DISCRETE | 2 | C464; C476 |
C0402 | C0402 | x_c1000p50x0402 | DISCRETE | 2 | C469; C528 |
C0402 | C0402 | x_c100p16x0402 | DISCRETE | 1 | C471 |
C0402 | C0402 | c12p50n | DISCRETE | 2 | C474; C475 |
C0402 | C0402 | 0.1u/16x4 | DISCRETE | 1 | C477 |
C0402 | C0402 | x_c1u6.3x0402 | DISCRETE | 3 | C490; C511; C597 |
C0402 | C0402 | x_c0.47u6.3x50402 | DISCRETE | 1 | C491 |
C0402 | C0402 | x_c1u6.3y0402-rh | DISCRETE | 1 | C504 |
C0402 | C0402 | c22p50n0402 | DISCRETE | 1 | C527 |
C0402 | C0402 | x_c22p50n0402 | DISCRETE | 1 | C538 |
C0402 | C0402 | x_15p50n0402 | DISCRETE | 2 | C542; C545 |
C0402 | C0402 | x_33p/50n4 | DISCRETE | 1 | C600 |
C0402 | C0402 | x_c1u16x50402-hf | DISCRETE | 1 | C603 |
C0402 | C0402 | x_0.1u25x | DISCRETE | 1 | C605 |
C0402 | C0402 | x_100p/16v/4 | DISCRETE | 1 | C606 |
C0402 | C0402 | ESD-mlvs0402m04-em | DISCRETE | 15 | D26; D27; D28; D29; D30; D31; D32; D33; D34; D43; D44; D46; D47; D48; D49 |
C0402 | C0402 | x_esd-mlvs0402m04-em | DISCRETE | 1 | D52 |
C0603 | C0603 | c0.22u25x5-hf | DISCRETE | 1 | C3 |
C0603 | C0603 | c1u16x5 | DISCRETE | 6 | C11; C236; C291; C313; C466; C562 |
C0603 | C0603 | c1u16y0805 | DISCRETE | 1 | C16 |
C0603 | C0603 | c1u25x-hf | DISCRETE | 3 | C68; C76; C144 |
C0603 | C0603 | c0.1u25x5-hf | DISCRETE | 1 | C235 |
C0603 | C0603 | x_10uf/6.3v/x5r/8 | DISCRETE | 2 | C361; C524 |
C0603 | C0603 | x_c10u6.3x50805-rh-3 | DISCRETE | 2 | C367; C461 |
C0603 | C0603 | c1u6.3x | DISCRETE | 2 | C386; C515 |
C0603 | C0603 | c10u6.3x50805 | DISCRETE | 1 | C398 |
C0603 | C0603 | x_c1u16x5 | DISCRETE | 3 | C431; C525; C529 |
C0603 | C0603 | 10uf/6.3v/x5r/8 | DISCRETE | 1 | C446 |
C0603 | C0603 | 1u/16v/6 | DISCRETE | 1 | C465 |
C0603 | C0603 | x_c1000p | DISCRETE | 1 | C607 |
C0603 | C0603 | x_c4.7u6.3x5-hf | DISCRETE | 1 | C626 |
C0603 | C0603 | x_esd-sfi0603ml080c-lf-rh | DISCRETE | 6 | D7; D11; D14; D18; D19; D24 |
C0603 | C0603 | esd-vport0603102mv05-rh | DISCRETE | 6 | D12; D13; D15; D16; D17; D20 |
C0805_67 | C0805_67 | x_c10u16x50805-hf | DISCRETE | 11 | C29; C65; C150; C166; C217; C220; C237; C266; C272; C288; C596 |
C0805_67 | C0805_67 | c10u16x50805-hf | DISCRETE | 20 | C30; C38; C54; C190; C230; C245; C252; C253; C276; C289; C406; C420; C437; C443; C540; C546; C552; C553; C566; C610 |
C0805_67 | C0805_67 | x_22uf/6.3v/x5r/0805 | DISCRETE | 9 | C80; C81; C152; C168; C184; C573; C577; C579; C581 |
C0805_67 | C0805_67 | 0.1uf/50v/x7r/0805 | DISCRETE | 7 | C112; C118; C123; C580; C583; C584; C585 |
C0805_67 | C0805_67 | 0.1uf/50v/x7r/8 | DISCRETE | 7 | C145; C154; C171; C195; C208; C574; C576 |
C0805_67 | C0805_67 | 22uf/6.3v/x5r/8 | DISCRETE | 15 | C151; C155; C162; C167; C174; C185; C187; C193; C198; C200; C207; C209; C212; C241; C582 |
C0805_67 | C0805_67 | x_22uf/6.3v/x5r/8 | DISCRETE | 11 | C156; C157; C163; C165; C175; C176; C186; C194; C199; C598; C599 |
C0805_67 | C0805_67 | 4.7uf/10v/x5r/0805 | DISCRETE | 1 | C170 |
C0805_67 | C0805_67 | c1u25x0805-rh | DISCRETE | 2 | C229; C355 |
C0805_67 | C0805_67 | 22uf/6.3v/x5r/0805 | DISCRETE | 1 | C233 |
C0805_67 | C0805_67 | c22u6.3x50805-hf | DISCRETE | 4 | C261; C547; C570; C608 |
C0805_67 | C0805_67 | x_c0.1u50x0805 | DISCRETE | 1 | C262 |
C0805_67 | C0805_67 | c4.7u6.3x50805-rh | DISCRETE | 2 | C392; C514 |
C0805_67 | C0805_67 | x_c4.7u10y0805 | DISCRETE | 1 | C421 |
