作品名:[AD 10][2层]漏电检测环(L75L05ABU+BL6526B+XN5106-48)原理图和PCB源文件
3 y% ^0 g) `' N! o/ k7 ]6 D
* q6 n% B9 U2 k文件描述
/ Z8 F& _8 R7 i1 i/ F0 S
2 `6 S2 I1 Y8 f; F- K2 x& D1 F1. 作品用途:漏电检测环
1 h: x4 D* V* Z# ]/ B; {
. x4 O+ @2 W7 m& I2. 软件版本:AD 10
0 s, b6 U( G* h' k$ @0 k
: I, d$ X* V: M9 { d# R3. 层数:2层板
( M! g' S2 I2 f0 Z% [4 G4 M( k. D" f6 a1 D# v# O- d4 q
4. 用到的主要芯片:L75L05ABU+BL6526B+XN5106-48
2 m6 E- h2 O$ D/ o* C
7 i2 a5 B* ?9 ]0 P4 z$ A2 O' d/ u, N5. PCB尺寸:半径:36.5mm-25mm
R. p4 j6 |- M; r1 a$ L* z, y" O5 r' |" G n
& i8 Z' r l$ ~" D! x作品截图如下:
. h8 z8 J y' t: O! }0 g. H; {! [0 `, @' e$ u3 j& H
顶层截图:
: G- ~9 ]/ Y' r1 ?
3 l$ k/ T& a) v0 U# _
5 P* m" M. Y# j6 {2 d& X$ K/ f7 W" S底层截图:& U8 n- |4 s" ^; B+ o
9 i# s& q/ w9 L) k
* C+ {& z4 X1 \/ d全层截图:+ m0 }" ], e% n& b. c( p+ k
1 Y* I3 u, \1 ]4 h/ v; C( H
% U. \% x: E( ~8 t
叠层信息截图如下:& t; H0 q, k+ N3 _
) D" h2 M2 }( ?$ w" x' c9 S- a( I8 \0 r3 W( |- Y% C
BOM:5 {1 Y2 r+ K( e8 [
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | TP | 1.8V, 3.3V, 5.0V, 12V | TESTPIONT | 4 | CON1 | +12V, 485A, 485B, GND | CON1 | 4 | 电流互感器 | A1 | MHDR1X3 | 1 | 100uF/16V | C1 | 100uF/16V | 1 | 0.1uF | C2, C3, C7, C14, C19, C20, C21, C22, C23, C24, C27, C28, C29 | C贴片-0603 | 13 | 1uF | C4, C5, C13, C16 | C贴片-0603 | 4 | 10nF | C6 | C贴片-0603 | 1 | 22uF/25V | C8 | 贴片钽电容 | 1 | 33nF | C9, C10, C11, C12, C15 | C贴片-0603 | 5 | 22pF | C17, C18, C25, C26 | C贴片-0603 | 4 | IN4007 | D1 | 二极管-IN4007 | 1 | SS210A | D2 | 贴片二极管-RM7 | 1 | TCLL4148 | D3, D4 | TCLL4148 | 2 | 22uH | L1 | 电感-CD43 | 1 | Header 2 | P1 | HDR1X2 | 1 | Header 9 | P2 | HDR1X9 | 1 | Header 4 | P3 | HDR1X4 | 1 | LMBT2222A | Q1 | SOT-23 | 1 | 5.1K/1% | R1 | R贴片-0603 | 1 | 28K/1% | R2 | R贴片-0603 | 1 | 9R | R3, R4, R5, R6, R7, R8 | R贴片-0603 | 6 | 1k | R9, R10, R11, R12 | R贴片-0603 | 4 | 10R | R13 | R贴片-0603 | 1 | 51k | R14 | R贴片-0603 | 1 | 330R | R15 | R贴片-0603 | 1 | 510R | R16 | R贴片-0603 | 1 | 5.1K | R17, R20, R21, R22 | R贴片-0603 | 4 | 10K | R18, R19, R26, R27, R40 | R贴片-0603 | 5 | 120R | R23 | R贴片-0603 | 1 | 1M | R24 | R贴片-0603 | 1 | 100R | R25 | R贴片-0603 | 1 | 2K | R28, R35, R36, R37, R38, R39 | R贴片-0603 | 6 | 200R | R29 | R贴片-0603 | 1 | 4.7K | R30, R31, R32, R33, R34 | R贴片-0603 | 5 | P6KE6.8CA | TVS1 | TVS管-SMD | 1 | L75L05ABU | U1 | L78L05ABU | 1 | BL9195-3.3 | U2 | SOT-23 | 1 | BL9195-1.8 | U3 | SOT-23 | 1 | BL9641 | U4 | SOT-23-6 | 1 | BL6526B | U5 | SO-16 | 1 | MAX13085EESA | U6 | SO-8 | 1 | XN5106-48 | U7 | XN5106C | 1 | MAX823_S | U8 | watchdog ic | 1 | 绿色 | V1, V3, V4 | 0805-led | 3 | 红色 | V2, V5 | 0805-led | 2 | 12MHz | XT1 | XTAL_SMD | 1 | 3.58MHz | Y1 | XTAL_SMD | 1 | / I Y' [$ h' v) A6 x/ H7 q9 C! e0 M
附件:
, Y9 ~: n4 _, u) G* d' ~* j% d
/ \/ i0 r1 H: t$ q. F原理图和PCB源文件如下:
5 Y; K# I N# y$ V# ~" F/ R$ e. j4 R/ X! L$ n; u
& x/ O6 }+ W9 `- B3 u0 a% A, q, ~8 s3 M8 L+ Y7 g6 J& K2 b
4 y' V: a5 e' A: B5 _ |