C0805_67 | C0805_67 | c4.7u10x50805 | DISCRETE | 1 | C433 |
C0805_67 | C0805_67 | c4.7u6.3x50805 | DISCRETE | 2 | C505; C518 |
C0805_67 | C0805_67 | x_c4.7u6.3x50805-rh | DISCRETE | 2 | C530; C531 |
C0805_67 | C0805_67 | c22u6.3x50805 | DISCRETE | 1 | C536 |
C0805_67 | C0805_67 | c0.1u50x50805-hf | DISCRETE | 2 | C537; C548 |
C0805_67 | C0805_67 | c4.7u10y0805 | DISCRETE | 1 | C554 |
C0805_67 | C0805_67 | x_0.1uf/50v/x7r/0805 | DISCRETE | 1 | C575 |
C0805_67 | C0805_67 | 4.7uf/10v/x5r/8 | DISCRETE | 1 | C578 |
C0805_67 | C0805_67 | x_22u6.3x8 | DISCRETE | 2 | C601; C602 |
CHK_D2_10_3X6_3 | CHK_D2_10_3X6_3 | ch-0.47u48a0.86m-rh | DISCRETE | 2 | CHOKE2; CHOKE3 |
CHK_D2_10_3X6_3 | CHK_D2_10_3X6_3 | ch-0.47u45a0.86m-rh | DISCRETE | 1 | CHOKE8 |
CHK_D2_P3_5_2 | CHK_D2_P3_5_2 | ch-1.2u15a1.7m-rh-2 | DISCRETE | 1 | CHOKE10 |
CHK_D2_P3_5 | CHK_D2_P3_5 | x_ch-1.2u15a1.7m-rh-2 | DISCRETE | 1 | CHOKE12 |
CHK_D2_P8_5X3_5_1 | CHK_D2_P8_5X3_5_1 | ch-1.1u35a1.7m-rh-1 | DISCRETE | 1 | CHOKE1 |
CHK_DIP2_4_5 | CHK_DIP2_4_5 | ch-0.5u40a1.4m-rh-1 | DISCRETE | 1 | CHOKE9 |
CHK_S2_P2_2 | CHK_S2_P2_2 | ch-4.7u0.75a190ms-rh | DISCRETE | 1 | CHOKE11 |
CONN_E21211_2X12P | CONN_E21211_2X12P | pwrconn24p_black-rh-2 | DISCRETE | 1 | ATX_POWER1 |
C_D_7343 | C_D_7343 | x_c100u6.3so-rh | DISCRETE | 1 | EC57 |
C_P2_5_D6_3_H5 | C_P2_5_D6_3_H5 | cd100u16el5-rh-1 | DISCRETE | 8 | EC1; EC5; EC38; EC44; EC45; EC50; EC53; EC54 |
C_P2_5_D6_3_H5 | C_P2_5_D6_3_H5 | cd100u16el5-rh | DISCRETE | 1 | EC43 |
C_P2_5_D6_3_H9_5 | C_P2_5_D6_3_H9_5 | c560u6.3so-rh | DISCRETE | 8 | EC9; EC11; EC14; EC15; EC17; EC19; EC21; EC24 |
C_P2_5_D6_3_H9_5 | C_P2_5_D6_3_H9_5 | x_c560u6.3so-rh | DISCRETE | 2 | EC10; EC59 |
C_P2_5_D6_3_H9_5 | C_P2_5_D6_3_H9_5 | cd560u6.3so-rh | DISCRETE | 2 | EC26; EC27 |
C_P2_5_D6_3_H9_5 | C_P2_5_D6_3_H9_5 | c470u6.3so-rh-3 | DISCRETE | 2 | EC35; EC36 |
C_P2_5_D6_3_H11 | C_P2_5_D6_3_H11 | x_cd470u6.3el11-rh | DISCRETE | 3 | EC34; EC40; EC56 |
C_P2_21_D4_H5 | C_P2_21_D4_H5 | cd10u16el5 | DISCRETE | 5 | EC2; EC46; EC47; EC48; EC49 |
C_P2_21_D5_H11 | C_P2_21_D5_H11 | x_cd22u16el11-hf | DISCRETE | 1 | EC51 |
C_P3_5_D8_H8 | C_P3_5_D8_H8 | cd1000u63el11.5-rh | DISCRETE | 9 | EC23; EC25; EC30; EC33; EC37; EC39; EC52; EC55; EC58 |
C_P3_5_D8_H11_5 | C_P3_5_D8_H11_5 | cd270u16so-rh-2 | DISCRETE | 4 | EC3; EC4; EC6; EC42 |
C_P3_5_D8_H11_5 | C_P3_5_D8_H11_5 | cd470u16el11.5-rh | DISCRETE | 1 | EC41 |
DDRIII240_1 | DDRIII240_1 | ddriii-240p_blue-rh-6 | DISCRETE | 1 | DIMM1 |
DDRIII240_1 | DDRIII240_1 | ddriii-240p_green-rh-7 | DISCRETE | 1 | DIMM2 |
DIODE_SOD123 | DIODE_SOD123 | 1n4148w | DISCRETE | 1 | D1 |
DIODE_SOD123 | DIODE_SOD123 | x_1n4148w-f_sod123-rh | DISCRETE | 2 | D3; D5 |
DIODE_SOD123 | DIODE_SOD123 | mmsz5235bt1g-rh | DISCRETE | 1 | D38 |
DIODE_SOD123 | DIODE_SOD123 | bas32l_ll34 | DISCRETE | 1 | D45 |
DPAKSGD | DPAKSGD | n-apm3023nuc-trg_to252-rh | IC | 1 | Q49 |
DPAKSGD | DPAKSGD | n-p0903bd_to252-3-hf | IC | 1 | Q72 |
ESD_2_5X1 | ESD_2_5X1 | x_esd-pdy050003-2510-rh | IO | 3 | U4; U8; U10 |
ESD_2_5X1 | ESD_2_5X1 | x_esd-ip4284cz10-tb-rh | IO | 2 | U24; U28 |
ESD_2_5X1 | ESD_2_5X1 | esd-esd3v3u4ulc-rh | IO | 2 | U31; U33 |
ESD_2_5X1 | ESD_2_5X1 | x_esd-esd3v3u4ulc-rh | IO | 1 | U39 |
FCBGA708_TEST | FCBGA708_TEST | lynx_23 | IC | 1 | U42 |
FILTER_S4_RN4P2R_COLAY | FILTER_S4_RN4P2R_COLAY | res array,0ohm,5% | IC | 8 | L1; L2; L3; L4; L18; L20; L22; L26 |
FILTER_S4_RN4P2R_COLAY | FILTER_S4_RN4P2R_COLAY | cmc-l12-9008104-rh | IC | 9 | L16; L17; L24; L25; L28; L29; L43; L44; L46 |
FILTER_S4_RN4P2R_COLAY | FILTER_S4_RN4P2R_COLAY | x_cmc-l12-9008104-rh | IC | 1 | L38 |
F_PAD_X | F_PAD_X | x_fm | IO | 8 | FM1; FM2; FM3; FM4; FM5; FM6; FM7; FM8 |
HC_49_US | HC_49_US | 25mhz18p_d-1 | DISCRETE | 2 | Y1; Y2 |
HDMI_D19_1 | HDMI_D19_1 | hdmi19pm_black-hf | DISCRETE | 1 | HDMI1 |
HDMI_D19_4 | HDMI_D19_4 | x_hdmi19p_black-hf | IO | 1 | HDMI3 |
HEAD2X6_2MM_NP10 | HEAD2X6_2MM_NP10 | h2x6[10]m-2pitch_black-rh-1 | DISCRETE | 1 | SPI_DEBUG |
HEAD2X6_NP11 | HEAD2X6_NP11 | x_h2x6[11]m_green-rh | IO | 1 | COM2 |
HEAD2X7_NP10 | HEAD2X7_NP10 | h2x7[10]m_colors-rh | IO | 1 | F_PANEL1 |
HOLES_4S_1 | HOLES_4S_1 | x_mh001 | DISCRETE | 6 | MH1; MH2; MH3; MH6; MH7; MH8 |
HOLES_R177D91 | HOLES_R177D91 | e2b-1024030-rh | DISCRETE | 2 | SP1; SP2 |
HS_ICH6 | HS_ICH6 | hs-0401634-rh | IO | 1 | U3_X1 |
JA333L_G01 | JA333L_G01 | jack-audiox3f_pk/lime/bu-rh | IC | 1 | AUDIO1 |
JAUD1 | JAUD1 | h2x5[8]m_black-rh | DISCRETE | 1 | F_AUDIO1 |
JLPC1_TPM | JLPC1_TPM | h2x7[10]m-2pitch_black-rh | DISCRETE | 1 | LPC_DEBUG |
JUSB1 | JUSB1 | h2x5[9]m_color-rh | DISCRETE | 2 | F_USB2; F_USB3 |
L0603 | L0603 | esd-sfi0603ml080c-lf-rh | DISCRETE | 1 | D53 |
L0603 | L0603 | 68n300ma | DISCRETE | 3 | FB5; FB6; FB7 |
L0603 | L0603 | 120l600ma-250 | DISCRETE | 6 | L32; L33; L34; L35; L36; L37 |
L0603 | L0603 | x_120l600ma-250 | DISCRETE | 1 | L39 |
L0603 | L0603 | 100l3a-30-rh | DISCRETE | 1 | L40 |
L0603 | L0603 | 60l3a-40 | DISCRETE | 1 | L42 |
L0805_67 | L0805_67 | 10u100ma_0805-rh-2 | DISCRETE | 1 | L41 |
L0805_67 | L0805_67 | x_30l3a-15_0805-rh | DISCRETE | 1 | L74 |
L1087A_GDS | L1087A_GDS | p-p06p03lcg_sot89-3-rh | DISCRETE | 2 | Q1; Q47 |
L1087A_GDS | L1087A_GDS | p06p03lcg_sot89 | DISCRETE | 2 | Q67; Q106 |
LQFP48 | LQFP48 | alc662-vd-rh | IC | 1 | U45 |
LQFP64 | LQFP64 | nct5537d-rh | IC | 1 | U37 |
NC_0402_6 | NC_0402_6 | x_r/0402 | DISCRETE | 17 | R29; R39; R93; R95; R115; R149; R213; R292; R294; R403; R416; R449; R665; R669; R672; R757; R758 |
NC_93519 | NC_93519 | x_cp | IO | 5 | CP1; CP3; CP4; CP23; CP24 |
NC_93519 | NC_93519 | x_copper | IO | 11 | CP2; CP5; CP6; CP7; CP8; CP9; CP10; CP19; CP20; CP21; CP22 |
OSCC_MS | OSCC_MS | 32.768khz12.5p_d-rh-2 | IO | 1 | Y3 |
PCI164_EXPRESS_X16_1 | PCI164_EXPRESS_X16_1 | slot-pci164p_blue-2pitch-rh-9 | IO | 1 | PCIE16X1 |
PCI_SLOT_36 | PCI_SLOT_36 | slot-pci36p_black-2pitch-rh-10 | DISCRETE | 1 | PCIE1X1 |
PC_HM25_NPEG | PC_HM25_NPEG | pwrconn4p_natural | DISCRETE | 1 | ATX_12V1 |
PS2_12P_1 | PS2_12P_1 | minidin12p-rh | DISCRETE | 1 | KB/MS1 |
PSOP8_TSMD130X94 | PSOP8_TSMD130X94 | gs7133so-r_psop8-hf | IC | 3 | U30; U40; U46 |
PSOP8_TSMDQ77 | PSOP8_TSMDQ77 | up1543ssu8 | IC | 1 | U21 |
PSOP8_TSMDQ77 | PSOP8_TSMDQ77 | up0109psw8_psop8-hf | IC | 1 | U27 |
QFN16_TSMDQ71 | QFN16_TSMDQ71 | x_up1714q | IC | 1 | U44 |
QFN32_TSMDQ110 | QFN32_TSMDQ110 | isl95816hrz_qfn32-hf | IC | 1 | U1 |
QFN32_TSMDQ110 | QFN32_TSMDQ110 | rtl8111ga-cg | IC | 1 | U48 |
R0402 | R0402 | 0r0402 | DISCRETE | 32 | R1; R5; R32; R47; R53; R55; R75; R81; R85; R309; R357; R384; R427; R452; R455; R456; R466; R471; R495; R504; R505; R533; R547; R581; R605; R613; R658; R699; R705; R768; R769; R771 |
R0402 | R0402 | x_0r0402 | DISCRETE | 42 | R3; R54; R63; R130; R165; R275; R281; R283; R288; R289; R351; R352; R353; R354; R355; R356; R358; R363; R364; R392; R398; R406; R441; R446; R468; R480; R590; R592; R593; R607; R668; R703; R711; R717; R722; R728; R736; R770; R774; R775; R783; R784 |
R0402 | R0402 | 4.02kr1%0402 | DISCRETE | 1 | R4 |
R0402 | R0402 | x_20kr1%0402 | DISCRETE | 3 | R7; R26; R62 |
R0402 | R0402 | 10r1%0402 | DISCRETE | 4 | R8; R25; R68; R90 |
R0402 | R0402 | 34kr1%0402 | DISCRETE | 1 | R9 |
R0402 | R0402 | 11kr1%0402 | DISCRETE | 1 | R12 |
R0402 | R0402 | 2kr1%0402 | DISCRETE | 1 | R13 |
R0402 | R0402 | 21kr1%0402-he | DISCRETE | 1 | R14 |
R0402 | R0402 | 1.54kr1%0402-he | DISCRETE | 3 | R15; R44; R82 |
R0402 | R0402 | 10kr1%0402 | DISCRETE | 27 | R16; R17; R22; R28; R37; R38; R42; R43; R51; R61; R67; R274; R299; R365; R368; R378; R460; R487; R515; R540; R553; R557; R568; R591; R679; R716; R749 |
R0402 | R0402 | 169kr1%0402 | DISCRETE | 1 | R20 |
R0402 | R0402 | 442r1%0402 | DISCRETE | 1 | R21 |
R0402 | R0402 | 1.5kr1%0402 | DISCRETE | 1 | R23 |
R0402 | R0402 | 8.2kr1%0402 | DISCRETE | 1 | R24 |
R0402 | R0402 | 130r1%0402 | DISCRETE | 1 | R27 |
R0402 | R0402 | 100r1%0402 | DISCRETE | 5 | R30; R104; R170; R172; R381 |
R0402 | R0402 | 10kr0402 | DISCRETE | 41 | R31; R33; R34; R64; R97; R98; R116; R117; R293; R334; R335; R336; R341; R373; R382; R383; R411; R413; R426; R433; R447; R567; R571; R577; R584; R599; R600; R601; R608; R626; R633; R636; R638; R640; R646; R661; R702; R712; R737; R738; R761 |
R0402 | R0402 | 4.7kr0402 | DISCRETE | 35 | R35; R40; R41; R50; R60; R76; R77; R80; R94; R99; R214; R215; R216; R220; R254; R362; R389; R390; R399; R428; R429; R431; R432; R435; R440; R448; R459; R467; R507; R511; R710; R729; R732; R739; R777 |
R0402 | R0402 | 75r1%0402 | DISCRETE | 1 | R36 |
R0402 | R0402 | 54.9r1%0402 | DISCRETE | 1 | R45 |
R0402 | R0402 | 27kr0402 | DISCRETE | 3 | R46; R52; R328 |
R0402 | R0402 | x_1k/1%/4 | DISCRETE | 2 | R48; R133 |
R0402 | R0402 | x_10kr0402 | DISCRETE | 18 | R49; R78; R91; R118; R250; R258; R260; R297; R310; R361; R374; R543; R544; R612; R615; R618; R632; R760 |
R0402 | R0402 | x_499r1%0402 | DISCRETE | 1 | R56 |
R0402 | R0402 | 11.3kr1%0402 | DISCRETE | 1 | R57 |
R0402 | R0402 | 82kr5%0402-rh | DISCRETE | 1 | R58 |
R0402 | R0402 | 2k/1%/0402 | DISCRETE | 1 | R59 |
R0402 | R0402 | 2.1kr1%0402-rh | DISCRETE | 3 | R65; R66; R158 |
R0402 | R0402 | 1kr0402 | DISCRETE | 26 | R79; R252; R255; R343; R350; R367; R410; R417; R438; R558; R562; R566; R570; R597; R598; R639; R643; R659; R700; R727; R733; R734; R740; R745; R746; R747 |
R0402 | R0402 | x_1kr0402 | DISCRETE | 9 | R83; R256; R474; R536; R641; R647; R681; R686; R694 |
R0402 | R0402 | 88.7kr1%0402-rh | DISCRETE | 1 | R84 |
R0402 | R0402 | 27.4kr1%0402-rh | DISCRETE | 1 | R86 |
R0402 | R0402 | x_110kr1%0402-rh | DISCRETE | 1 | R87 |
R0402 | R0402 | 2.74kr1%0402 | DISCRETE | 2 | R88; R89 |
R0402 | R0402 | Apr-51 | DISCRETE | 3 | R92; R134; R142 |
R0402 | R0402 | x_100r0402 | DISCRETE | 1 | R96 |
R0402 | R0402 | x_825/4 | DISCRETE | 1 | R100 |
R0402 | R0402 | x_0/4 | DISCRETE | 12 | R101; R321; R322; R323; R763; R794; R795; R796; R797; R798; R799; R800 |
R0402 | R0402 | 10k/4 | DISCRETE | 21 | R102; R106; R128; R393; R465; R538; R550; R576; R602; R650; R667; R673; R677; R682; R684; R689; R693; R695; R764; R773; R776 |
R0402 | R0402 | 1k/4 | DISCRETE | 5 | R103; R122; R376; R476; R500 |
R0402 | R0402 | 1kr1%0402 | DISCRETE | 12 | R105; R107; R129; R132; R267; R268; R282; R291; R302; R306; R493; R494 |
R0402 | R0402 | 2r1%0402 | DISCRETE | 2 | R108; R109 |
R0402 | R0402 | x_178r/1% | DISCRETE | 1 | R110 |
R0402 | R0402 | 2.2kr0402 | DISCRETE | 13 | R111; R121; R126; R127; R147; R160; R345; R348; R497; R604; R627; R696; R701 |
R0402 | R0402 | x_84.5r/1%/4 | DISCRETE | 1 | R112 |
R0402 | R0402 | 100r0402 | DISCRETE | 2 | R113; R725 |
R0402 | R0402 | x_1k/4 | DISCRETE | 7 | R114; R124; R140; R156; R181; R451; R560 |
R0402 | R0402 | 24.9/1%/4 | DISCRETE | 5 | R119; R120; R286; R300; R316 |
R0402 | R0402 | 604/1%/4 | DISCRETE | 1 | R123 |
R0402 | R0402 | 150/1%/4 | DISCRETE | 7 | R125; R163; R164; R166; R548; R556; R563 |
R0402 | R0402 | x_10k/4 | DISCRETE | 23 | R131; R445; R464; R469; R499; R502; R506; R559; R573; R589; R595; R622; R637; R648; R651; R657; R662; R683; R690; R691; R765; R766; R767 |
R0402 | R0402 | 100/1%/4 | DISCRETE | 2 | R135; R159 |
R0402 | R0402 | 20kr0402-2 | DISCRETE | 4 | R136; R248; R730; R755 |
R0402 | R0402 | 1mr0402 | DISCRETE | 3 | R137; R450; R588 |
R0402 | R0402 | 49.9r/1%/4 | DISCRETE | 3 | R138; R317; R318 |
R0402 | R0402 | 44.2r1%0402-rh-1 | DISCRETE | 1 | R143 |
R0402 | R0402 | x_100r/1%/4 | DISCRETE | 1 | R144 |
R0402 | R0402 | 75/1%/4 | DISCRETE | 2 | R145; R312 |
R0402 | R0402 | x_51/4 | DISCRETE | 4 | R146; R154; R155; R759 |
R0402 | R0402 | 110/1%/4 | DISCRETE | 1 | R152 |
R0402 | R0402 | x_90.9/1%/4 | DISCRETE | 1 | R153 |
R0402 | R0402 | 470r1%0402 | DISCRETE | 8 | R167; R169; R171; R174; R175; R178; R180; R183 |
R0402 | R0402 | x_180r0402-rh | DISCRETE | 4 | R168; R173; R177; R182 |
R0402 | R0402 | 11.8kr1%0402 | DISCRETE | 1 | R218 |
R0402 | R0402 | x_4.7kr0402 | DISCRETE | 14 | R221; R253; R385; R401; R405; R415; R496; R512; R524; R549; R709; R743; R750; R762 |
R0402 | R0402 | 10r0402 | DISCRETE | 4 | R249; R457; R697; R751 |
R0402 | R0402 | 510r0402 | DISCRETE | 2 | R251; R525 |
R0402 | R0402 | x_47kr0402 | DISCRETE | 1 | R257 |
R0402 | R0402 | 49.9r1%0402 | DISCRETE | 1 | R259 |
R0402 | R0402 | 200kr0402 | DISCRETE | 1 | R264 |
R0402 | R0402 | 56kr1%0402 | DISCRETE | 1 | R266 |
R0402 | R0402 | x_1k/4/1% | DISCRETE | 1 | R269 |
R0402 | R0402 | 3kr/4/1% | DISCRETE | 1 | R270 |
R0402 | R0402 | 24.9k/4/1% | DISCRETE | 1 | R271 |
R0402 | R0402 | 2.4kr1%0402-1 | DISCRETE | 1 | R272 |
R0402 | R0402 | 15kr1%0402 | DISCRETE | 5 | R273; R301; R333; R369; R756 |
R0402 | R0402 | 47kr0402 | DISCRETE | 3 | R279; R484; R579 |
R0402 | R0402 | 18kr1%0402 | DISCRETE | 1 | R280 |
R0402 | R0402 | 30kr1%0402 | DISCRETE | 3 | R285; R453; R486 |
R0402 | R0402 | x_15kr1%0402 | DISCRETE | 1 | R303 |
R0402 | R0402 | x_8.2kr0402 | DISCRETE | 1 | R304 |
R0402 | R0402 | 75r0402 | DISCRETE | 7 | R305; R610; R617; R652; R656; R715; R731 |
R0402 | R0402 | 33kr0402 | DISCRETE | 1 | R307 |
R0402 | R0402 | x_10kr1%0402 | DISCRETE | 1 | R308 |
R0402 | R0402 | x_47k/4 | DISCRETE | 1 | R311 |
R0402 | R0402 | 100r/1%/4 | DISCRETE | 2 | R313; R315 |
R0402 | R0402 | 2.8k/4 | DISCRETE | 1 | R319 |
R0402 | R0402 | 6.04k/4 | DISCRETE | 1 | R320 |
R0402 | R0402 | 43r0402 | DISCRETE | 4 | R324; R327; R473; R475 |
R0402 | R0402 | 120kr1%0402 | DISCRETE | 1 | R325 |
R0402 | R0402 | 137kr1%0402 | DISCRETE | 1 | R329 |
R0402 | R0402 | 47.5kr1%0402 | DISCRETE | 1 | R331 |
R0402 | R0402 | 20kr0402 | DISCRETE | 1 | R337 |
R0402 | R0402 | 0ohm0402 | DISCRETE | 2 | R339; R412 |
R0402 | R0402 | 1.1kr1%0402 | DISCRETE | 1 | R340 |
R0402 | R0402 | 976r1%0402 | DISCRETE | 1 | R342 |
R0402 | R0402 | 33r0402 | DISCRETE | 4 | R346; R349; R439; R634 |
R0402 | R0402 | 0/4 | DISCRETE | 2 | R347; R508 |
R0402 | R0402 | x_100kr0402 | DISCRETE | 3 | R366; R485; R585 |
R0402 | R0402 | 100kr1%0402-1 | DISCRETE | 1 | R370 |
R0402 | R0402 | 32.4kr1%0402-1 | DISCRETE | 1 | R372 |
R0402 | R0402 | 4.7k/4 | DISCRETE | 2 | R375; R503 |
R0402 | R0402 | 16kr1%0402-he | DISCRETE | 1 | R377 |
R0402 | R0402 | x_56kr1%0402 | DISCRETE | 1 | R379 |
R0402 | R0402 | 4.99kr1%0402 | DISCRETE | 1 | R380 |
R0402 | R0402 | 1k/1% | DISCRETE | 2 | R386; R629 |
R0402 | R0402 | 22r0402 | DISCRETE | 5 | R388; R391; R611; R645; R676 |
R0402 | R0402 | 10k/1%/4 | DISCRETE | 7 | R394; R400; R402; R422; R423; R470; R479 |
R0402 | R0402 | 249r1%0402 | DISCRETE | 3 | R404; R526; R527 |
R0402 | R0402 | 680r0402-rh | DISCRETE | 1 | R407 |
R0402 | R0402 | 7.5k/1%/4 | DISCRETE | 5 | R408; R424; R430; R458; R478 |
R0402 | R0402 | x_680r0402-rh | DISCRETE | 2 | R409; R414 |
R0402 | R0402 | 22kr0402 | DISCRETE | 10 | R418; R419; R420; R421; R462; R463; R698; R721; R744; R754 |
R0402 | R0402 | 8.2k/1%/4 | DISCRETE | 1 | R425 |
R0402 | R0402 | 8.2kr0402 | DISCRETE | 3 | R444; R501; R692 |
R0402 | R0402 | 100kr0402 | DISCRETE | 1 | R454 |
R0402 | R0402 | 150kr1%0402 | DISCRETE | 1 | R514 |
R0402 | R0402 | 2.49k/1% | DISCRETE | 1 | R523 |
R0402 | R0402 | 15r0402 | DISCRETE | 10 | R537; R546; R551; R555; R569; R620; R621; R644; R687; R688 |
R0402 | R0402 | x_510r0402 | DISCRETE | 1 | R539 |
R0402 | R0402 | 32.4kr1%0402 | DISCRETE | 2 | R541; R706 |
R0402 | R0402 | x_2.7kr0402 | DISCRETE | 2 | R542; R552 |
R0402 | R0402 | x_182kr1%0402-rh | DISCRETE | 1 | R554 |
R0402 | R0402 | 3.3kr0402 | DISCRETE | 1 | R564 |
R0402 | R0402 | 1.8kr0402 | DISCRETE | 1 | R565 |
R0402 | R0402 | 39r0402 | DISCRETE | 3 | R572; R580; R685 |
R0402 | R0402 | 649/1%/4 | DISCRETE | 1 | R575 |
R0402 | R0402 | 51r0402 | DISCRETE | 2 | R578; R582 |
R0402 | R0402 | 20k/1%/4 | DISCRETE | 1 | R583 |
R0402 | R0402 | 499r1%0402 | DISCRETE | 1 | R587 |
R0402 | R0402 | 390kr0402 | DISCRETE | 2 | R594; R625 |
R0402 | R0402 | x_5.6kr1%0402 | DISCRETE | 1 | R596 |
R0402 | R0402 | 1k/1%/4 | DISCRETE | 1 | R603 |
R0402 | R0402 | 4月22日 | DISCRETE | 2 | R606; R614 |
R0402 | R0402 | 22.6/1%/4 | DISCRETE | 1 | R609 |
R0402 | R0402 | x_20kr0402-2 | DISCRETE | 1 | R616 |
R0402 | R0402 | 2.2k/4 | DISCRETE | 2 | R619; R635 |
R0402 | R0402 | x_47.5kr1%0402-rh-1 | DISCRETE | 1 | R623 |
R0402 | R0402 | x_1kr1%0402 | DISCRETE | 1 | R624 |
R0402 | R0402 | x_750r1%0402 | DISCRETE | 1 | R628 |
R0402 | R0402 | 15k/1% | DISCRETE | 1 | R630 |
R0402 | R0402 | x_33kr0402 | DISCRETE | 1 | R631 |
R0402 | R0402 | x_301kr1%0402 | DISCRETE | 1 | R654 |
R0402 | R0402 | x_30.1kr1%0402 | DISCRETE | 1 | R655 |
R0402 | R0402 | 220kr0402-1 | DISCRETE | 1 | R670 |
R0402 | R0402 | 5.1kr1%0402 | DISCRETE | 1 | R678 |
R0402 | R0402 | 20kr1%0402 | DISCRETE | 3 | R680; R704; R713 |
R0402 | R0402 | 39.2kr1%0402 | DISCRETE | 1 | R707 |
R0402 | R0402 | 6.8kr0402 | DISCRETE | 1 | R778 |
R0402 | R0402 | 10krt1%0402-rh | DISCRETE | 1 | RT3 |
R0603 | R0603 | 33r | IO | 4 | FB1; FB2; FB3; FB4 |
R0603 | R0603 | 1r-lf | IO | 1 | R2 |
R0603 | R0603 | 10kr0603 | IO | 3 | R72; R74; R234 |
R0603 | R0603 | 0r | IO | 7 | R139; R141; R157; R162; R217; R231; R718 |
R0603 | R0603 | 1.5kr-rh | IO | 1 | R261 |
R0603 | R0603 | 10r | IO | 1 | R344 |
R0603 | R0603 | 330r | IO | 6 | R481; R482; R534; R545; R735; R742 |
R0603 | R0603 | x_0r/6 | IO | 1 | R561 |
R0603 | R0603 | 1月6日 | IO | 1 | R574 |
R0603 | R0603 | 10mr | IO | 1 | R586 |
R0603 | R0603 | 300r | IO | 2 | R708; R724 |
R0603 | R0603 | x_0r | IO | 1 | R726 |
R0603 | R0603 | 270r | IO | 2 | R741; R748 |
R0603 | R0603 | 180r | IO | 2 | R752; R753 |
R0603 | R0603 | x_6.2mr0603 | IO | 1 | R779 |
R0603_NTC | R0603_NTC | 100krt1% | DISCRETE | 1 | RT1 |
R0603_NTC | R0603_NTC | 10krt1% | DISCRETE | 2 | RT2; RT4 |
R0805_67 | R0805_67 | 0r0805 | DISCRETE | 11 | R6; R69; R70; R150; R161; R227; R233; R276; R461; R472; R509 |
R0805_67 | R0805_67 | 2.2r0805 | DISCRETE | 8 | R71; R73; R148; R151; R211; R219; R284; R298 |
R0805_67 | R0805_67 | 2.2r/8 | DISCRETE | 1 | R265 |
R0805_67 | R0805_67 | 2.2r20805 | DISCRETE | 1 | R290 |
R0805_67 | R0805_67 | x_0r0805 | DISCRETE | 2 | R488; R510 |
R0805_67 | R0805_67 | 0r/8 | DISCRETE | 3 | R664; R674; R675 |
R0805_67 | R0805_67 | x_0r/8 | DISCRETE | 1 | R666 |
R0805_67 | R0805_67 | 5.11/1%/8 | DISCRETE | 1 | R671 |
R0805_67 | R0805_67 | x_330r0805 | DISCRETE | 4 | R714; R719; R720; R723 |
R1206_113 | R1206_113 | x_0r/1206 | DISCRETE | 2 | R10; R11 |
RN0402_MSI | RN0402_MSI | 8p4r-2.7kr0402 | DISCRETE | 1 | RN1 |
RN0402_MSI | RN0402_MSI | 8p4r-0r0402 | DISCRETE | 2 | RN5; RN7 |
RN0402_MSI | RN0402_MSI | 8.2k/4/8p4r | DISCRETE | 2 | RN9; RN10 |
RN0402_MSI | RN0402_MSI | 8p4r-150r0402 | DISCRETE | 1 | RN11 |
RN0402_MSI | RN0402_MSI | 2.2k/4/8p4r | DISCRETE | 1 | RN13 |
RN0402_MSI | RN0402_MSI | 10k/4/8p4r | DISCRETE | 6 | RN14; RN16; RN17; RN18; RN19; RN20 |
RN0603 | RN0603 | x_8p4r-270r | DISCRETE | 4 | RN2; RN3; RN4; RN6 |
SATA_D7_16 | SATA_D7_16 | sata7pm_white-p | DISCRETE | 2 | SATA1; SATA2 |
SATA_D7_16 | SATA_D7_16 | sata7pm_black-p-rh-13 | DISCRETE | 1 | SATA3 |
SC70_6 | SC70_6 | nn-cmkt3904 | IC | 2 | Q9; Q10 |
SC70_6 | SC70_6 | nn-cmkt3904_sot363-6-rh | IC | 1 | Q11 |
SC70_6 | SC70_6 | nn-pumx1_sot363-6-rh | IC | 5 | Q76; Q77; Q85; Q99; Q100 |
SC70_6 | SC70_6 | x_nn-cmkt3904_sot363-6-rh | IC | 2 | Q79; Q80 |
SC70_6 | SC70_6 | lvc2g14idckrq1_sc70-6-rh | IC | 1 | U43 |
SINGLE_SIP2 | SINGLE_SIP2 | x_pin1*2 | IC | 2 | SIP1; SIP2 |
SIP2 | SIP2 | h1x2m_black-rh | IC | 2 | JGPIO1; JGPIO2 |
SIP3 | SIP3 | x_h1x3m_red-rh | IC | 2 | BIOS_WP; ME_DIS |
SIP3 | SIP3 | h1x3m_red-rh | IC | 1 | CLR_CMOS |
SIP4_FAN_1N | SIP4_FAN_1N | bh1x4b_brown-rh | DISCRETE | 1 | CPU_FAN |
SIP4_FAN_1N | SIP4_FAN_1N | bh1x4b_white-rh-2 | DISCRETE | 1 | SYS_FAN |
SLOT_MINIPCIEXP52_H9 | SLOT_MINIPCIEXP52_H9 | slot-minipci52p_white-rh | IC | 1 | MINI_PCIE1 |
SOIC8 | SOIC8 | np-p5003qvg_soic8-rh | IC | 1 | Q59 |
SOT23EBC_T | SOT23EBC_T | x_n-mmbt3904_nl_sot23 | DISCRETE | 1 | Q3 |
SOT23EBC_T | SOT23EBC_T | x_n-sst3904_sot23 | DISCRETE | 4 | Q21; Q75; Q107; Q113 |
SOT23EBC_T | SOT23EBC_T | n-mmbt3904_nl_sot23 | DISCRETE | 6 | Q44; Q45; Q61; Q62; Q66; Q71 |
SOT23EBC_T | SOT23EBC_T | x_npn-mmbt2222a-7-f_sot23-rh | DISCRETE | 1 | Q56 |
SOT23EBC_T | SOT23EBC_T | 2n3904 | DISCRETE | 2 | Q65; Q105 |
SOT23EBC_T | SOT23EBC_T | x_2n3904 | DISCRETE | 2 | Q86; Q108 |
SOT23EBC_T | SOT23EBC_T | n-sst3904 | DISCRETE | 1 | Q88 |
SOT23EBC_T | SOT23EBC_T | p-mmbt3906lt1g_sot23-rh | DISCRETE | 3 | Q89; Q92; Q93 |
SOT23EBC_T | SOT23EBC_T | x_p-mmbt3906lt1g_sot23-rh | DISCRETE | 2 | Q90; Q91 |
SOT23EBC_T | SOT23EBC_T | n-sst3904_sot23 | DISCRETE | 1 | Q96 |
SOT23EBC_T | SOT23EBC_T | npn-mmbt2222a-7-f_sot23-rh | DISCRETE | 1 | Q98 |
SOT23SGD_T | SOT23SGD_T | n-p8503bmg_sot23-3-rh | DISCRETE | 1 | Q8 |
SOT23SGD_T | SOT23SGD_T | n-2n7002lt1g_sot23-rh | DISCRETE | 7 | Q12; Q17; Q18; Q22; Q23; Q24; Q95 |
SOT23SGD_T | SOT23SGD_T | x_n-2n7002lt1g_sot23-rh | DISCRETE | 7 | Q39; Q50; Q53; Q57; Q81; Q94; Q97 |
SOT23SGD_T | SOT23SGD_T | n-2n7002_sot23 | DISCRETE | 11 | Q51; Q63; Q68; Q82; Q83; Q87; Q103; Q109; Q110; Q117; Q118 |
SOT23SGD_T | SOT23SGD_T | x_n-2n7002_sot23 | DISCRETE | 5 | Q69; Q78; Q102; Q111; Q112 |
SOT23SGD_T | SOT23SGD_T | x_p-pa502fmg_sot23-3-rh | DISCRETE | 1 | Q84 |
SOT23_3P_U1 | SOT23_3P_U1 | s-bat54c_sot23 | DISCRETE | 1 | D22 |
SOT23_3P_U1 | SOT23_3P_U1 | s-bat54a_sot23 | DISCRETE | 1 | D37 |
SOT23_3P_U1 | SOT23_3P_U1 | x_s-bat54a_sot23 | DISCRETE | 1 | D39 |
SOT23_3P_U1 | SOT23_3P_U1 | bav99 | DISCRETE | 2 | D41; D42 |
SOT23_3P_U1 | SOT23_3P_U1 | bat54c_sot23 | DISCRETE | 1 | D50 |
SOT23_3P_U1 | SOT23_3P_U1 | x_bat54c_sot23 | DISCRETE | 1 | D55 |
SOT23_5_NPC30X | SOT23_5_NPC30X | x_sn74ahc1g14dbv_sc70-5 | DISCRETE | 1 | U3 |
SOT23_5_NPC30X | SOT23_5_NPC30X | x_sn74lvc1g08dbvr_sot23-5-rh | DISCRETE | 1 | U9 |
SOT23_8 | SOT23_8 | up7501m8_sot23-8-rh | IC | 1 | U18 |
SOT23_8 | SOT23_8 | up7550pma8_sot23-8-hf | IC | 5 | U20; U23; U29; U47; U49 |
SOT26 | SOT26 | cm1293a-04so | IC | 6 | D10; D21; D23; D40; D51; D54 |
SOT26 | SOT26 | esd-aoz8902cil-hf | IC | 2 | U2; U7 |
SOT669_COLAY | SOT669_COLAY | x_n-pk516ba_pdfn8-hf | DISCRETE | 3 | Q4; Q6; Q46 |
SOT669_COLAY | SOT669_COLAY | n-pk510ba_pdfn8-hf | DISCRETE | 6 | Q5; Q7; Q14; Q16; Q37; Q38 |
SOT669_COLAY | SOT669_COLAY | n-pk516ba_pdfn8-hf | DISCRETE | 6 | Q13; Q15; Q43; Q48; Q52; Q54 |
SOT_363 | SOT_363 | nn-2n7002d | IC | 4 | Q2; Q19; Q20; Q116 |
SOT_363 | SOT_363 | x_nn-2n7002d | IC | 2 | Q25; Q101 |
SPIFLASH8 | SPIFLASH8 | spi flash-8p_black-rh | IC | 1 | U41 |
SSOP20 | SSOP20 | x_gd75232_ssop20 | IC | 1 | U50 |
TDFN8_TSMD59X29 | TDFN8_TSMD59X29 | isl6625acrz_dfn8-hf | IC | 3 | U5; U6; U14 |
TESTPIN25 | TESTPIN25 | x_test_point | IC | 46 | TP1; TP2; TP3; TP4; TP5; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48 |
TSOP6 | TSOP6 | esd-ip4220 | IC | 1 | D4 |
TSOP_6P_0_95MM | TSOP_6P_0_95MM | x_p-p4402fag_tsop6-rh | IC | 1 | Q104 |
TSOP_6P_0_95MM | TSOP_6P_0_95MM | apl5611ci-trg_sot23-6-hf | IC | 1 | U36 |
USB_2P | USB_2P | usbax2m_black-rh-21 | DISCRETE | 1 | USB1 |
USMD100 | USMD100 | f-microsmd110 | DISCRETE | 1 | F1 |
VGAF_1 | VGAF_1 | dsub-vgaf_blue-rh-2 | DISCRETE | 1 | VGA1 |
VQFN16_3X3X0_9 | VQFN16_3X3X0_9 | tps2546rter_qfn16-hf | IC | 1 | U38 |
ZIF_SOCK1150_T | ZIF_SOCK1150_T | cpu2_2 | IO | 1 | CPU1 |
附件:
